[mapguide-commits] r7967 - in trunk/Tools/Maestro/Maestro.Editors: LayerDefinition MapDefinition WatermarkDefinition
svn_mapguide at osgeo.org
Tue Dec 24 02:52:59 PST 2013
Author: jng
Date: 2013-12-24 02:52:59 -0800 (Tue, 24 Dec 2013)
New Revision: 7967
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/TilePositionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditor.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditorDialog.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkSettingsCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/XYPositionEditor.cs
#2389: Watermark editor fixes:
- The X/Y position UI is not properly initialized from the underlying model
- Editing any position properties does not trigger dirty state on the resource
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -62,7 +62,7 @@
this.Controls.Remove(layerProperties);
this.Controls.Remove(layerStyles);
- var wm = new WatermarkCollectionEditorCtrl(service.ResourceService, sl2);
+ var wm = new WatermarkCollectionEditorCtrl(service, sl2);
wm.Dock = DockStyle.Top;
this.Controls.Add(wm);
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -66,7 +66,7 @@
this.Controls.Remove(mapSettingsCtrl);
this.Controls.Remove(mapLayersCtrl);
- var wm = new WatermarkCollectionEditorCtrl(service.ResourceService, mp2);
+ var wm = new WatermarkCollectionEditorCtrl(service, mp2);
wm.Dock = DockStyle.Fill;
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/TilePositionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/TilePositionEditor.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/TilePositionEditor.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -32,13 +32,15 @@
internal partial class TilePositionEditor : UserControl
private ITilePosition _pos;
+ private IEditorService _edSvc;
private bool _init = false;
- public TilePositionEditor(ITilePosition pos)
+ public TilePositionEditor(ITilePosition pos, IEditorService service)
InitializeComponent();
_pos = pos;
+ _edSvc = service;
try
@@ -72,6 +74,7 @@
return;
_pos.TileWidth = Convert.ToDouble(numTileWidth.Value);
+ _edSvc.MarkDirty();
private void numTileHeight_ValueChanged(object sender, EventArgs e)
@@ -80,6 +83,7 @@
return;
_pos.TileHeight = Convert.ToDouble(numTileHeight.Value);
private void numHorizontalOffset_ValueChanged(object sender, EventArgs e)
@@ -88,6 +92,7 @@
return;
_pos.HorizontalPosition.Offset = Convert.ToDouble(numHorizontalOffset.Value);
private void cmbHorizontalUnits_SelectedIndexChanged(object sender, EventArgs e)
@@ -96,6 +101,7 @@
return;
_pos.HorizontalPosition.Unit = (UnitType)cmbHorizontalUnits.SelectedItem;
private void cmbHorizontalAlignment_SelectedIndexChanged(object sender, EventArgs e)
@@ -104,6 +110,7 @@
return;
_pos.HorizontalPosition.Alignment = (HorizontalAlignmentType)cmbHorizontalAlignment.SelectedItem;
private void numVerticalOffset_ValueChanged(object sender, EventArgs e)
@@ -112,6 +119,7 @@
return;
_pos.VerticalPosition.Offset = Convert.ToDouble(numVerticalOffset.Value);
private void cmbVerticalUnits_SelectedIndexChanged(object sender, EventArgs e)
@@ -120,6 +128,7 @@
return;
_pos.VerticalPosition.Unit = (UnitType)cmbVerticalUnits.SelectedItem;
private void cmbVerticalAlignment_SelectedIndexChanged(object sender, EventArgs e)
@@ -128,6 +137,7 @@
return;
_pos.VerticalPosition.Alignment = (VerticalAlignmentType)cmbVerticalAlignment.SelectedItem;
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -40,14 +40,14 @@
private BindingList<IWatermark> _list;
- private IResourceService _resSvc;
- public WatermarkCollectionEditorCtrl(IResourceService resSvc, IWatermarkCollection watermarks)
+ public WatermarkCollectionEditorCtrl(IEditorService service, IWatermarkCollection watermarks)
grdWatermarks.AutoGenerateColumns = false;
_watermarks = watermarks;
- _resSvc = resSvc;
+ _edSvc = service;
_list = new BindingList<IWatermark>();
foreach (var wm in _watermarks.Watermarks)
@@ -58,15 +58,15 @@
private void btnAdd_Click(object sender, EventArgs e)
- using (var picker = new ResourcePicker(_resSvc, ResourceTypes.WatermarkDefinition, ResourcePickerMode.OpenResource))
+ using (var picker = new ResourcePicker(_edSvc.ResourceService, ResourceTypes.WatermarkDefinition, ResourcePickerMode.OpenResource))
if (picker.ShowDialog() == DialogResult.OK)
LastSelectedFolder.FolderId = picker.SelectedFolder;
- var wdf = (IWatermarkDefinition)_resSvc.GetResource(picker.ResourceID);
+ var wdf = (IWatermarkDefinition)_edSvc.ResourceService.GetResource(picker.ResourceID);
//var wm = wdf.CreateInstance();
var wm = _watermarks.AddWatermark(wdf);
- var diag = new WatermarkInstanceEditorDialog(_resSvc, wm);
+ var diag = new WatermarkInstanceEditorDialog(_edSvc, wm);
if (diag.ShowDialog() == DialogResult.OK)
_list.Add(wm);
@@ -86,7 +86,7 @@
var wm = grdWatermarks.SelectedRows[0].DataBoundItem as IWatermark;
if (wm != null)
diag.ShowDialog();
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditor.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditor.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -36,7 +36,7 @@
internal partial class WatermarkInstanceEditor : UserControl
private IWatermark _watermark;
private IWatermarkAppearance _ovAppearance;
private ITilePosition _ovTilePosition;
@@ -44,11 +44,11 @@
- public WatermarkInstanceEditor(IResourceService resSvc, IWatermark watermark)
+ public WatermarkInstanceEditor(IEditorService service, IWatermark watermark)
+ _edSvc = service;
_watermark = watermark;
- _resSvc = resSvc;
try
@@ -110,11 +110,11 @@
Control c = null;
if (rdOvPosXY.Checked)
- c = new XYPositionEditor(_ovXyPosition);
+ c = new XYPositionEditor(_ovXyPosition, _edSvc);
else if (rdOvTilePos.Checked)
- c = new TilePositionEditor(_ovTilePosition);
+ c = new TilePositionEditor(_ovTilePosition, _edSvc);
if (c != null)
@@ -126,7 +126,7 @@
private void btnBrowse_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditorDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditorDialog.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkInstanceEditorDialog.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -33,10 +33,10 @@
private WatermarkInstanceEditor _ed;
- public WatermarkInstanceEditorDialog(IResourceService resSvc, IWatermark watermark)
+ public WatermarkInstanceEditorDialog(IEditorService service, IWatermark watermark)
- _ed = new WatermarkInstanceEditor(resSvc, watermark);
+ _ed = new WatermarkInstanceEditor(service, watermark);
_ed.Dock = DockStyle.Fill;
panel1.Controls.Add(_ed);
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkSettingsCtrl.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkSettingsCtrl.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -41,10 +41,12 @@
private IWatermarkDefinition _wm;
private ITilePosition _tile;
private IXYPosition _xy;
public override void Bind(IEditorService service)
- service.RegisterCustomNotifier(this);
+ _edSvc = service;
+ _edSvc.RegisterCustomNotifier(this);
_wm = (IWatermarkDefinition)service.GetEditedResource();
NumericBinder.BindValueChanged(numRotation, _wm.Appearance, "Rotation");
@@ -72,9 +74,9 @@
grpPositionSettings.Controls.Clear();
Control c = null;
if (rdTile.Checked)
- c = new TilePositionEditor(_tile);
+ c = new TilePositionEditor(_tile, _edSvc);
else if (rdXY.Checked)
- c = new XYPositionEditor(_xy);
+ c = new XYPositionEditor(_xy, _edSvc);
if (c != null)
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/XYPositionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/XYPositionEditor.cs 2013-12-24 10:16:13 UTC (rev 7966)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/XYPositionEditor.cs 2013-12-24 10:52:59 UTC (rev 7967)
@@ -32,22 +32,24 @@
internal partial class XYPositionEditor : UserControl
private IXYPosition _pos;
- public XYPositionEditor(IXYPosition pos)
+ public XYPositionEditor(IXYPosition pos, IEditorService service)
_pos = pos;
+ _edSvc = service;
- cmbHorizontalAlignment.DataSource = Enum.GetValues(typeof(HorizontalAlignmentType));
- cmbVerticalAlignment.DataSource = Enum.GetValues(typeof(VerticalAlignmentType));
- cmbHorizontalUnits.DataSource = Enum.GetValues(typeof(UnitType));
- cmbVerticalUnits.DataSource = Enum.GetValues(typeof(UnitType));
try
_init = true;
+ cmbHorizontalAlignment.DataSource = Enum.GetValues(typeof(HorizontalAlignmentType));
+ cmbVerticalAlignment.DataSource = Enum.GetValues(typeof(VerticalAlignmentType));
+ cmbHorizontalUnits.DataSource = Enum.GetValues(typeof(UnitType));
+ cmbVerticalUnits.DataSource = Enum.GetValues(typeof(UnitType));
cmbVerticalAlignment.SelectedItem = _pos.YPosition.Alignment;
cmbVerticalUnits.SelectedItem = _pos.YPosition.Unit;
numVerticalOffset.Value = Convert.ToDecimal(_pos.YPosition.Offset);
@@ -68,6 +70,7 @@
return;
_pos.XPosition.Offset = Convert.ToDouble(numHorizontalOffset.Value);
@@ -76,6 +79,7 @@
return;
_pos.XPosition.Unit = (UnitType)cmbHorizontalUnits.SelectedItem;
@@ -84,6 +88,7 @@
return;
_pos.XPosition.Alignment = (HorizontalAlignmentType)cmbHorizontalAlignment.SelectedItem;
@@ -92,6 +97,7 @@
return;
_pos.YPosition.Offset = Convert.ToDouble(numVerticalOffset.Value);
@@ -100,6 +106,7 @@
return;
_pos.YPosition.Unit = (UnitType)cmbVerticalUnits.SelectedItem;
@@ -108,6 +115,7 @@
return;
_pos.YPosition.Alignment = (VerticalAlignmentType)cmbVerticalAlignment.SelectedItem;
More information about the mapguide-commits
