[mapguide-commits] r7306 - in trunk/MgDev/Desktop/MgDesktop/Services: . Feature
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jan 12 10:51:12 PST 2013
Author: jng
Date: 2013-01-12 10:51:11 -0800 (Sat, 12 Jan 2013)
New Revision: 7306
   trunk/MgDev/Desktop/MgDesktop/Services/DataReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/DataReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.cpp
   trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.h
   trunk/MgDev/Desktop/MgDesktop/Services/TileService.cpp
Fix mg-desktop build post-RFC130
Modified: trunk/MgDev/Desktop/MgDesktop/Services/DataReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/DataReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/DataReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -671,6 +671,22 @@
 //INTERNAL_API:
+string MgdDataReader::GetResponseElementName() { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+string MgdDataReader::GetBodyElementName() { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+void MgdDataReader::ResponseStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+void MgdDataReader::ResponseEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+void MgdDataReader::BodyStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+void MgdDataReader::BodyEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::GetResponseElementName"); }
+void MgdDataReader::CurrentToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::CurrentToStringUtf8"); }
+void MgdDataReader::HeaderToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdDataReader::HeaderToStringUtf8"); }
 const wchar_t* MgdDataReader::GetString(CREFSTRING propertyName, INT32& length)
     FdoString* retVal;
Modified: trunk/MgDev/Desktop/MgDesktop/Services/DataReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/DataReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/DataReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -95,6 +95,86 @@
 INTERNAL_API:
+    /// \brief
+    /// Returns the starting element name as a UTF-8 string. The mime
+    /// type must be a text type, for example text/xml.
+    /// \param str
+    /// Destination string.
+    virtual string GetResponseElementName();
+    /// \brief
+    /// Returns the body starting element name as a UTF-8 string. The mime
+    /// \param str
+    virtual string GetBodyElementName();
+    /// \brief
+    /// Returns the start of the response as a UTF-8 string. The mime
+    /// \param str
+    virtual void ResponseStartUtf8(string& str);
+    /// \brief
+    /// Returns the end of the response as a UTF-8 string. The mime
+    /// \param str
+    virtual void ResponseEndUtf8(string& str);
+    /// \brief
+    /// Returns the start of the response body as a UTF-8 string. The mime
+    /// \param str
+    virtual void BodyStartUtf8(string& str);
+    /// \brief
+    /// Returns the end of the response body as a UTF-8 string. The mime
+    /// \param str
+    virtual void BodyEndUtf8(string& str);
+    /// \brief
+    /// Returns the contents of the header in this reader as a UTF-8 string.  The mime
+    /// \param str
+    virtual void HeaderToStringUtf8(string& str);
+    /// \brief
+    /// Returns the contents of the current record/feature in the reader as a UTF-8 string.  The mime
+    /// \param str
+    virtual void CurrentToStringUtf8(string& str);
     virtual const wchar_t* GetString(CREFSTRING propertyName, INT32& length);
     virtual void Serialize(MgStream* stream);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -729,24 +729,79 @@
         // TODO: define a schema for this XML
         // TODO: rename FeatureSet element to avoid conflict with FeatureSet-1.0.0.xsd?
-        str += "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
-        str += "<FeatureSet>";
-        classDef->ToXml(str);
-        str += "<Features>";
+        ResponseStartUtf8(str);
+        HeaderToStringUtf8(str);
+        BodyStartUtf8(str);
         while ( this->ReadNext() )
-            Ptr<MgPropertyCollection> propCol = m_set->GetFeatureAt(m_currRecord-1);
-            INT32 cnt = propCol->GetCount();
-            if (propCol != NULL && cnt > 0)
-                propCol->ToFeature(str);
+            CurrentToStringUtf8(str);
-        str += "</Features>";
-        str += "</FeatureSet>";
+        BodyEndUtf8(str);
+        ResponseEndUtf8(str);
+string MgdFeatureSetReader::GetResponseElementName()
+    return "FeatureSet";
+string MgdFeatureSetReader::GetBodyElementName()
+    return "Features";
+void MgdFeatureSetReader::ResponseStartUtf8(string& str)
+    str += "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
+    str += "<";
+    str += GetResponseElementName();
+    str += ">";
+void MgdFeatureSetReader::ResponseEndUtf8(string& str)
+    str += "</";
+    str += ">";
+void MgdFeatureSetReader::BodyStartUtf8(string& str)
+    str += "<";
+    str += GetBodyElementName();
+    str += ">";
+void MgdFeatureSetReader::BodyEndUtf8(string& str)
+    str += "</";
+    str += ">";
+void MgdFeatureSetReader::HeaderToStringUtf8(string& str)
+    Ptr<MgClassDefinition> classDef = this->GetClassDefinition();
+    if (classDef != NULL)
+        classDef->ToXml(str);
+void MgdFeatureSetReader::CurrentToStringUtf8(string& str)
+    if (NULL != (MgFeatureSet*)m_set)
+        Ptr<MgPropertyCollection> propCol = m_set->GetFeatureAt(m_currRecord-1);
+        INT32 cnt = propCol->GetCount();
+        if (propCol != NULL && cnt > 0)
+            propCol->ToFeature(str);
 /// <summary>
 /// Releases all the resources of feature reader.
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/FeatureSetReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -81,6 +81,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
     virtual const wchar_t* GetString(INT32 index, INT32& length);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -1262,7 +1262,22 @@
         __LINE__, __WFILE__, NULL, L"", NULL);
+string MgdGwsFeatureReader::GetResponseElementName() { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+string MgdGwsFeatureReader::GetBodyElementName() { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+void MgdGwsFeatureReader::ResponseStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+void MgdGwsFeatureReader::ResponseEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+void MgdGwsFeatureReader::BodyStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+void MgdGwsFeatureReader::BodyEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::GetResponseElementName"); }
+void MgdGwsFeatureReader::CurrentToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::CurrentToStringUtf8"); }
+void MgdGwsFeatureReader::HeaderToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdGwsFeatureReader::HeaderToStringUtf8"); }
 /// <summary>
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/GwsFeatureReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -410,6 +410,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
     /// <summary>
     /// Gets the definition of the object currently being read. If the user
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -331,6 +331,22 @@
 //INTERNAL_API:
+string MgdProjectedFeatureReader::GetResponseElementName() { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+string MgdProjectedFeatureReader::GetBodyElementName() { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+void MgdProjectedFeatureReader::ResponseStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+void MgdProjectedFeatureReader::ResponseEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+void MgdProjectedFeatureReader::BodyStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+void MgdProjectedFeatureReader::BodyEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::GetResponseElementName"); }
+void MgdProjectedFeatureReader::CurrentToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::CurrentToStringUtf8"); }
+void MgdProjectedFeatureReader::HeaderToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdProjectedFeatureReader::HeaderToStringUtf8"); }
 const wchar_t* MgdProjectedFeatureReader::GetString(CREFSTRING propertyName, INT32& length)
 	return m_reader->GetString(propertyName, length);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProjectedFeatureReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -79,6 +79,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -701,6 +701,68 @@
     str += "</PropertySet>";
+string MgdProxyDataReader::GetResponseElementName()
+    return "PropertySet";
+string MgdProxyDataReader::GetBodyElementName()
+    return "Properties";
+void MgdProxyDataReader::ResponseStartUtf8(string& str)
+    str += "<";
+    str += ">";
+void MgdProxyDataReader::ResponseEndUtf8(string& str)
+    str += "</";
+    str += ">";
+void MgdProxyDataReader::BodyStartUtf8(string& str)
+    str += "<";
+    str += ">";
+void MgdProxyDataReader::BodyEndUtf8(string& str)
+    str += "</";
+    str += ">";
+void MgdProxyDataReader::HeaderToStringUtf8(string& str)
+    if (NULL != (MgPropertyDefinitionCollection*)m_propDefCol)
+        m_propDefCol->ToXml(str);
+void MgdProxyDataReader::CurrentToStringUtf8(string& str)
+    if (NULL != (MgBatchPropertyCollection*)m_set)
+        Ptr<MgPropertyCollection> propCol = m_set->GetItem(m_currRecord-1);
+            str += "<PropertyCollection>";
+            propCol->ToXml(str, false);
+            str += "</PropertyCollection>";
 void MgdProxyDataReader::SetService(MgFeatureService* service)
     CHECKNULL(service, L"MgdProxyDataReader.SetService");
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/ProxyDataReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -516,6 +516,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
     /// \brief
     /// Gets the string value of the specified property. No conversion is
Modified: trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -647,6 +647,22 @@
 //INTERNAL_API:
+string MgdFeatureReader::GetResponseElementName() { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+string MgdFeatureReader::GetBodyElementName() { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::ResponseStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::ResponseEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::BodyStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::BodyEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::HeaderToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
+void MgdFeatureReader::CurrentToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdFeatureReader::GetResponseElementName"); }
 const wchar_t* MgdFeatureReader::GetString(CREFSTRING propertyName, INT32& length)
 	CHECKNULL(m_reader, L"MgdFeatureReader::GetString");
Modified: trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/FeatureReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -88,6 +88,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
Modified: trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -558,6 +558,22 @@
 //INTERNAL_API:
+string MgdSqlDataReader::GetResponseElementName() { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+string MgdSqlDataReader::GetBodyElementName() { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+void MgdSqlDataReader::ResponseStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+void MgdSqlDataReader::ResponseEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+void MgdSqlDataReader::BodyStartUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+void MgdSqlDataReader::BodyEndUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::GetResponseElementName"); }
+void MgdSqlDataReader::CurrentToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::CurrentToStringUtf8"); }
+void MgdSqlDataReader::HeaderToStringUtf8(string& str) { NOT_IMPLEMENTED(L"MgdSqlDataReader::HeaderToStringUtf8"); }
 MgByteReader* MgdSqlDataReader::GetLOB(CREFSTRING propertyName)
     Ptr<MgByteReader> byteReader;
Modified: trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.h
--- trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.h	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/SqlReader.h	2013-01-12 18:51:11 UTC (rev 7306)
@@ -94,6 +94,86 @@
 INTERNAL_API:
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
+    /// \brief
+    /// \param str
     MgByteReader* GetLOB(CREFSTRING propertyName);
Modified: trunk/MgDev/Desktop/MgDesktop/Services/TileService.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/TileService.cpp	2013-01-12 17:28:02 UTC (rev 7305)
+++ trunk/MgDev/Desktop/MgDesktop/Services/TileService.cpp	2013-01-12 18:51:11 UTC (rev 7306)
@@ -75,7 +75,7 @@
 bool MgdTileService::DetectTileLockFile(CREFSTRING lockPathname)
     bool found = false;
-    struct _stat lockFileInfo;
+    struct _stat64 lockFileInfo;
     // Check the lock file to see if another thread/process is writing the tile file.
     while (MgFileUtil::GetFileStatus(lockPathname, lockFileInfo))
More information about the mapguide-commits mailing list
