[mapguide-commits] r7311 - in branches/2.5/MgDev/nuget: . MapGuideNuget MapGuideNuget/.nuget MapGuideNuget/CoordSysEnumTest MapGuideNuget/CoordSysEnumTest64 MapGuideNuget/CoordSysEnumTest64/Properties MapGuideNuget/DesktopConsoleTest64 MapGuideNuget/DesktopConsoleTest64/Properties MapGuideNuget/DesktopViewerTest64 MapGuideNuget/DesktopViewerTest64/Properties MapGuideNuget/MapGuideNuget64 MapGuideNuget/MapGuideNuget64/Properties
svn_mapguide at osgeo.org
Sun Jan 13 05:01:56 PST 2013
Author: jng
Date: 2013-01-13 05:01:56 -0800 (Sun, 13 Jan 2013)
New Revision: 7311
Added:
branches/2.5/MgDev/nuget/MapGuideNuget/
branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/
branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config
branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Properties/
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings
branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings
branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini
branches/2.5/MgDev/nuget/MapGuideNuget/Web.sln
branches/2.5/MgDev/nuget/MapGuideNuget/Web64.sln
Removed:
Add a set of test applications (VS2012, .net 4.0) for testing our nuget packages
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget
___________________________________________________________________
Added: bugtraq:number
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config
--- trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,6 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<configuration>
- <solution>
- <add key="disableSourceControlIntegration" value="true" />
- </solution>
-</configuration>
\ No newline at end of file
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.Config (rev 0)
@@ -0,0 +1,6 @@
+<?xml version="1.0" encoding="utf-8"?>
+<configuration>
+ <solution>
+ <add key="disableSourceControlIntegration" value="true" />
+ </solution>
+</configuration>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe
(Binary files differ)
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.exe)
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets
--- trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,150 +0,0 @@
-<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <PropertyGroup>
- <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">$(MSBuildProjectDirectory)\..\</SolutionDir>
- <!-- Enable the restore command to run before builds -->
- <RestorePackages Condition=" '$(RestorePackages)' == '' ">false</RestorePackages>
- <!-- Property that enables building a package from a project -->
- <BuildPackage Condition=" '$(BuildPackage)' == '' ">false</BuildPackage>
- <!-- Determines if package restore consent is required to restore packages -->
- <RequireRestoreConsent Condition=" '$(RequireRestoreConsent)' != 'false' ">true</RequireRestoreConsent>
- <!-- Download NuGet.exe if it does not already exist -->
- <DownloadNuGetExe Condition=" '$(DownloadNuGetExe)' == '' ">false</DownloadNuGetExe>
- </PropertyGroup>
- <ItemGroup Condition=" '$(PackageSources)' == '' ">
- <!-- Package sources used to restore packages. By default will used the registered sources under %APPDATA%\NuGet\NuGet.Config -->
- <PackageSource Include="https://nuget.org/api/v2/" />
- <PackageSource Include="https://my-nuget-source/nuget/" />
- </ItemGroup>
- <PropertyGroup Condition=" '$(OS)' == 'Windows_NT'">
- <!-- Windows specific commands -->
- <NuGetToolsPath>$([System.IO.Path]::Combine($(SolutionDir), ".nuget"))</NuGetToolsPath>
- <PackagesConfig>$([System.IO.Path]::Combine($(ProjectDir), "packages.config"))</PackagesConfig>
- </PropertyGroup>
- <PropertyGroup Condition=" '$(OS)' != 'Windows_NT'">
- <!-- We need to launch nuget.exe with the mono command if we're not on windows -->
- <NuGetToolsPath>$(SolutionDir).nuget</NuGetToolsPath>
- <PackagesConfig>packages.config</PackagesConfig>
- </PropertyGroup>
- <PropertyGroup>
- <!-- NuGet command -->
- <NuGetExePath Condition=" '$(NuGetExePath)' == '' ">$(NuGetToolsPath)\nuget.exe</NuGetExePath>
- <PackageSources Condition=" $(PackageSources) == '' ">@(PackageSource)</PackageSources>
- <NuGetCommand Condition=" '$(OS)' == 'Windows_NT'">"$(NuGetExePath)"</NuGetCommand>
- <NuGetCommand Condition=" '$(OS)' != 'Windows_NT' ">mono --runtime=v4.0.30319 $(NuGetExePath)</NuGetCommand>
- <PackageOutputDir Condition="$(PackageOutputDir) == ''">$(TargetDir.Trim('\\'))</PackageOutputDir>
- <RequireConsentSwitch Condition=" $(RequireRestoreConsent) == 'true' ">-RequireConsent</RequireConsentSwitch>
- <!-- Commands -->
- <RestoreCommand>$(NuGetCommand) install "$(PackagesConfig)" -source "$(PackageSources)" $(RequireConsentSwitch) -solutionDir "$(SolutionDir) "</RestoreCommand>
- <BuildCommand>$(NuGetCommand) pack "$(ProjectPath)" -p Configuration=$(Configuration) -o "$(PackageOutputDir)" -symbols</BuildCommand>
- <!-- We need to ensure packages are restored prior to assembly resolve -->
- <ResolveReferencesDependsOn Condition="$(RestorePackages) == 'true'">
- RestorePackages;
- $(ResolveReferencesDependsOn);
- </ResolveReferencesDependsOn>
- <!-- Make the build depend on restore packages -->
- <BuildDependsOn Condition="$(BuildPackage) == 'true'">
- $(BuildDependsOn);
- BuildPackage;
- </BuildDependsOn>
- </PropertyGroup>
- <Target Name="CheckPrerequisites">
- <!-- Raise an error if we're unable to locate nuget.exe -->
- <Error Condition="'$(DownloadNuGetExe)' != 'true' AND !Exists('$(NuGetExePath)')" Text="Unable to locate '$(NuGetExePath)'" />
- <SetEnvironmentVariable EnvKey="VisualStudioVersion" EnvValue="$(VisualStudioVersion)" Condition=" '$(VisualStudioVersion)' != '' AND '$(OS)' == 'Windows_NT' " />
- Take advantage of MsBuild's build dependency tracking to make sure that we only ever download nuget.exe once.
- This effectively acts as a lock that makes sure that the download operation will only happen once and all
- parallel builds will have to wait for it to complete.
- <MsBuild Targets="_DownloadNuGet" Projects="$(MSBuildThisFileFullPath)" Properties="Configuration=NOT_IMPORTANT" />
- </Target>
- <Target Name="_DownloadNuGet">
- <DownloadNuGet OutputFilename="$(NuGetExePath)" Condition=" '$(DownloadNuGetExe)' == 'true' AND !Exists('$(NuGetExePath)')" />
- </Target>
- <Target Name="RestorePackages" DependsOnTargets="CheckPrerequisites">
- <Exec Command="$(RestoreCommand)"
- Condition="'$(OS)' != 'Windows_NT' And Exists('$(PackagesConfig)')" />
- LogStandardErrorAsError="true"
- Condition="'$(OS)' == 'Windows_NT' And Exists('$(PackagesConfig)')" />
- </Target>
- <Target Name="BuildPackage" DependsOnTargets="CheckPrerequisites">
- <Exec Command="$(BuildCommand)"
- Condition=" '$(OS)' != 'Windows_NT' " />
- Condition=" '$(OS)' == 'Windows_NT' " />
- </Target>
- <UsingTask TaskName="DownloadNuGet" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
- <ParameterGroup>
- <OutputFilename ParameterType="System.String" Required="true" />
- </ParameterGroup>
- <Task>
- <Reference Include="System.Core" />
- <Using Namespace="System" />
- <Using Namespace="System.IO" />
- <Using Namespace="System.Net" />
- <Using Namespace="Microsoft.Build.Framework" />
- <Using Namespace="Microsoft.Build.Utilities" />
- <Code Type="Fragment" Language="cs">
- <![CDATA[
- try {
- OutputFilename = Path.GetFullPath(OutputFilename);
- Log.LogMessage("Downloading latest version of NuGet.exe...");
- WebClient webClient = new WebClient();
- webClient.DownloadFile("https://nuget.org/nuget.exe", OutputFilename);
- return true;
- catch (Exception ex) {
- Log.LogErrorFromException(ex);
- return false;
- </Code>
- </Task>
- </UsingTask>
- <UsingTask TaskName="SetEnvironmentVariable" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
- <ParameterGroup>
- <EnvKey ParameterType="System.String" Required="true" />
- <EnvValue ParameterType="System.String" Required="true" />
- </ParameterGroup>
- <Task>
- <![CDATA[
- try {
- Environment.SetEnvironmentVariable(EnvKey, EnvValue, System.EnvironmentVariableTarget.Process);
- catch {
- </Code>
- </Task>
- </UsingTask>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets)
--- branches/2.5/MgDev/nuget/MapGuideNuget/.nuget/NuGet.targets (rev 0)
@@ -0,0 +1,150 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">$(MSBuildProjectDirectory)\..\</SolutionDir>
+ <!-- Enable the restore command to run before builds -->
+ <RestorePackages Condition=" '$(RestorePackages)' == '' ">false</RestorePackages>
+ <!-- Property that enables building a package from a project -->
+ <BuildPackage Condition=" '$(BuildPackage)' == '' ">false</BuildPackage>
+ <!-- Determines if package restore consent is required to restore packages -->
+ <RequireRestoreConsent Condition=" '$(RequireRestoreConsent)' != 'false' ">true</RequireRestoreConsent>
+ <!-- Download NuGet.exe if it does not already exist -->
+ <DownloadNuGetExe Condition=" '$(DownloadNuGetExe)' == '' ">false</DownloadNuGetExe>
+ </PropertyGroup>
+ <ItemGroup Condition=" '$(PackageSources)' == '' ">
+ <!-- Package sources used to restore packages. By default will used the registered sources under %APPDATA%\NuGet\NuGet.Config -->
+ <PackageSource Include="https://nuget.org/api/v2/" />
+ <PackageSource Include="https://my-nuget-source/nuget/" />
+ </ItemGroup>
+ <PropertyGroup Condition=" '$(OS)' == 'Windows_NT'">
+ <!-- Windows specific commands -->
+ <NuGetToolsPath>$([System.IO.Path]::Combine($(SolutionDir), ".nuget"))</NuGetToolsPath>
+ <PackagesConfig>$([System.IO.Path]::Combine($(ProjectDir), "packages.config"))</PackagesConfig>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(OS)' != 'Windows_NT'">
+ <!-- We need to launch nuget.exe with the mono command if we're not on windows -->
+ <NuGetToolsPath>$(SolutionDir).nuget</NuGetToolsPath>
+ <PackagesConfig>packages.config</PackagesConfig>
+ </PropertyGroup>
+ <PropertyGroup>
+ <!-- NuGet command -->
+ <NuGetExePath Condition=" '$(NuGetExePath)' == '' ">$(NuGetToolsPath)\nuget.exe</NuGetExePath>
+ <PackageSources Condition=" $(PackageSources) == '' ">@(PackageSource)</PackageSources>
+ <NuGetCommand Condition=" '$(OS)' == 'Windows_NT'">"$(NuGetExePath)"</NuGetCommand>
+ <NuGetCommand Condition=" '$(OS)' != 'Windows_NT' ">mono --runtime=v4.0.30319 $(NuGetExePath)</NuGetCommand>
+ <PackageOutputDir Condition="$(PackageOutputDir) == ''">$(TargetDir.Trim('\\'))</PackageOutputDir>
+ <RequireConsentSwitch Condition=" $(RequireRestoreConsent) == 'true' ">-RequireConsent</RequireConsentSwitch>
+ <!-- Commands -->
+ <RestoreCommand>$(NuGetCommand) install "$(PackagesConfig)" -source "$(PackageSources)" $(RequireConsentSwitch) -solutionDir "$(SolutionDir) "</RestoreCommand>
+ <BuildCommand>$(NuGetCommand) pack "$(ProjectPath)" -p Configuration=$(Configuration) -o "$(PackageOutputDir)" -symbols</BuildCommand>
+ <!-- We need to ensure packages are restored prior to assembly resolve -->
+ <ResolveReferencesDependsOn Condition="$(RestorePackages) == 'true'">
+ RestorePackages;
+ $(ResolveReferencesDependsOn);
+ </ResolveReferencesDependsOn>
+ <!-- Make the build depend on restore packages -->
+ <BuildDependsOn Condition="$(BuildPackage) == 'true'">
+ $(BuildDependsOn);
+ BuildPackage;
+ </BuildDependsOn>
+ </PropertyGroup>
+ <Target Name="CheckPrerequisites">
+ <!-- Raise an error if we're unable to locate nuget.exe -->
+ <Error Condition="'$(DownloadNuGetExe)' != 'true' AND !Exists('$(NuGetExePath)')" Text="Unable to locate '$(NuGetExePath)'" />
+ <SetEnvironmentVariable EnvKey="VisualStudioVersion" EnvValue="$(VisualStudioVersion)" Condition=" '$(VisualStudioVersion)' != '' AND '$(OS)' == 'Windows_NT' " />
+ Take advantage of MsBuild's build dependency tracking to make sure that we only ever download nuget.exe once.
+ This effectively acts as a lock that makes sure that the download operation will only happen once and all
+ parallel builds will have to wait for it to complete.
+ <MsBuild Targets="_DownloadNuGet" Projects="$(MSBuildThisFileFullPath)" Properties="Configuration=NOT_IMPORTANT" />
+ </Target>
+ <Target Name="_DownloadNuGet">
+ <DownloadNuGet OutputFilename="$(NuGetExePath)" Condition=" '$(DownloadNuGetExe)' == 'true' AND !Exists('$(NuGetExePath)')" />
+ </Target>
+ <Target Name="RestorePackages" DependsOnTargets="CheckPrerequisites">
+ <Exec Command="$(RestoreCommand)"
+ Condition="'$(OS)' != 'Windows_NT' And Exists('$(PackagesConfig)')" />
+ LogStandardErrorAsError="true"
+ Condition="'$(OS)' == 'Windows_NT' And Exists('$(PackagesConfig)')" />
+ </Target>
+ <Target Name="BuildPackage" DependsOnTargets="CheckPrerequisites">
+ <Exec Command="$(BuildCommand)"
+ Condition=" '$(OS)' != 'Windows_NT' " />
+ Condition=" '$(OS)' == 'Windows_NT' " />
+ </Target>
+ <UsingTask TaskName="DownloadNuGet" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
+ <ParameterGroup>
+ <OutputFilename ParameterType="System.String" Required="true" />
+ </ParameterGroup>
+ <Task>
+ <Reference Include="System.Core" />
+ <Using Namespace="System" />
+ <Using Namespace="System.IO" />
+ <Using Namespace="System.Net" />
+ <Using Namespace="Microsoft.Build.Framework" />
+ <Using Namespace="Microsoft.Build.Utilities" />
+ <Code Type="Fragment" Language="cs">
+ <![CDATA[
+ try {
+ OutputFilename = Path.GetFullPath(OutputFilename);
+ Log.LogMessage("Downloading latest version of NuGet.exe...");
+ WebClient webClient = new WebClient();
+ webClient.DownloadFile("https://nuget.org/nuget.exe", OutputFilename);
+ return true;
+ catch (Exception ex) {
+ Log.LogErrorFromException(ex);
+ return false;
+ </Code>
+ </Task>
+ </UsingTask>
+ <UsingTask TaskName="SetEnvironmentVariable" TaskFactory="CodeTaskFactory" AssemblyFile="$(MSBuildToolsPath)\Microsoft.Build.Tasks.v4.0.dll">
+ <ParameterGroup>
+ <EnvKey ParameterType="System.String" Required="true" />
+ <EnvValue ParameterType="System.String" Required="true" />
+ </ParameterGroup>
+ <Task>
+ <![CDATA[
+ try {
+ Environment.SetEnvironmentVariable(EnvKey, EnvValue, System.EnvironmentVariableTarget.Process);
+ catch {
+ </Code>
+ </Task>
+ </UsingTask>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,104 +0,0 @@
-<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <PropertyGroup>
- <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
- <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
- <ProductVersion>8.0.30703</ProductVersion>
- <SchemaVersion>2.0</SchemaVersion>
- <ProjectGuid>{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}</ProjectGuid>
- <OutputType>WinExe</OutputType>
- <AppDesignerFolder>Properties</AppDesignerFolder>
- <RootNamespace>CoordSysEnumTest</RootNamespace>
- <AssemblyName>CoordSysEnumTest</AssemblyName>
- <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
- <TargetFrameworkProfile>Client</TargetFrameworkProfile>
- <FileAlignment>512</FileAlignment>
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
- <PlatformTarget>x86</PlatformTarget>
- <DebugSymbols>true</DebugSymbols>
- <DebugType>full</DebugType>
- <Optimize>false</Optimize>
- <OutputPath>bin\Debug\</OutputPath>
- <DefineConstants>DEBUG;TRACE</DefineConstants>
- <ErrorReport>prompt</ErrorReport>
- <WarningLevel>4</WarningLevel>
- <UseVSHostingProcess>false</UseVSHostingProcess>
- </PropertyGroup>
- <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
- <DebugType>pdbonly</DebugType>
- <Optimize>true</Optimize>
- <OutputPath>bin\Release\</OutputPath>
- <DefineConstants>TRACE</DefineConstants>
- </PropertyGroup>
- <ItemGroup>
- <Reference Include="OSGeo.MapGuide.Foundation">
- <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.Geometry">
- <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.PlatformBase">
- <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
- </Reference>
- <Reference Include="System" />
- <Reference Include="System.Xml.Linq" />
- <Reference Include="System.Data.DataSetExtensions" />
- <Reference Include="Microsoft.CSharp" />
- <Reference Include="System.Data" />
- <Reference Include="System.Deployment" />
- <Reference Include="System.Drawing" />
- <Reference Include="System.Windows.Forms" />
- <Reference Include="System.Xml" />
- </ItemGroup>
- <ItemGroup>
- <Compile Include="MainForm.cs">
- <SubType>Form</SubType>
- </Compile>
- <Compile Include="MainForm.Designer.cs">
- <DependentUpon>MainForm.cs</DependentUpon>
- </Compile>
- <Compile Include="Program.cs" />
- <Compile Include="Properties\AssemblyInfo.cs" />
- <EmbeddedResource Include="MainForm.resx">
- </EmbeddedResource>
- <EmbeddedResource Include="Properties\Resources.resx">
- <Generator>ResXFileCodeGenerator</Generator>
- <LastGenOutput>Resources.Designer.cs</LastGenOutput>
- <SubType>Designer</SubType>
- <Compile Include="Properties\Resources.Designer.cs">
- <AutoGen>True</AutoGen>
- <DependentUpon>Resources.resx</DependentUpon>
- </Compile>
- <None Include="packages.config" />
- <None Include="Properties\Settings.settings">
- <Generator>SettingsSingleFileGenerator</Generator>
- <LastGenOutput>Settings.Designer.cs</LastGenOutput>
- </None>
- <Compile Include="Properties\Settings.Designer.cs">
- <DependentUpon>Settings.settings</DependentUpon>
- <DesignTimeSharedInput>True</DesignTimeSharedInput>
- </Compile>
- </ItemGroup>
- <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
- <PropertyGroup>
- <PostBuildEvent>
-if not exist "$(TargetDir)Dictionaries" md "$(TargetDir)Dictionaries"
-xcopy /s /y "$(SolutionDir)packages\cs-map-dictionaries.2.4.0.7093\dictionaries\*.*" "$(TargetDir)Dictionaries"
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x86.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
- </PropertyGroup>
- <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
- Other similar extension points exist, see Microsoft.Common.targets.
- <Target Name="BeforeBuild">
- </Target>
- <Target Name="AfterBuild">
- </Target>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/CoordSysEnumTest.csproj (rev 0)
@@ -0,0 +1,104 @@
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">x86</Platform>
+ <ProductVersion>8.0.30703</ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}</ProjectGuid>
+ <OutputType>WinExe</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>CoordSysEnumTest</RootNamespace>
+ <AssemblyName>CoordSysEnumTest</AssemblyName>
+ <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+ <TargetFrameworkProfile>Client</TargetFrameworkProfile>
+ <FileAlignment>512</FileAlignment>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
+ <PlatformTarget>x86</PlatformTarget>
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>bin\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ <UseVSHostingProcess>false</UseVSHostingProcess>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>bin\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="OSGeo.MapGuide.Foundation">
+ <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Geometry">
+ <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.PlatformBase">
+ <HintPath>..\packages\mapguide-api-base-x86.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+ </Reference>
+ <Reference Include="System" />
+ <Reference Include="System.Xml.Linq" />
+ <Reference Include="System.Data.DataSetExtensions" />
+ <Reference Include="Microsoft.CSharp" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Deployment" />
+ <Reference Include="System.Drawing" />
+ <Reference Include="System.Windows.Forms" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="MainForm.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MainForm.Designer.cs">
+ <DependentUpon>MainForm.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Program.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <EmbeddedResource Include="MainForm.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ <SubType>Designer</SubType>
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DependentUpon>Resources.resx</DependentUpon>
+ </Compile>
+ <None Include="packages.config" />
+ <None Include="Properties\Settings.settings">
+ <Generator>SettingsSingleFileGenerator</Generator>
+ <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+ </None>
+ <Compile Include="Properties\Settings.Designer.cs">
+ <DependentUpon>Settings.settings</DependentUpon>
+ <DesignTimeSharedInput>True</DesignTimeSharedInput>
+ </Compile>
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <PropertyGroup>
+ <PostBuildEvent>
+if not exist "$(TargetDir)Dictionaries" md "$(TargetDir)Dictionaries"
+xcopy /s /y "$(SolutionDir)packages\cs-map-dictionaries.2.4.0.7093\dictionaries\*.*" "$(TargetDir)Dictionaries"
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x86.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,73 +0,0 @@
-namespace CoordSysEnumTest
- partial class MainForm
- /// <summary>
- /// Required designer variable.
- /// </summary>
- private System.ComponentModel.IContainer components = null;
- /// <summary>
- /// Clean up any resources being used.
- /// </summary>
- /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
- protected override void Dispose(bool disposing)
- if (disposing && (components != null))
- components.Dispose();
- base.Dispose(disposing);
- #region Windows Form Designer generated code
- /// <summary>
- /// Required method for Designer support - do not modify
- /// the contents of this method with the code editor.
- /// </summary>
- private void InitializeComponent()
- this.label1 = new System.Windows.Forms.Label();
- this.lstCoordSysCategories = new System.Windows.Forms.ListBox();
- this.SuspendLayout();
- // label1
- this.label1.AutoSize = true;
- this.label1.Location = new System.Drawing.Point(13, 13);
- this.label1.Name = "label1";
- this.label1.Size = new System.Drawing.Size(400, 13);
- this.label1.TabIndex = 0;
- this.label1.Text = "If you see these coordinate system categories, the MapGuide API base is working :" +
- // lstCoordSysCategories
- this.lstCoordSysCategories.FormattingEnabled = true;
- this.lstCoordSysCategories.Location = new System.Drawing.Point(16, 47);
- this.lstCoordSysCategories.Name = "lstCoordSysCategories";
- this.lstCoordSysCategories.Size = new System.Drawing.Size(406, 186);
- this.lstCoordSysCategories.TabIndex = 1;
- // MainForm
- this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
- this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
- this.ClientSize = new System.Drawing.Size(434, 257);
- this.Controls.Add(this.lstCoordSysCategories);
- this.Controls.Add(this.label1);
- this.Name = "MainForm";
- this.Text = "Form1";
- this.ResumeLayout(false);
- this.PerformLayout();
- #endregion
- private System.Windows.Forms.Label label1;
- private System.Windows.Forms.ListBox lstCoordSysCategories;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.Designer.cs (rev 0)
@@ -0,0 +1,73 @@
+namespace CoordSysEnumTest
+ partial class MainForm
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.label1 = new System.Windows.Forms.Label();
+ this.lstCoordSysCategories = new System.Windows.Forms.ListBox();
+ this.SuspendLayout();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(13, 13);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(400, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "If you see these coordinate system categories, the MapGuide API base is working :" +
+ // lstCoordSysCategories
+ this.lstCoordSysCategories.FormattingEnabled = true;
+ this.lstCoordSysCategories.Location = new System.Drawing.Point(16, 47);
+ this.lstCoordSysCategories.Name = "lstCoordSysCategories";
+ this.lstCoordSysCategories.Size = new System.Drawing.Size(406, 186);
+ this.lstCoordSysCategories.TabIndex = 1;
+ // MainForm
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(434, 257);
+ this.Controls.Add(this.lstCoordSysCategories);
+ this.Controls.Add(this.label1);
+ this.Name = "MainForm";
+ this.Text = "Form1";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.ListBox lstCoordSysCategories;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,38 +0,0 @@
-using System;
-using System.Collections.Generic;
-using System.ComponentModel;
-using System.Data;
-using System.Drawing;
-using System.Linq;
-using System.Text;
-using System.Windows.Forms;
-using OSGeo.MapGuide;
- public partial class MainForm : Form
- private MainForm()
- InitializeComponent();
- private MgCoordinateSystemFactory _fact;
- public MainForm(MgCoordinateSystemFactory fact) : this()
- _fact = fact;
- protected override void OnLoad(EventArgs e)
- base.OnLoad(e);
- MgStringCollection categories = _fact.EnumerateCategories();
- var items = new List<string>();
- for (int i = 0; i < categories.GetCount(); i++)
- items.Add(categories.GetItem(i));
- lstCoordSysCategories.DataSource = items;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.cs (rev 0)
@@ -0,0 +1,38 @@
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide;
+ public partial class MainForm : Form
+ private MainForm()
+ InitializeComponent();
+ private MgCoordinateSystemFactory _fact;
+ public MainForm(MgCoordinateSystemFactory fact) : this()
+ _fact = fact;
+ protected override void OnLoad(EventArgs e)
+ base.OnLoad(e);
+ MgStringCollection categories = _fact.EnumerateCategories();
+ var items = new List<string>();
+ for (int i = 0; i < categories.GetCount(); i++)
+ items.Add(categories.GetItem(i));
+ lstCoordSysCategories.DataSource = items;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,120 +0,0 @@
-<root>
- Microsoft ResX Schema
- Version 2.0
- The primary goals of this format is to allow a simple XML format
- that is mostly human readable. The generation and parsing of the
- various data types are done through the TypeConverter classes
- associated with the data types.
- Example:
- ... ado.net/XML headers & schema ...
- <resheader name="resmimetype">text/microsoft-resx</resheader>
- <resheader name="version">2.0</resheader>
- <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
- <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
- <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
- <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
- <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>[base64 mime encoded serialized .NET Framework object]</value>
- </data>
- <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
- <comment>This is a comment</comment>
- </data>
- There are any number of "resheader" rows that contain simple
- name/value pairs.
- Each data row contains a name, and value. The row also contains a
- type or mimetype. Type corresponds to a .NET class that support
- text/value conversion through the TypeConverter architecture.
- Classes that don't support this are serialized and stored with the
- mimetype set.
- The mimetype is used for serialized objects, and tells the
- ResXResourceReader how to depersist the object. This is currently not
- extensible. For a given mimetype the value must be set accordingly:
- Note - application/x-microsoft.net.object.binary.base64 is the format
- that the ResXResourceWriter will generate, however the reader can
- read any of the formats listed below.
- mimetype: application/x-microsoft.net.object.binary.base64
- value : The object must be serialized with
- : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
- : and then encoded with base64 encoding.
- mimetype: application/x-microsoft.net.object.soap.base64
- : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
- mimetype: application/x-microsoft.net.object.bytearray.base64
- value : The object must be serialized into a byte array
- : using a System.ComponentModel.TypeConverter
- <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
- <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
- <xsd:element name="root" msdata:IsDataSet="true">
- <xsd:complexType>
- <xsd:choice maxOccurs="unbounded">
- <xsd:element name="metadata">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" />
- </xsd:sequence>
- <xsd:attribute name="name" use="required" type="xsd:string" />
- <xsd:attribute name="type" type="xsd:string" />
- <xsd:attribute name="mimetype" type="xsd:string" />
- <xsd:attribute ref="xml:space" />
- </xsd:complexType>
- </xsd:element>
- <xsd:element name="assembly">
- <xsd:complexType>
- <xsd:attribute name="alias" type="xsd:string" />
- <xsd:attribute name="name" type="xsd:string" />
- </xsd:element>
- <xsd:element name="data">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
- <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
- <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
- <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
- </xsd:element>
- <xsd:element name="resheader">
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" />
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- <value>text/microsoft-resx</value>
- </resheader>
- <value>2.0</value>
- </resheader>
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
-</root>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/MainForm.resx (rev 0)
@@ -0,0 +1,120 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,28 +0,0 @@
-using System;
-using System.Linq;
-using System.IO;
- static class Program
- /// <summary>
- /// The main entry point for the application.
- /// </summary>
- [STAThread]
- static void Main()
- Application.EnableVisualStyles();
- Application.SetCompatibleTextRenderingDefault(false);
- MgCoordinateSystemFactory fact = new MgCoordinateSystemFactory();
- MgCoordinateSystemCatalog cat = fact.GetCatalog();
- cat.SetDictionaryDir(Path.Combine(Application.StartupPath, "Dictionaries"));
- Application.Run(new MainForm(fact));
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/Program.cs (rev 0)
@@ -0,0 +1,28 @@
+using System;
+using System.Linq;
+using System.IO;
+ static class Program
+ /// <summary>
+ /// The main entry point for the application.
+ /// </summary>
+ [STAThread]
+ static void Main()
+ Application.EnableVisualStyles();
+ Application.SetCompatibleTextRenderingDefault(false);
+ MgCoordinateSystemFactory fact = new MgCoordinateSystemFactory();
+ MgCoordinateSystemCatalog cat = fact.GetCatalog();
+ cat.SetDictionaryDir(Path.Combine(Application.StartupPath, "Dictionaries"));
+ Application.Run(new MainForm(fact));
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,5 +0,0 @@
-<packages>
- <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
- <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/packages.config (rev 0)
@@ -0,0 +1,5 @@
+<packages>
+ <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
+ <package id="mapguide-api-base-x86" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,106 +0,0 @@
- <PropertyGroup>
- <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
- <RestorePackages>true</RestorePackages>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
- <OutputPath>bin\x64\Debug\</OutputPath>
- <PlatformTarget>x64</PlatformTarget>
- <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
- <OutputPath>bin\x64\Release\</OutputPath>
- </PropertyGroup>
- <ItemGroup>
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
- </Reference>
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
- </Reference>
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
- </Reference>
- </ItemGroup>
- <ItemGroup>
- </Compile>
- </Compile>
- </Compile>
- </None>
- </Compile>
- </ItemGroup>
- <PropertyGroup>
- <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
- </PropertyGroup>
- <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
- </Target>
- </Target>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/CoordSysEnumTest.csproj (rev 0)
@@ -0,0 +1,106 @@
+ <PropertyGroup>
+ <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
+ <RestorePackages>true</RestorePackages>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
+ <OutputPath>bin\x64\Debug\</OutputPath>
+ <PlatformTarget>x64</PlatformTarget>
+ <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
+ <OutputPath>bin\x64\Release\</OutputPath>
+ </PropertyGroup>
+ <ItemGroup>
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+ </Reference>
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+ </Reference>
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+ </Reference>
+ </ItemGroup>
+ <ItemGroup>
+ </Compile>
+ </Compile>
+ </Compile>
+ </None>
+ </Compile>
+ </ItemGroup>
+ <PropertyGroup>
+ <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+ <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
+ </Target>
+ </Target>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,73 +0,0 @@
- /// <summary>
- /// </summary>
- /// <summary>
- /// </summary>
- /// <summary>
- /// </summary>
- // label1
- // MainForm
- #endregion
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.Designer.cs (rev 0)
@@ -0,0 +1,73 @@
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ // label1
+ // MainForm
+ #endregion
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,38 +0,0 @@
-using System;
-using System.Data;
-using System.Linq;
-using System.Text;
- _fact = fact;
- base.OnLoad(e);
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.cs (rev 0)
@@ -0,0 +1,38 @@
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ _fact = fact;
+ base.OnLoad(e);
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,120 +0,0 @@
-<root>
- Version 2.0
- Example:
- </data>
- </data>
- name/value pairs.
- mimetype set.
- <xsd:complexType>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- </xsd:element>
- <xsd:complexType>
- </xsd:element>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- </xsd:element>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- </resheader>
- </resheader>
- </resheader>
- </resheader>
-</root>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/MainForm.resx (rev 0)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,28 +0,0 @@
-using System;
-using System.Linq;
-using System.IO;
- /// <summary>
- /// </summary>
- [STAThread]
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Program.cs (rev 0)
@@ -0,0 +1,28 @@
+using System;
+using System.Linq;
+using System.IO;
+ /// <summary>
+ /// </summary>
+ [STAThread]
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,36 +0,0 @@
-using System.Reflection;
-using System.Runtime.CompilerServices;
-using System.Runtime.InteropServices;
-// General Information about an assembly is controlled through the following
-// set of attributes. Change these attribute values to modify the information
-// associated with an assembly.
-[assembly: AssemblyTitle("CoordSysEnumTest")]
-[assembly: AssemblyDescription("")]
-[assembly: AssemblyConfiguration("")]
-[assembly: AssemblyCompany("")]
-[assembly: AssemblyProduct("CoordSysEnumTest")]
-[assembly: AssemblyCopyright("Copyright © 2012")]
-[assembly: AssemblyTrademark("")]
-[assembly: AssemblyCulture("")]
-// Setting ComVisible to false makes the types in this assembly not visible
-// to COM components. If you need to access a type in this assembly from
-// COM, set the ComVisible attribute to true on that type.
-[assembly: ComVisible(false)]
-// The following GUID is for the ID of the typelib if this project is exposed to COM
-[assembly: Guid("c7322422-5546-4cd1-a5c8-67b65c671874")]
-// Version information for an assembly consists of the following four values:
-// Major Version
-// Minor Version
-// Build Number
-// Revision
-// You can specify all the values or you can default the Build and Revision Numbers
-// by using the '*' as shown below:
-// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("1.0.0.0")]
-[assembly: AssemblyFileVersion("1.0.0.0")]
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/AssemblyInfo.cs (rev 0)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("CoordSysEnumTest")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("CoordSysEnumTest")]
+[assembly: AssemblyCopyright("Copyright © 2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("c7322422-5546-4cd1-a5c8-67b65c671874")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,71 +0,0 @@
-// <auto-generated>
-// This code was generated by a tool.
-// Runtime Version:4.0.30319.269
-// Changes to this file may cause incorrect behavior and will be lost if
-// the code is regenerated.
-// </auto-generated>
-namespace CoordSysEnumTest.Properties
- /// <summary>
- /// A strongly-typed resource class, for looking up localized strings, etc.
- /// </summary>
- // This class was auto-generated by the StronglyTypedResourceBuilder
- // class via a tool like ResGen or Visual Studio.
- // To add or remove a member, edit your .ResX file then rerun ResGen
- // with the /str option, or rebuild your VS project.
- [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
- [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
- [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
- internal class Resources
- private static global::System.Resources.ResourceManager resourceMan;
- private static global::System.Globalization.CultureInfo resourceCulture;
- [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
- internal Resources()
- /// <summary>
- /// Returns the cached ResourceManager instance used by this class.
- /// </summary>
- [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
- internal static global::System.Resources.ResourceManager ResourceManager
- get
- if ((resourceMan == null))
- global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("CoordSysEnumTest.Properties.Resources", typeof(Resources).Assembly);
- resourceMan = temp;
- return resourceMan;
- /// <summary>
- /// Overrides the current thread's CurrentUICulture property for all
- /// resource lookups using this strongly typed resource class.
- /// </summary>
- internal static global::System.Globalization.CultureInfo Culture
- get
- return resourceCulture;
- set
- resourceCulture = value;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.Designer.cs (rev 0)
@@ -0,0 +1,71 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:4.0.30319.269
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace CoordSysEnumTest.Properties
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources()
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager
+ get
+ if ((resourceMan == null))
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("CoordSysEnumTest.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture
+ get
+ return resourceCulture;
+ set
+ resourceCulture = value;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,117 +0,0 @@
-<root>
- Version 2.0
- Example:
- </data>
- </data>
- name/value pairs.
- mimetype set.
- : System.Serialization.Formatters.Binary.BinaryFormatter
- <xsd:complexType>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- </xsd:element>
- <xsd:complexType>
- </xsd:element>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
- </xsd:element>
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- </resheader>
- </resheader>
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
-</root>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Resources.resx (rev 0)
@@ -0,0 +1,117 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ : System.Serialization.Formatters.Binary.BinaryFormatter
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,30 +0,0 @@
- [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")]
- internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
- private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
- public static Settings Default
- get
- return defaultInstance;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.Designer.cs (rev 0)
@@ -0,0 +1,30 @@
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")]
+ internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+ private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+ public static Settings Default
+ get
+ return defaultInstance;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,7 +0,0 @@
-<?xml version='1.0' encoding='utf-8'?>
-<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
- <Profiles>
- <Profile Name="(Default)" />
- </Profiles>
- <Settings />
-</SettingsFile>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/Properties/Settings.settings (rev 0)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+ <Profiles>
+ <Profile Name="(Default)" />
+ </Profiles>
+ <Settings />
+</SettingsFile>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,5 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<packages>
- <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
\ No newline at end of file
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/CoordSysEnumTest64/packages.config (rev 0)
@@ -0,0 +1,5 @@
+<?xml version="1.0" encoding="utf-8"?>
+<packages>
+ <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64
___________________________________________________________________
Added: bugtraq:number
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,83 +0,0 @@
- <PropertyGroup>
- <ProjectGuid>{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}</ProjectGuid>
- <OutputType>Exe</OutputType>
- <RootNamespace>DesktopConsoleTest</RootNamespace>
- <AssemblyName>DesktopConsoleTest</AssemblyName>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- <ItemGroup>
- <Reference Include="OSGeo.MapGuide.Desktop">
- <HintPath>..\packages\mg-desktop-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
- </Reference>
- </Reference>
- </Reference>
- </Reference>
- </ItemGroup>
- <ItemGroup>
- </ItemGroup>
- <ItemGroup>
- </ItemGroup>
- <PropertyGroup>
- <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x64.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
- </PropertyGroup>
- </Target>
- </Target>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/DesktopConsoleTest.csproj (rev 0)
@@ -0,0 +1,83 @@
+ <PropertyGroup>
+ <ProjectGuid>{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}</ProjectGuid>
+ <OutputType>Exe</OutputType>
+ <RootNamespace>DesktopConsoleTest</RootNamespace>
+ <AssemblyName>DesktopConsoleTest</AssemblyName>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="OSGeo.MapGuide.Desktop">
+ <HintPath>..\packages\mg-desktop-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Desktop.dll</HintPath>
+ </Reference>
+ </Reference>
+ </Reference>
+ </Reference>
+ </ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
+ <PropertyGroup>
+ <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mg-desktop-net40-x64.2.4.0.7093\mg-desktop\*.*" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+ </Target>
+ </Target>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,42 +0,0 @@
-using System;
-using System.Linq;
-using System.Text;
-using System.IO;
-namespace DesktopConsoleTest
- class Program
- static void Main(string[] args)
- MgdPlatform.Initialize("Platform.ini");
- string currentDir = Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location);
- //Test mapguide-api-base
- MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
- Console.WriteLine("Testing coordinate system categories");
- MgStringCollection csCategories = csFact.EnumerateCategories();
- for (int i = 0; i < csCategories.GetCount(); i++)
- Console.WriteLine(csCategories.GetItem(i));
- //Test mg-desktop
- MgdServiceFactory serviceFact = new MgdServiceFactory();
- Console.Write("Can we create a MgdFeatureService? ");
- MgdFeatureService featSvc = (MgdFeatureService)serviceFact.CreateService(MgServiceType.FeatureService);
- Console.WriteLine("yes");
- Console.Write("Can we create a MgdResourceService? ");
- MgdResourceService resSvc = (MgdResourceService)serviceFact.CreateService(MgServiceType.ResourceService);
- MgdPlatform.Terminate();
- Console.WriteLine("Things look all good :) Press any key to continue");
- Console.Read();
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Program.cs (rev 0)
@@ -0,0 +1,42 @@
+using System;
+using System.Linq;
+using System.Text;
+using System.IO;
+namespace DesktopConsoleTest
+ class Program
+ static void Main(string[] args)
+ MgdPlatform.Initialize("Platform.ini");
+ string currentDir = Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location);
+ //Test mapguide-api-base
+ MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
+ Console.WriteLine("Testing coordinate system categories");
+ MgStringCollection csCategories = csFact.EnumerateCategories();
+ for (int i = 0; i < csCategories.GetCount(); i++)
+ Console.WriteLine(csCategories.GetItem(i));
+ //Test mg-desktop
+ MgdServiceFactory serviceFact = new MgdServiceFactory();
+ Console.Write("Can we create a MgdFeatureService? ");
+ MgdFeatureService featSvc = (MgdFeatureService)serviceFact.CreateService(MgServiceType.FeatureService);
+ Console.WriteLine("yes");
+ Console.Write("Can we create a MgdResourceService? ");
+ MgdResourceService resSvc = (MgdResourceService)serviceFact.CreateService(MgServiceType.ResourceService);
+ MgdPlatform.Terminate();
+ Console.WriteLine("Things look all good :) Press any key to continue");
+ Console.Read();
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,36 +0,0 @@
-[assembly: AssemblyTitle("DesktopConsoleTest")]
-[assembly: AssemblyProduct("DesktopConsoleTest")]
-[assembly: Guid("cafc7a89-4da9-48b9-87e3-f564367718bd")]
-// Major Version
-// Minor Version
-// Build Number
-// Revision
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/Properties/AssemblyInfo.cs (rev 0)
@@ -0,0 +1,36 @@
+[assembly: AssemblyTitle("DesktopConsoleTest")]
+[assembly: AssemblyProduct("DesktopConsoleTest")]
+[assembly: Guid("cafc7a89-4da9-48b9-87e3-f564367718bd")]
+// Major Version
+// Minor Version
+// Build Number
+// Revision
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,6 +0,0 @@
-<packages>
- <package id="mg-desktop-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopConsoleTest64/packages.config (rev 0)
@@ -0,0 +1,6 @@
+<packages>
+ <package id="mg-desktop-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,112 +0,0 @@
- <PropertyGroup>
- <ProjectGuid>{A0DCC768-B341-426B-889A-0701A2399CE8}</ProjectGuid>
- <RootNamespace>DesktopViewerTest</RootNamespace>
- <AssemblyName>DesktopViewerTest</AssemblyName>
- </PropertyGroup>
- </PropertyGroup>
- </PropertyGroup>
- <ItemGroup>
- </Reference>
- </Reference>
- </Reference>
- </Reference>
- <Reference Include="OSGeo.MapGuide.Viewer">
- <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.Viewer.Desktop">
- <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
- </Reference>
- <Reference Include="System.Core" />
- </ItemGroup>
- <ItemGroup>
- </Compile>
- </Compile>
- </Compile>
- </None>
- </Compile>
- </ItemGroup>
- <PropertyGroup>
- <PostBuildEvent>
- </PropertyGroup>
- </Target>
- </Target>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/DesktopViewerTest.csproj (rev 0)
@@ -0,0 +1,112 @@
+ <PropertyGroup>
+ <ProjectGuid>{A0DCC768-B341-426B-889A-0701A2399CE8}</ProjectGuid>
+ <RootNamespace>DesktopViewerTest</RootNamespace>
+ <AssemblyName>DesktopViewerTest</AssemblyName>
+ </PropertyGroup>
+ </PropertyGroup>
+ </PropertyGroup>
+ <ItemGroup>
+ </Reference>
+ </Reference>
+ </Reference>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Viewer">
+ <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Viewer.Desktop">
+ <HintPath>..\packages\mg-desktop-viewer-net40-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
+ </Reference>
+ <Reference Include="System.Core" />
+ </ItemGroup>
+ <ItemGroup>
+ </Compile>
+ </Compile>
+ </Compile>
+ </None>
+ </Compile>
+ </ItemGroup>
+ <PropertyGroup>
+ <PostBuildEvent>
+ </PropertyGroup>
+ </Target>
+ </Target>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,208 +0,0 @@
-namespace DesktopViewerTest
- /// <summary>
- /// </summary>
- /// <summary>
- /// </summary>
- /// <summary>
- /// </summary>
- this.mgDefaultToolbar1 = new OSGeo.MapGuide.Viewer.MgDefaultToolbar();
- this.statusStrip1 = new System.Windows.Forms.StatusStrip();
- this.lblCoords = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
- this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
- this.splitContainer1 = new System.Windows.Forms.SplitContainer();
- this.splitContainer2 = new System.Windows.Forms.SplitContainer();
- this.mgLegend1 = new OSGeo.MapGuide.Viewer.MgLegend();
- this.mgPropertyPane1 = new OSGeo.MapGuide.Viewer.MgPropertyPane();
- this.mgMapViewer1 = new OSGeo.MapGuide.Viewer.MgMapViewer();
- this.statusStrip1.SuspendLayout();
- this.splitContainer1.Panel1.SuspendLayout();
- this.splitContainer1.Panel2.SuspendLayout();
- this.splitContainer1.SuspendLayout();
- this.splitContainer2.Panel1.SuspendLayout();
- this.splitContainer2.Panel2.SuspendLayout();
- this.splitContainer2.SuspendLayout();
- // mgDefaultToolbar1
- this.mgDefaultToolbar1.Location = new System.Drawing.Point(0, 0);
- this.mgDefaultToolbar1.Name = "mgDefaultToolbar1";
- this.mgDefaultToolbar1.Size = new System.Drawing.Size(613, 25);
- this.mgDefaultToolbar1.TabIndex = 0;
- this.mgDefaultToolbar1.Text = "mgDefaultToolbar1";
- this.mgDefaultToolbar1.Viewer = null;
- // statusStrip1
- this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.lblCoords,
- this.lblSelected,
- this.lblScale,
- this.lblSize});
- this.statusStrip1.Location = new System.Drawing.Point(0, 484);
- this.statusStrip1.Name = "statusStrip1";
- this.statusStrip1.Size = new System.Drawing.Size(613, 22);
- this.statusStrip1.TabIndex = 1;
- this.statusStrip1.Text = "statusStrip1";
- // lblCoords
- this.lblCoords.Name = "lblCoords";
- this.lblCoords.Size = new System.Drawing.Size(0, 17);
- // lblSelected
- this.lblSelected.Name = "lblSelected";
- this.lblSelected.Size = new System.Drawing.Size(598, 17);
- this.lblSelected.Spring = true;
- this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
- // lblScale
- this.lblScale.Name = "lblScale";
- this.lblScale.Size = new System.Drawing.Size(0, 17);
- this.lblScale.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
- // lblSize
- this.lblSize.Name = "lblSize";
- this.lblSize.Size = new System.Drawing.Size(0, 17);
- // splitContainer1
- this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
- this.splitContainer1.Location = new System.Drawing.Point(0, 25);
- this.splitContainer1.Name = "splitContainer1";
- // splitContainer1.Panel1
- this.splitContainer1.Panel1.Controls.Add(this.splitContainer2);
- // splitContainer1.Panel2
- this.splitContainer1.Panel2.Controls.Add(this.mgMapViewer1);
- this.splitContainer1.Size = new System.Drawing.Size(613, 459);
- this.splitContainer1.SplitterDistance = 204;
- this.splitContainer1.TabIndex = 2;
- // splitContainer2
- this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
- this.splitContainer2.Location = new System.Drawing.Point(0, 0);
- this.splitContainer2.Name = "splitContainer2";
- this.splitContainer2.Orientation = System.Windows.Forms.Orientation.Horizontal;
- // splitContainer2.Panel1
- this.splitContainer2.Panel1.Controls.Add(this.mgLegend1);
- // splitContainer2.Panel2
- this.splitContainer2.Panel2.Controls.Add(this.mgPropertyPane1);
- this.splitContainer2.Size = new System.Drawing.Size(204, 459);
- this.splitContainer2.SplitterDistance = 219;
- this.splitContainer2.TabIndex = 0;
- // mgLegend1
- this.mgLegend1.Dock = System.Windows.Forms.DockStyle.Fill;
- this.mgLegend1.GroupContextMenu = null;
- this.mgLegend1.LayerContextMenu = null;
- this.mgLegend1.Location = new System.Drawing.Point(0, 0);
- this.mgLegend1.Name = "mgLegend1";
- this.mgLegend1.ShowTooltips = true;
- this.mgLegend1.Size = new System.Drawing.Size(204, 219);
- this.mgLegend1.TabIndex = 0;
- this.mgLegend1.ThemeCompressionLimit = 0;
- // mgPropertyPane1
- this.mgPropertyPane1.Dock = System.Windows.Forms.DockStyle.Fill;
- this.mgPropertyPane1.Location = new System.Drawing.Point(0, 0);
- this.mgPropertyPane1.Name = "mgPropertyPane1";
- this.mgPropertyPane1.Size = new System.Drawing.Size(204, 236);
- this.mgPropertyPane1.TabIndex = 0;
- // mgMapViewer1
- this.mgMapViewer1.Cursor = System.Windows.Forms.Cursors.Default;
- this.mgMapViewer1.Dock = System.Windows.Forms.DockStyle.Fill;
- this.mgMapViewer1.Location = new System.Drawing.Point(0, 0);
- this.mgMapViewer1.MaxScale = 1000000000;
- this.mgMapViewer1.MinScale = 10;
- this.mgMapViewer1.MouseWheelDelayRenderInterval = 800;
- this.mgMapViewer1.Name = "mgMapViewer1";
- this.mgMapViewer1.PointPixelBuffer = 2;
- this.mgMapViewer1.SelectionColor = System.Drawing.Color.Blue;
- this.mgMapViewer1.Size = new System.Drawing.Size(405, 459);
- this.mgMapViewer1.TabIndex = 0;
- this.mgMapViewer1.Text = "mgMapViewer1";
- this.mgMapViewer1.TooltipDelayInterval = 1000;
- this.mgMapViewer1.ZoomInFactor = 0.5;
- this.mgMapViewer1.ZoomOutFactor = 2;
- this.mgMapViewer1.SelectionChanged += new System.EventHandler(this.mgMapViewer1_SelectionChanged);
- // MainForm
- this.ClientSize = new System.Drawing.Size(613, 506);
- this.Controls.Add(this.splitContainer1);
- this.Controls.Add(this.statusStrip1);
- this.Controls.Add(this.mgDefaultToolbar1);
- this.Text = "mg-desktop Sample";
- this.statusStrip1.ResumeLayout(false);
- this.statusStrip1.PerformLayout();
- this.splitContainer1.Panel1.ResumeLayout(false);
- this.splitContainer1.Panel2.ResumeLayout(false);
- this.splitContainer1.ResumeLayout(false);
- this.splitContainer2.Panel1.ResumeLayout(false);
- this.splitContainer2.Panel2.ResumeLayout(false);
- this.splitContainer2.ResumeLayout(false);
- #endregion
- private OSGeo.MapGuide.Viewer.MgDefaultToolbar mgDefaultToolbar1;
- private System.Windows.Forms.StatusStrip statusStrip1;
- private System.Windows.Forms.ToolStripStatusLabel lblCoords;
- private System.Windows.Forms.ToolStripStatusLabel lblSelected;
- private System.Windows.Forms.ToolStripStatusLabel lblScale;
- private System.Windows.Forms.ToolStripStatusLabel lblSize;
- private System.Windows.Forms.SplitContainer splitContainer1;
- private OSGeo.MapGuide.Viewer.MgMapViewer mgMapViewer1;
- private System.Windows.Forms.SplitContainer splitContainer2;
- private OSGeo.MapGuide.Viewer.MgLegend mgLegend1;
- private OSGeo.MapGuide.Viewer.MgPropertyPane mgPropertyPane1;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.Designer.cs (rev 0)
@@ -0,0 +1,208 @@
+namespace DesktopViewerTest
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.mgDefaultToolbar1 = new OSGeo.MapGuide.Viewer.MgDefaultToolbar();
+ this.statusStrip1 = new System.Windows.Forms.StatusStrip();
+ this.lblCoords = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
+ this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+ this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+ this.mgLegend1 = new OSGeo.MapGuide.Viewer.MgLegend();
+ this.mgPropertyPane1 = new OSGeo.MapGuide.Viewer.MgPropertyPane();
+ this.mgMapViewer1 = new OSGeo.MapGuide.Viewer.MgMapViewer();
+ this.statusStrip1.SuspendLayout();
+ this.splitContainer1.Panel1.SuspendLayout();
+ this.splitContainer1.Panel2.SuspendLayout();
+ this.splitContainer1.SuspendLayout();
+ this.splitContainer2.Panel1.SuspendLayout();
+ this.splitContainer2.Panel2.SuspendLayout();
+ this.splitContainer2.SuspendLayout();
+ // mgDefaultToolbar1
+ this.mgDefaultToolbar1.Location = new System.Drawing.Point(0, 0);
+ this.mgDefaultToolbar1.Name = "mgDefaultToolbar1";
+ this.mgDefaultToolbar1.Size = new System.Drawing.Size(613, 25);
+ this.mgDefaultToolbar1.TabIndex = 0;
+ this.mgDefaultToolbar1.Text = "mgDefaultToolbar1";
+ this.mgDefaultToolbar1.Viewer = null;
+ // statusStrip1
+ this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.lblCoords,
+ this.lblSelected,
+ this.lblScale,
+ this.lblSize});
+ this.statusStrip1.Location = new System.Drawing.Point(0, 484);
+ this.statusStrip1.Name = "statusStrip1";
+ this.statusStrip1.Size = new System.Drawing.Size(613, 22);
+ this.statusStrip1.TabIndex = 1;
+ this.statusStrip1.Text = "statusStrip1";
+ // lblCoords
+ this.lblCoords.Name = "lblCoords";
+ this.lblCoords.Size = new System.Drawing.Size(0, 17);
+ // lblSelected
+ this.lblSelected.Name = "lblSelected";
+ this.lblSelected.Size = new System.Drawing.Size(598, 17);
+ this.lblSelected.Spring = true;
+ this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblScale
+ this.lblScale.Name = "lblScale";
+ this.lblScale.Size = new System.Drawing.Size(0, 17);
+ this.lblScale.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblSize
+ this.lblSize.Name = "lblSize";
+ this.lblSize.Size = new System.Drawing.Size(0, 17);
+ // splitContainer1
+ this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer1.Location = new System.Drawing.Point(0, 25);
+ this.splitContainer1.Name = "splitContainer1";
+ // splitContainer1.Panel1
+ this.splitContainer1.Panel1.Controls.Add(this.splitContainer2);
+ // splitContainer1.Panel2
+ this.splitContainer1.Panel2.Controls.Add(this.mgMapViewer1);
+ this.splitContainer1.Size = new System.Drawing.Size(613, 459);
+ this.splitContainer1.SplitterDistance = 204;
+ this.splitContainer1.TabIndex = 2;
+ // splitContainer2
+ this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer2.Location = new System.Drawing.Point(0, 0);
+ this.splitContainer2.Name = "splitContainer2";
+ this.splitContainer2.Orientation = System.Windows.Forms.Orientation.Horizontal;
+ // splitContainer2.Panel1
+ this.splitContainer2.Panel1.Controls.Add(this.mgLegend1);
+ // splitContainer2.Panel2
+ this.splitContainer2.Panel2.Controls.Add(this.mgPropertyPane1);
+ this.splitContainer2.Size = new System.Drawing.Size(204, 459);
+ this.splitContainer2.SplitterDistance = 219;
+ this.splitContainer2.TabIndex = 0;
+ // mgLegend1
+ this.mgLegend1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgLegend1.GroupContextMenu = null;
+ this.mgLegend1.LayerContextMenu = null;
+ this.mgLegend1.Location = new System.Drawing.Point(0, 0);
+ this.mgLegend1.Name = "mgLegend1";
+ this.mgLegend1.ShowTooltips = true;
+ this.mgLegend1.Size = new System.Drawing.Size(204, 219);
+ this.mgLegend1.TabIndex = 0;
+ this.mgLegend1.ThemeCompressionLimit = 0;
+ // mgPropertyPane1
+ this.mgPropertyPane1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgPropertyPane1.Location = new System.Drawing.Point(0, 0);
+ this.mgPropertyPane1.Name = "mgPropertyPane1";
+ this.mgPropertyPane1.Size = new System.Drawing.Size(204, 236);
+ this.mgPropertyPane1.TabIndex = 0;
+ // mgMapViewer1
+ this.mgMapViewer1.Cursor = System.Windows.Forms.Cursors.Default;
+ this.mgMapViewer1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgMapViewer1.Location = new System.Drawing.Point(0, 0);
+ this.mgMapViewer1.MaxScale = 1000000000;
+ this.mgMapViewer1.MinScale = 10;
+ this.mgMapViewer1.MouseWheelDelayRenderInterval = 800;
+ this.mgMapViewer1.Name = "mgMapViewer1";
+ this.mgMapViewer1.PointPixelBuffer = 2;
+ this.mgMapViewer1.SelectionColor = System.Drawing.Color.Blue;
+ this.mgMapViewer1.Size = new System.Drawing.Size(405, 459);
+ this.mgMapViewer1.TabIndex = 0;
+ this.mgMapViewer1.Text = "mgMapViewer1";
+ this.mgMapViewer1.TooltipDelayInterval = 1000;
+ this.mgMapViewer1.ZoomInFactor = 0.5;
+ this.mgMapViewer1.ZoomOutFactor = 2;
+ this.mgMapViewer1.SelectionChanged += new System.EventHandler(this.mgMapViewer1_SelectionChanged);
+ // MainForm
+ this.ClientSize = new System.Drawing.Size(613, 506);
+ this.Controls.Add(this.splitContainer1);
+ this.Controls.Add(this.statusStrip1);
+ this.Controls.Add(this.mgDefaultToolbar1);
+ this.Text = "mg-desktop Sample";
+ this.statusStrip1.ResumeLayout(false);
+ this.statusStrip1.PerformLayout();
+ this.splitContainer1.Panel1.ResumeLayout(false);
+ this.splitContainer1.Panel2.ResumeLayout(false);
+ this.splitContainer1.ResumeLayout(false);
+ this.splitContainer2.Panel1.ResumeLayout(false);
+ this.splitContainer2.Panel2.ResumeLayout(false);
+ this.splitContainer2.ResumeLayout(false);
+ #endregion
+ private OSGeo.MapGuide.Viewer.MgDefaultToolbar mgDefaultToolbar1;
+ private System.Windows.Forms.StatusStrip statusStrip1;
+ private System.Windows.Forms.ToolStripStatusLabel lblCoords;
+ private System.Windows.Forms.ToolStripStatusLabel lblSelected;
+ private System.Windows.Forms.ToolStripStatusLabel lblScale;
+ private System.Windows.Forms.ToolStripStatusLabel lblSize;
+ private System.Windows.Forms.SplitContainer splitContainer1;
+ private OSGeo.MapGuide.Viewer.MgMapViewer mgMapViewer1;
+ private System.Windows.Forms.SplitContainer splitContainer2;
+ private OSGeo.MapGuide.Viewer.MgLegend mgLegend1;
+ private OSGeo.MapGuide.Viewer.MgPropertyPane mgPropertyPane1;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,125 +0,0 @@
-using System;
-using System.Data;
-using System.Linq;
-using System.Text;
-using OSGeo.MapGuide.Viewer;
-using OSGeo.MapGuide.Viewer.Desktop;
- public partial class MainForm : Form, IMapStatusBar
- public MainForm()
- new MapViewerController(mgMapViewer1, //The MgMapViewer
- mgLegend1, //The MgLegend
- this, //The IMapStatusBar
- mgPropertyPane1, //The MgPropertyPane
- mgDefaultToolbar1); //The MgDefaultToolbar
- MgdServiceFactory factory = new MgdServiceFactory();
- MgdResourceService resSvc = (MgdResourceService)factory.CreateService(MgServiceType.ResourceService);
- MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
- //If this map definition doesn't exist, we ask the user to
- //load the Sheboygan package
- if (!resSvc.ResourceExists(mapDefId))
- using (OpenFileDialog diag = new OpenFileDialog())
- diag.Filter = "MapGuide Packages (*.mgp)|*.mgp";
- if (diag.ShowDialog() == DialogResult.OK)
- MgByteSource source = new MgByteSource(diag.FileName);
- MgByteReader reader = source.GetReader();
- resSvc.ApplyResourcePackage(reader);
- else
- //No map, nothing to do here
- Application.Exit();
- //Create our runtime map
- MgdMap map = new MgdMap(mapDefId);
- //Create our viewer provider
- MgMapViewerProvider provider = new MgDesktopMapViewerProvider(map);
- //Initialize our viewer with this provider
- mgMapViewer1.Init(provider);
- public void SetCursorPositionMessage(string message)
- lblCoords.Text = message;
- public void SetFeatureSelectedMessage(string message)
- lblSelected.Text = message;
- public void SetMapScaleMessage(string message)
- lblScale.Text = message;
- public void SetMapSizeMessage(string message)
- lblSize.Text = message;
- private void mgMapViewer1_SelectionChanged(object sender, EventArgs e)
- MgSelectionBase selection = mgMapViewer1.GetSelection();
- MgReadOnlyLayerCollection layers = selection.GetLayers();
- if (layers != null)
- for (int i = 0; i < layers.GetCount(); i++)
- MgLayerBase layer = layers.GetItem(i);
- if (layer.Name == "Parcels") //The selected layer is parcels
- //Check that we only have one selected object
- int count = selection.GetSelectedFeaturesCount(layer, layer.FeatureClassName);
- if (count == 1)
- MgFeatureReader reader = null;
- try
- reader = selection.GetSelectedFeatures(layer, layer.FeatureClassName, false);
- if (reader.ReadNext())
- //Address is in the RPROPAD property
- if (reader.IsNull("RPROPAD"))
- MessageBox.Show("Selected parcel has no address");
- else
- MessageBox.Show("Address: " + reader.GetString("RPROPAD"));
- finally //Must close all readers, otherwise connections will leak
- reader.Close();
- else
- MessageBox.Show("Please select only one parcel");
- break;
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/MainForm.cs (rev 0)
@@ -0,0 +1,125 @@
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.Viewer;
+using OSGeo.MapGuide;
+using OSGeo.MapGuide.Viewer.Desktop;
+ public partial class MainForm : Form, IMapStatusBar
+ public MainForm()
+ InitializeComponent();
+ protected override void OnLoad(EventArgs e)
+ new MapViewerController(mgMapViewer1, //The MgMapViewer
+ mgLegend1, //The MgLegend
+ this, //The IMapStatusBar
+ mgPropertyPane1, //The MgPropertyPane
+ mgDefaultToolbar1); //The MgDefaultToolbar
+ MgdServiceFactory factory = new MgdServiceFactory();
+ MgdResourceService resSvc = (MgdResourceService)factory.CreateService(MgServiceType.ResourceService);
+ MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+ //If this map definition doesn't exist, we ask the user to
+ //load the Sheboygan package
+ if (!resSvc.ResourceExists(mapDefId))
+ using (OpenFileDialog diag = new OpenFileDialog())
+ diag.Filter = "MapGuide Packages (*.mgp)|*.mgp";
+ if (diag.ShowDialog() == DialogResult.OK)
+ MgByteSource source = new MgByteSource(diag.FileName);
+ MgByteReader reader = source.GetReader();
+ resSvc.ApplyResourcePackage(reader);
+ else
+ //No map, nothing to do here
+ Application.Exit();
+ //Create our runtime map
+ MgdMap map = new MgdMap(mapDefId);
+ //Create our viewer provider
+ MgMapViewerProvider provider = new MgDesktopMapViewerProvider(map);
+ //Initialize our viewer with this provider
+ mgMapViewer1.Init(provider);
+ public void SetCursorPositionMessage(string message)
+ lblCoords.Text = message;
+ public void SetFeatureSelectedMessage(string message)
+ lblSelected.Text = message;
+ public void SetMapScaleMessage(string message)
+ lblScale.Text = message;
+ public void SetMapSizeMessage(string message)
+ lblSize.Text = message;
+ private void mgMapViewer1_SelectionChanged(object sender, EventArgs e)
+ MgSelectionBase selection = mgMapViewer1.GetSelection();
+ MgReadOnlyLayerCollection layers = selection.GetLayers();
+ if (layers != null)
+ for (int i = 0; i < layers.GetCount(); i++)
+ MgLayerBase layer = layers.GetItem(i);
+ if (layer.Name == "Parcels") //The selected layer is parcels
+ //Check that we only have one selected object
+ int count = selection.GetSelectedFeaturesCount(layer, layer.FeatureClassName);
+ if (count == 1)
+ MgFeatureReader reader = null;
+ try
+ reader = selection.GetSelectedFeatures(layer, layer.FeatureClassName, false);
+ if (reader.ReadNext())
+ //Address is in the RPROPAD property
+ if (reader.IsNull("RPROPAD"))
+ MessageBox.Show("Selected parcel has no address");
+ else
+ MessageBox.Show("Address: " + reader.GetString("RPROPAD"));
+ finally //Must close all readers, otherwise connections will leak
+ reader.Close();
+ else
+ MessageBox.Show("Please select only one parcel");
+ break;
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,24 +0,0 @@
-using System;
-using System.Collections.Generic;
-using System.Linq;
-using System.Windows.Forms;
-using OSGeo.MapGuide;
- /// <summary>
- /// </summary>
- [STAThread]
- Application.Run(new MainForm());
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Program.cs (rev 0)
@@ -0,0 +1,24 @@
+using System;
+using System.Linq;
+ /// <summary>
+ /// </summary>
+ [STAThread]
+ Application.Run(new MainForm());
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,36 +0,0 @@
-[assembly: AssemblyTitle("DesktopViewerTest")]
-[assembly: AssemblyProduct("DesktopViewerTest")]
-[assembly: Guid("65637a5a-6232-4741-910e-d57f120d5806")]
-// Major Version
-// Minor Version
-// Build Number
-// Revision
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/AssemblyInfo.cs (rev 0)
@@ -0,0 +1,36 @@
+[assembly: AssemblyTitle("DesktopViewerTest")]
+[assembly: AssemblyProduct("DesktopViewerTest")]
+[assembly: Guid("65637a5a-6232-4741-910e-d57f120d5806")]
+// Major Version
+// Minor Version
+// Build Number
+// Revision
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,71 +0,0 @@
-namespace DesktopViewerTest.Properties
- /// <summary>
- /// </summary>
- /// <summary>
- /// </summary>
- get
- global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DesktopViewerTest.Properties.Resources", typeof(Resources).Assembly);
- /// <summary>
- /// </summary>
- get
- set
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.Designer.cs (rev 0)
@@ -0,0 +1,71 @@
+namespace DesktopViewerTest.Properties
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ get
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DesktopViewerTest.Properties.Resources", typeof(Resources).Assembly);
+ /// <summary>
+ /// </summary>
+ get
+ set
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,117 +0,0 @@
-<root>
- Microsoft ResX Schema
- Version 2.0
- The primary goals of this format is to allow a simple XML format
- that is mostly human readable. The generation and parsing of the
- various data types are done through the TypeConverter classes
- associated with the data types.
- Example:
- ... ado.net/XML headers & schema ...
- <resheader name="resmimetype">text/microsoft-resx</resheader>
- <resheader name="version">2.0</resheader>
- <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
- <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
- <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
- <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
- <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>[base64 mime encoded serialized .NET Framework object]</value>
- </data>
- <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
- <comment>This is a comment</comment>
- </data>
- There are any number of "resheader" rows that contain simple
- name/value pairs.
- Each data row contains a name, and value. The row also contains a
- type or mimetype. Type corresponds to a .NET class that support
- text/value conversion through the TypeConverter architecture.
- Classes that don't support this are serialized and stored with the
- mimetype set.
- The mimetype is used for serialized objects, and tells the
- ResXResourceReader how to depersist the object. This is currently not
- extensible. For a given mimetype the value must be set accordingly:
- Note - application/x-microsoft.net.object.binary.base64 is the format
- that the ResXResourceWriter will generate, however the reader can
- read any of the formats listed below.
- mimetype: application/x-microsoft.net.object.binary.base64
- value : The object must be serialized with
- : and then encoded with base64 encoding.
- mimetype: application/x-microsoft.net.object.soap.base64
- : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
- mimetype: application/x-microsoft.net.object.bytearray.base64
- value : The object must be serialized into a byte array
- : using a System.ComponentModel.TypeConverter
- <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
- <xsd:element name="root" msdata:IsDataSet="true">
- <xsd:complexType>
- <xsd:choice maxOccurs="unbounded">
- <xsd:element name="metadata">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" />
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" />
- <xsd:attribute name="type" type="xsd:string" />
- <xsd:attribute name="mimetype" type="xsd:string" />
- </xsd:complexType>
- </xsd:element>
- <xsd:element name="assembly">
- <xsd:complexType>
- <xsd:attribute name="alias" type="xsd:string" />
- </xsd:element>
- <xsd:element name="data">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
- <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
- </xsd:sequence>
- <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
- <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
- </xsd:element>
- <xsd:element name="resheader">
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" />
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- <value>text/microsoft-resx</value>
- </resheader>
- <value>2.0</value>
- </resheader>
- </resheader>
- </resheader>
-</root>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Resources.resx (rev 0)
@@ -0,0 +1,117 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,30 +0,0 @@
- get
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.Designer.cs (rev 0)
@@ -0,0 +1,30 @@
+ get
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,7 +0,0 @@
- <Profiles>
- </Profiles>
- <Settings />
-</SettingsFile>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/Properties/Settings.settings (rev 0)
@@ -0,0 +1,7 @@
+ <Profiles>
+ </Profiles>
+ <Settings />
+</SettingsFile>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,7 +0,0 @@
-<packages>
- <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
- <package id="mg-desktop-viewer-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
-</packages>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/DesktopViewerTest64/packages.config (rev 0)
@@ -0,0 +1,7 @@
+<packages>
+ <package id="cs-map-dictionaries" version="2.4.0.7093" targetFramework="net40-Client" />
+ <package id="mg-desktop-viewer-net40-x64" version="2.4.0.7093" targetFramework="net40-Client" />
+</packages>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,32 +0,0 @@
-Microsoft Visual Studio Solution File, Format Version 12.00
-# Visual Studio Express 2012 for Windows Desktop
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
-EndProject
-Global
- GlobalSection(SolutionConfigurationPlatforms) = preSolution
- Debug|x86 = Debug|x86
- Release|x86 = Release|x86
- EndGlobalSection
- GlobalSection(ProjectConfigurationPlatforms) = postSolution
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.ActiveCfg = Debug|x86
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.Build.0 = Debug|x86
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.ActiveCfg = Release|x86
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.Build.0 = Release|x86
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.ActiveCfg = Debug|x86
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.Build.0 = Debug|x86
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.ActiveCfg = Release|x86
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.Build.0 = Release|x86
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.ActiveCfg = Debug|x86
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.Build.0 = Debug|x86
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.ActiveCfg = Release|x86
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.Build.0 = Release|x86
- EndGlobalSection
- GlobalSection(SolutionProperties) = preSolution
- HideSolutionNode = FALSE
- EndGlobalSection
-EndGlobal
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget.sln (rev 0)
@@ -0,0 +1,32 @@
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
+EndProject
+Global
+ GlobalSection(SolutionConfigurationPlatforms) = preSolution
+ Debug|x86 = Debug|x86
+ Release|x86 = Release|x86
+ EndGlobalSection
+ GlobalSection(ProjectConfigurationPlatforms) = postSolution
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.ActiveCfg = Debug|x86
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x86.Build.0 = Debug|x86
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.ActiveCfg = Release|x86
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x86.Build.0 = Release|x86
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.ActiveCfg = Debug|x86
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x86.Build.0 = Debug|x86
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.ActiveCfg = Release|x86
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x86.Build.0 = Release|x86
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.ActiveCfg = Debug|x86
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x86.Build.0 = Debug|x86
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.ActiveCfg = Release|x86
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x86.Build.0 = Release|x86
+ EndGlobalSection
+ GlobalSection(SolutionProperties) = preSolution
+ HideSolutionNode = FALSE
+ EndGlobalSection
+EndGlobal
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1 +0,0 @@
-<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="MapGuideNuget.Default" Trace="true" %>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx (rev 0)
@@ -0,0 +1 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="MapGuideNuget.Default" Trace="true" %>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,50 +0,0 @@
-using System;
-using System.Linq;
-using System.Web;
-using System.Web.UI;
-using System.Web.UI.WebControls;
-namespace MapGuideNuget
- public partial class Default : System.Web.UI.Page
- protected void Page_Load(object sender, EventArgs e)
- MgUserInformation user = new MgUserInformation("Anonymous", "");
- MgSite site = new MgSite();
- site.Open(user);
- string sessionId = site.CreateSession();
- user.SetMgSessionId(sessionId);
- MgSiteConnection siteConn = new MgSiteConnection();
- siteConn.Open(user);
- MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
- System.Diagnostics.Stopwatch sw = new System.Diagnostics.Stopwatch();
- sw.Start();
- MgMap map1 = new MgMap(siteConn);
- map1.Create(mdfId, "ColdStart");
- sw.Stop();
- Trace.Write("ColdStart - " + sw.ElapsedMilliseconds + "ms");
- sw.Reset();
- sw.Start();
- MgMap map2 = new MgMap(siteConn);
- map2.Create(mdfId, "WarmStart");
- sw.Stop();
- Trace.Write("WarmStart - " + sw.ElapsedMilliseconds + "ms");
- sw.Start();
- MgMap map3 = new MgMap(siteConn);
- map3.Create(mdfId, "WarmStart2");
- sw.Stop();
- Trace.Write("WarmStart2 - " + sw.ElapsedMilliseconds + "ms");
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.cs (rev 0)
@@ -0,0 +1,50 @@
+using System;
+using System.Linq;
+using System.Web;
+using System.Web.UI;
+using System.Web.UI.WebControls;
+namespace MapGuideNuget
+ public partial class Default : System.Web.UI.Page
+ protected void Page_Load(object sender, EventArgs e)
+ MgUserInformation user = new MgUserInformation("Anonymous", "");
+ MgSite site = new MgSite();
+ site.Open(user);
+ string sessionId = site.CreateSession();
+ user.SetMgSessionId(sessionId);
+ MgSiteConnection siteConn = new MgSiteConnection();
+ siteConn.Open(user);
+ MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+ System.Diagnostics.Stopwatch sw = new System.Diagnostics.Stopwatch();
+ sw.Start();
+ MgMap map1 = new MgMap(siteConn);
+ map1.Create(mdfId, "ColdStart");
+ sw.Stop();
+ Trace.Write("ColdStart - " + sw.ElapsedMilliseconds + "ms");
+ sw.Reset();
+ sw.Start();
+ MgMap map2 = new MgMap(siteConn);
+ map2.Create(mdfId, "WarmStart");
+ sw.Stop();
+ Trace.Write("WarmStart - " + sw.ElapsedMilliseconds + "ms");
+ sw.Start();
+ MgMap map3 = new MgMap(siteConn);
+ map3.Create(mdfId, "WarmStart2");
+ sw.Stop();
+ Trace.Write("WarmStart2 - " + sw.ElapsedMilliseconds + "ms");
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,15 +0,0 @@
-// <auto-generated>
-// This code was generated by a tool.
-// Changes to this file may cause incorrect behavior and will be lost if
-// the code is regenerated.
-// </auto-generated>
-namespace MapGuideNuget {
- public partial class Default {
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Default.aspx.designer.cs (rev 0)
@@ -0,0 +1,15 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace MapGuideNuget {
+ public partial class Default {
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1 +0,0 @@
-<%@ Application Codebehind="Global.asax.cs" Inherits="MapGuideNuget.Global" Language="C#" %>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax (rev 0)
@@ -0,0 +1 @@
+<%@ Application Codebehind="Global.asax.cs" Inherits="MapGuideNuget.Global" Language="C#" %>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,49 +0,0 @@
-using System;
-using System.Linq;
-using System.Web;
-using System.Web.Security;
-using System.Web.SessionState;
- public class Global : System.Web.HttpApplication
- protected void Application_Start(object sender, EventArgs e)
- MapGuideApi.MgInitializeWebTier(Server.MapPath("~/webconfig.ini"));
- protected void Session_Start(object sender, EventArgs e)
- protected void Application_BeginRequest(object sender, EventArgs e)
- protected void Application_AuthenticateRequest(object sender, EventArgs e)
- protected void Application_Error(object sender, EventArgs e)
- protected void Session_End(object sender, EventArgs e)
- protected void Application_End(object sender, EventArgs e)
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Global.asax.cs (rev 0)
@@ -0,0 +1,49 @@
+using System;
+using System.Linq;
+using System.Web;
+using System.Web.Security;
+using System.Web.SessionState;
+ public class Global : System.Web.HttpApplication
+ protected void Application_Start(object sender, EventArgs e)
+ MapGuideApi.MgInitializeWebTier(Server.MapPath("~/webconfig.ini"));
+ protected void Session_Start(object sender, EventArgs e)
+ protected void Application_BeginRequest(object sender, EventArgs e)
+ protected void Application_AuthenticateRequest(object sender, EventArgs e)
+ protected void Application_Error(object sender, EventArgs e)
+ protected void Session_End(object sender, EventArgs e)
+ protected void Application_End(object sender, EventArgs e)
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,143 +0,0 @@
-<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
- <PropertyGroup>
- <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
- <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>
- </ProductVersion>
- <SchemaVersion>2.0</SchemaVersion>
- <ProjectGuid>{A4665445-2B49-4808-BD7A-8A6B6AAF5237}</ProjectGuid>
- <ProjectTypeGuids>{349c5851-65df-11da-9384-00065b846f21};{fae04ec0-301f-11d3-bf4b-00c04f79efbc}</ProjectTypeGuids>
- <OutputType>Library</OutputType>
- <AppDesignerFolder>Properties</AppDesignerFolder>
- <RootNamespace>MapGuideNuget</RootNamespace>
- <AssemblyName>MapGuideNuget</AssemblyName>
- <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
- <UseIISExpress>false</UseIISExpress>
- <IISExpressSSLPort />
- <IISExpressAnonymousAuthentication />
- <IISExpressWindowsAuthentication />
- <IISExpressUseClassicPipelineMode />
- <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
- <RestorePackages>true</RestorePackages>
- </PropertyGroup>
- <ItemGroup>
- <Reference Include="Microsoft.CSharp" />
- <Reference Include="OSGeo.MapGuide.Foundation">
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.Geometry">
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.MapGuideCommon">
- <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.PlatformBase">
- <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.Web">
- <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
- </Reference>
- <Reference Include="System.Web.DynamicData" />
- <Reference Include="System.Web.Entity" />
- <Reference Include="System.Web.ApplicationServices" />
- <Reference Include="System.ComponentModel.DataAnnotations" />
- <Reference Include="System" />
- <Reference Include="System.Data" />
- <Reference Include="System.Data.DataSetExtensions" />
- <Reference Include="System.Web.Extensions" />
- <Reference Include="System.Xml.Linq" />
- <Reference Include="System.Drawing" />
- <Reference Include="System.Web" />
- <Reference Include="System.Xml" />
- <Reference Include="System.Configuration" />
- <Reference Include="System.Web.Services" />
- <Reference Include="System.EnterpriseServices" />
- </ItemGroup>
- <ItemGroup>
- <Content Include="Default.aspx" />
- <Content Include="Global.asax" />
- <Content Include="Web.config" />
- </ItemGroup>
- <ItemGroup>
- <Compile Include="Default.aspx.cs">
- <DependentUpon>Default.aspx</DependentUpon>
- <SubType>ASPXCodeBehind</SubType>
- </Compile>
- <Compile Include="Default.aspx.designer.cs">
- </Compile>
- <Compile Include="Global.asax.cs">
- <DependentUpon>Global.asax</DependentUpon>
- </Compile>
- <Compile Include="Properties\AssemblyInfo.cs" />
- </ItemGroup>
- <ItemGroup>
- <Content Include="packages.config" />
- <None Include="Web.Debug.config">
- <DependentUpon>Web.config</DependentUpon>
- </None>
- <None Include="Web.Release.config">
- </None>
- <Content Include="webconfig.ini" />
- </ItemGroup>
- <PropertyGroup>
- <VisualStudioVersion Condition="'$(VisualStudioVersion)' == ''">10.0</VisualStudioVersion>
- <VSToolsPath Condition="'$(VSToolsPath)' == ''">$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v$(VisualStudioVersion)</VSToolsPath>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
- <DebugSymbols>true</DebugSymbols>
- <OutputPath>bin\</OutputPath>
- <DefineConstants>DEBUG;TRACE</DefineConstants>
- <DebugType>full</DebugType>
- <PlatformTarget>x64</PlatformTarget>
- <ErrorReport>prompt</ErrorReport>
- <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
- </PropertyGroup>
- <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
- <DefineConstants>TRACE</DefineConstants>
- <Optimize>true</Optimize>
- <DebugType>pdbonly</DebugType>
- </PropertyGroup>
- <Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
- <Import Project="$(VSToolsPath)\WebApplications\Microsoft.WebApplication.targets" Condition="'$(VSToolsPath)' != ''" />
- <Import Project="$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v10.0\WebApplications\Microsoft.WebApplication.targets" Condition="false" />
- <ProjectExtensions>
- <VisualStudio>
- <FlavorProperties GUID="{349c5851-65df-11da-9384-00065b846f21}">
- <WebProjectProperties>
- <UseIIS>True</UseIIS>
- <AutoAssignPort>True</AutoAssignPort>
- <DevelopmentServerPort>58686</DevelopmentServerPort>
- <DevelopmentServerVPath>/</DevelopmentServerVPath>
- <IISUrl>http://localhost/MapGuideNuget64</IISUrl>
- <NTLMAuthentication>False</NTLMAuthentication>
- <UseCustomServer>False</UseCustomServer>
- <CustomServerUrl>
- </CustomServerUrl>
- <SaveServerSettingsInUserFile>False</SaveServerSettingsInUserFile>
- </WebProjectProperties>
- </FlavorProperties>
- </VisualStudio>
- </ProjectExtensions>
- <PropertyGroup>
- <PostBuildEvent>
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"
-xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x64.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
- </PropertyGroup>
- <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
- <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
- Other similar extension points exist, see Microsoft.Common.targets.
- <Target Name="BeforeBuild">
- </Target>
- <Target Name="AfterBuild">
- </Target>
-</Project>
\ No newline at end of file
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj (rev 0)
@@ -0,0 +1,143 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProductVersion>
+ </ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{A4665445-2B49-4808-BD7A-8A6B6AAF5237}</ProjectGuid>
+ <ProjectTypeGuids>{349c5851-65df-11da-9384-00065b846f21};{fae04ec0-301f-11d3-bf4b-00c04f79efbc}</ProjectTypeGuids>
+ <OutputType>Library</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>MapGuideNuget</RootNamespace>
+ <AssemblyName>MapGuideNuget</AssemblyName>
+ <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+ <UseIISExpress>false</UseIISExpress>
+ <IISExpressSSLPort />
+ <IISExpressAnonymousAuthentication />
+ <IISExpressWindowsAuthentication />
+ <IISExpressUseClassicPipelineMode />
+ <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\</SolutionDir>
+ <RestorePackages>true</RestorePackages>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="Microsoft.CSharp" />
+ <Reference Include="OSGeo.MapGuide.Foundation">
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Geometry">
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.MapGuideCommon">
+ <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.MapGuideCommon.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.PlatformBase">
+ <HintPath>..\packages\mapguide-api-base-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Web">
+ <HintPath>..\packages\mapguide-api-web-x64.2.4.0.7093\lib\net40\OSGeo.MapGuide.Web.dll</HintPath>
+ </Reference>
+ <Reference Include="System.Web.DynamicData" />
+ <Reference Include="System.Web.Entity" />
+ <Reference Include="System.Web.ApplicationServices" />
+ <Reference Include="System.ComponentModel.DataAnnotations" />
+ <Reference Include="System" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Data.DataSetExtensions" />
+ <Reference Include="System.Web.Extensions" />
+ <Reference Include="System.Xml.Linq" />
+ <Reference Include="System.Drawing" />
+ <Reference Include="System.Web" />
+ <Reference Include="System.Xml" />
+ <Reference Include="System.Configuration" />
+ <Reference Include="System.Web.Services" />
+ <Reference Include="System.EnterpriseServices" />
+ </ItemGroup>
+ <ItemGroup>
+ <Content Include="Default.aspx" />
+ <Content Include="Global.asax" />
+ <Content Include="Web.config" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="Default.aspx.cs">
+ <DependentUpon>Default.aspx</DependentUpon>
+ <SubType>ASPXCodeBehind</SubType>
+ </Compile>
+ <Compile Include="Default.aspx.designer.cs">
+ </Compile>
+ <Compile Include="Global.asax.cs">
+ <DependentUpon>Global.asax</DependentUpon>
+ </Compile>
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ </ItemGroup>
+ <ItemGroup>
+ <Content Include="packages.config" />
+ <None Include="Web.Debug.config">
+ <DependentUpon>Web.config</DependentUpon>
+ </None>
+ <None Include="Web.Release.config">
+ </None>
+ <Content Include="webconfig.ini" />
+ </ItemGroup>
+ <PropertyGroup>
+ <VisualStudioVersion Condition="'$(VisualStudioVersion)' == ''">10.0</VisualStudioVersion>
+ <VSToolsPath Condition="'$(VSToolsPath)' == ''">$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v$(VisualStudioVersion)</VSToolsPath>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
+ <DebugSymbols>true</DebugSymbols>
+ <OutputPath>bin\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <DebugType>full</DebugType>
+ <PlatformTarget>x64</PlatformTarget>
+ <ErrorReport>prompt</ErrorReport>
+ <CodeAnalysisRuleSet>ManagedMinimumRules.ruleset</CodeAnalysisRuleSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
+ <DefineConstants>TRACE</DefineConstants>
+ <Optimize>true</Optimize>
+ <DebugType>pdbonly</DebugType>
+ </PropertyGroup>
+ <Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
+ <Import Project="$(VSToolsPath)\WebApplications\Microsoft.WebApplication.targets" Condition="'$(VSToolsPath)' != ''" />
+ <Import Project="$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v10.0\WebApplications\Microsoft.WebApplication.targets" Condition="false" />
+ <ProjectExtensions>
+ <VisualStudio>
+ <FlavorProperties GUID="{349c5851-65df-11da-9384-00065b846f21}">
+ <WebProjectProperties>
+ <UseIIS>True</UseIIS>
+ <AutoAssignPort>True</AutoAssignPort>
+ <DevelopmentServerPort>58686</DevelopmentServerPort>
+ <DevelopmentServerVPath>/</DevelopmentServerVPath>
+ <IISUrl>http://localhost/MapGuideNuget64</IISUrl>
+ <NTLMAuthentication>False</NTLMAuthentication>
+ <UseCustomServer>False</UseCustomServer>
+ <CustomServerUrl>
+ </CustomServerUrl>
+ <SaveServerSettingsInUserFile>False</SaveServerSettingsInUserFile>
+ </WebProjectProperties>
+ </FlavorProperties>
+ </VisualStudio>
+ </ProjectExtensions>
+ <PropertyGroup>
+ <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x64.2.4.0.7093\mapguide-api-base\*.*" "$(TargetDir)"
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-web-x64.2.4.0.7093\mapguide-api-web\*.*" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+ <Import Project="$(SolutionDir)\.nuget\nuget.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,28 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
- <VisualStudio>
- <StartPageUrl>
- </StartPageUrl>
- <StartAction>CurrentPage</StartAction>
- <AspNetDebugging>True</AspNetDebugging>
- <SilverlightDebugging>False</SilverlightDebugging>
- <NativeDebugging>False</NativeDebugging>
- <SQLDebugging>False</SQLDebugging>
- <ExternalProgram>
- </ExternalProgram>
- <StartExternalURL>
- </StartExternalURL>
- <StartCmdLineArguments>
- </StartCmdLineArguments>
- <StartWorkingDirectory>
- </StartWorkingDirectory>
- <EnableENC>False</EnableENC>
- <AlwaysStartWebServerOnDebug>True</AlwaysStartWebServerOnDebug>
- </VisualStudio>
-</Project>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/MapGuideNuget.csproj.user (rev 0)
@@ -0,0 +1,28 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <VisualStudio>
+ <StartPageUrl>
+ </StartPageUrl>
+ <StartAction>CurrentPage</StartAction>
+ <AspNetDebugging>True</AspNetDebugging>
+ <SilverlightDebugging>False</SilverlightDebugging>
+ <NativeDebugging>False</NativeDebugging>
+ <SQLDebugging>False</SQLDebugging>
+ <ExternalProgram>
+ </ExternalProgram>
+ <StartExternalURL>
+ </StartExternalURL>
+ <StartCmdLineArguments>
+ </StartCmdLineArguments>
+ <StartWorkingDirectory>
+ </StartWorkingDirectory>
+ <EnableENC>False</EnableENC>
+ <AlwaysStartWebServerOnDebug>True</AlwaysStartWebServerOnDebug>
+ </VisualStudio>
+</Project>
Property changes on: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties
___________________________________________________________________
Added: bugtraq:number
+ true
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,35 +0,0 @@
-using System.Reflection;
-using System.Runtime.CompilerServices;
-using System.Runtime.InteropServices;
-// General Information about an assembly is controlled through the following
-// set of attributes. Change these attribute values to modify the information
-// associated with an assembly.
-[assembly: AssemblyTitle("MapGuideNuget")]
-[assembly: AssemblyDescription("")]
-[assembly: AssemblyConfiguration("")]
-[assembly: AssemblyCompany("")]
-[assembly: AssemblyProduct("MapGuideNuget")]
-[assembly: AssemblyCopyright("Copyright © 2012")]
-[assembly: AssemblyTrademark("")]
-[assembly: AssemblyCulture("")]
-// Setting ComVisible to false makes the types in this assembly not visible
-// to COM components. If you need to access a type in this assembly from
-// COM, set the ComVisible attribute to true on that type.
-[assembly: ComVisible(false)]
-// The following GUID is for the ID of the typelib if this project is exposed to COM
-[assembly: Guid("43a5bb36-748c-4637-8a4e-386ed3a7aa82")]
-// Version information for an assembly consists of the following four values:
-// Major Version
-// Minor Version
-// Build Number
-// Revision
-// You can specify all the values or you can default the Revision and Build Numbers
-// by using the '*' as shown below:
-[assembly: AssemblyVersion("1.0.0.0")]
-[assembly: AssemblyFileVersion("1.0.0.0")]
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Properties/AssemblyInfo.cs (rev 0)
@@ -0,0 +1,35 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("MapGuideNuget")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("MapGuideNuget")]
+[assembly: AssemblyCopyright("Copyright © 2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("43a5bb36-748c-4637-8a4e-386ed3a7aa82")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Revision and Build Numbers
+// by using the '*' as shown below:
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,30 +0,0 @@
-<!-- For more information on using web.config transformation visit http://go.microsoft.com/fwlink/?LinkId=125889 -->
-<configuration xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
- In the example below, the "SetAttributes" transform will change the value of
- "connectionString" to use "ReleaseSQLServer" only when the "Match" locator
- finds an attribute "name" that has a value of "MyDB".
- <connectionStrings>
- <add name="MyDB"
- connectionString="Data Source=ReleaseSQLServer;Initial Catalog=MyReleaseDB;Integrated Security=True"
- xdt:Transform="SetAttributes" xdt:Locator="Match(name)"/>
- </connectionStrings>
- <system.web>
- In the example below, the "Replace" transform will replace the entire
- <customErrors> section of your web.config file.
- Note that because there is only one customErrors section under the
- <system.web> node, there is no need to use the "xdt:Locator" attribute.
- <customErrors defaultRedirect="GenericError.htm"
- mode="RemoteOnly" xdt:Transform="Replace">
- <error statusCode="500" redirect="InternalError.htm"/>
- </customErrors>
- </system.web>
-</configuration>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Debug.config (rev 0)
@@ -0,0 +1,30 @@
+<!-- For more information on using web.config transformation visit http://go.microsoft.com/fwlink/?LinkId=125889 -->
+<configuration xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
+ In the example below, the "SetAttributes" transform will change the value of
+ "connectionString" to use "ReleaseSQLServer" only when the "Match" locator
+ finds an attribute "name" that has a value of "MyDB".
+ <connectionStrings>
+ <add name="MyDB"
+ connectionString="Data Source=ReleaseSQLServer;Initial Catalog=MyReleaseDB;Integrated Security=True"
+ xdt:Transform="SetAttributes" xdt:Locator="Match(name)"/>
+ </connectionStrings>
+ <system.web>
+ In the example below, the "Replace" transform will replace the entire
+ <customErrors> section of your web.config file.
+ Note that because there is only one customErrors section under the
+ <system.web> node, there is no need to use the "xdt:Locator" attribute.
+ <customErrors defaultRedirect="GenericError.htm"
+ mode="RemoteOnly" xdt:Transform="Replace">
+ <error statusCode="500" redirect="InternalError.htm"/>
+ </customErrors>
+ </system.web>
+</configuration>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,31 +0,0 @@
- <add name="MyDB"
- <system.web>
- <compilation xdt:Transform="RemoveAttributes(debug)" />
- </customErrors>
- </system.web>
-</configuration>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.Release.config (rev 0)
@@ -0,0 +1,31 @@
+ <add name="MyDB"
+ <system.web>
+ <compilation xdt:Transform="RemoveAttributes(debug)" />
+ </customErrors>
+ </system.web>
+</configuration>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,13 +0,0 @@
-<?xml version="1.0"?>
- For more information on how to configure your ASP.NET application, please visit
- http://go.microsoft.com/fwlink/?LinkId=169433
-<configuration>
- <system.web>
- <compilation debug="true" targetFramework="4.0" />
- </system.web>
-</configuration>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/Web.config (rev 0)
@@ -0,0 +1,13 @@
+<?xml version="1.0"?>
+ For more information on how to configure your ASP.NET application, please visit
+ http://go.microsoft.com/fwlink/?LinkId=169433
+<configuration>
+ <system.web>
+ <compilation debug="true" targetFramework="4.0" />
+ </system.web>
+</configuration>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,5 +0,0 @@
-<packages>
- <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40" />
- <package id="mapguide-api-web-x64" version="2.4.0.7093" targetFramework="net40" />
-</packages>
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/packages.config (rev 0)
@@ -0,0 +1,5 @@
+<packages>
+ <package id="mapguide-api-base-x64" version="2.4.0.7093" targetFramework="net40" />
+ <package id="mapguide-api-web-x64" version="2.4.0.7093" targetFramework="net40" />
+</packages>
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,198 +0,0 @@
-# MapGuide Web Configuration File
-# WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
-# ADVERSLY IMPACT SERVER PERFORMANCE
-# COMMON VALIDATION INFORMATION
-# (Unless otherwise noted under the property description)
-# String Property Range of String Length Reserved Characters
-# File Name 0 < Length <= 128 \/:*?"<>|
-# Folder Name 0 < Length <= 128 \/:*?"<>|
-# Log Parameters 0 <= Length <= 1024
-# Password 0 <= Length <= 64 \t\r\n\v\f
-# Path 0 < Length <= 255 *?"<>|
-# Numeric Property Range of Numeric Value
-# Port Number 0 <= Value <= 65535
-[GeneralProperties]
-# G E N E R A L
-# Property Name Description
-# DefaultMessageLocale ISO 639-1 name for the message locale
-# Length = 2
-# Example: en
-# or
-# Length = 5
-# Example: en-US
-# WARNING: if a 5 character locale is specified
-# the first 2 characters must be lower
-# case and the last 2 characters must
-# be upper case.
-# LogsPath Path where log files are stored
-# MentorDictionaryPath The path where the CS-Map Coordinate System Dictionaries are installed
-# ResourcesPath Path where the localization resource files are stored
-# TcpIpMtu The TCP/IP maximum transmission unit
-# 0 < Value <= 65535
-# TempPath Path where the temporary files are stored
-# FailoverRetryTime Time in seconds for when to retry connecting
-# to a MapGuide server that has gone offline.
-# Note: For a single Web Tier and MapGuide server
-# pair use 1. For a load balanced
-# configuration with multiple MapGuide
-# servers use 60. Values other than 1 will
-# cause a delay when re-establishing a
-# connection with the Web Tier after
-# restarting a MapGuide server.
-DefaultMessageLocale = en
-LogsPath = Logs/
-MentorDictionaryPath =C:\Program Files\OSGeo\MapGuide\CS-Map\Dictionaries\
-ResourcesPath =C:\Program Files\OSGeo\MapGuide\Web\www\mapagent\Resources
-TcpIpMtu = 1460
-TempPath =C:\Program Files\OSGeo\MapGuide\Web\Temp\
-FailoverRetryTime = 1
-[AdministrativeConnectionProperties]
-# A D M I N I S T R A T I V E C O N N E C T I O N
-# MaxConnections The maximum allowed concurrent connections for this port.
-# Default value of 2 is for a typical load when the web
-# is connected to a quad core server machine.
-# Port The port to use for administration operations
-# WARNING: If you change the port # here you
-# must also change the corresponding
-# port # for the server configuration
-# file.
-MaxConnections = 2
-Port =2810
-[ClientConnectionProperties]
-# C L I E N T C O N N E C T I O N
-# Default value of 12 is for a typical load when the web
-# Port The port to use for client operations
-# file.
-MaxConnections = 12
-Port =2811
-[SiteConnectionProperties]
-# S I T E C O N N E C T I O N
-# IpAddress The IP address of the site server
-# 0 < Length <= 255
-# Default value of 6 is for a typical load when the web
-# Port The port to use for site operations
-# file.
-IpAddress =127.0.0.1
-MaxConnections = 6
-Port =2812
-[AgentProperties]
-# M A P A G E N T
-# DebugPause Number of seconds the agent pauses before
-# each request, for debugging purpose
-# 0 <= Value <= 86400
-# DisableAuthoring Disables Authoring HTTP requests
-# 0 = false and 1 = true
-# DisableWfs Disables OGC Wfs HTTP requests
-# DisableWms Disables OGC Wms HTTP requests
-# ErrorLogEnabled 0 = log disabled, 1 = log enabled
-# ErrorLogFilename Name of the log file
-# RequestLogEnabled 0 = log disabled, 1 = log enabled
-# RequestLogFilename Name of the log file
-DebugPause = 0
-DisableAuthoring = 0
-DisableWfs = 0
-DisableWms = 0
-ErrorLogEnabled = 0
-ErrorLogFilename = Error.log
-RequestLogEnabled = 0
-RequestLogFilename = Request.log
-[OgcProperties]
-# O G C S E T T I N G S
-# WfsPassword Password to be used for credentials in WFS
-# requests
-# WmsPassword Password to be used for credentials in WMS
-# requests
-# CITEWfsEnabled Enable OGC CITE Test for WFS
-# Consider unknown requests as OGC Wfs HTTP requests
-# CITEWmsEnabled Enable OGC CITE Test for WMS
-# Consider unknown requests as OGC Wms HTTP requests
-WfsPassword = wfs
-WmsPassword = wms
-CITEWfsEnabled = 0
-CITEWmsEnabled = 0
-[WebApplicationProperties]
-# W E B A P P L I C A T I O N S E T T I N G S
-# TemplateRootFolder The root folder containing the viewer
-# templates
-# WidgetInfoFolder The folder containing widget info files
-# ContainerInfoFolder The folder containing container info files
-TemplateRootFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\templates\mapguide
-WidgetInfoFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\widgets\widgetinfo
-ContainerInfoFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\containerinfo
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64/webconfig.ini (rev 0)
@@ -0,0 +1,198 @@
+# MapGuide Web Configuration File
+# WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
+# ADVERSLY IMPACT SERVER PERFORMANCE
+# COMMON VALIDATION INFORMATION
+# (Unless otherwise noted under the property description)
+# String Property Range of String Length Reserved Characters
+# File Name 0 < Length <= 128 \/:*?"<>|
+# Folder Name 0 < Length <= 128 \/:*?"<>|
+# Log Parameters 0 <= Length <= 1024
+# Password 0 <= Length <= 64 \t\r\n\v\f
+# Path 0 < Length <= 255 *?"<>|
+# Numeric Property Range of Numeric Value
+# Port Number 0 <= Value <= 65535
+[GeneralProperties]
+# G E N E R A L
+# Property Name Description
+# DefaultMessageLocale ISO 639-1 name for the message locale
+# Length = 2
+# Example: en
+# or
+# Length = 5
+# Example: en-US
+# WARNING: if a 5 character locale is specified
+# the first 2 characters must be lower
+# case and the last 2 characters must
+# be upper case.
+# LogsPath Path where log files are stored
+# MentorDictionaryPath The path where the CS-Map Coordinate System Dictionaries are installed
+# ResourcesPath Path where the localization resource files are stored
+# TcpIpMtu The TCP/IP maximum transmission unit
+# 0 < Value <= 65535
+# TempPath Path where the temporary files are stored
+# FailoverRetryTime Time in seconds for when to retry connecting
+# to a MapGuide server that has gone offline.
+# Note: For a single Web Tier and MapGuide server
+# pair use 1. For a load balanced
+# configuration with multiple MapGuide
+# servers use 60. Values other than 1 will
+# cause a delay when re-establishing a
+# connection with the Web Tier after
+# restarting a MapGuide server.
+DefaultMessageLocale = en
+LogsPath = Logs/
+MentorDictionaryPath =C:\Program Files\OSGeo\MapGuide\CS-Map\Dictionaries\
+ResourcesPath =C:\Program Files\OSGeo\MapGuide\Web\www\mapagent\Resources
+TcpIpMtu = 1460
+TempPath =C:\Program Files\OSGeo\MapGuide\Web\Temp\
+FailoverRetryTime = 1
+[AdministrativeConnectionProperties]
+# A D M I N I S T R A T I V E C O N N E C T I O N
+# MaxConnections The maximum allowed concurrent connections for this port.
+# Default value of 2 is for a typical load when the web
+# is connected to a quad core server machine.
+# Port The port to use for administration operations
+# WARNING: If you change the port # here you
+# must also change the corresponding
+# port # for the server configuration
+# file.
+MaxConnections = 2
+Port =2810
+[ClientConnectionProperties]
+# C L I E N T C O N N E C T I O N
+# Default value of 12 is for a typical load when the web
+# Port The port to use for client operations
+# file.
+MaxConnections = 12
+Port =2811
+[SiteConnectionProperties]
+# S I T E C O N N E C T I O N
+# IpAddress The IP address of the site server
+# 0 < Length <= 255
+# Default value of 6 is for a typical load when the web
+# Port The port to use for site operations
+# file.
+IpAddress =127.0.0.1
+MaxConnections = 6
+Port =2812
+[AgentProperties]
+# M A P A G E N T
+# DebugPause Number of seconds the agent pauses before
+# each request, for debugging purpose
+# 0 <= Value <= 86400
+# DisableAuthoring Disables Authoring HTTP requests
+# 0 = false and 1 = true
+# DisableWfs Disables OGC Wfs HTTP requests
+# DisableWms Disables OGC Wms HTTP requests
+# ErrorLogEnabled 0 = log disabled, 1 = log enabled
+# ErrorLogFilename Name of the log file
+# RequestLogEnabled 0 = log disabled, 1 = log enabled
+# RequestLogFilename Name of the log file
+DebugPause = 0
+DisableAuthoring = 0
+DisableWfs = 0
+DisableWms = 0
+ErrorLogEnabled = 0
+ErrorLogFilename = Error.log
+RequestLogEnabled = 0
+RequestLogFilename = Request.log
+[OgcProperties]
+# O G C S E T T I N G S
+# WfsPassword Password to be used for credentials in WFS
+# requests
+# WmsPassword Password to be used for credentials in WMS
+# requests
+# CITEWfsEnabled Enable OGC CITE Test for WFS
+# Consider unknown requests as OGC Wfs HTTP requests
+# CITEWmsEnabled Enable OGC CITE Test for WMS
+# Consider unknown requests as OGC Wms HTTP requests
+WfsPassword = wfs
+WmsPassword = wms
+CITEWfsEnabled = 0
+CITEWmsEnabled = 0
+[WebApplicationProperties]
+# W E B A P P L I C A T I O N S E T T I N G S
+# TemplateRootFolder The root folder containing the viewer
+# templates
+# WidgetInfoFolder The folder containing widget info files
+# ContainerInfoFolder The folder containing container info files
+TemplateRootFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\templates\mapguide
+WidgetInfoFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\widgets\widgetinfo
+ContainerInfoFolder =C:\Program Files\OSGeo\MapGuide\Web\www\fusion\containerinfo
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln
--- trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,39 +0,0 @@
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest64\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest64\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
-EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest64\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
-EndProject
-Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = ".nuget", ".nuget", "{A4AD55B7-4C81-4238-846D-F78A67B138B8}"
- ProjectSection(SolutionItems) = preProject
- .nuget\NuGet.Config = .nuget\NuGet.Config
- .nuget\NuGet.exe = .nuget\NuGet.exe
- .nuget\NuGet.targets = .nuget\NuGet.targets
- EndProjectSection
-EndProject
-Global
- Debug|x64 = Debug|x64
- Release|x64 = Release|x64
- EndGlobalSection
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.ActiveCfg = Debug|x64
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.Build.0 = Debug|x64
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.ActiveCfg = Release|x64
- {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.Build.0 = Release|x64
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.ActiveCfg = Debug|x64
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.Build.0 = Debug|x64
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.ActiveCfg = Release|x64
- {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.Build.0 = Release|x64
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.ActiveCfg = Debug|x64
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.Build.0 = Debug|x64
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.ActiveCfg = Release|x64
- {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln)
--- branches/2.5/MgDev/nuget/MapGuideNuget/MapGuideNuget64.sln (rev 0)
@@ -0,0 +1,39 @@
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CoordSysEnumTest", "CoordSysEnumTest64\CoordSysEnumTest.csproj", "{1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopConsoleTest", "DesktopConsoleTest64\DesktopConsoleTest.csproj", "{87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DesktopViewerTest", "DesktopViewerTest64\DesktopViewerTest.csproj", "{A0DCC768-B341-426B-889A-0701A2399CE8}"
+EndProject
+Project("{2150E333-8FDC-42A3-9474-1A3956D46DE8}") = ".nuget", ".nuget", "{A4AD55B7-4C81-4238-846D-F78A67B138B8}"
+ ProjectSection(SolutionItems) = preProject
+ .nuget\NuGet.Config = .nuget\NuGet.Config
+ .nuget\NuGet.exe = .nuget\NuGet.exe
+ .nuget\NuGet.targets = .nuget\NuGet.targets
+ EndProjectSection
+EndProject
+Global
+ Debug|x64 = Debug|x64
+ Release|x64 = Release|x64
+ EndGlobalSection
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.ActiveCfg = Debug|x64
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Debug|x64.Build.0 = Debug|x64
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.ActiveCfg = Release|x64
+ {1B74DF59-B3D2-49E8-80EF-9BC5A84552F3}.Release|x64.Build.0 = Release|x64
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.ActiveCfg = Debug|x64
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Debug|x64.Build.0 = Debug|x64
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.ActiveCfg = Release|x64
+ {87BA0B9E-F36E-4D45-89EC-C1CD95C73B62}.Release|x64.Build.0 = Release|x64
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.ActiveCfg = Debug|x64
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Debug|x64.Build.0 = Debug|x64
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.ActiveCfg = Release|x64
+ {A0DCC768-B341-426B-889A-0701A2399CE8}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/Web.sln
--- trunk/MgDev/nuget/MapGuideNuget/Web.sln 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/Web.sln 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,20 +0,0 @@
-# Visual Studio Express 2012 for Web
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
-EndProject
-Global
- EndGlobalSection
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.ActiveCfg = Debug|x86
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.Build.0 = Debug|x86
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.ActiveCfg = Release|x86
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.Build.0 = Release|x86
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/Web.sln (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/Web.sln)
--- branches/2.5/MgDev/nuget/MapGuideNuget/Web.sln (rev 0)
@@ -0,0 +1,20 @@
+# Visual Studio Express 2012 for Web
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
+EndProject
+Global
+ EndGlobalSection
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.ActiveCfg = Debug|x86
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x86.Build.0 = Debug|x86
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.ActiveCfg = Release|x86
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x86.Build.0 = Release|x86
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
Deleted: branches/2.5/MgDev/nuget/MapGuideNuget/Web64.sln
--- trunk/MgDev/nuget/MapGuideNuget/Web64.sln 2013-01-13 12:26:06 UTC (rev 7310)
+++ branches/2.5/MgDev/nuget/MapGuideNuget/Web64.sln 2013-01-13 13:01:56 UTC (rev 7311)
@@ -1,20 +0,0 @@
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget64\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
-EndProject
-Global
- EndGlobalSection
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.ActiveCfg = Debug|x64
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.Build.0 = Debug|x64
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.ActiveCfg = Release|x64
- {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.Build.0 = Release|x64
- EndGlobalSection
- EndGlobalSection
-EndGlobal
Copied: branches/2.5/MgDev/nuget/MapGuideNuget/Web64.sln (from rev 7310, trunk/MgDev/nuget/MapGuideNuget/Web64.sln)
--- branches/2.5/MgDev/nuget/MapGuideNuget/Web64.sln (rev 0)
@@ -0,0 +1,20 @@
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MapGuideNuget", "MapGuideNuget64\MapGuideNuget.csproj", "{A4665445-2B49-4808-BD7A-8A6B6AAF5237}"
+EndProject
+Global
+ EndGlobalSection
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.ActiveCfg = Debug|x64
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Debug|x64.Build.0 = Debug|x64
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.ActiveCfg = Release|x64
+ {A4665445-2B49-4808-BD7A-8A6B6AAF5237}.Release|x64.Build.0 = Release|x64
+ EndGlobalSection
+ EndGlobalSection
+EndGlobal
More information about the mapguide-commits
