[mapguide-commits] r7661 - trunk/MgDev/UnitTest/TestData/FeatureService
svn_mapguide at osgeo.org
Thu Jul 4 08:16:07 PDT 2013
Author: jng
Date: 2013-07-04 08:16:07 -0700 (Thu, 04 Jul 2013)
New Revision: 7661
trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
#2307: This is an update to the Feature Service test suite in light of #2315 and #2316
Modified: trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
--- trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2013-07-04 15:12:23 UTC (rev 7660)
+++ trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2013-07-04 15:16:07 UTC (rev 7661)
@@ -1461,7 +1461,7 @@
INSERT INTO "ApiTestResults" VALUES('DescribeSchema on a raster resource with valid schema', 4013, 'text/xml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
20202020202020203C78733A6669656C643E3C2F78733A6669656C643E0A20202020202020203C78733A73656C6563746F723E3C2F78733A73656C6563746F723E0A2020202020203C2F78733A6B65793E3C2F78733A656C656D656E743E0A20203C2F78733A736368656D613E');
INSERT INTO "ApiTestResults" VALUES('DescribeSchema on a raster resource with invalid schema', 4014, 'text/plain', X'6D6766646F657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('Clean up operation', 5001, '', '');
-INSERT INTO "ApiTestResults" VALUES('SelectFeatures on a SDF resource before setting resource data', 5002, 'text/plain', X'6D676170706C69636174696F6E657863657074696F6E');
+INSERT INTO "ApiTestResults" VALUES('SelectFeatures on a SDF resource before setting resource data', 5002, 'text/plain', 'mgresourcetagnotfoundexception');
INSERT INTO "ApiTestResults" VALUES('SelectFeatures with valid class name', 5003, '', '<?xml version="1.0" encoding="UTF-8"?><FeatureSet><xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/TempSchema" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:TempSchema="http://fdo.osgeo.org/schemas/feature/TempSchema" elementFormDefault="qualified" attributeFormDefault="unqualified"><xs:annotation><xs:documentation/></xs:annotation><xs:element name="TEST" type="TempSchema:TESTType" abstract="false" substitutionGroup="gml:_Feature"><xs:key name="TESTKey"><xs:selector xpath=".//TEST"/><xs:field xpath="Key"/></xs:key></xs:element><xs:complexType name="TESTType" abstract="false" fdo:geometryName="Data"><xs:annotation><xs:documentation/><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:complexContent><xs:extension base="gml:AbstractFeatureType"><xs:sequence><xs:element name="
Key" minOccurs="0"><xs:annotation><xs:documentation>The key of the object</xs:documentation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:simpleType><xs:restriction base="xs:string"><xs:maxLength value=""/></xs:restriction></xs:simpleType></xs:element><xs:element name="Name" minOccurs="0"><xs:annotation><xs:documentation>The name of the object</xs:documentation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:simpleType><xs:restriction base="xs:string"><xs:maxLength value=""/></xs:restriction></xs:simpleType></xs:element><xs:element name="Url" minOccurs="0"><xs:annotation><xs:documentation>The url of the object</xs:documentation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:simpleType><xs:restriction base="xs:string"><xs:maxLength value=""/></xs:restriction></xs:simpleType></xs:element><xs:element name="Data" type="gml:AbstractGeometryType" fdo:hasMeasure="false" fdo:hasElevation="false" fdo:srsName="LL8
4" fdo:geometricTypes="curve "><xs:annotation><xs:documentation>The geometry of the object</xs:documentation><xs:appinfo source="http://fdo.osgeo.org/schemas"/></xs:annotation></xs:element></xs:sequence></xs:extension></xs:complexContent></xs:complexType></xs:schema><Features><Feature><Property><Name>Key</Name><Value>1</Value></Property><Property><Name>Name</Name><Value>Polypolyline - 2 geometry segments, 4 points</Value></Property><Property><Name>Url</Name><Value></Value></Property><Property><Name>Data</Name><Value>MULTILINESTRING ((10 10, 20 20), (40 40, 30 30))</Value></Property></Feature></Features></FeatureSet>');
INSERT INTO "ApiTestResults" VALUES('SelectFeatures with blank class name', 5004, 'text/plain', X'6D67696E76616C6964617267756D656E74657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('SelectFeatures with invalid class name', 5005, 'text/plain', X'6D6766646F657863657074696F6E');
@@ -1742,7 +1742,7 @@
INSERT INTO "ApiTestResults" VALUES('SelectAggregates on RFP resource with invalid class name', 6016, 'text/plain', 'An exception occurred');
INSERT INTO "ApiTestResults" VALUES('Clean up operation', 7001, '', '');
-INSERT INTO "ApiTestResults" VALUES('Execute SQL query on an SDF resource when resource data is not set yet', 7002, 'text/plain', X'6D676170706C69636174696F6E657863657074696F6E');
+INSERT INTO "ApiTestResults" VALUES('Execute SQL query on an SDF resource when resource data is not set yet', 7002, 'text/plain', 'mgresourcetagnotfoundexception');
INSERT INTO "ApiTestResults" VALUES('Execute SQL query on an SDF resource - not valid operation', 7003, 'text/plain', X'6D67696E76616C69646F7065726174696F6E657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('Execute SQL query with blank query', 7004, 'text/plain', X'6D67696E76616C6964617267756D656E74657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('Execute SQL query on an ArcSDE resource. Selects the table names in the database', 7005, 'text/xml', '<?xml version="1.0" encoding="UTF-8" ?><RowSet><ColumnDefinitions><Column><Name>TABLE_NAME</Name><Type>string</Type></Column></ColumnDefinitions><Rows><Row><Column><Name>TABLE_NAME</Name><Value>A12874</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13596</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13597</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13598</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13600</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13614</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13615</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13616</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13621</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13622</
Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13623</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13645</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13646</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13647</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13654</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13696</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13697</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13704</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13705</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13706</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13765</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13766</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13767</Value></Column></Row><Row><Column><Name>TABLE_NAME</N
ame><Value>A13772</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13773</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13774</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13797</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13798</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13799</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13804</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13805</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13806</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13812</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13813</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13814</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13819</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13820</Value></Column></Row><Row><Column>
<Name>TABLE_NAME</Name><Value>A13821</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13828</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13829</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13830</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13835</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13836</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13837</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13844</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13947</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13948</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13949</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13954</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13955</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13956</Value></Column>
</Row><Row><Column><Name>TABLE_NAME</Name><Value>A13976</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13987</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A13988</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A14139</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A14141</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A14228</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A15918</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A15984</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A16203</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A18037</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A18061</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A18062</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>A6534</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>ADDRE
S1</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>ADDRES2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>ADDRES3</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>BEACH</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>CITY</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>CUSTOMER</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>CUSTOMER2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D12874</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13596</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13597</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13598</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13600</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13844</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13976</Value></Column></Row><Row><Column><Name>TABLE
_NAME</Name><Value>D13987</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D13988</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D14139</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D14141</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D14228</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D15918</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D15984</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D16203</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D18037</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D18061</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D18062</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>D6534</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>EXAMPLE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>EXAMPLE2</Value></Column></Row><Ro
w><Column><Name>TABLE_NAME</Name><Value>F491</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F50</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F51</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F52</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F550</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F831</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F953</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>F955</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13032</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13034</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13106</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13596</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13597</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13598</Value></Column></Row><Ro
w><Column><Name>TABLE_NAME</Name><Value>L13600</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13844</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13976</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13987</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L13988</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L14139</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L14141</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L14142</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L14228</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L18053</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L18055</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>L18106</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LAKES</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST10</Va
lue></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST11</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST12</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST13</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST14</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOCKTEST15</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOTLINES_UPDATE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOTLINES_UPDATE2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>LOTLINES_UPDATE3</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_156E6$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_156FD$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_1570E$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_15730$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><
Value>MDQT_15741$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_15C82$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_165B0$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_165C1$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_165D2$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_165F4$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_19D8A$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_29428$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_29436$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDQT_2ADBF$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2253B$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2254C$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_24A89$</Value></Column></Row><Row><Column><Name>TABLE_
NAME</Name><Value>MDRT_2904E$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2905A$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_29175$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_29186$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_29446$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_29460$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_29AC2$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2DB02$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2DCB9$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2DCC9$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MDRT_2DCDF$</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MEXICO_ARC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MEXICO_NODE</Value></Column></Row><Row><Column><
Name>TABLE_NAME</Name><Value>MEXICO_POLYGON</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MEXICO_REGION_STATE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MEXICO_REGION_TEST</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MEXICO_TIC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MYARC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MYPOLYGON</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MYROADS</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>MYTIC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>PDTEST10</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>PDTEST20</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>PDTEST21</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>PIERRECOV1_ARC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>PIERREPLAIN1</Value></Column></Row><Row><Co
lumn><Name>TABLE_NAME</Name><Value>PYSANTEST3</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>QE_PROXY_API_TEST</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>REDLANDS_ARC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>REDLANDS_POLYGON</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>REDLANDS_TIC</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>ROAD_SEGMENTS</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S491</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S50</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S51</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S52</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S550</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S831</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>S953</Value></Column></Row><Row><Column><Name>TABLE_NAME</Nam
e><Value>S955</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SAMPLE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SAMPLE3</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SAMPLENONLOCKING</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SAMPLEWITHGEOM</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SDE_EXCEPTIONS</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SDE_LOGFILES</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>SDE_LOGFILE_DATA</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TEMPCLASS</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTCLASSCOMPLEX</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTCLASSGEOMZM</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTCLASSGEOMZM2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTCLASSNEW</Value></Column></Row><Row><Co
lumn><Name>TABLE_NAME</Name><Value>TESTCLASSNULLABLE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTCLASSSIMPLE</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTFEB05</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT1</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT4</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT5</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT6</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTLT7</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTUSERMANAGEDID</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTUSERMANAGEDIDLOCKS</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TESTUSERMANAGEDIDLT</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>TUX_TEST</Value></Col
umn></Row><Row><Column><Name>TABLE_NAME</Name><Value>VINAYTEST</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>VINAYTEST1</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>VINAYTEST2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>XXX</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>XXX2</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>XXX3</Value></Column></Row><Row><Column><Name>TABLE_NAME</Name><Value>XXX4</Value></Column></Row></Rows></RowSet>');
@@ -1800,8 +1800,8 @@
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions with non-existent resource', 9005, 'text/plain', X'6D677265736F757263656E6F74666F756E64657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on Oracle resource', 9006, 'text/xml', X'0A20203C46646F4C6F6E675472616E73616374696F6E4C6973743E0A202020203C4C6F6E675472616E73616374696F6E3E0A2020202020203C4465736372697074696F6E3E3C2F4465736372697074696F6E3E0A2020202020203C4E616D653E4C4956453C2F4E616D653E0A2020202020203C4F776E65723E5359533C2F4F776E65723E0A202020203C2F4C6F6E675472616E73616374696F6E3E0A202020203C50726F76696465724E616D653E4175746F6465736B2E4F7261636C652E332E303C2F50726F76696465724E616D653E0A20203C2F46646F4C6F6E675472616E73616374696F6E4C6973743E');
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on Oracle resource', 9007, 'text/xml', X'0A20203C46646F4C6F6E675472616E73616374696F6E4C6973743E0A202020203C4C6F6E675472616E73616374696F6E3E0A2020202020203C4465736372697074696F6E3E3C2F4465736372697074696F6E3E0A2020202020203C4E616D653E4C4956453C2F4E616D653E0A2020202020203C4F776E65723E5359533C2F4F776E65723E0A202020203C2F4C6F6E675472616E73616374696F6E3E0A202020203C50726F76696465724E616D653E4175746F6465736B2E4F7261636C652E332E303C2F50726F76696465724E616D653E0A20203C2F46646F4C6F6E675472616E73616374696F6E4C6973743E');
-INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource when the resource data is not set', 9008, 'text/plain', X'6D676170706C69636174696F6E657863657074696F6E');
-INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource when the resource data is not set', 9009, 'text/plain', X'6D676170706C69636174696F6E657863657074696F6E');
+INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource when the resource data is not set', 9008, 'text/plain', 'mgresourcetagnotfoundexception');
+INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource when the resource data is not set', 9009, 'text/plain', 'mgresourcetagnotfoundexception');
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource', 9010, 'text/plain', X'6D67696E76616C69646F7065726174696F6E657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on SDF resource', 9011, 'text/plain', X'6D67696E76616C69646F7065726174696F6E657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('GetLongTransactions on RFP resource when the resource data is not set', 9012, 'text/plain', X'6D677265736F75726365646174616E6F74666F756E64657863657074696F6E');
@@ -1811,7 +1811,7 @@
INSERT INTO "ApiTestResults" VALUES('Clean up operation', 10001, '', '');
INSERT INTO "ApiTestResults" VALUES('TestConnection with blank resource', 10002, 'text/plain', X'6D67696E76616C6964617267756D656E74657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('TestConnection with non existent resource', 10003, 'text/plain', X'6D677265736F757263656E6F74666F756E64657863657074696F6E');
-INSERT INTO "ApiTestResults" VALUES('TestConnection on SDF resource when resource data is not set', 10004, 'text/plain', X'6D676170706C69636174696F6E657863657074696F6E');
+INSERT INTO "ApiTestResults" VALUES('TestConnection on SDF resource when resource data is not set', 10004, 'text/plain', 'mgresourcetagnotfoundexception');
INSERT INTO "ApiTestResults" VALUES('TestConnection on ArcSDE resource', 10005, 'text/plain', '1');
INSERT INTO "ApiTestResults" VALUES('TestConnection on Oracle resource', 10006, 'text/plain', X'54727565');
INSERT INTO "ApiTestResults" VALUES('TestConnection on RFP resource when resource data is not set', 10007, 'text/plain', X'6D677265736F75726365646174616E6F74666F756E64657863657074696F6E');
More information about the mapguide-commits
