[mapguide-commits] r7668 - in branches/2.4/MgDev: Oem/SWIGEx/Lib/csharp Web/src/DotNetUnmanagedApi/Foundation Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom Web/src/MapGuideApi
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jul 8 02:16:56 PDT 2013
Author: jng
Date: 2013-07-08 02:16:56 -0700 (Mon, 08 Jul 2013)
New Revision: 7668
Added:
   branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgResourceTagNotFoundException
   branches/2.4/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg
   branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
   branches/2.4/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
#2315, #2316: Merge r7658 and r7666 to 2.4 branch
Modified: branches/2.4/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg
--- branches/2.4/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg	2013-07-08 09:03:52 UTC (rev 7667)
+++ branches/2.4/MgDev/Oem/SWIGEx/Lib/csharp/csharphead.swg	2013-07-08 09:16:56 UTC (rev 7668)
@@ -81,7 +81,7 @@
             if (type == null)
-                exception = new Exception();
+                exception = new Exception("Exception (" + className + ") was thrown. No .net type could be found for this exception type");
             else
                 exception = Activator.CreateInstance(type, parameters);
Modified: branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
--- branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2013-07-08 09:03:52 UTC (rev 7667)
+++ branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2013-07-08 09:16:56 UTC (rev 7668)
@@ -147,6 +147,7 @@
     <Header path="../../../../Common/Foundation/Exception/PlatformNotSupportedException.h" />
     <Header path="../../../../Common/Foundation/Exception/ResourcesException.h" />
     <Header path="../../../../Common/Foundation/Exception/ResourcesLoadFailedException.h" />
+    <Header path="../../../../Common/Foundation/Exception/ResourceTagNotFoundException.h" />
     <Header path="../../../../Common/Foundation/Exception/RuntimeException.h" />
     <Header path="../../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h" />
     <Header path="../../../../Common/Foundation/Exception/ThirdPartyException.h" />
Added: branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgResourceTagNotFoundException
--- branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgResourceTagNotFoundException	                        (rev 0)
+++ branches/2.4/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationCustom/MgResourceTagNotFoundException	2013-07-08 09:16:56 UTC (rev 7668)
@@ -0,0 +1 @@
+DESERIALIZATION
Modified: branches/2.4/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
--- branches/2.4/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2013-07-08 09:03:52 UTC (rev 7667)
+++ branches/2.4/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2013-07-08 09:16:56 UTC (rev 7668)
@@ -156,6 +156,7 @@
     <Header path="../../../Common/Foundation/Exception/PlatformNotSupportedException.h" />
     <Header path="../../../Common/Foundation/Exception/ResourcesException.h" />
     <Header path="../../../Common/Foundation/Exception/ResourcesLoadFailedException.h" />
+    <Header path="../../../Common/Foundation/Exception/ResourceTagNotFoundException.h" />
     <Header path="../../../Common/Foundation/Exception/RuntimeException.h" />
     <Header path="../../../Common/Foundation/Exception/TemporaryFileNotAvailableException.h" />
     <Header path="../../../Common/Foundation/Exception/ThirdPartyException.h" />
More information about the mapguide-commits mailing list
