[mapguide-commits] r7684 - branches/maestro-4.0.x/Maestro
svn_mapguide at osgeo.org
Tue Jul 9 08:11:53 PDT 2013
Author: jng
Date: 2013-07-09 08:11:52 -0700 (Tue, 09 Jul 2013)
New Revision: 7684
branches/maestro-4.0.x/Maestro/changelog.txt
changelog.txt update
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt 2013-07-09 14:55:32 UTC (rev 7683)
+++ branches/maestro-4.0.x/Maestro/changelog.txt 2013-07-09 15:11:52 UTC (rev 7684)
@@ -1,4 +1,14 @@
- - Fix: Bad image mime types in WMS configuration that could cause MapGuide to throw MgUnclassifiedExceptions
+4.0.6
+ - Added secured credentials support for ODBC Feature Source editor in RawConnectionString mode
+ - New WebLayout now auto-prompts for Map Definition like its Fusion counterpart
+ - Fix: MgCooker not running in batch mode (patch by dcreado)
+ - Fix: MgCooker requesting wrong tiles from server when using override bounds (patch by dcreado)
+ - Fix: Prevent ability to enter duplicate extended feature class names
+ - Fix: Prevent ability to enter duplicate map group name in
+ - Fix: "ResamplingMethod" parameter in GDAL Feature Source editor is optional and its UI should reflect that
+ - Fix: XML content error when working with layers containing composite styles
+ - Fix: Bad image mime types in WMS configuration that could cause MapGuide to throw MgUnclassifiedExceptions
4.0.5
More information about the mapguide-commits
