[mapguide-commits] r7691 - in sandbox/jng/http304: Common/MapGuideCommon/Services Server/src/Services/Tile Server/src/UnitTesting
svn_mapguide at osgeo.org
Thu Jul 18 02:55:09 PDT 2013
Author: jng
Date: 2013-07-18 02:55:09 -0700 (Thu, 18 Jul 2013)
New Revision: 7691
Added:
sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.cpp
sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.h
sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.cpp
sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.h
sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.cpp
sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.h
sandbox/jng/http304/Server/src/Services/Tile/ServerTileService.cpp
sandbox/jng/http304/Server/src/Services/Tile/TileCache.cpp
sandbox/jng/http304/Server/src/UnitTesting/TestMisc.cpp
sandbox/jng/http304/Server/src/UnitTesting/TestMisc.h
This submission includes the following changes:
- We left out the operation classes in ServerTileService
- Fix up MgTile header and use Ptr<> for members
- Use the time_t value (ToTimeValue() instead of ToNumber()) as the basis for cloning stack allocated MgDateTime objects to heap allocated ones.
- Add a MgTile serialization/deserialization unit test.
Modified: sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.cpp
--- sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.cpp 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -33,8 +33,8 @@
MgTile::~MgTile()
- SAFE_RELEASE(m_image);
- SAFE_RELEASE(m_creationDate);
+ m_image = NULL;
+ m_creationDate = NULL;
void MgTile::SetImage(MgByteReader* image)
@@ -54,12 +54,12 @@
MgByteReader* MgTile::GetImage()
- return SAFE_ADDREF(m_image);
+ return SAFE_ADDREF((MgByteReader*)m_image);
MgDateTime* MgTile::GetCreationDate()
- return SAFE_ADDREF(m_creationDate);
+ return SAFE_ADDREF((MgDateTime*)m_creationDate);
void MgTile::Deserialize(MgStream* stream)
Modified: sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.h
--- sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.h 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Common/MapGuideCommon/Services/Tile.h 2013-07-18 09:55:09 UTC (rev 7691)
@@ -36,6 +36,8 @@
void SetCreationDate(MgDateTime* creationDate);
virtual INT32 GetClassId();
+ virtual void Deserialize(MgStream* stream);
+ virtual void Serialize(MgStream* stream);
PUBLISHED_API:
MgByteReader* GetImage();
@@ -48,12 +50,9 @@
delete this;
- void Deserialize(MgStream* stream);
- void Serialize(MgStream* stream);
private:
- MgByteReader* m_image;
- MgDateTime* m_creationDate;
+ Ptr<MgByteReader> m_image;
+ Ptr<MgDateTime> m_creationDate;
CLASS_ID:
static const INT32 m_cls_id = MapGuide_TileService_Tile;
Added: sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.cpp
--- sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.cpp (rev 0)
+++ sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -0,0 +1,162 @@
+// Copyright (C) 2004-2013 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "OpGetTileCreationDate.h"
+#include "LogManager.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpGetTileCreationDate::MgOpGetTileCreationDate()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpGetTileCreationDate::~MgOpGetTileCreationDate()
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetTileCreationDate::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpGetTileCreationDate::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"GetTileCreationDate");
+ MG_TRY()
+ MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+ ACE_ASSERT(m_stream != NULL);
+ if (4 == m_packet.m_NumArguments)
+ Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
+ map->SetDelayedLoadResourceService(m_resourceService);
+ Ptr<MgResourceIdentifier> resource = map->GetResourceId();
+ STRING baseMapLayerGroupName;
+ m_stream->GetString(baseMapLayerGroupName);
+ INT32 tileCol = 0;
+ m_stream->GetInt32(tileCol);
+ INT32 tileRow = 0;
+ m_stream->GetInt32(tileRow);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(baseMapLayerGroupName.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileCol);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileRow);
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ Ptr<MgByteReader> byteReader =
+ m_service->GetTile(map, baseMapLayerGroupName, tileCol, tileRow);
+ EndExecution(byteReader);
+ else if (5 == m_packet.m_NumArguments)
+ Ptr<MgResourceIdentifier> mapDefinition = (MgResourceIdentifier*)m_stream->GetObject();
+ INT32 scale = 0;
+ m_stream->GetInt32(scale);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == mapDefinition) ? L"MgResourceIdentifier" : mapDefinition->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(scale);
+ Validate();
+ m_service->GetTile(mapDefinition, baseMapLayerGroupName, tileCol, tileRow, scale);
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpGetTileCreationDate.Execute",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ // Successful operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+ MG_CATCH(L"MgOpGetTileCreationDate.Execute")
+ if (mgException != NULL)
+ // Failed operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+ // Add access log entry for operation
+ MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
+ MG_THROW()
Added: sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.h
--- sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.h (rev 0)
+++ sandbox/jng/http304/Server/src/Services/Tile/OpGetTileCreationDate.h 2013-07-18 09:55:09 UTC (rev 7691)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_GET_TILE_CREATION_DATE_H
+#define MG_OP_GET_TILE_CREATION_DATE_H
+#include "TileOperation.h"
+class MgOpGetTileCreationDate : public MgTileOperation
+ public:
+ MgOpGetTileCreationDate();
+ virtual ~MgOpGetTileCreationDate();
+ public:
+ virtual void Execute();
+#endif
Added: sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.cpp
--- sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.cpp (rev 0)
+++ sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -0,0 +1,162 @@
+#include "OpGetTileWithCreationDate.h"
+/// <summary>
+/// </summary>
+MgOpGetTileWithCreationDate::MgOpGetTileWithCreationDate()
+/// <summary>
+/// </summary>
+MgOpGetTileWithCreationDate::~MgOpGetTileWithCreationDate()
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetTileWithCreationDate::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpGetTileWithCreationDate::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"GetTileWithCreationDate");
+ MG_TRY()
+ BeginExecution();
+ Validate();
+ Ptr<MgTile> tile =
+ m_service->GetTileWithCreationDate(map, baseMapLayerGroupName, tileCol, tileRow);
+ EndExecution(tile);
+ INT32 scale = 0;
+ BeginExecution();
+ Validate();
+ m_service->GetTileWithCreationDate(mapDefinition, baseMapLayerGroupName, tileCol, tileRow, scale);
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpGetTileWithCreationDate.Execute",
+ MG_CATCH(L"MgOpGetTileWithCreationDate.Execute")
+ MG_THROW()
Added: sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.h
--- sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.h (rev 0)
+++ sandbox/jng/http304/Server/src/Services/Tile/OpGetTileWithCreationDate.h 2013-07-18 09:55:09 UTC (rev 7691)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_GET_TILE_WITH_CREATION_DATE_H
+#define MG_OP_GET_TILE_WITH_CREATION_DATE_H
+class MgOpGetTileWithCreationDate : public MgTileOperation
+ public:
+ MgOpGetTileWithCreationDate();
+ virtual ~MgOpGetTileWithCreationDate();
+ public:
+#endif
Modified: sandbox/jng/http304/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/jng/http304/Server/src/Services/Tile/ServerTileService.cpp 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Server/src/Services/Tile/ServerTileService.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -184,7 +184,7 @@
if (MgFileUtil::IsFile(tilePathname))
MgDateTime cdate = MgFileUtil::GetFileCreationTime(tilePathname);
- ret = new MgDateTime(cdate.ToNumber());
+ ret = new MgDateTime(cdate.ToTimeValue());
MG_CATCH_AND_THROW(L"MgServerTileService.GetTileCreationDate")
@@ -231,7 +231,7 @@
@@ -526,7 +526,7 @@
img->Rewind();
- Ptr<MgDateTime> creationDate = new MgDateTime(cdate.ToNumber());
+ Ptr<MgDateTime> creationDate = new MgDateTime(cdate.ToTimeValue());
tile = new MgTile(img, creationDate);
Modified: sandbox/jng/http304/Server/src/Services/Tile/TileCache.cpp
--- sandbox/jng/http304/Server/src/Services/Tile/TileCache.cpp 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Server/src/Services/Tile/TileCache.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -170,7 +170,7 @@
Ptr<MgByteReader> image = byteSource->GetReader();
- Ptr<MgDateTime> createDate = new MgDateTime(cdate.ToNumber());
+ Ptr<MgDateTime> createDate = new MgDateTime(cdate.ToTimeValue());
ret = new MgTile(image, createDate);
Modified: sandbox/jng/http304/Server/src/UnitTesting/TestMisc.cpp
--- sandbox/jng/http304/Server/src/UnitTesting/TestMisc.cpp 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Server/src/UnitTesting/TestMisc.cpp 2013-07-18 09:55:09 UTC (rev 7691)
@@ -573,4 +573,47 @@
throw;
+void TestMisc::TestCase_MgTileSerializable()
+ try
+ std::string str = "Test Image";
+ Ptr<MgByteReader> image;
+ Ptr<MgByteSource> source = new MgByteSource((BYTE_ARRAY_IN)str.c_str(), (INT32)str.length());
+ //MgTile is just a container for a MgByteReader, it doesn't care about the underlying content.
+ image = source->GetReader();
+ Ptr<MgDateTime> createDate = new MgDateTime();
+ Ptr<MgTile> tile = new MgTile(image, createDate);
+ Ptr<MgMemoryStreamHelper> helper = new MgMemoryStreamHelper();
+ Ptr<MgStream> stream = new MgStream(helper);
+ tile->Serialize(stream);
+ Ptr<MgTile> tile2 = new MgTile();
+ tile2->Deserialize(stream);
+ Ptr<MgDateTime> dt1 = tile->GetCreationDate();
+ Ptr<MgDateTime> dt2 = tile2->GetCreationDate();
+ CPPUNIT_ASSERT(NULL != dt1.p);
+ CPPUNIT_ASSERT(NULL != dt2.p);
+ CPPUNIT_ASSERT(*(dt1.p) == *(dt2.p));
+ Ptr<MgByteReader> br1 = tile->GetImage();
+ STRING str1 = br1->ToString();
+ Ptr<MgByteReader> br2 = tile2->GetImage();
+ STRING str2 = br2->ToString();
+ CPPUNIT_ASSERT(str1 == str2);
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
\ No newline at end of file
Modified: sandbox/jng/http304/Server/src/UnitTesting/TestMisc.h
--- sandbox/jng/http304/Server/src/UnitTesting/TestMisc.h 2013-07-16 14:14:16 UTC (rev 7690)
+++ sandbox/jng/http304/Server/src/UnitTesting/TestMisc.h 2013-07-18 09:55:09 UTC (rev 7691)
@@ -30,6 +30,7 @@
CPPUNIT_TEST(TestCase_1304);
CPPUNIT_TEST(TestCase_MapLayerCollections);
CPPUNIT_TEST(TestCase_Rfc1123Dates);
+ CPPUNIT_TEST(TestCase_MgTileSerializable);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -48,6 +49,7 @@
void TestCase_1304();
void TestCase_MapLayerCollections();
void TestCase_Rfc1123Dates();
+ void TestCase_MgTileSerializable();
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
