[mapguide-commits] r7694 - in trunk/Tools/Maestro/UserDoc/source: . images
svn_mapguide at osgeo.org
Sat Jul 20 22:08:35 PDT 2013
Author: jng
Date: 2013-07-20 22:08:34 -0700 (Sat, 20 Jul 2013)
New Revision: 7694
Added:
trunk/Tools/Maestro/UserDoc/source/images/ironpython_runfile.PNG
trunk/Tools/Maestro/UserDoc/source/scripting_and_automating_maestro.rst
trunk/Tools/Maestro/UserDoc/source/index.rst
trunk/Tools/Maestro/UserDoc/source/local_connection_mode.rst
trunk/Tools/Maestro/UserDoc/source/user_interface.rst
Document the IronPython console feature and fix up some bad RST syntax
Added: trunk/Tools/Maestro/UserDoc/source/images/ironpython_runfile.PNG
(Binary files differ)
Property changes on: trunk/Tools/Maestro/UserDoc/source/images/ironpython_runfile.PNG
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/UserDoc/source/index.rst
--- trunk/Tools/Maestro/UserDoc/source/index.rst 2013-07-19 07:52:31 UTC (rev 7693)
+++ trunk/Tools/Maestro/UserDoc/source/index.rst 2013-07-21 05:08:34 UTC (rev 7694)
@@ -36,6 +36,7 @@
mgcooker
localpreview
+ scripting_and_automating_maestro
other_tools
other_resources
Modified: trunk/Tools/Maestro/UserDoc/source/local_connection_mode.rst
--- trunk/Tools/Maestro/UserDoc/source/local_connection_mode.rst 2013-07-19 07:52:31 UTC (rev 7693)
+++ trunk/Tools/Maestro/UserDoc/source/local_connection_mode.rst 2013-07-21 05:08:34 UTC (rev 7694)
@@ -22,7 +22,7 @@
.. figure:: images/connect_local.png
- * Connecting to the local repository *
+ *Connecting to the local repository*
For the **Platform Configuration File**, select the **Platform.ini** file in the Maestro installation directory. Then click **OK** to connect to your local repository.
Added: trunk/Tools/Maestro/UserDoc/source/scripting_and_automating_maestro.rst
--- trunk/Tools/Maestro/UserDoc/source/scripting_and_automating_maestro.rst (rev 0)
+++ trunk/Tools/Maestro/UserDoc/source/scripting_and_automating_maestro.rst 2013-07-21 05:08:34 UTC (rev 7694)
@@ -0,0 +1,135 @@
+.. _scripting-and-automating-maestro:
+Scripting and Automating Maestro
+.. note::
+ The IronPython Console feature is only available on Windows and is only bundled with the Windows installer package of Maestro
+As mentioned in the section (:ref:`user-interface`), Maestro includes a **IronPython Console** which provides the user an interactive scripting environment to drive and automate certain parts of the Maestro application with IronPython code
+About IronPython
+IronPython is an open source implementation of the Python programming language which is tightly integrated with the .net Framework. IronPython can use the .net Framework and Python libraries and also allows for .net applications to easily use Python code.
+Maestro embeds an IronPython scripting engine allowing for easy scripting and automation of the application by users.
+For more information about the .net specific details of IronPython, `click here <http://www.ironpython.net/documentation/dotnet/>`_
+The Host Application
+The IronPython Console exposes a top-level global object named `app`, which represents the Maestro Host Application. The Host Application provides the following services:
+ * Displaying messages/questions in a dialog box
+ * Displaying file pickers for file selection
+ * Obtaining `IServerConnection` references
+ * Convenience methods to fetch/set resource XML content by their resource id
+ * A UI-thread invoker for running UI interaction code from a background thread
+The `IServerConnection` interface represents the top-level interface of the Maestro API and is the gateway into most of the functionality that is offered by the Maestro API
+For more information about the `IServerConnection` interface, consult the Maestro API documentation which is included with the `Maestro SDK <http://trac.osgeo.org/mapguide/wiki/maestro/Downloads>`_
+You can bring up documentation of any object or function with the `help` command. For example, to describe the structure of our global Host Application:
+.. highlight:: Python
+.. code-block:: Python
+ >>> help(app)
+ ?Help on HostApplication in module __builtin__
+ | A simplified helper class that is exposed to python scripts to provide
+ | convenience functionality or to workaround concepts that don't cleanly
+ | translate to IronPython (eg. Generics)
+ | HostApplication()
+ | Data and other attributes defined here:
+ | AskQuestion(...)
+ | AskQuestion(self: HostApplication, title: str, question: str) -> bool
+ | Prompts for a question that requires a boolean response
+ | GetConnection(...)
+ | GetConnection(self: HostApplication, name: str) -> IServerConnection
+ | Gets the connection by its specified name
+ | GetConnectionNames(...)
+ | GetConnectionNames(self: HostApplication) -> Array[str]
+ | Returns a list of the names of all currently open connections
+ | GetResourceXml(...)
+ | GetResourceXml(self: HostApplication, conn: IServerConnection, resourceId: str) -> str
+ | Gets the XML content of the given resource id
+ | OpenEditor(...)
+ | OpenEditor(self: HostApplication, conn: IServerConnection, resourceId: str)
+ | Opens the default editor for the specified resource
+ | OpenUrl(...)
+ | OpenUrl(self: HostApplication, url: str)
+ | Launches the specified url
+ | PickFolder(...)
+ | PickFolder(self: HostApplication, conn: IServerConnection) -> str
+ | Prompts a dialog to select a folder
+ | PickResourceOpen(...)
+ | PickResourceOpen(self: HostApplication, conn: IServerConnection, resourceType: str) -> str
+ | Displays a resource picker for opening
+ | PickResourceSave(...)
+ | PickResourceSave(self: HostApplication, conn: IServerConnection, resourceType: str) -> str
+ | Displays a resource picker for saving
+ | PreviewResource(...)
+ | PreviewResource(self: HostApplication, conn: IServerConnection, resourceId: str, locale: str)
+ | Launches a preview of the given open resource
+ | SetResourceXml(...)
+ | SetResourceXml(self: HostApplication, conn: IServerConnection, resourceId: str, xml: str)
+ | Sets the XML content of the given resource id
+ | ShowError(...)
+ | ShowError(self: HostApplication, ex: Exception)
+ | Displays an exception in a dialog
+ | ShowMessage(...)
+ | ShowMessage(self: HostApplication, title: str, message: str)
+ | Displays a message
+ | UIInvoke(...)
+ | UIInvoke(self: HostApplication, method: Delegate)
+ | Invokes the specified method on the UI thread. Methods that interact with the
+ | UI or create UI components
+ | must be done on this thread
+ | __repr__(...)
+ | __repr__(self: object) -> str
+Loading scripts
+The IronPython console also supports loading pre-defined scripts. Click **Run File** and select the python script you want to load.
+.. figure:: images/ironpython_runfile.png
+All classes and functions defined in that python script will be loaded into the console's global namespace.
+Example scripts
+You can find some example scripts `here <http://trac.osgeo.org/mapguide/wiki/CodeSamples/Other/MaestroScripts>`_ which may give you some ideas as to what you can do through scripting and automation with IronPython
\ No newline at end of file
Modified: trunk/Tools/Maestro/UserDoc/source/user_interface.rst
--- trunk/Tools/Maestro/UserDoc/source/user_interface.rst 2013-07-19 07:52:31 UTC (rev 7693)
+++ trunk/Tools/Maestro/UserDoc/source/user_interface.rst 2013-07-21 05:08:34 UTC (rev 7694)
@@ -1,3 +1,5 @@
+.. _user-interface:
The Maestro User Interface
@@ -24,8 +26,12 @@
The **IronPython Console** provides the user with an interactive REPL console, by which the user can run and evaluate snippets of IronPython code. The full Maestro API is
exposed to the console, allowing the user to script and automate the application through IronPython code. IronPython is a dialect of Python geared towards integration with
-the .net Framework. For more information about IronPython, see `IronPython.net <http://ironpython.net/>`_
+the .net Framework. For more information about this feature, see :ref:`scripting-and-automating-maestro`. For more information about IronPython, see `IronPython.net <http://ironpython.net/>`_
+.. note::
The **Resource ID bar** functions like an address bar in a web browser. Entering a Resource ID in the **Resource ID bar** and clicking `Go` will allow you to directly open
the specified resource for editing. Similarly, selecting an open editor tab will show you the Resource ID of the resource being edited. This is a feature that power users
will appreciate, as it allows for quick resource access without the need to navigate the repository in the **Site Explorer** to find it.
More information about the mapguide-commits
