[mapguide-commits] r7555 - in sandbox/jng/createruntimemap: Common/Schema Server/src/Services/Mapping
svn_mapguide at osgeo.org
Mon Jun 3 03:18:35 PDT 2013
Author: jng
Date: 2013-06-03 03:18:35 -0700 (Mon, 03 Jun 2013)
New Revision: 7555
sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd
sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp
One last change for RFC 134: Include the Display DPI in the CreateRuntimeMap response.
Modified: sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd
--- sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd 2013-06-03 05:37:45 UTC (rev 7554)
+++ sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd 2013-06-03 10:18:35 UTC (rev 7555)
@@ -26,6 +26,11 @@
<xs:documentation>The map's background color in ARGB hex string format</xs:documentation>
</xs:annotation>
</xs:element>
+ <xs:element name="DisplayDpi" type="xs:integer">
+ <xs:annotation>
+ <xs:documentation>The number of dots per inch of the map display</xs:documentation>
+ </xs:annotation>
+ </xs:element>
<xs:element name="IconMimeType" type="xs:string" minOccurs="0">
<xs:annotation>
<xs:documentation>The mime type of all inline icons</xs:documentation>
Modified: sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp 2013-06-03 05:37:45 UTC (rev 7554)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp 2013-06-03 10:18:35 UTC (rev 7555)
@@ -1942,7 +1942,13 @@
// ------------------------------ Background Color ---------------------------------- //
xml.append("<BackgroundColor>");
xml.append(MgUtil::WideCharToMultiByte(map->GetBackgroundColor()));
- xml.append("</BackgroundColor>");
+ xml.append("</BackgroundColor>\n");
+ // ------------------------------ Display DPI --------------------------------------- //
+ xml.append("<DisplayDpi>");
+ std::string sDpi;
+ MgUtil::Int32ToString(map->GetDisplayDpi(), sDpi);
+ xml.append(sDpi);
+ xml.append("</DisplayDpi>\n");
// ------------------------------ Icon Image Format --------------------------------- //
if ((requestedFeatures & REQUEST_LAYER_ICONS) == REQUEST_LAYER_ICONS)
@@ -1953,7 +1959,7 @@
xml.append(MgUtil::WideCharToMultiByte(MgMimeType::Jpeg));
else if (iconFormat == MgImageFormats::Png || iconFormat == MgImageFormats::Png8)
xml.append(MgUtil::WideCharToMultiByte(MgMimeType::Png));
- xml.append("</IconMimeType>");
+ xml.append("</IconMimeType>\n");
// ------------------------------ Coordinate System --------------------------------- //
xml.append("<CoordinateSystem>\n");
More information about the mapguide-commits
