[mapguide-commits] r7558 - in trunk/Tools/JenkinsCI/home/slave_win/jobs: MapGuide Open Source x64 MapGuide Open Source x86
svn_mapguide at osgeo.org
Tue Jun 4 06:15:37 PDT 2013
Author: jng
Date: 2013-06-04 06:15:37 -0700 (Tue, 04 Jun 2013)
New Revision: 7558
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
#2210: Re-order the SVN revision recording step to avoid potential file locking issues on the SVN working copy.
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml 2013-06-04 10:26:33 UTC (rev 7557)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml 2013-06-04 13:15:37 UTC (rev 7558)
@@ -104,6 +104,13 @@
echo [prepare]: Cleaning out build artifacts
if exist %MG_BUILD_OUTPUT64% rd /S /Q %MG_BUILD_OUTPUT64%
+pushd %MG_BUILD_SRC64%\MgDev
+echo [prepare]: Noting SVN revision
+svn info . | perl %REVNUM_FILE64% > revision.txt
+set /p MG_REVISION64= < revision.txt
+copy /Y revision.txt %MG_STAMP_FILE64%
+popd
if "%CLEAR_WORKING_AREA%"=="false" (
echo [prepare]: Skip cleaning build area
goto build_mapguide
@@ -165,12 +172,6 @@
echo Updated - %MG_BUILD_AREA64%\Installer\build64.bat
:build_mapguide
-cd %MG_BUILD_SRC64%\MgDev
-echo [prepare]: Noting SVN revision
-svn info . | perl %REVNUM_FILE64% > revision.txt
-set /p MG_REVISION64= < revision.txt
-copy /Y revision.txt %MG_STAMP_FILE64%
cd %MG_BUILD_AREA64%\MgDev
echo [build]: Stamp version numbers
SET BUILD_ACTION=Stamp version numbers
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml 2013-06-04 10:26:33 UTC (rev 7557)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml 2013-06-04 13:15:37 UTC (rev 7558)
if exist %MG_BUILD_OUTPUT% rd /S /Q %MG_BUILD_OUTPUT%
+pushd %MG_BUILD_SRC%\MgDev
+svn info . | perl %REVNUM_FILE% > revision.txt
+set /p MG_REVISION= < revision.txt
+copy /Y revision.txt %MG_STAMP_FILE%
+popd
goto build_mapguide
REM echo Updated - %MG_BUILD_AREA%\Installer\build64.bat
:build_mapguide
-cd %MG_BUILD_SRC%\MgDev
-svn info . | perl %REVNUM_FILE% > revision.txt
-set /p MG_REVISION= < revision.txt
-copy /Y revision.txt %MG_STAMP_FILE%
cd %MG_BUILD_AREA%\MgDev
More information about the mapguide-commits
