[mapguide-commits] r7570 - branches/2.5/MgDev/Server/src/Services/Mapping
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jun 6 08:15:16 PDT 2013
Author: jng
Date: 2013-06-06 08:15:15 -0700 (Thu, 06 Jun 2013)
New Revision: 7570
   branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
   branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.h
   branches/2.5/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
#2270: And here's the fix
Modified: branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2013-06-06 15:13:31 UTC (rev 7569)
+++ branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2013-06-06 15:15:15 UTC (rev 7570)
@@ -1200,7 +1200,8 @@
                                      MdfModel::FeatureTypeStyle* fts,
                                      INT32 imgWidth,
                                      INT32 imgHeight,
-                                     INT32 themeCategory)
+                                     INT32 themeCategory,
+                                     CREFSTRING format)
     if (!fts)
         return NULL;
@@ -1218,9 +1219,6 @@
     // draw the preview
     StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman);
-    // TODO: use user-specified format
-    RS_String format = L"PNG";
     auto_ptr<RS_ByteData> data;
     data.reset(er.Save(format, imgWidth, imgHeight));
@@ -1228,8 +1226,14 @@
         // put this into a byte source
         Ptr<MgByteSource> bs = new MgByteSource(data->GetBytes(), data->GetNumBytes());
-        bs->SetMimeType(MgMimeType::Png);
+        if (format == MgImageFormats::Gif)
+            bs->SetMimeType(MgMimeType::Gif);
+        else if (format == MgImageFormats::Jpeg)
+            bs->SetMimeType(MgMimeType::Jpeg);
+        else if (format == MgImageFormats::Png || format == MgImageFormats::Png8)
+            bs->SetMimeType(MgMimeType::Png);
         return bs->GetReader();
Modified: branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.h
--- branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.h	2013-06-06 15:13:31 UTC (rev 7569)
+++ branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.h	2013-06-06 15:15:15 UTC (rev 7570)
@@ -86,7 +86,7 @@
     static MdfModel::MapDefinition* GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
-    static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory);
+    static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory, CREFSTRING format = L"PNG");
     static double ComputeStylizationOffset(MgMap* map, MdfModel::VectorScaleRange* scaleRange, double scale);
     static MgEnvelope* TransformExtent(MgEnvelope* extent, MgCoordinateSystemTransform* xform);
Modified: branches/2.5/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- branches/2.5/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp	2013-06-06 15:13:31 UTC (rev 7569)
+++ branches/2.5/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp	2013-06-06 15:15:15 UTC (rev 7570)
@@ -1671,7 +1671,7 @@
             if (fts)
-                byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory);
+                byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory, format);
             else
                 //return the fixed array
More information about the mapguide-commits mailing list
