[mapguide-commits] r7586 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Sun Jun 9 06:23:35 PDT 2013
Author: jng
Date: 2013-06-09 06:23:35 -0700 (Sun, 09 Jun 2013)
New Revision: 7586
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
Copy entire updated MgLegendControlPresenter back to 2.4, this includes the fix for #2288 and the fixes for draw ordering and infinite loops.
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-06-09 13:17:13 UTC (rev 7585)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-06-09 13:23:35 UTC (rev 7586)
@@ -352,12 +352,12 @@
public TreeNode[] CreateNodes()
- List<TreeNode> output = new List<TreeNode>();
- var nodesById = new Dictionary<string, TreeNode>();
+ List<TreeNode> topLevelNodes = new List<TreeNode>();
var scale = _map.ViewScale;
if (scale < 10.0)
- return output.ToArray();
+ return topLevelNodes.ToArray();
+ var nodesById = new Dictionary<string, TreeNode>();
+ var groupsById = new Dictionary<string, TreeNode>();
var groups = _map.GetLayerGroups();
var layers = _map.GetLayers();
@@ -372,7 +372,7 @@
if (!group.GetDisplayInLegend())
continue;
- //Add ones without parents first.
+ //Add ones without parents first. Queue up child groups
if (group.Group != null)
remainingNodes.Add(group);
@@ -380,22 +380,32 @@
else
var node = CreateGroupNode(group);
- output.Add(node);
+ topLevelNodes.Add(node);
nodesById.Add(group.GetObjectId(), node);
+ groupsById.Add(group.GetObjectId(), node);
+ //Process child groups
while (remainingNodes.Count > 0)
List<MgLayerGroup> toRemove = new List<MgLayerGroup>();
+ //Establish parent-child relationship for any child groups here
for (int j = 0; j < remainingNodes.Count; j++)
var parentId = remainingNodes[j].Group.GetObjectId();
if (nodesById.ContainsKey(parentId))
- var node = CreateGroupNode(remainingNodes[j]);
+ MgLayerGroup grp = remainingNodes[j];
+ var node = CreateGroupNode(grp);
nodesById[parentId].Nodes.Add(node);
- toRemove.Add(remainingNodes[j]);
+ //Got to add this group node too, otherwise we could infinite
+ //loop looking for a parent that's not registered
+ nodesById.Add(grp.GetObjectId(), node);
+ groupsById.Add(grp.GetObjectId(), node);
+ toRemove.Add(grp);
//Whittle down this list
@@ -414,7 +424,8 @@
var layerMetaNodesToUpdate = new Dictionary<string, MgLayerBase>();
//Now process layers. Layers without metadata nodes or without layer definition content
//are added to the list
- for (int i = 0; i < layers.GetCount(); i++)
+ int layerCount = layers.GetCount();
+ for (int i = 0; i < layerCount; i++)
var lyr = layers.GetItem(i);
bool display = lyr.DisplayInLegend;
@@ -425,30 +436,34 @@
if (!visible)
continue;
- if (_layers.ContainsKey(lyr.GetObjectId()))
+ var lyrObjId = lyr.GetObjectId();
+ if (_layers.ContainsKey(lyrObjId))
- if (string.IsNullOrEmpty(_layers[lyr.GetObjectId()].LayerDefinitionContent))
+ if (string.IsNullOrEmpty(_layers[lyrObjId].LayerDefinitionContent))
var ldfId = lyr.LayerDefinition;
- layerIds.Add(ldfId.ToString());
- layerMetaNodesToUpdate[ldfId.ToString()] = lyr;
+ var ldfIdStr = ldfId.ToString();
+ layerIds.Add(ldfIdStr);
+ layerMetaNodesToUpdate[ldfIdStr] = lyr;
else
- if (layerIds.GetCount() > 0)
+ int layerIdCount = layerIds.GetCount();
+ if (layerIdCount > 0)
int added = 0;
int updated = 0;
//Fetch the contents and create/update the required layer metadata nodes
MgStringCollection layerContents = _resSvc.GetResourceContents(layerIds, null);
- for (int i = 0; i < layerIds.GetCount(); i++)
+ for (int i = 0; i < layerIdCount; i++)
string lid = layerIds.GetItem(i);
var lyr = layerMetaNodesToUpdate[lid];
@@ -470,11 +485,16 @@
Trace.TraceInformation("CreateNodes: {0} layer contents added, {1} layer contents updated", added, updated); //NOXLATE
+ //Now create our layer nodes
List<MgLayerBase> remainingLayers = new List<MgLayerBase>();
+ //NOTE: We're taking a page out of the Fusion playbook of reverse iterating the layer
+ //collection and prepending the nodes, as this control suffered the same problem as the
+ //Legend widget in Fusion. Doing it this way eliminates the need for doing an extra pass to fix
+ //the layer/group ordering, which may make an impact on really chunky maps.
+ for (int i = layerCount - 1; i >= 0; i--)
var layer = layers.GetItem(i);
bool display = layer.DisplayInLegend;
bool visible = _provider.IsLayerPotentiallyVisibleAtScale(layer, false);
if (!display)
@@ -493,7 +513,7 @@
var node = CreateLayerNode(layer);
if (node != null)
- output.Add(node);
+ topLevelNodes.Insert(0, node);
nodesById.Add(layer.GetObjectId(), node);
if (layer.ExpandInLegend)
node.Expand();
@@ -504,7 +524,7 @@
while (remainingLayers.Count > 0)
List<MgLayerBase> toRemove = new List<MgLayerBase>();
- for (int j = 0; j < remainingLayers.Count; j++)
+ for (int j = remainingLayers.Count - 1; j >= 0; j--)
var parentGroup = remainingLayers[j].Group;
var parentId = parentGroup.GetObjectId();
@@ -513,13 +533,13 @@
var node = CreateLayerNode(remainingLayers[j]);
if (node != null)
- nodesById[parentId].Nodes.Add(node);
+ nodesById[parentId].Nodes.Insert(0, node);
if (remainingLayers[j].ExpandInLegend)
node.Expand();
toRemove.Add(remainingLayers[j]);
- else //Check parent group visibility. Could explain it
+ else
if (!parentGroup.GetDisplayInLegend())
@@ -549,7 +569,7 @@
Trace.TraceInformation("{0} calls made to GenerateLegendImage", legendCallCount); //NOXLATE
private static bool IsThemeLayerNode(TreeNode node)
@@ -868,7 +888,7 @@
base.IsGroup = false;
this.Layer = layer;
- this.Checkable = (layer.Group != null && layer.Group.LayerGroupType == MgLayerGroupType.Normal);
+ this.Checkable = (layer.LayerType != MgLayerType.BaseMap);
this.IsSelectable = (layer != null) ? layer.Selectable : false;
this.DrawSelectabilityIcon = (layer != null && bInitiallySelectable);
this.WasInitiallySelectable = bInitiallySelectable;
@@ -1069,4 +1089,4 @@
\ No newline at end of file
More information about the mapguide-commits
