[mapguide-commits] r7588 - in branches/2.4/MgDev: . Common/Stylization Server/src/Services/Feature Server/src/Services/Mapping Server/src/UnitTesting Web/src/mapadmin/HelpDocs Web/src/mapviewerphp Web/src/viewerfiles
svn_mapguide at osgeo.org
Sun Jun 9 07:39:49 PDT 2013
Author: jng
Date: 2013-06-09 07:39:48 -0700 (Sun, 09 Jun 2013)
New Revision: 7588
branches/2.4/MgDev/
branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp
branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.h
branches/2.4/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.cpp
branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.h
branches/2.4/MgDev/Web/src/mapadmin/HelpDocs/
branches/2.4/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
branches/2.4/MgDev/Web/src/viewerfiles/
branches/2.4/MgDev/Web/src/viewerfiles/quickplot.js
#2270: Backport to 2.4
Property changes on: branches/2.4/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/rfc94:5099-5163
/trunk/MgDev:6611,6690,6746,7230-7231
+ /branches/2.5/MgDev:7569-7570
Property changes on: branches/2.4/MgDev/Common/Stylization/SE_Renderer.cpp
- /sandbox/adsk/2.4j/Common/Stylization/SE_Renderer.cpp:6327-6445
/sandbox/rfc94/Common/Stylization/SE_Renderer.cpp:5099-5163
/trunk/MgDev/Common/Stylization/SE_Renderer.cpp:6250-6326,6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Common/Stylization/SE_Renderer.cpp:7569-7570
Property changes on: branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp
- /sandbox/adsk/2.4j/Server/src/Services/Feature/ServerFeatureUtil.cpp:6327-6481
/sandbox/rfc94/Server/src/Services/Feature/ServerFeatureUtil.cpp:5099-5163
/trunk/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp:6250-6326,6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Server/src/Services/Feature/ServerFeatureUtil.cpp:7569-7570
Modified: branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2013-06-09 13:45:16 UTC (rev 7587)
+++ branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2013-06-09 14:39:48 UTC (rev 7588)
@@ -1189,7 +1189,8 @@
MdfModel::FeatureTypeStyle* fts,
INT32 imgWidth,
INT32 imgHeight,
- INT32 themeCategory)
+ INT32 themeCategory,
+ CREFSTRING format)
if (!fts)
return NULL;
@@ -1207,9 +1208,6 @@
// draw the preview
StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman);
- // TODO: use user-specified format
- RS_String format = L"PNG";
auto_ptr<RS_ByteData> data;
data.reset(er.Save(format, imgWidth, imgHeight));
@@ -1217,8 +1215,14 @@
// put this into a byte source
Ptr<MgByteSource> bs = new MgByteSource(data->GetBytes(), data->GetNumBytes());
- bs->SetMimeType(MgMimeType::Png);
+ if (format == MgImageFormats::Gif)
+ bs->SetMimeType(MgMimeType::Gif);
+ else if (format == MgImageFormats::Jpeg)
+ bs->SetMimeType(MgMimeType::Jpeg);
+ else if (format == MgImageFormats::Png || format == MgImageFormats::Png8)
+ bs->SetMimeType(MgMimeType::Png);
return bs->GetReader();
Property changes on: branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
- /sandbox/adsk/2.4j/Server/src/Services/Mapping/MappingUtil.cpp:6327-6535
/sandbox/rfc94/Server/src/Services/Mapping/MappingUtil.cpp:5099-5163
/trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp:6250-6326,6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Server/src/Services/Mapping/MappingUtil.cpp:7569-7570
Modified: branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.h
--- branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.h 2013-06-09 13:45:16 UTC (rev 7587)
+++ branches/2.4/MgDev/Server/src/Services/Mapping/MappingUtil.h 2013-06-09 14:39:48 UTC (rev 7588)
@@ -86,7 +86,7 @@
static MdfModel::MapDefinition* GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
- static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory);
+ static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory, CREFSTRING format = L"PNG");
static double ComputeStylizationOffset(MgMap* map, MdfModel::VectorScaleRange* scaleRange, double scale);
static MgEnvelope* TransformExtent(MgEnvelope* extent, MgCoordinateSystemTransform* xform);
Modified: branches/2.4/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- branches/2.4/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2013-06-09 13:45:16 UTC (rev 7587)
+++ branches/2.4/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2013-06-09 14:39:48 UTC (rev 7588)
@@ -1671,7 +1671,7 @@
if (fts)
- byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory);
+ byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory, format);
else
//return the fixed array
Modified: branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.cpp
--- branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2013-06-09 13:45:16 UTC (rev 7587)
+++ branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2013-06-09 14:39:48 UTC (rev 7588)
@@ -647,7 +647,39 @@
+void TestMappingService::TestCase_GetLegendImage()
+ try
+ Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgByteReader> rdr = m_svcMapping->GenerateLegendImage(ldf, 10000.0, 16, 16, MgImageFormats::Png, 3, 0);
+ Ptr<MgByteSink> sink = new MgByteSink(rdr);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImage_Parcels_16x16_PNG.png");
+ rdr = m_svcMapping->GenerateLegendImage(ldf, 10000.0, 16, 16, MgImageFormats::Png8, 3, 0);
+ sink = new MgByteSink(rdr);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImage_Parcels_16x16_PNG8.png");
+ rdr = m_svcMapping->GenerateLegendImage(ldf, 10000.0, 16, 16, MgImageFormats::Jpeg, 3, 0);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImage_Parcels_16x16_JPG.jpg");
+ rdr = m_svcMapping->GenerateLegendImage(ldf, 10000.0, 16, 16, MgImageFormats::Gif, 3, 0);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImage_Parcels_16x16_GIF.gif");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestMappingService::TestCase_GetLegendImagePointStyleWithConstRotations()
try
Modified: branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.h
--- branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.h 2013-06-09 13:45:16 UTC (rev 7587)
+++ branches/2.4/MgDev/Server/src/UnitTesting/TestMappingService.h 2013-06-09 14:39:48 UTC (rev 7588)
@@ -34,6 +34,7 @@
CPPUNIT_TEST(TestCase_GetPlotUsingExtents);
CPPUNIT_TEST(TestCase_GetPlotUsingExtentsAndExpandToFit);
CPPUNIT_TEST(TestCase_GetLegendPlot);
+ CPPUNIT_TEST(TestCase_GetLegendImage);
CPPUNIT_TEST(TestCase_GetLegendImagePointStyleWithConstRotations);
//CPPUNIT_TEST(TestCase_QueryFeaturesImageMap);
@@ -60,6 +61,7 @@
void TestCase_GetPlotUsingExtents();
void TestCase_GetPlotUsingExtentsAndExpandToFit();
void TestCase_GetLegendPlot();
+ void TestCase_GetLegendImage();
void TestCase_GetLegendImagePointStyleWithConstRotations();
void TestCase_QueryFeaturesImageMap();
Property changes on: branches/2.4/MgDev/Web/src/mapadmin/HelpDocs
- /sandbox/adsk/2.4j/Web/src/mapadmin/HelpDocs:6413
/sandbox/rfc94/Web/src/mapadmin/HelpDocs:5099-5163
/trunk/MgDev/Web/src/mapadmin/HelpDocs:6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Web/src/mapadmin/HelpDocs:7569-7570
Property changes on: branches/2.4/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm
- /sandbox/adsk/2.4j/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6327-6435
/sandbox/rfc94/Web/src/mapadmin/HelpDocs/configuring_servers.htm:5099-5163
/trunk/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:6250-6326,6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Web/src/mapadmin/HelpDocs/configuring_servers.htm:7569-7570
Property changes on: branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
- /sandbox/adsk/2.4jbeta2/Web/src/mapviewerphp/quickplotgeneratepicture.php:6334-6374
/sandbox/rfc94/Web/src/mapviewerphp/quickplotgeneratepicture.php:5099-5163
/trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:7569-7570
Property changes on: branches/2.4/MgDev/Web/src/viewerfiles
- /sandbox/adsk/2.2gp/Web/src/viewerfiles:5392
/trunk/MgDev/Web/src/viewerfiles:6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Web/src/viewerfiles:7569-7570
Property changes on: branches/2.4/MgDev/Web/src/viewerfiles/quickplot.js
- /sandbox/adsk/2.2gp/Web/src/viewerfiles/quickplot.js:5392
/sandbox/adsk/2.4j/Web/src/viewerfiles/quickplot.js:6327-6474
/trunk/MgDev/Web/src/viewerfiles/quickplot.js:6250-6326,6611,6690,6746,7230-7231
+ /branches/2.5/MgDev/Web/src/viewerfiles/quickplot.js:7569-7570
More information about the mapguide-commits
