[mapguide-commits] r7593 - trunk/MgDev/Desktop/MgDesktop/Services/Feature/Commands
svn_mapguide at osgeo.org
Sun Jun 9 09:01:40 PDT 2013
Author: jng
Date: 2013-06-09 09:01:40 -0700 (Sun, 09 Jun 2013)
New Revision: 7593
trunk/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp
mg-desktop: Port r7574 to trunk
Modified: trunk/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp
--- trunk/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp 2013-06-09 15:43:05 UTC (rev 7592)
+++ trunk/MgDev/Desktop/MgDesktop/Services/Feature/Commands/DescribeSchema.cpp 2013-06-09 16:01:40 UTC (rev 7593)
@@ -1264,7 +1264,7 @@
bool MgdDescribeSchema::IsClassNameHintUsed(FdoIDescribeSchema* fdoCommand)
- CHECKNULL(fdoCommand, L"MgdDescribeSchema.IsClassNameHintUsed");
+ CHECKARGUMENTNULL(fdoCommand, L"MgdDescribeSchema.IsClassNameHintUsed");
FdoPtr<FdoStringCollection> classNames = fdoCommand->GetClassNames();
bool classNameHintUsed = (NULL != classNames.p);
@@ -1275,7 +1275,7 @@
MgStringCollection* MgdDescribeSchema::GetSchemaNames(MgFeatureSchemaCollection* schemas)
- CHECKNULL(schemas, L"MgdDescribeSchema.GetSchemaNames");
+ CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetSchemaNames");
Ptr<MgStringCollection> schemaNames = new MgStringCollection();
INT32 schemaCount = schemas->GetCount();
@@ -1336,7 +1336,7 @@
MgClassDefinition* MgdDescribeSchema::GetClassDefinition(MgFeatureSchemaCollection* schemas, CREFSTRING schemaName, CREFSTRING className)
- CHECKNULL(schemas, L"MgdDescribeSchema.GetClassDefinition");
+ CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetClassDefinition");
Ptr<MgClassDefinition> classDef;
@@ -1390,9 +1390,12 @@
FdoFeatureSchemaCollection* schemas, MgResourceIdentifier* resource,
- CHECKNULL(schemas, L"MgdDescribeSchema.GetIdentityProperties");
+ CHECKARGUMENTNULL(schemas, L"MgdDescribeSchema.GetIdentityProperties");
+ CHECKARGUMENTNULL(resource, L"MgdDescribeSchema.GetIdentityProperties");
+ Ptr<MgPropertyDefinitionCollection> idProps;
- Ptr<MgPropertyDefinitionCollection> idProps = new MgPropertyDefinitionCollection();
+ MG_FEATURE_SERVICE_TRY()
+ idProps = new MgPropertyDefinitionCollection();
// There should be at least one schema for the primary feature source.
@@ -1453,6 +1456,31 @@
+ MG_FEATURE_SERVICE_CATCH_WITH_FEATURE_SOURCE(L"MgdDescribeSchema.GetIdentityProperties", resource)
+ if (mgException != NULL)
+ //Sorry, if you're complaining about duplicate identity properties, then we need that thing called context
+ if (mgException->IsOfClass(Foundation_Exception_MgDuplicateObjectException))
+ STRING detail = mgException->GetDetails();
+ MgStringCollection args;
+ args.Add(resource->ToString());
+ STRING qualifiedClassName;
+ qualifiedClassName += schemaName;
+ qualifiedClassName += L":";
+ qualifiedClassName += className;
+ args.Add(qualifiedClassName);
+ args.Add(L"MgDuplicateObjectException"); //NOXLATE
+ args.Add(detail);
+ mgException = NULL;
+ mgException = new MgFeatureServiceException(L"MgdDescribeSchema.GetIdentityProperties", __LINE__, __WFILE__, NULL, L"MgFeatureSourceFormatInnerExceptionMessage", &args);
+ MG_FEATURE_SERVICE_THROW()
return idProps.Detach();
More information about the mapguide-commits
