[mapguide-commits] r7639 - trunk/Tools/Maestro/Maestro.Editors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jun 25 04:14:41 PDT 2013
Author: jng
Date: 2013-06-25 04:14:41 -0700 (Tue, 25 Jun 2013)
New Revision: 7639
   trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs
#2300: Fix XML content error when working with layers containing composite styles. The problem is due to the ResourceEditorServiceBase calling a naked IResource.Serialize() instead of going through ResourceTypeRegistry.Serialize(), which has the necessary pre-serialization hooks to clean out invalid content for things like inline SymbolDefinitions. A simple case of not RTFA(PI documentation), because the API docs for IResource.Serialize() clearly state this!
Modified: trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs
--- trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs	2013-06-22 17:40:12 UTC (rev 7638)
+++ trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs	2013-06-25 11:14:41 UTC (rev 7639)
@@ -456,7 +456,7 @@
         /// </summary>
         public void SyncSessionCopy()
-            string xml = _editCopy.Serialize();
+            string xml = ResourceTypeRegistry.SerializeAsString(_editCopy);
             try
                 using (var ms = new MemoryStream(Encoding.UTF8.GetBytes(xml)))
More information about the mapguide-commits mailing list
