[mapguide-commits] r7642 - in branches/maestro-4.0.x/Maestro.Editors: . FeatureSource/Providers FeatureSource/Providers/Odbc/SubEditors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jun 25 05:20:17 PDT 2013
Author: jng
Date: 2013-06-25 05:20:17 -0700 (Tue, 25 Jun 2013)
New Revision: 7642
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.Designer.cs
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.cs
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.cs
   branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs
   branches/maestro-4.0.x/Maestro.Editors/Strings.resx
#2232: Add %MG_USERNAME% and %MG_PASSWORD% placeholder token support for the ODBC Feature Source editor in RawConnectionString mode.
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.Designer.cs	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.Designer.cs	2013-06-25 12:20:17 UTC (rev 7642)
@@ -31,6 +31,7 @@
             System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ConnectionStringCtrl));
             this.label1 = new System.Windows.Forms.Label();
             this.txtConnStr = new System.Windows.Forms.TextBox();
+            this.lnkApplyCredentials = new System.Windows.Forms.LinkLabel();
             this.SuspendLayout();
             // label1
@@ -43,10 +44,18 @@
             resources.ApplyResources(this.txtConnStr, "txtConnStr");
             this.txtConnStr.Name = "txtConnStr";
+            // lnkApplyCredentials
+            resources.ApplyResources(this.lnkApplyCredentials, "lnkApplyCredentials");
+            this.lnkApplyCredentials.Name = "lnkApplyCredentials";
+            this.lnkApplyCredentials.TabStop = true;
+            this.lnkApplyCredentials.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkApplyCredentials_LinkClicked);
             // ConnectionStringCtrl
             resources.ApplyResources(this, "$this");
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.Controls.Add(this.lnkApplyCredentials);
             this.Controls.Add(this.txtConnStr);
             this.Controls.Add(this.label1);
             this.Name = "ConnectionStringCtrl";
@@ -59,5 +68,6 @@
         private System.Windows.Forms.Label label1;
         private System.Windows.Forms.TextBox txtConnStr;
+        private System.Windows.Forms.LinkLabel lnkApplyCredentials;
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.cs	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.cs	2013-06-25 12:20:17 UTC (rev 7642)
@@ -25,6 +25,8 @@
 using System.Text;
 using System.Windows.Forms;
 using System.Collections.Specialized;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
 namespace Maestro.Editors.FeatureSource.Providers.Odbc.SubEditors
@@ -36,9 +38,12 @@
             InitializeComponent();
+        private IEditorService _service;
         public override void Bind(IEditorService service)
-            service.RegisterCustomNotifier(this);
+            _service = service;
+            _service.RegisterCustomNotifier(this);
         void OnConnectionChanged()
@@ -76,5 +81,33 @@
         public event EventHandler RequestDocumentReset;
+        private void lnkApplyCredentials_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+            string connStr = txtConnStr.Text;
+            if (connStr.Contains("%MG_USERNAME%") &&
+                connStr.Contains("%MG_PASSWORD%"))
+                using (var diag = new SetCredentialsDialog("%MG_USERNAME%", "%MG_PASSWORD%"))
+                    if (diag.ShowDialog() == DialogResult.OK)
+                        var fs = (IFeatureSource)_service.GetEditedResource();
+                        fs.SetEncryptedCredentials(diag.Username, diag.Password);
+                        //Bit of a hack as parent does a 64-bit driver check to determine
+                        //which NameValueCollection to return from the child, but we can
+                        //get away with this because the same NameValueCollection is returned
+                        //for both
+                        fs.ApplyConnectionProperties(this.ConnectionProperties);
+                        _service.SyncSessionCopy();
+                        MessageBox.Show("Credentials applied");
+            else
+                MessageBox.Show(Strings.OdbcConnStrMissingMgPlaceholders);
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.resx	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/ConnectionStringCtrl.resx	2013-06-25 12:20:17 UTC (rev 7642)
@@ -112,16 +112,16 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="label1.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
     <value>3, 10</value>
   </data>
@@ -138,26 +138,26 @@
     <value>label1</value>
   </data>
   <data name=">>label1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>label1.Parent" xml:space="preserve">
     <value>$this</value>
   </data>
   <data name=">>label1.ZOrder" xml:space="preserve">
-    <value>1</value>
+    <value>2</value>
   </data>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="txtConnStr.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Bottom, Left, Right</value>
   </data>
   <data name="txtConnStr.Location" type="System.Drawing.Point, System.Drawing">
-    <value>3, 26</value>
+    <value>3, 35</value>
   </data>
   <data name="txtConnStr.Multiline" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
   <data name="txtConnStr.Size" type="System.Drawing.Size, System.Drawing">
-    <value>583, 158</value>
+    <value>583, 149</value>
   </data>
   <data name="txtConnStr.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
@@ -166,15 +166,42 @@
     <value>txtConnStr</value>
   </data>
   <data name=">>txtConnStr.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name=">>txtConnStr.Parent" xml:space="preserve">
   </data>
   <data name=">>txtConnStr.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <data name="lnkApplyCredentials.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
+  </data>
+  <data name="lnkApplyCredentials.Location" type="System.Drawing.Point, System.Drawing">
+    <value>179, 10</value>
+  </data>
+  <data name="lnkApplyCredentials.Size" type="System.Drawing.Size, System.Drawing">
+    <value>94, 13</value>
+  </data>
+  <data name="lnkApplyCredentials.TabIndex" type="System.Int32, mscorlib">
+    <value>2</value>
+  </data>
+  <data name="lnkApplyCredentials.Text" xml:space="preserve">
+    <value>(Apply Credentials)</value>
+  </data>
+  <data name=">>lnkApplyCredentials.Name" xml:space="preserve">
+    <value>lnkApplyCredentials</value>
+  </data>
+  <data name=">>lnkApplyCredentials.Type" xml:space="preserve">
+    <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>lnkApplyCredentials.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name=">>lnkApplyCredentials.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
@@ -187,6 +214,6 @@
     <value>ConnectionStringCtrl</value>
   </data>
   <data name=">>$this.Type" xml:space="preserve">
-    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
 </root>
\ No newline at end of file
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.cs	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/SetCredentialsDialog.cs	2013-06-25 12:20:17 UTC (rev 7642)
@@ -38,6 +38,15 @@
             _propertyNames = propertyNames;
+        public SetCredentialsDialog(string userProp, string passProp)
+            InitializeComponent();
+            txtUserProperty.Text = userProp;
+            txtPasswordProperty.Text = passProp;
+            btnUserProperty.Visible = false;
+            btnPasswordProperty.Visible = false;
         public string UserProperty { get { return txtUserProperty.Text; } }
         public string PasswordProperty { get { return txtPasswordProperty.Text; } }
Modified: branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/Strings.Designer.cs	2013-06-25 12:20:17 UTC (rev 7642)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.5420
+//     Runtime Version:2.0.50727.5466
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -68,5 +68,14 @@
                 return ResourceManager.GetString("ConfirmWmsLogicalClassSwap", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to The ODBC connection string requires a %MG_USERNAME% and %MG_PASSWORD% placeholder tokens present.
+        /// </summary>
+        internal static string OdbcConnStrMissingMgPlaceholders {
+            get {
+                return ResourceManager.GetString("OdbcConnStrMissingMgPlaceholders", resourceCulture);
Modified: branches/maestro-4.0.x/Maestro.Editors/Strings.resx
--- branches/maestro-4.0.x/Maestro.Editors/Strings.resx	2013-06-25 12:10:39 UTC (rev 7641)
+++ branches/maestro-4.0.x/Maestro.Editors/Strings.resx	2013-06-25 12:20:17 UTC (rev 7642)
@@ -120,4 +120,7 @@
   <data name="ConfirmWmsLogicalClassSwap" xml:space="preserve">
     <value>In some cases, the actual WMS layer name would be generated in the FDO class description. Swap FDO logical class names with their descriptions?</value>
   </data>
+  <data name="OdbcConnStrMissingMgPlaceholders" xml:space="preserve">
+    <value>The ODBC connection string requires a %MG_USERNAME% and %MG_PASSWORD% placeholder tokens present</value>
+  </data>
 </root>
More information about the mapguide-commits mailing list
