[mapguide-commits] r7651 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Thu Jun 27 23:47:04 PDT 2013
Author: jng
Date: 2013-06-27 23:47:04 -0700 (Thu, 27 Jun 2013)
New Revision: 7651
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2013-06-28 06:38:22 UTC (rev 7650)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2013-06-28 06:47:04 UTC (rev 7651)
@@ -1,5 +1,22 @@
-5.0 RC1
+5.0 RC2
+ - Updated known site version list
+ - Added %MG_USERNAME% and %MG_PASSWORD% placeholder token support for the ODBC Feature Source editor under RawConnectionString mode
+ - Remove redundant MRT files in Coordinate System Dictionaries
+ - Feature Class / Geometry is auto-assigned when creating a new Layer Definition if there is only one Feature Class / Geometry in the Feature Source
+ - Layers in the "Layers and Groups" tab of the Map Definition editor can be re-ordered within the group. This has the effect of modifying the draw order of these layers with respect to other layers from the same group
+ - Fix: Infinite looping still happening in Maestro MapViewer legend component
+ - Fix: "OK" button not enabled in Create Package dialog under certain conditions
+ - Fix: XML content error in Layer Definition editor due to unwanted attributes inserted into inline SymbolDefinition elements
+ - Fix: Guard against duplicate names when creating a new Extended Feature Class in the Feature Source editor
+ - Fix: Guard against layers being auto-associated to another group with the same name when editing a group's name in the Layer Definition editor
+ - Fix: MgCooker not running in batch mode (patch by dcreado)
+ - Fix: MgCooker requesting wrong tiles from server when using override bounds (patch by dcreado)
+ - Fix: Bad spacing and executable name in MgCooker batch file generation
+ - Fix: Bad console progress format string in MgCooker command-line mode
+5.0 RC1
- mg-desktop binary update (2.5.0.7449)
- Re-pointer command now supports all resource types with downstream dependencies.
- Added support for viewing layer draw order in RtMapInspector
@@ -8,18 +25,18 @@
- All specialized Fusion widget editors removed. All widget editing is through XML
- Live Map Definition Editor enhancements:
- Layers can be added to a map by drag/drop Layer Definitions from the repository view.
- - Layers can be re-ordered in "Draw Order" view
- - Layers/Groups can be re-organized in Legend view
- - Map Settings dialog can now support:
- - Extent computation based on current layers
- - Extent computation based on current viewer extents
- - Assorted bug fixes.
+ - Layers can be re-ordered in "Draw Order" view
+ - Layers/Groups can be re-organized in Legend view
+ - Map Settings dialog can now support:
+ - Extent computation based on current layers
+ - Extent computation based on current viewer extents
+ - Assorted bug fixes.
- Fusion editor enhancements:
- Using ICSharpCode.TextEditor for all XML editing functionality
- - Fix errant whitespace in widget XML
+ - Fix errant whitespace in widget XML
- Basic XML editor support for the Map Widget
- Indicate which widgets are dockable
- - Filter out un-dockable widgets when prompting the user for the widget to attach to a toolbar/container
+ - Filter out un-dockable widgets when prompting the user for the widget to attach to a toolbar/container
- Support for new Resampling Method paramter in GDAL Feature Source editor
- Fix: MgCooker command-line ignoring basegroup parameter
- Fix: NullReferenceException when using cut command on an item in the Site Explorer
More information about the mapguide-commits
