[mapguide-commits] r7653 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Sun Jun 30 07:51:36 PDT 2013
Author: jng
Date: 2013-06-30 07:51:36 -0700 (Sun, 30 Jun 2013)
New Revision: 7653
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2013-06-30 14:49:53 UTC (rev 7652)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2013-06-30 14:51:36 UTC (rev 7653)
@@ -5,6 +5,7 @@
- Remove redundant MRT files in Coordinate System Dictionaries
- Feature Class / Geometry is auto-assigned when creating a new Layer Definition if there is only one Feature Class / Geometry in the Feature Source
- Layers in the "Layers and Groups" tab of the Map Definition editor can be re-ordered within the group. This has the effect of modifying the draw order of these layers with respect to other layers from the same group
+ - Fix: "Resampling Method" in GDAL Feature Source editor should not be mandatory
- Fix: Infinite looping still happening in Maestro MapViewer legend component
- Fix: "OK" button not enabled in Create Package dialog under certain conditions
- Fix: XML content error in Layer Definition editor due to unwanted attributes inserted into inline SymbolDefinition elements
More information about the mapguide-commits
