[mapguide-commits] r7397 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Mar 14 06:36:27 PDT 2013
Author: jng
Date: 2013-03-14 06:36:26 -0700 (Thu, 14 Mar 2013)
New Revision: 7397
trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
#2214: Fix two issues with our RFC123 implementation:
1. Un-selectable layers due to the MgFeatureReader not presenting a MgClassDefinition with identity properties
2. Selects with an explicit property list failing due to not doing the [property_alias] -> [class_alias].[propertyName] reverse mapping for the underlying FDO join query
Modified: trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp
--- trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp 2013-03-14 13:13:18 UTC (rev 7396)
+++ trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp 2013-03-14 13:36:26 UTC (rev 7397)
@@ -415,16 +415,26 @@
MG_FEATURE_SERVICE_TRY()
+#ifdef DEBUG_FDO_JOIN
+ FdoPtr<FdoIdentifierCollection> cmdPropNames = m_command->GetPropertyNames();
+ for (FdoInt32 i = 0; i < cmdPropNames->GetCount(); i++)
+ FdoPtr<FdoIdentifier> ident = cmdPropNames->GetItem(i);
+ STRING idStr = ident->ToString();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n(%t) [FdoISelect]: (%W)"), idStr.c_str()));
+#endif
FdoPtr<FdoIFeatureReader> fdoReader = m_command->Execute();
if (bForceOneToOne)
FdoPtr<FdoStringCollection> names = MgServerFeatureUtil::MgToFdoStringCollection(idPropNames, false);
FdoPtr<FdoIFeatureReader> forcedReader = new MgFdoForcedOneToOneFeatureReader(fdoReader, names);
- ret = new MgServerFeatureReader(m_connection, forcedReader);
+ ret = new MgServerFeatureReader(m_connection, forcedReader, idPropNames);
else
- ret = new MgServerFeatureReader(m_connection, fdoReader);
+ ret = new MgServerFeatureReader(m_connection, fdoReader, idPropNames);
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgSelectCommand.ExecuteJoined")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2013-03-14 13:13:18 UTC (rev 7396)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2013-03-14 13:36:26 UTC (rev 7397)
@@ -28,7 +28,7 @@
///</summary>
///<param name="byteSource">Byte source object</param>
-MgServerFeatureReader::MgServerFeatureReader(MgServerFeatureConnection* connection, FdoIFeatureReader* fdoReader)
+MgServerFeatureReader::MgServerFeatureReader(MgServerFeatureConnection* connection, FdoIFeatureReader* fdoReader, MgStringCollection* forceIdProps)
@@ -36,6 +36,7 @@
m_featureSet = NULL;
m_connection = SAFE_ADDREF(connection);
m_fdoReader = FDO_SAFE_ADDREF(fdoReader);
+ m_forceIdProps = SAFE_ADDREF(forceIdProps); //This is only passed in for select queries that involve the FDO Join APIs
m_removeFromPoolOnDestruction = false;
// The reader takes ownership of the FDO connection
@@ -140,6 +141,39 @@
// Convert FdoClassDefinition to MgClassDefinition
m_classDef = MgServerFeatureUtil::GetMgClassDefinition(fdoClassDefinition, true);
CHECKNULL(m_classDef.p, L"MgServerGetFeatures.GetFeatures");
+ // The class definition presented by a FDO reader from a join select query will probably
+ // not contain any identity properties, thereby violating our golden rule of selection (no id props = unselectable)
+ // so for such queries executed by MapGuide, we pass this list of identity properties on to this reader (sourced
+ // with the identity properties from the "primary" class definition) so that we can "rewrite" the converted MgClassDefinition
+ if (NULL != m_forceIdProps && m_forceIdProps->GetCount() > 0)
+ Ptr<MgPropertyDefinitionCollection> clsProps = m_classDef->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> clsIdProps = m_classDef->GetIdentityProperties();
+ // This is most likely empty, but we're overwriting this anyway, so clear it
+ clsIdProps->Clear();
+ // Copy across any properties from the explicity identity property name list
+ for (INT32 i = 0; i < m_forceIdProps->GetCount(); i++)
+ STRING propName = m_forceIdProps->GetItem(i);
+ INT32 pidx = clsProps->IndexOf(propName);
+ if (pidx >= 0)
+ Ptr<MgPropertyDefinition> p = clsProps->GetItem(pidx);
+ clsIdProps->Add(p);
+ } //else should we care about correctness?
+ Ptr<MgPropertyDefinitionCollection> idProps = m_classDef->GetIdentityProperties();
+ Ptr<MgPropertyDefinitionCollection> props = m_classDef->GetProperties();
+ INT32 idCount = idProps->GetCount();
+ INT32 propCount = props->GetCount();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n(%t) [MgFeatureReader::GetClassDefinition] %d props, %d identity props"), propCount, idCount));
+#endif
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureReader.GetClassDefinition")
@@ -176,6 +210,39 @@
m_classDef = MgServerFeatureUtil::GetMgClassDefinition(fdoClassDefinition, false);
+ if (pidx >= 0)
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n(%t) [MgFeatureReader::GetClassDefinitionNoXml] %d props, %d identity props"), propCount, idCount));
+#endif
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureReader.GetClassDefinitionNoXml")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h 2013-03-14 13:13:18 UTC (rev 7396)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h 2013-03-14 13:36:26 UTC (rev 7397)
@@ -555,7 +555,7 @@
MgServerFeatureReader();
- MgServerFeatureReader(MgServerFeatureConnection* connection, FdoIFeatureReader* fdoReader);
+ MgServerFeatureReader(MgServerFeatureConnection* connection, FdoIFeatureReader* fdoReader, MgStringCollection* forceIdProps = NULL);
~MgServerFeatureReader();
virtual void Dispose();
@@ -574,6 +574,7 @@
Ptr<MgServerFeatureConnection> m_connection;
FdoIFeatureReader* m_fdoReader;
bool m_removeFromPoolOnDestruction;
+ Ptr<MgStringCollection> m_forceIdProps;
CLASS_ID:
static const INT32 m_cls_id = PlatformBase_FeatureService_FeatureReader;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2013-03-14 13:13:18 UTC (rev 7396)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2013-03-14 13:36:26 UTC (rev 7397)
@@ -365,9 +365,6 @@
if (cnt <= 0)
return; // Nothing to do
- //TODO: Need to check if FDO join optimization is supported, and whether this contains prefixed
- //secondary properties.
FdoPtr<FdoIdentifierCollection> fic = m_command->GetPropertyNames();
CHECKNULL((FdoIdentifierCollection*)fic, L"MgServerSelectFeatures.ApplyClassProperties");
@@ -382,7 +379,58 @@
+void MgServerSelectFeatures::ApplyClassPropertiesForFdoJoin(CREFSTRING primaryAlias, CREFSTRING secondaryAlias, CREFSTRING secondaryPrefix)
+ CHECKNULL(m_options, L"MgServerSelectFeatures.ApplyClassPropertiesForFdoJoin");
+ CHECKNULL(m_command, L"MgServerSelectFeatures.ApplyClassPropertiesForFdoJoin");
+ Ptr<MgStringCollection> properties = m_options->GetClassProperties();
+ if (properties == NULL)
+ return; // Nothing to do
+ INT32 cnt = properties->GetCount();
+ if (cnt <= 0)
+ FdoPtr<FdoIdentifierCollection> fic = m_command->GetPropertyNames();
+ CHECKNULL((FdoIdentifierCollection*)fic, L"MgServerSelectFeatures.ApplyClassPropertiesForFdoJoin");
+ //If we're given an explicit property list, it will be whatever is presented by the Extended Feature Class
+ //So we have to "re-shape" this property list into a aliased qualified property list like the standard FDO
+ //join query. Basically, were doing a reverse property mapping.
+ for (INT32 i=0; i < cnt; i++)
+ STRING propertyName = properties->GetItem(i);
+ //Check if this name starts with prefix
+ // If it does, it's a secondary join property and should be re-aliased as [secondaryAlias].[propertyNameWithoutPrefix]
+ // Otherwise, it should be re-aliased as [primaryAlias].[propertyNameAsIs]
+ STRING reAliasedPropName;
+ if (propertyName.compare(0, secondaryPrefix.length(), secondaryPrefix) == 0)
+ reAliasedPropName = secondaryAlias;
+ reAliasedPropName += L".";
+ reAliasedPropName += propertyName.substr(secondaryPrefix.length());
+ else
+ reAliasedPropName = primaryAlias;
+ reAliasedPropName += propertyName;
+ //This will now be [alias].[reAliasedPropertyName] AS [propertyName]
+ FdoPtr<FdoExpression> expr = FdoExpression::Parse((FdoString*)reAliasedPropName.c_str());
+ FdoPtr<FdoComputedIdentifier> fdoIden = FdoComputedIdentifier::Create((FdoString*)propertyName.c_str(), expr);
+ CHECKNULL((FdoComputedIdentifier*)fdoIden, L"MgServerSelectFeatures.ApplyClassPropertiesForFdoJoin");
+ fic->Add(fdoIden);
// Computed properties
void MgServerSelectFeatures::ApplyComputedProperties()
@@ -465,7 +513,7 @@
if (!filterText.empty())
regularFilter = FdoFilter::Parse(filterText.c_str());
- #ifdef _DEBUG
+ #if defined(_DEBUG) || defined(DEBUG_FDO_JOIN)
ACE_DEBUG((LM_ERROR, ACE_TEXT("FILTER(size=%d):\n%W\n\n"), filterText.length(), filterText.c_str()));
#endif
@@ -1917,7 +1965,11 @@
CHECKNULL(extension, L"MgServerSelectFeatures.SelectFdoJoin");
- m_command->SetFeatureClassName(extension->GetFeatureClass().c_str());
+ FdoString* clsName = extension->GetFeatureClass().c_str();
+ m_command->SetFeatureClassName(clsName);
+ ACE_DEBUG((LM_INFO, ACE_TEXT("\n\t(%t) [FdoISelect] Set primary feature class: %W"), clsName));
+#endif
MdfModel::AttributeRelateCollection* relates = extension->GetAttributeRelates();
CHECKNULL(relates, L"MgServerSelectFeatures.SelectFdoJoin");
MdfModel::AttributeRelate* relate = relates->GetAt(0);
@@ -1955,11 +2007,9 @@
bool bAppliedProperties = false;
if (m_options != NULL)
- //ApplyClassProperties();
ApplyComputedProperties();
// TODO: We need to find out if there are any filters involving the secondary side
ApplyFilter();
- // ApplySpatialFilter();
ApplyOrderingOptions();
// We don't apply aggregate options here because these go through the FDO Expression Engine
ApplyAggregateOptions(isAggregate);
@@ -1970,7 +2020,7 @@
Ptr<MgStringCollection> props = m_options->GetClassProperties();
if (props->GetCount() > 0)
- ApplyClassProperties();
+ ApplyClassPropertiesForFdoJoin(primaryAlias, secondaryAlias, prefix);
bAppliedProperties = true;
@@ -2211,7 +2261,6 @@
STRING idName = prefix + propDef->GetName();
//[alias].[propertyName] AS [prefix][propertyName]
FdoPtr<FdoComputedIdentifier> compId = FdoComputedIdentifier::Create(idName.c_str(), expr);
propNames->Add(compId);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2013-03-14 13:13:18 UTC (rev 7396)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2013-03-14 13:36:26 UTC (rev 7397)
@@ -96,6 +96,7 @@
bool m_bUseFdoJoinOptimization;
// FDO join optimization
+ void ApplyClassPropertiesForFdoJoin(CREFSTRING primaryAlias, CREFSTRING secondaryAlias, CREFSTRING secondaryPrefix);
bool IsFunctionOnPrimaryProperty(FdoFunction* function, FdoIConnection* conn, CREFSTRING schemaName, CREFSTRING className);
bool SupportsFdoJoin(MgResourceIdentifier* featureSourceId, CREFSTRING extension, bool isAggregate);
MgReader* SelectFdoJoin(MgResourceIdentifier* featureSourceId, CREFSTRING extension, bool isAggregate);
More information about the mapguide-commits
