[mapguide-commits] r7401 - in	sandbox/adsk/2.3r.sce/Server/src/Services: Mapping Rendering
    svn_mapguide at osgeo.org
    Tue Mar 19 18:55:18 PDT 2013
Author: hubu
Date: 2013-03-19 18:55:18 -0700 (Tue, 19 Mar 2013)
New Revision: 7401
   sandbox/adsk/2.3r.sce/Server/src/Services/Mapping/MappingUtil.cpp
   sandbox/adsk/2.3r.sce/Server/src/Services/Rendering/ServerRenderingService.cpp
Submit on behalf of Andy Zhang.
This submission is for SCE project.
Fix the issue that Label cannot display correctly.
Modified: sandbox/adsk/2.3r.sce/Server/src/Services/Mapping/MappingUtil.cpp
--- sandbox/adsk/2.3r.sce/Server/src/Services/Mapping/MappingUtil.cpp	2013-03-18 10:46:14 UTC (rev 7400)
+++ sandbox/adsk/2.3r.sce/Server/src/Services/Mapping/MappingUtil.cpp	2013-03-20 01:55:18 UTC (rev 7401)
@@ -590,7 +590,7 @@
                         // iterate through the rulecollection
                         RuleCollection* ruleColl = pfts->GetRules();
                         int rccount = ruleColl->GetCount();
-                        for (int k=0; k<rccount; ++k)
+                        for (int k=0; k < rccount && !hasRuleFilter; ++k)
                             Rule* rule = ruleColl->GetAt(k);
                             if (!rule->GetFilter().empty())
@@ -598,6 +598,42 @@
                                 hasRuleFilter = true;
                                 break;
+                            Label* label = rule->GetLabel();
+                            if (label)
+                                MdfModel::TextSymbol* textSymbol = label->GetSymbol();
+                                if (textSymbol)
+                                    hasRuleFilter = true;
+                                    break;
+                            //AreaRule* paRule = dynamic_cast<AreaRule*>(rule);
+                            //LineRule* plRule = dynamic_cast<LineRule*>(rule);
+                            //PointRule* ppRule = dynamic_cast<PointRule*>(rule);
+                            CompositeRule* pcRule = dynamic_cast<CompositeRule*>(rule);
+                            if (pcRule)
+                                CompositeSymbolization* cSym = pcRule->GetSymbolization();
+                                SymbolInstanceCollection* sIs = cSym->GetSymbolCollection();
+                                for (int l = 0; l <sIs->GetCount() && !hasRuleFilter; l++)
+                                    SymbolInstance* si = sIs->GetAt(l);
+                                    SymbolDefinition* sd = si->GetSymbolDefinition();
+                                    SimpleSymbolDefinition* ssd = dynamic_cast<SimpleSymbolDefinition*>(sd);
+                                    GraphicElementCollection* graphics = ssd->GetGraphics();
+                                    for (int m = 0; m <graphics->GetCount(); m++)
+                                        GraphicElement* ge = graphics->GetAt(m);
+                                        Text* text = dynamic_cast<Text*>(ge);
+                                        if (text)
+                                            break;
Modified: sandbox/adsk/2.3r.sce/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/adsk/2.3r.sce/Server/src/Services/Rendering/ServerRenderingService.cpp	2013-03-18 10:46:14 UTC (rev 7400)
+++ sandbox/adsk/2.3r.sce/Server/src/Services/Rendering/ServerRenderingService.cpp	2013-03-20 01:55:18 UTC (rev 7401)
@@ -1568,7 +1568,7 @@
@@ -1576,6 +1576,39 @@
                                 break;
+                            if (label)
+                                if (textSymbol)
+                                    break;
+                            if (pcRule)
+                                for (int l = 0; l < sIs->GetCount() && !hasRuleFilter; l++)
+                                        if (text)
+                                            break;
                     if (!hasRuleFilter)
@@ -1589,6 +1622,10 @@
                             Ptr<MgPropertyDefinition> prop = props->GetItem(i);
                             options->AddFeatureProperty(prop->GetName());
+                        if (geometry != NULL)
+                            options->AddFeatureProperty(layer->GetFeatureGeometryName());
More information about the mapguide-commits
