[mapguide-commits] r7406 - trunk/MgDev/Desktop/UnitTest
svn_mapguide at osgeo.org
Wed Mar 20 09:38:21 PDT 2013
Author: jng
Date: 2013-03-20 09:38:21 -0700 (Wed, 20 Mar 2013)
New Revision: 7406
trunk/MgDev/Desktop/UnitTest/TestFeatureService.cpp
trunk/MgDev/Desktop/UnitTest/TestFeatureService.h
trunk/MgDev/Desktop/UnitTest/main.cpp
mg-desktop changes: Port over some Feature Service tests from the server test-suite
Modified: trunk/MgDev/Desktop/UnitTest/TestFeatureService.cpp
--- trunk/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2013-03-20 16:18:54 UTC (rev 7405)
+++ trunk/MgDev/Desktop/UnitTest/TestFeatureService.cpp 2013-03-20 16:38:21 UTC (rev 7406)
@@ -2817,6 +2817,145 @@
/// Test Case Description:
+/// This test case exercises the UpdateFeatures API for insertion
+void TestFeatureService::TestCase_UpdateFeaturesInsert()
+ try
+ Ptr<MgdServiceFactory> fact = new MgdServiceFactory();
+ if (fact == 0)
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> pService = dynamic_cast<MgFeatureService*>(fact->CreateService(MgServiceType::FeatureService));
+ if (pService == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_SavePoint", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceIdentifier> featureSource = new MgResourceIdentifier(L"Library://UnitTests/Data/TestInsert.FeatureSource");
+ //Create our test data store (SQLite)
+ STRING scName = L"Default";
+ STRING srsWkt = L"LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ //Setup schema
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"Test schema for TestCase_2218");
+ Ptr<MgClassDefinition> klass = new MgClassDefinition();
+ klass->SetName(L"TestClass");
+ Ptr<MgPropertyDefinitionCollection> clsProps = klass->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> idProps = klass->GetIdentityProperties();
+ //ID
+ Ptr<MgDataPropertyDefinition> idProperty = new MgDataPropertyDefinition(L"ID");
+ idProperty->SetDataType(MgPropertyType::Int32);
+ idProperty->SetAutoGeneration(false);
+ idProperty->SetNullable(false);
+ clsProps->Add(idProperty);
+ idProps->Add(idProperty);
+ //Name
+ Ptr<MgDataPropertyDefinition> nameProperty = new MgDataPropertyDefinition(L"Name");
+ nameProperty->SetDataType(MgPropertyType::String);
+ nameProperty->SetLength(255);
+ nameProperty->SetNullable(true);
+ clsProps->Add(nameProperty);
+ //Geom
+ Ptr<MgGeometricPropertyDefinition> geomProperty = new MgGeometricPropertyDefinition(L"Geom");
+ geomProperty->SetSpatialContextAssociation(scName);
+ clsProps->Add(geomProperty);
+ klass->SetDefaultGeometryPropertyName(L"Geom");
+ Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
+ classes->Add(klass);
+ //Create the feature source
+ Ptr<MgFileFeatureSourceParams> fileParams = new MgFileFeatureSourceParams(L"OSGeo.SQLite", scName, srsWkt, schema);
+ pService->CreateFeatureSource(featureSource, fileParams);
+ //Set up insert command
+ Ptr<MgFeatureCommandCollection> commands = new MgFeatureCommandCollection();
+ Ptr<MgPropertyCollection> propVals = new MgPropertyCollection();
+ Ptr<MgInt32Property> idVal = new MgInt32Property(L"ID", 1);
+ Ptr<MgStringProperty> nameVal = new MgStringProperty(L"Name", L"Foo");
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
+ Ptr<MgAgfReaderWriter> agfRw = new MgAgfReaderWriter();
+ Ptr<MgGeometry> geom = wktRw->Read(L"POINT (1 2)");
+ Ptr<MgByteReader> agf = agfRw->Write(geom);
+ Ptr<MgGeometryProperty> geomVal = new MgGeometryProperty(L"Geom", agf);
+ propVals->Add(idVal);
+ propVals->Add(nameVal);
+ propVals->Add(geomVal);
+ Ptr<MgInsertFeatures> insert = new MgInsertFeatures(L"Default:TestClass", propVals);
+ commands->Add(insert);
+ //Execute insert. Should be fine
+ Ptr<MgPropertyCollection> result = pService->UpdateFeatures(featureSource, commands, true);
+ CPPUNIT_ASSERT(result->GetCount() == 1);
+ INT32 i = 0;
+ Ptr<MgProperty> resItem1 = result->GetItem(i);
+ CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::Feature);
+ Ptr<MgFeatureReader> rdr = ((MgFeatureProperty*)resItem1.p)->GetValue();
+ rdr->Close();
+ //Change name, retain same id
+ nameVal->SetValue(L"Bar");
+ //Execute again, expect MgFdoException due to constraint violation
+ CPPUNIT_ASSERT_THROW_MG(result = pService->UpdateFeatures(featureSource, commands, true), MgFdoException*);
+ //Expect one inserted result
+ Ptr<MgFeatureQueryOptions> query = new MgFeatureQueryOptions();
+ Ptr<MgFeatureReader> qryReader = pService->SelectFeatures(featureSource, L"Default:TestClass", query);
+ INT32 count = 0;
+ while (qryReader->ReadNext()) { count++; }
+ qryReader->Close();
+ CPPUNIT_ASSERT(1 == count);
+ //Execute again, useTransaction = false. Should not throw exception, but log
+ //the error as a MgStringProperty
+ result = pService->UpdateFeatures(featureSource, commands, false);
+ resItem1 = result->GetItem(i);
+ CPPUNIT_ASSERT(resItem1->GetPropertyType() == MgPropertyType::String); //Errors are of type String
+ //Use new id
+ idVal->SetValue(2);
+ //Should be fine now
+ result = pService->UpdateFeatures(featureSource, commands, true);
+ rdr = ((MgFeatureProperty*)resItem1.p)->GetValue();
+ rdr->Close();
+ catch(MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch(FdoException* e)
+ FDO_SAFE_RELEASE(e);
+ CPPUNIT_FAIL("FdoException occurred");
+ catch(...)
+ throw;
+/// Test Case Description:
/// This test case exercises the FDO join optimization
void TestFeatureService::TestCase_JoinFdoFeatures()
@@ -4514,4 +4653,70 @@
throw;
+/// This test case tests the correct response for a non-transactional failure
+/// in UpdateFeatures
+void TestFeatureService::TestCase_UpdateFeaturesPartialFailure()
+ try
+ if (fact == 0)
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_UpdateFeaturesPartialFailure", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> featSvc = dynamic_cast<MgFeatureService*>(fact->CreateService(MgServiceType::FeatureService));
+ if (featSvc == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_UpdateFeaturesPartialFailure",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
+ Ptr<MgPropertyCollection> props = new MgPropertyCollection();
+ Ptr<MgInt32Property> idProp = new MgInt32Property(L"id", 0);
+ props->Add(idProp);
+ Ptr<MgInsertFeatures> insert = new MgInsertFeatures(L"Parcels1", props); //Bogus class name to trigger exception
+ Ptr<MgFeatureCommandCollection> cmds = new MgFeatureCommandCollection();
+ cmds->Add(insert);
+ Ptr<MgPropertyCollection> result = featSvc->UpdateFeatures(fsId, cmds, false);
+ CPPUNIT_ASSERT(result->GetCount() > 0);
+ bool bPartialFailure = false;
+ for (INT32 i = 0; i < result->GetCount(); i++)
+ Ptr<MgProperty> prop = result->GetItem(i);
+ if (prop->GetPropertyType() == MgPropertyType::String)
+ bPartialFailure = true;
+ break;
+ CPPUNIT_ASSERT(bPartialFailure);
+ SAFE_RELEASE(e);
+ STRING message = L"FdoException occurred: ";
+ message += e->GetExceptionMessage();
+ catch(...)
+ throw;
\ No newline at end of file
Modified: trunk/MgDev/Desktop/UnitTest/TestFeatureService.h
--- trunk/MgDev/Desktop/UnitTest/TestFeatureService.h 2013-03-20 16:18:54 UTC (rev 7405)
+++ trunk/MgDev/Desktop/UnitTest/TestFeatureService.h 2013-03-20 16:38:21 UTC (rev 7406)
@@ -47,6 +47,8 @@
CPPUNIT_TEST(TestCase_InsertFeatures);
CPPUNIT_TEST(TestCase_InsertFeaturesBatch);
CPPUNIT_TEST(TestCase_UpdateFeatures);
+ CPPUNIT_TEST(TestCase_UpdateFeaturesInsert);
+ CPPUNIT_TEST(TestCase_UpdateFeaturesPartialFailure);
CPPUNIT_TEST(TestCase_DeleteFeatures);
// TODO write test case when know how to make command collection
CPPUNIT_TEST(TestCase_ExecuteSqlQuery);
@@ -102,6 +104,8 @@
void TestCase_SelectFeaturesTransformed();
void TestCase_SelectScrollable();
void TestCase_SelectAggregate();
+ void TestCase_UpdateFeaturesInsert();
+ void TestCase_UpdateFeaturesPartialFailure();
void TestCase_InsertFeatures();
void TestCase_InsertFeaturesBatch();
void TestCase_UpdateFeatures();
Modified: trunk/MgDev/Desktop/UnitTest/main.cpp
--- trunk/MgDev/Desktop/UnitTest/main.cpp 2013-03-20 16:18:54 UTC (rev 7405)
+++ trunk/MgDev/Desktop/UnitTest/main.cpp 2013-03-20 16:38:21 UTC (rev 7406)
@@ -24,7 +24,6 @@
#endif
#endif
-#define TEST_COORDINATE_SYSTEM 1
#define TEST_LOG_MANAGER 1
#define TEST_RESOURCE_SERVICE 1
#define TEST_FEATURE_SERVICE 1
@@ -73,14 +72,6 @@
#if TEST_LOG_MANAGER == 1
runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestLogManager").makeTest());
#endif
-#ifdef _DEBUG
- ACE_DEBUG((LM_INFO, ACE_TEXT(">>>>> Running all unit tests - Excluding Performance and CoordinateSystem. <<<<<\n\n")));
-#else
- ACE_DEBUG((LM_INFO, ACE_TEXT(">>>>> Running all unit tests - Excluding Performance. <<<<<\n\n")));
- #if TEST_COORDINATE_SYSTEM == 1
- runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestCoordinateSystem").makeTest());
- #endif
-#endif
#if TEST_RESOURCE_SERVICE == 1
runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestResourceService").makeTest());
#endif
More information about the mapguide-commits
