[mapguide-commits] r7423 - trunk/Tools/Maestro/Maestro.MapViewer
svn_mapguide at osgeo.org
Thu Mar 28 07:24:56 PDT 2013
Author: jng
Date: 2013-03-28 07:24:55 -0700 (Thu, 28 Mar 2013)
New Revision: 7423
trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
Fix two problems with the Maestro.MapViewer legend:
- #2284: Fix infinite loop due to nested groups being handled improperly
- Fix layer/group presentation order at any particular level. This ensures that AJAX/Fusion/Maestro viewers for the first time present the same view of the layer/group structure as presented in the Map Definition editor.
Modified: trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2013-03-28 10:42:41 UTC (rev 7422)
+++ trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2013-03-28 14:24:55 UTC (rev 7423)
@@ -361,13 +361,13 @@
public TreeNode[] CreateNodes()
- List<TreeNode> output = new List<TreeNode>();
- var nodesById = new Dictionary<string, TreeNode>();
+ List<TreeNode> topLevelNodes = new List<TreeNode>();
var scale = _map.ViewScale;
if (scale < 10.0)
- return output.ToArray();
+ return topLevelNodes.ToArray();
+ var nodesById = new Dictionary<string, TreeNode>();
+ var groupsById = new Dictionary<string, TreeNode>();
var groups = _map.Groups;
var layers = _map.Layers;
@@ -381,7 +381,7 @@
if (!_legend.ShowAllLayersAndGroups && !group.ShowInLegend)
continue;
- //Add ones without parents first.
+ //Add ones without parents first. Queue up child groups
if (!string.IsNullOrEmpty(group.Group))
remainingNodes.Add(group);
@@ -389,13 +389,16 @@
else
var node = CreateGroupNode(group);
- output.Add(node);
+ topLevelNodes.Add(node);
nodesById.Add(group.ObjectId, node);
+ groupsById.Add(group.ObjectId, node);
+ //Process child groups
while (remainingNodes.Count > 0)
List<RuntimeMapGroup> toRemove = new List<RuntimeMapGroup>();
+ //Establish parent-child relationships for any child groups here
for (int j = 0; j < remainingNodes.Count; j++)
var grpName = remainingNodes[j].Group;
@@ -404,6 +407,12 @@
var node = CreateGroupNode(remainingNodes[j]);
nodesById[parentGroup.ObjectId].Nodes.Add(node);
+ //Got to add this group node too, otherwise we could infinite
+ //loop looking for a parent that's not registered
+ nodesById.Add(group.ObjectId, node);
toRemove.Add(remainingNodes[j]);
@@ -487,8 +496,13 @@
Trace.TraceInformation("CreateNodes: {0} layer contents added, {1} layer contents updated", added, updated);
+ //Now create our layer nodes
List<RuntimeMapLayer> remainingLayers = new List<RuntimeMapLayer>();
- for (int i = 0; i < layers.Count; i++)
+ //NOTE: We're taking a page out of the Fusion playbook of reverse iterating the layer
+ //collection and prepending the nodes, as this control suffered the same problem as the
+ //Legend widget in Fusion. Doing it this way eliminates the need for doing an extra pass to fix
+ //the layer/group ordering, which may make an impact on really chunky maps.
+ for (int i = layers.Count - 1; i >= 0; i--)
var layer = layers[i];
@@ -500,7 +514,7 @@
if (!_legend.ShowAllLayersAndGroups && !visible)
continue;
+ //Add ones without parents first. Queue up parented layers
if (!string.IsNullOrEmpty(layer.Group))
remainingLayers.Add(layer);
@@ -510,17 +524,18 @@
var node = CreateLayerNode(layer);
if (node != null)
- output.Add(node);
+ topLevelNodes.Insert(0, node);
nodesById.Add(layer.ObjectId, node);
if (layer.ExpandInLegend)
node.Expand();
+ //Process parented layers
while (remainingLayers.Count > 0)
List<RuntimeMapLayer> toRemove = new List<RuntimeMapLayer>();
- for (int j = 0; j < remainingLayers.Count; j++)
+ for (int j = remainingLayers.Count - 1; j >= 0; j--)
var grpName = remainingLayers[j].Group;
var parentGroup = _map.Groups[grpName];
@@ -529,7 +544,7 @@
var node = CreateLayerNode(remainingLayers[j]);
if (node != null)
- nodesById[parentGroup.ObjectId].Nodes.Add(node);
+ nodesById[parentGroup.ObjectId].Nodes.Insert(0, node);
if (remainingLayers[j].ExpandInLegend)
node.Expand();
@@ -561,7 +576,7 @@
Trace.TraceInformation("{0} calls made to GenerateLegendImage", legendCallCount);
private static bool IsThemeLayerNode(TreeNode node)
More information about the mapguide-commits
