[mapguide-commits] r7432 - branches/2.5/MgDev
svn_mapguide at osgeo.org
Sat Mar 30 04:25:16 PDT 2013
Author: jng
Date: 2013-03-30 04:25:15 -0700 (Sat, 30 Mar 2013)
New Revision: 7432
Added:
branches/2.5/MgDev/dotnetxml_excludes.txt
branches/2.5/MgDev/build.bat
branches/2.5/MgDev/build64.bat
#2250: Filter out the .net XML documentation files for directories that would affect file offsets of php-cgi.exe and isapi_MapAgent.dll
Modified: branches/2.5/MgDev/build.bat
--- branches/2.5/MgDev/build.bat 2013-03-30 06:33:04 UTC (rev 7431)
+++ branches/2.5/MgDev/build.bat 2013-03-30 11:25:15 UTC (rev 7432)
@@ -328,7 +328,7 @@
echo [install]: Web Tier - mapagent
%XCOPY% "%MG_WEB_SRC%\mapagent" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapagent test forms
%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - stdicons
@@ -342,11 +342,11 @@
echo [install]: Web Tier - mapviewerphp
%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - Tomcat - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - php - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - php ext - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapviewernet
%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapviewernet - MapGuide API unmanaged binaries
Modified: branches/2.5/MgDev/build64.bat
--- branches/2.5/MgDev/build64.bat 2013-03-30 06:33:04 UTC (rev 7431)
+++ branches/2.5/MgDev/build64.bat 2013-03-30 11:25:15 UTC (rev 7432)
@@ -360,7 +360,7 @@
%XCOPY% "%MG_WEB_SRC%\mapagent64" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%CONFIGURATION%_excludes.txt
@@ -374,11 +374,11 @@
%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%CONFIGURATION%_excludes.txt
Added: branches/2.5/MgDev/dotnetxml_excludes.txt
--- branches/2.5/MgDev/dotnetxml_excludes.txt (rev 0)
+++ branches/2.5/MgDev/dotnetxml_excludes.txt 2013-03-30 11:25:15 UTC (rev 7432)
@@ -0,0 +1,5 @@
+OSGeo.MapGuide.Foundation.xml
+OSGeo.MapGuide.Geometry.xml
+OSGeo.MapGuide.PlatformBase.xml
+OSGeo.MapGuide.MapGuideCommon.xml
+OSGeo.MapGuide.Web.xml
\ No newline at end of file
More information about the mapguide-commits
