[mapguide-commits] r7436 - trunk/MgDev
svn_mapguide at osgeo.org
Sun Mar 31 23:29:47 PDT 2013
Author: jng
Date: 2013-03-31 23:29:47 -0700 (Sun, 31 Mar 2013)
New Revision: 7436
Added:
trunk/MgDev/dotnetxml_excludes.txt
trunk/MgDev/build.bat
trunk/MgDev/build64.bat
#2250: Filter out the .net XML documentation files for directories that would affect file offsets of php-cgi.exe and isapi_MapAgent.dll
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat 2013-03-31 10:19:27 UTC (rev 7435)
+++ trunk/MgDev/build.bat 2013-04-01 06:29:47 UTC (rev 7436)
@@ -328,7 +328,7 @@
echo [install]: Web Tier - mapagent
%XCOPY% "%MG_WEB_SRC%\mapagent" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%TYPEBUILD%_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+java_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapagent test forms
%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - stdicons
@@ -342,11 +342,11 @@
echo [install]: Web Tier - mapviewerphp
%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - Tomcat - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - php - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - php ext - MapGuide API unmanaged binaries
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapviewernet
%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%TYPEBUILD%_excludes.txt
echo [install]: Web Tier - mapviewernet - MapGuide API unmanaged binaries
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat 2013-03-31 10:19:27 UTC (rev 7435)
+++ trunk/MgDev/build64.bat 2013-04-01 06:29:47 UTC (rev 7436)
@@ -360,7 +360,7 @@
%XCOPY% "%MG_WEB_SRC%\mapagent64" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:svn_excludes.txt+mapagent_excludes.txt+%CONFIGURATION%_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+java_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
%XCOPY% "%MG_UNIT_TEST%\WebTier\MapAgent\MapAgentForms" "%MG_OUTPUT_WEB%\www\mapagent" /EXCLUDE:%CONFIGURATION%_excludes.txt
@@ -374,11 +374,11 @@
%XCOPY% "%MG_WEB_SRC%\mapviewerphp" "%MG_OUTPUT_WEB%\www\mapviewerphp" /EXCLUDE:%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Tomcat\bin"/EXCLUDE:java_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php"/EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
-%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_WEB_BIN%\%TYPEBUILD%" "%MG_OUTPUT_WEB%\Php\ext" /EXCLUDE:php_excludes.txt+dotnetapi_excludes.txt+dotnetxml_excludes.txt+svn_excludes.txt+%CONFIGURATION%_excludes.txt
%XCOPY% "%MG_WEB_SRC%\mapviewernet" "%MG_OUTPUT_WEB%\www\mapviewernet" /EXCLUDE:%CONFIGURATION%_excludes.txt
Copied: trunk/MgDev/dotnetxml_excludes.txt (from rev 7432, branches/2.5/MgDev/dotnetxml_excludes.txt)
--- trunk/MgDev/dotnetxml_excludes.txt (rev 0)
+++ trunk/MgDev/dotnetxml_excludes.txt 2013-04-01 06:29:47 UTC (rev 7436)
@@ -0,0 +1,5 @@
+OSGeo.MapGuide.Foundation.xml
+OSGeo.MapGuide.Geometry.xml
+OSGeo.MapGuide.PlatformBase.xml
+OSGeo.MapGuide.MapGuideCommon.xml
+OSGeo.MapGuide.Web.xml
\ No newline at end of file
More information about the mapguide-commits
