[mapguide-commits] r7506 - in trunk/Tools/Maestro: MaestroAPITests OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Mon May 20 04:55:57 PDT 2013
Author: jng
Date: 2013-05-20 04:55:56 -0700 (Mon, 20 May 2013)
New Revision: 7506
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
#2233: This is actually fixed in trunk. Nevertheless, still worth merging in the cleaned up code and the updated unit tests.
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2013-05-20 11:50:43 UTC (rev 7505)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2013-05-20 11:55:56 UTC (rev 7506)
@@ -173,6 +173,12 @@
var map2 = mapSvc.CreateMap("Session:" + _conn.SessionID + "//TestCreate2.Map", "Library://UnitTests/Maps/Sheboygan.MapDefinition", 1.0);
//var map3 = mapSvc.CreateMap("Library://UnitTests/Maps/Sheboygan.MapDefinition", 1.0);
+ Assert.NotNull(map.Layers["Parcels"]);
+ var parcelsLayers = map.Layers["Parcels"];
+ Assert.AreEqual(1, parcelsLayers.ScaleRanges.Length);
+ Assert.AreEqual(0.0, parcelsLayers.ScaleRanges[0].MinScale);
+ Assert.AreEqual(13000.0, parcelsLayers.ScaleRanges[0].MaxScale);
Assert.NotNull(map);
Assert.NotNull(map2);
//Assert.NotNull(map3);
@@ -259,6 +265,11 @@
//Tweak some settings
var parcels = map2.Layers["Parcels"];
+ //Check these values still came through
+ Assert.AreEqual(1, parcels.ScaleRanges.Length);
+ Assert.AreEqual(0.0, parcels.ScaleRanges[0].MinScale);
+ Assert.AreEqual(13000.0, parcels.ScaleRanges[0].MaxScale);
var rail = map2.Layers["Rail"];
Assert.NotNull(parcels);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2013-05-20 11:50:43 UTC (rev 7505)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2013-05-20 11:55:56 UTC (rev 7506)
@@ -136,18 +136,8 @@
_featureSourceId = vl.ResourceId;
_filter = vl.Filter;
InitIdentityProperties(vl);
+ InitScaleRanges(vl);
_hasTooltips = !string.IsNullOrEmpty(vl.ToolTip);
- if (vl.HasVectorScaleRanges())
- int vsrCount = vl.GetScaleRangeCount();
- _scaleRanges = new double[vsrCount * 2];
- for (int i = 0; i < vsrCount; i++)
- var vsr = vl.GetScaleRangeAt(i);
- _scaleRanges[i * 2] = vsr.MinScale.HasValue ? vsr.MinScale.Value : 0;
- _scaleRanges[i * 2 + 1] = vsr.MaxScale.HasValue ? vsr.MaxScale.Value : InfinityScale;
else if (ldf.SubLayer.LayerType == LayerType.Raster)
@@ -155,22 +145,18 @@
_qualifiedClassName = rl.FeatureName;
_geometryPropertyName = rl.Geometry;
_featureSourceId = rl.ResourceId;
- if (rl.GridScaleRangeCount > 0)
- _scaleRanges = new double[rl.GridScaleRangeCount * 2];
- int i = 0;
- foreach (var gsr in rl.GridScaleRange)
- _scaleRanges[i * 2] = gsr.MinScale.HasValue ? gsr.MinScale.Value : 0;
- _scaleRanges[i * 2 + 1] = gsr.MaxScale.HasValue ? gsr.MaxScale.Value : InfinityScale;
- i++;
+ InitScaleRanges(rl);
else if (ldf.SubLayer.LayerType == LayerType.Drawing)
_featureSourceId = ldf.SubLayer.ResourceId;
+ var dl = ((IDrawingLayerDefinition)ldf.SubLayer);
+ _scaleRanges = new double[]
+ dl.MinScale,
+ dl.MaxScale
+ EnsureOrderedMinMaxScales();
_expandInLegend = false;
@@ -179,8 +165,6 @@
_selectable = true;
_showInLegend = true;
_visible = true;
- EnsureOrderedMinMaxScales();
/// <summary>
@@ -210,6 +194,44 @@
_disableChangeTracking = false;
+ private void InitScaleRanges(IRasterLayerDefinition rl)
+ List<double> scales = new List<double>();
+ foreach (var gsr in rl.GridScaleRange)
+ if (gsr.MinScale.HasValue)
+ scales.Add(gsr.MinScale.Value);
+ else
+ scales.Add(0.0);
+ if (gsr.MaxScale.HasValue)
+ scales.Add(gsr.MaxScale.Value);
+ else
+ scales.Add(InfinityScale);
+ _scaleRanges = scales.ToArray();
+ private void InitScaleRanges(IVectorLayerDefinition vl)
+ foreach (var vsr in vl.VectorScaleRange)
+ if (vsr.MinScale.HasValue)
+ scales.Add(vsr.MinScale.Value);
+ else
+ scales.Add(0.0);
+ if (vsr.MaxScale.HasValue)
+ scales.Add(vsr.MaxScale.Value);
+ else
/// <summary>
/// Initializes a new instance of the <see cref="RuntimeMapLayer"/> class.
/// </summary>
More information about the mapguide-commits
