[mapguide-commits] r7510 - trunk/Tools/Maestro/Maestro.MapViewer
svn_mapguide at osgeo.org
Tue May 21 08:03:30 PDT 2013
Author: jng
Date: 2013-05-21 08:03:29 -0700 (Tue, 21 May 2013)
New Revision: 7510
trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
This submission contains the following changes:
- #2248: Previous fix was incorrect. This is the proper infinite looping fix for nested groups.
- Add ParentGroupName to LayerNodeMetadata and GroupNodeMetadata
- Enable/Disable the Legend in a cross-thread safe manner.
Modified: trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2013-05-20 12:26:02 UTC (rev 7509)
+++ trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2013-05-21 15:03:29 UTC (rev 7510)
@@ -100,7 +100,13 @@
void OnViewerPropertyChanged(object sender, PropertyChangedEventArgs e)
if (e.PropertyName == "IsBusy")
- this.Enabled = !_viewer.IsBusy;
+ Action<bool> set = (value) => { this.Enabled = value; };
+ if (this.InvokeRequired)
+ this.Invoke(set, !_viewer.IsBusy);
+ else
+ set(!_viewer.IsBusy);
void OnMapLoaded(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2013-05-20 12:26:02 UTC (rev 7509)
+++ trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2013-05-21 15:03:29 UTC (rev 7510)
@@ -393,36 +393,36 @@
nodesById.Add(group.ObjectId, node);
groupsById.Add(group.ObjectId, node);
- //Process child groups
- while (remainingNodes.Count > 0)
+ //Process child groups
+ while (remainingNodes.Count > 0)
+ List<RuntimeMapGroup> toRemove = new List<RuntimeMapGroup>();
+ //Establish parent-child relationships for any child groups here
+ for (int j = 0; j < remainingNodes.Count; j++)
- List<RuntimeMapGroup> toRemove = new List<RuntimeMapGroup>();
- //Establish parent-child relationships for any child groups here
- for (int j = 0; j < remainingNodes.Count; j++)
+ var grpName = remainingNodes[j].Group;
+ var parentGroup = _map.Groups[grpName];
+ if (parentGroup != null && nodesById.ContainsKey(parentGroup.ObjectId))
- var grpName = remainingNodes[j].Group;
- var parentGroup = _map.Groups[grpName];
- if (parentGroup != null && nodesById.ContainsKey(parentGroup.ObjectId))
- var node = CreateGroupNode(remainingNodes[j]);
- nodesById[parentGroup.ObjectId].Nodes.Add(node);
+ var node = CreateGroupNode(remainingNodes[j]);
+ nodesById[parentGroup.ObjectId].Nodes.Add(node);
+ var grpId = remainingNodes[j].ObjectId;
+ //Got to add this group node too, otherwise we could infinite
+ //loop looking for a parent that's not registered
+ nodesById.Add(grpId, node);
+ groupsById.Add(grpId, node);
- //Got to add this group node too, otherwise we could infinite
- //loop looking for a parent that's not registered
- nodesById.Add(group.ObjectId, node);
- groupsById.Add(group.ObjectId, node);
- toRemove.Add(remainingNodes[j]);
+ toRemove.Add(remainingNodes[j]);
- //Whittle down this list
- if (toRemove.Count > 0)
+ //Whittle down this list
+ if (toRemove.Count > 0)
+ foreach (var g in toRemove)
- foreach (var g in toRemove)
- remainingNodes.Remove(g);
+ remainingNodes.Remove(g);
@@ -880,6 +880,8 @@
public string LegendLabel { get { return this.Group.LegendLabel; } }
+ public string ParentGroupName { get { return this.Group.Group; } }
public string Name { get { return this.Group.Name; } }
public override string ObjectId
@@ -990,6 +992,11 @@
/// <summary>
+ /// Gets the parent group name
+ /// </summary>
+ public string ParentGroupName { get { return this.Layer.Group; } }
+ /// <summary>
/// Gets the name
/// </summary>
public string Name { get { return this.Layer.Name; } }
More information about the mapguide-commits
