[mapguide-commits] r7516 - trunk/Tools/Maestro/RtMapInspector
svn_mapguide at osgeo.org
Thu May 23 22:14:00 PDT 2013
Author: jng
Date: 2013-05-23 22:14:00 -0700 (Thu, 23 May 2013)
New Revision: 7516
trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs
trunk/Tools/Maestro/RtMapInspector/MainForm.cs
trunk/Tools/Maestro/RtMapInspector/MainForm.resx
#2275: Add Draw Order tab to RtMapInspector allowing us to see the layers of a RuntimeMap sorted by draw order
Modified: trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs
--- trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs 2013-05-21 16:44:00 UTC (rev 7515)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.Designer.cs 2013-05-24 05:14:00 UTC (rev 7516)
@@ -47,12 +47,15 @@
this.trvSelection = new System.Windows.Forms.TreeView();
this.groupBox3 = new System.Windows.Forms.GroupBox();
this.properties = new System.Windows.Forms.PropertyGrid();
+ this.TAB_DRAW_ORDER = new System.Windows.Forms.TabPage();
+ this.lstDrawOrder = new System.Windows.Forms.ListBox();
this.groupBox1.SuspendLayout();
this.groupBox2.SuspendLayout();
this.tabControl1.SuspendLayout();
this.TAB_LAYERS.SuspendLayout();
this.TAB_SELECTION.SuspendLayout();
this.groupBox3.SuspendLayout();
+ this.TAB_DRAW_ORDER.SuspendLayout();
this.SuspendLayout();
// groupBox1
@@ -120,6 +123,7 @@
// tabControl1
this.tabControl1.Controls.Add(this.TAB_LAYERS);
+ this.tabControl1.Controls.Add(this.TAB_DRAW_ORDER);
this.tabControl1.Controls.Add(this.TAB_SELECTION);
resources.ApplyResources(this.tabControl1, "tabControl1");
this.tabControl1.Name = "tabControl1";
@@ -174,6 +178,20 @@
resources.ApplyResources(this.properties, "properties");
this.properties.Name = "properties";
+ // TAB_DRAW_ORDER
+ this.TAB_DRAW_ORDER.Controls.Add(this.lstDrawOrder);
+ resources.ApplyResources(this.TAB_DRAW_ORDER, "TAB_DRAW_ORDER");
+ this.TAB_DRAW_ORDER.Name = "TAB_DRAW_ORDER";
+ this.TAB_DRAW_ORDER.UseVisualStyleBackColor = true;
+ // lstDrawOrder
+ resources.ApplyResources(this.lstDrawOrder, "lstDrawOrder");
+ this.lstDrawOrder.FormattingEnabled = true;
+ this.lstDrawOrder.Name = "lstDrawOrder";
+ this.lstDrawOrder.SelectedIndexChanged += new System.EventHandler(this.lstDrawOrder_SelectedIndexChanged);
// MainForm
resources.ApplyResources(this, "$this");
@@ -189,6 +207,7 @@
this.TAB_LAYERS.ResumeLayout(false);
this.TAB_SELECTION.ResumeLayout(false);
this.groupBox3.ResumeLayout(false);
+ this.TAB_DRAW_ORDER.ResumeLayout(false);
this.ResumeLayout(false);
@@ -212,6 +231,8 @@
private System.Windows.Forms.TreeView trvLayersAndGroups;
private System.Windows.Forms.TabPage TAB_SELECTION;
private System.Windows.Forms.TreeView trvSelection;
+ private System.Windows.Forms.TabPage TAB_DRAW_ORDER;
+ private System.Windows.Forms.ListBox lstDrawOrder;
Modified: trunk/Tools/Maestro/RtMapInspector/MainForm.cs
--- trunk/Tools/Maestro/RtMapInspector/MainForm.cs 2013-05-21 16:44:00 UTC (rev 7515)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.cs 2013-05-24 05:14:00 UTC (rev 7516)
@@ -397,6 +397,24 @@
+ class DrawOrderDisplayItem
+ public string Label { get; private set; }
+ public LayerDecorator Decorator { get; private set; }
+ public DrawOrderDisplayItem(RuntimeMapLayer layer)
+ this.Label = layer.Name + " (" + layer.LegendLabel + ")";
+ this.Decorator = new LayerDecorator(layer);
+ public override string ToString()
+ return this.Label;
class ScaleRangeCollection : List<string>
public ScaleRangeCollection(RuntimeMapLayer.ScaleRange[] ranges)
@@ -446,6 +464,7 @@
_rtMap = null;
properties.SelectedObject = null;
trvLayersAndGroups.Nodes.Clear();
+ lstDrawOrder.Items.Clear();
trvSelection.Nodes.Clear();
if (rdMapName.Checked)
@@ -462,7 +481,7 @@
return;
- InitTreeView();
+ InitTabs();
const int IDX_GROUP = 0;
@@ -498,7 +517,7 @@
return node;
- private void InitTreeView()
+ private void InitTabs()
try
@@ -518,6 +537,19 @@
trvLayersAndGroups.EndUpdate();
+ try
+ lstDrawOrder.BeginUpdate();
+ foreach (var layer in _rtMap.Layers)
+ lstDrawOrder.Items.Add(new DrawOrderDisplayItem(layer));
+ finally
+ lstDrawOrder.EndUpdate();
var sel = _rtMap.Selection;
if (sel != null)
@@ -558,5 +590,12 @@
properties.SelectedObject = e.Node.Tag;
+ private void lstDrawOrder_SelectedIndexChanged(object sender, EventArgs e)
+ var item = lstDrawOrder.SelectedItem as DrawOrderDisplayItem;
+ if (item != null)
+ properties.SelectedObject = item.Decorator;
Modified: trunk/Tools/Maestro/RtMapInspector/MainForm.resx
--- trunk/Tools/Maestro/RtMapInspector/MainForm.resx 2013-05-21 16:44:00 UTC (rev 7515)
+++ trunk/Tools/Maestro/RtMapInspector/MainForm.resx 2013-05-24 05:14:00 UTC (rev 7516)
@@ -330,86 +330,6 @@
<data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
- <data name="trvLayersAndGroups.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- <value>Fill</value>
- </data>
- <data name="trvLayersAndGroups.ImageIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <metadata name="imgList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
- <data name="imgList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>
- AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
- LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAE
- DAAAAk1TRnQBSQFMAgEBBQEAARgBAAEYAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
- AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
- AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
- AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
- AWYDAAGZAwABzAIAATMDAAIzAgABMwFmAgABMwGZAgABMwHMAgABMwH/AgABZgMAAWYBMwIAAmYCAAFm
- AZkCAAFmAcwCAAFmAf8CAAGZAwABmQEzAgABmQFmAgACmQIAAZkBzAIAAZkB/wIAAcwDAAHMATMCAAHM
- AWYCAAHMAZkCAALMAgABzAH/AgAB/wFmAgAB/wGZAgAB/wHMAQABMwH/AgAB/wEAATMBAAEzAQABZgEA
- ATMBAAGZAQABMwEAAcwBAAEzAQAB/wEAAf8BMwIAAzMBAAIzAWYBAAIzAZkBAAIzAcwBAAIzAf8BAAEz
- AWYCAAEzAWYBMwEAATMCZgEAATMBZgGZAQABMwFmAcwBAAEzAWYB/wEAATMBmQIAATMBmQEzAQABMwGZ
- AWYBAAEzApkBAAEzAZkBzAEAATMBmQH/AQABMwHMAgABMwHMATMBAAEzAcwBZgEAATMBzAGZAQABMwLM
- AQABMwHMAf8BAAEzAf8BMwEAATMB/wFmAQABMwH/AZkBAAEzAf8BzAEAATMC/wEAAWYDAAFmAQABMwEA
- AWYBAAFmAQABZgEAAZkBAAFmAQABzAEAAWYBAAH/AQABZgEzAgABZgIzAQABZgEzAWYBAAFmATMBmQEA
- AWYBMwHMAQABZgEzAf8BAAJmAgACZgEzAQADZgEAAmYBmQEAAmYBzAEAAWYBmQIAAWYBmQEzAQABZgGZ
- AWYBAAFmApkBAAFmAZkBzAEAAWYBmQH/AQABZgHMAgABZgHMATMBAAFmAcwBmQEAAWYCzAEAAWYBzAH/
- AQABZgH/AgABZgH/ATMBAAFmAf8BmQEAAWYB/wHMAQABzAEAAf8BAAH/AQABzAEAApkCAAGZATMBmQEA
- AZkBAAGZAQABmQEAAcwBAAGZAwABmQIzAQABmQEAAWYBAAGZATMBzAEAAZkBAAH/AQABmQFmAgABmQFm
- ATMBAAGZATMBZgEAAZkBZgGZAQABmQFmAcwBAAGZATMB/wEAApkBMwEAApkBZgEAA5kBAAKZAcwBAAKZ
- Af8BAAGZAcwCAAGZAcwBMwEAAWYBzAFmAQABmQHMAZkBAAGZAswBAAGZAcwB/wEAAZkB/wIAAZkB/wEz
- AQABmQHMAWYBAAGZAf8BmQEAAZkB/wHMAQABmQL/AQABzAMAAZkBAAEzAQABzAEAAWYBAAHMAQABmQEA
- AcwBAAHMAQABmQEzAgABzAIzAQABzAEzAWYBAAHMATMBmQEAAcwBMwHMAQABzAEzAf8BAAHMAWYCAAHM
- AWYBMwEAAZkCZgEAAcwBZgGZAQABzAFmAcwBAAGZAWYB/wEAAcwBmQIAAcwBmQEzAQABzAGZAWYBAAHM
- ApkBAAHMAZkBzAEAAcwBmQH/AQACzAIAAswBMwEAAswBZgEAAswBmQEAA8wBAALMAf8BAAHMAf8CAAHM
- Af8BMwEAAZkB/wFmAQABzAH/AZkBAAHMAf8BzAEAAcwC/wEAAcwBAAEzAQAB/wEAAWYBAAH/AQABmQEA
- AcwBMwIAAf8CMwEAAf8BMwFmAQAB/wEzAZkBAAH/ATMBzAEAAf8BMwH/AQAB/wFmAgAB/wFmATMBAAHM
- AmYBAAH/AWYBmQEAAf8BZgHMAQABzAFmAf8BAAH/AZkCAAH/AZkBMwEAAf8BmQFmAQAB/wKZAQAB/wGZ
- AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
- AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
- AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
- AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAD/8xAAG8DQcBvDEA
- AQcB/wv0Af8BBzEAAbwB9AZzAngBHAKZAfQBvDEAAbwB9AFzARwBeAFzAngBmQEcAZ8BwwEIAfQBvDEA
- AbwB9AFzARwBeAFzAXgCmQGYAZ8BGwEHAfQBvDEAAbwB9ANzA3gBmAKZAQgBuwH0AbwxAAG8Af8BcwN4
- ApkBnwGZARsBGQG7Af8BvDEAAbwB/wFzA3gCmQGfAZkB8QHcAboB/wG8MQAB8AH/AXMBeAGZAXgBmQGf
- AcMBCAEJAdwBugH/AfAxAAHwAf8DeAOZAQgCuwK6Af8B8DEAAfAB/wF4A5kBwwEbAfEBuwLcAboB/wHw
- MQAB8AH/AXgDmQHDAcIBCQG6AdwB2wG6Af8B8DEAAfAB/wF4AZgCmQEIArsDugG0Af8B8DEAAfEN/wHx
- MQAB8w3yAfMxAAH/AfQBHAp0ARwB9AL/AfQBHAp0ARwB9CP/AXQImgFSAZoBdAHyA/8BdAiaAVIBmgF0
- AfIC/wHzDLwB8wL/AfMMvAHzAf8CAAGZAZoGegGaAXQBmgHaAZkBAAGTAW4ERQFLA3oBmgF0AZoB2gGZ
- AgAB8QHwCvIB8AHxAgAB8QHwBvIBbgVFAZMCAAGZAZoGegGaAXQBmgHaAZkBAAFvBeMBRQN6AZoBdAGa
- AdoBmQIAAfAM8gHwAgAB8AfyAUUF4wFvAgABmQiaAXQBmgHzAZkBAAGTAW8ERgFMBJoBdAGaAfMBmQIA
- AfAM8gHwAgAB8AfyAW8ERgFFAZMCAAGZCJoBdAGaAfQBmQMAAZkImgF0AZoB9AGZAgAB8QzyAfECAAHx
- DPIB8QMAAZkImgF0AZoB/wGZAwABmQiaAXQBmgH/AZkCAAHxAfML8gHxAgAB8QHzC/IB8QMAAZkImgJ5
- Af8BmQMAAZkImgJ5Af8BmQIAAfEB8wvyAfECAAHxAfML8gHxAwABmQmaAXkBmQH0AwABmQmaAXkBmQH0
- AgAB8QPzCfIB8QIAAfED8wnyAfEDAAGZCZoBoAGZBAABmQmaAaABmQMAAfIG8wfyAgAB8gbzB/IDAAEa
- AaAImgGgARoEAAEaAaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaAaAImgGgARoEAAEa
- AaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaCqABGgQAARoKoAEaAwAB8gH0CvMB9AHy
- AgAB8gH0CvMB9AHyAwABGgqgARoEAAEaCqABGgMAAfMB8gr0AfIB8wIAAfMB8gr0AfIB8wMAARoBwwig
- AcMBGgQAARoBwwigAcMBGgMAAf8B8wryAfMB/wIAAf8B8wryAfMB/wMAARsKGgEbBAABGwoaARsiAAFC
- AU0BPgcAAT4DAAEoAwABQAMAASADAAEBAQABAQYAAQEWAAP/AgABAQcAAQEHAAEBBwABAQcAAQEHAAEB
- BwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABARYAAcABAQEAAQEBgAEBAYABAAHA
- AQEBAAEBAYABAQGAAQABwAEBAQABAQGAAQEBgAEAAcABAQHAAQEBgAEBAYABAQHAAQEBwAEBAYABAQGA
- AQEBwAEBAcABAQGAAQEBgAEBAcABAQHAAQEBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGA
- AQEBgAEBAcABAwHAAQMBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGAAQEBgAEBAcABAwHA
- AQMBgAEBAYABAQHAAQMBwAEDBP8L
-</value>
- </data>
- <data name="trvLayersAndGroups.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 3</value>
- </data>
- <data name="trvLayersAndGroups.SelectedImageIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name="trvLayersAndGroups.Size" type="System.Drawing.Size, System.Drawing">
- <value>301, 277</value>
- </data>
- <data name="trvLayersAndGroups.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
<data name=">>trvLayersAndGroups.Name" xml:space="preserve">
<value>trvLayersAndGroups</value>
</data>
@@ -449,24 +369,57 @@
<data name=">>TAB_LAYERS.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="trvSelection.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <data name="lstDrawOrder.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
- <data name="trvSelection.ImageIndex" type="System.Int32, mscorlib">
+ <data name="lstDrawOrder.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 3</value>
+ </data>
+ <data name="lstDrawOrder.Size" type="System.Drawing.Size, System.Drawing">
+ <value>301, 277</value>
+ </data>
+ <data name="lstDrawOrder.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
</data>
- <data name="trvSelection.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 0</value>
+ <data name=">>lstDrawOrder.Name" xml:space="preserve">
+ <value>lstDrawOrder</value>
</data>
- <data name="trvSelection.SelectedImageIndex" type="System.Int32, mscorlib">
+ <data name=">>lstDrawOrder.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lstDrawOrder.Parent" xml:space="preserve">
+ <value>TAB_DRAW_ORDER</value>
+ </data>
+ <data name=">>lstDrawOrder.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="trvSelection.Size" type="System.Drawing.Size, System.Drawing">
+ <data name="TAB_DRAW_ORDER.Location" type="System.Drawing.Point, System.Drawing">
+ <value>4, 22</value>
+ </data>
+ <data name="TAB_DRAW_ORDER.Padding" type="System.Windows.Forms.Padding, System.Windows.Forms">
+ <value>3, 3, 3, 3</value>
+ </data>
+ <data name="TAB_DRAW_ORDER.Size" type="System.Drawing.Size, System.Drawing">
<value>307, 283</value>
</data>
- <data name="trvSelection.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
+ <data name="TAB_DRAW_ORDER.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
</data>
+ <data name="TAB_DRAW_ORDER.Text" xml:space="preserve">
+ <value>Draw Order</value>
+ </data>
+ <data name=">>TAB_DRAW_ORDER.Name" xml:space="preserve">
+ </data>
+ <data name=">>TAB_DRAW_ORDER.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>TAB_DRAW_ORDER.Parent" xml:space="preserve">
+ <value>tabControl1</value>
+ </data>
+ <data name=">>TAB_DRAW_ORDER.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name=">>trvSelection.Name" xml:space="preserve">
<value>trvSelection</value>
</data>
@@ -501,7 +454,7 @@
</data>
<data name=">>TAB_SELECTION.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>2</value>
</data>
<data name="tabControl1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
@@ -551,21 +504,131 @@
<data name=">>groupBox2.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Bottom, Right</value>
+ <data name="trvLayersAndGroups.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
</data>
- <data name="properties.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <data name="trvLayersAndGroups.ImageIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <metadata name="imgList.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="imgList.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAE
+ DAAAAk1TRnQBSQFMAgEBBQEAASABAAEgAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
+ AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
+ AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
+ AWYDAAGZAwABzAIAATMDAAIzAgABMwFmAgABMwGZAgABMwHMAgABMwH/AgABZgMAAWYBMwIAAmYCAAFm
+ AZkCAAFmAcwCAAFmAf8CAAGZAwABmQEzAgABmQFmAgACmQIAAZkBzAIAAZkB/wIAAcwDAAHMATMCAAHM
+ AWYCAAHMAZkCAALMAgABzAH/AgAB/wFmAgAB/wGZAgAB/wHMAQABMwH/AgAB/wEAATMBAAEzAQABZgEA
+ ATMBAAGZAQABMwEAAcwBAAEzAQAB/wEAAf8BMwIAAzMBAAIzAWYBAAIzAZkBAAIzAcwBAAIzAf8BAAEz
+ AWYCAAEzAWYBMwEAATMCZgEAATMBZgGZAQABMwFmAcwBAAEzAWYB/wEAATMBmQIAATMBmQEzAQABMwGZ
+ AWYBAAEzApkBAAEzAZkBzAEAATMBmQH/AQABMwHMAgABMwHMATMBAAEzAcwBZgEAATMBzAGZAQABMwLM
+ AQABMwHMAf8BAAEzAf8BMwEAATMB/wFmAQABMwH/AZkBAAEzAf8BzAEAATMC/wEAAWYDAAFmAQABMwEA
+ AWYBAAFmAQABZgEAAZkBAAFmAQABzAEAAWYBAAH/AQABZgEzAgABZgIzAQABZgEzAWYBAAFmATMBmQEA
+ AWYBMwHMAQABZgEzAf8BAAJmAgACZgEzAQADZgEAAmYBmQEAAmYBzAEAAWYBmQIAAWYBmQEzAQABZgGZ
+ AWYBAAFmApkBAAFmAZkBzAEAAWYBmQH/AQABZgHMAgABZgHMATMBAAFmAcwBmQEAAWYCzAEAAWYBzAH/
+ AQABZgH/AgABZgH/ATMBAAFmAf8BmQEAAWYB/wHMAQABzAEAAf8BAAH/AQABzAEAApkCAAGZATMBmQEA
+ AZkBAAGZAQABmQEAAcwBAAGZAwABmQIzAQABmQEAAWYBAAGZATMBzAEAAZkBAAH/AQABmQFmAgABmQFm
+ ATMBAAGZATMBZgEAAZkBZgGZAQABmQFmAcwBAAGZATMB/wEAApkBMwEAApkBZgEAA5kBAAKZAcwBAAKZ
+ Af8BAAGZAcwCAAGZAcwBMwEAAWYBzAFmAQABmQHMAZkBAAGZAswBAAGZAcwB/wEAAZkB/wIAAZkB/wEz
+ AQABmQHMAWYBAAGZAf8BmQEAAZkB/wHMAQABmQL/AQABzAMAAZkBAAEzAQABzAEAAWYBAAHMAQABmQEA
+ AcwBAAHMAQABmQEzAgABzAIzAQABzAEzAWYBAAHMATMBmQEAAcwBMwHMAQABzAEzAf8BAAHMAWYCAAHM
+ AWYBMwEAAZkCZgEAAcwBZgGZAQABzAFmAcwBAAGZAWYB/wEAAcwBmQIAAcwBmQEzAQABzAGZAWYBAAHM
+ ApkBAAHMAZkBzAEAAcwBmQH/AQACzAIAAswBMwEAAswBZgEAAswBmQEAA8wBAALMAf8BAAHMAf8CAAHM
+ Af8BMwEAAZkB/wFmAQABzAH/AZkBAAHMAf8BzAEAAcwC/wEAAcwBAAEzAQAB/wEAAWYBAAH/AQABmQEA
+ AcwBMwIAAf8CMwEAAf8BMwFmAQAB/wEzAZkBAAH/ATMBzAEAAf8BMwH/AQAB/wFmAgAB/wFmATMBAAHM
+ AmYBAAH/AWYBmQEAAf8BZgHMAQABzAFmAf8BAAH/AZkCAAH/AZkBMwEAAf8BmQFmAQAB/wKZAQAB/wGZ
+ AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
+ AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
+ AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
+ AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAD/8xAAG8DQcBvDEA
+ AQcB/wv0Af8BBzEAAbwB9AZzAngBHAKZAfQBvDEAAbwB9AFzARwBeAFzAngBmQEcAZ8BwwEIAfQBvDEA
+ AbwB9AFzARwBeAFzAXgCmQGYAZ8BGwEHAfQBvDEAAbwB9ANzA3gBmAKZAQgBuwH0AbwxAAG8Af8BcwN4
+ ApkBnwGZARsBGQG7Af8BvDEAAbwB/wFzA3gCmQGfAZkB8QHcAboB/wG8MQAB8AH/AXMBeAGZAXgBmQGf
+ AcMBCAEJAdwBugH/AfAxAAHwAf8DeAOZAQgCuwK6Af8B8DEAAfAB/wF4A5kBwwEbAfEBuwLcAboB/wHw
+ MQAB8AH/AXgDmQHDAcIBCQG6AdwB2wG6Af8B8DEAAfAB/wF4AZgCmQEIArsDugG0Af8B8DEAAfEN/wHx
+ MQAB8w3yAfMxAAH/AfQBHAp0ARwB9AL/AfQBHAp0ARwB9CP/AXQImgFSAZoBdAHyA/8BdAiaAVIBmgF0
+ AfIC/wHzDLwB8wL/AfMMvAHzAf8CAAGZAZoGegGaAXQBmgHaAZkBAAGTAW4ERQFLA3oBmgF0AZoB2gGZ
+ AgAB8QHwCvIB8AHxAgAB8QHwBvIBbgVFAZMCAAGZAZoGegGaAXQBmgHaAZkBAAFvBeMBRQN6AZoBdAGa
+ AdoBmQIAAfAM8gHwAgAB8AfyAUUF4wFvAgABmQiaAXQBmgHzAZkBAAGTAW8ERgFMBJoBdAGaAfMBmQIA
+ AfAM8gHwAgAB8AfyAW8ERgFFAZMCAAGZCJoBdAGaAfQBmQMAAZkImgF0AZoB9AGZAgAB8QzyAfECAAHx
+ DPIB8QMAAZkImgF0AZoB/wGZAwABmQiaAXQBmgH/AZkCAAHxAfML8gHxAgAB8QHzC/IB8QMAAZkImgJ5
+ Af8BmQMAAZkImgJ5Af8BmQIAAfEB8wvyAfECAAHxAfML8gHxAwABmQmaAXkBmQH0AwABmQmaAXkBmQH0
+ AgAB8QPzCfIB8QIAAfED8wnyAfEDAAGZCZoBoAGZBAABmQmaAaABmQMAAfIG8wfyAgAB8gbzB/IDAAEa
+ AaAImgGgARoEAAEaAaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaAaAImgGgARoEAAEa
+ AaAImgGgARoDAAHyAfQK8wH0AfICAAHyAfQK8wH0AfIDAAEaCqABGgQAARoKoAEaAwAB8gH0CvMB9AHy
+ AgAB8gH0CvMB9AHyAwABGgqgARoEAAEaCqABGgMAAfMB8gr0AfIB8wIAAfMB8gr0AfIB8wMAARoBwwig
+ AcMBGgQAARoBwwigAcMBGgMAAf8B8wryAfMB/wIAAf8B8wryAfMB/wMAARsKGgEbBAABGwoaARsiAAFC
+ AU0BPgcAAT4DAAEoAwABQAMAASADAAEBAQABAQYAAQEWAAP/AgABAQcAAQEHAAEBBwABAQcAAQEHAAEB
+ BwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABAQcAAQEHAAEBBwABARYAAcABAQEAAQEBgAEBAYABAAHA
+ AQEBAAEBAYABAQGAAQABwAEBAQABAQGAAQEBgAEAAcABAQHAAQEBgAEBAYABAQHAAQEBwAEBAYABAQGA
+ AQEBwAEBAcABAQGAAQEBgAEBAcABAQHAAQEBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGA
+ AQEBgAEBAcABAwHAAQMBgAEBAYABAQHAAQMBwAEDAYABAQGAAQEBwAEDAcABAwGAAQEBgAEBAcABAwHA
+ AQMBgAEBAYABAQHAAQMBwAEDBP8L
+</value>
+ </data>
+ <data name="trvLayersAndGroups.Location" type="System.Drawing.Point, System.Drawing">
+ </data>
+ <data name="trvLayersAndGroups.SelectedImageIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="trvLayersAndGroups.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="trvLayersAndGroups.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>trvLayersAndGroups.Name" xml:space="preserve">
+ <value>trvLayersAndGroups</value>
+ </data>
+ <data name=">>trvLayersAndGroups.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>trvLayersAndGroups.Parent" xml:space="preserve">
+ <value>TAB_LAYERS</value>
+ </data>
+ <data name=">>trvLayersAndGroups.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="trvSelection.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
- <data name="properties.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 16</value>
+ <data name="trvSelection.ImageIndex" type="System.Int32, mscorlib">
+ <value>0</value>
</data>
- <data name="properties.Size" type="System.Drawing.Size, System.Drawing">
- <value>264, 309</value>
+ <data name="trvSelection.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
</data>
- <data name="properties.TabIndex" type="System.Int32, mscorlib">
+ <data name="trvSelection.SelectedImageIndex" type="System.Int32, mscorlib">
<value>0</value>
</data>
+ <data name="trvSelection.Size" type="System.Drawing.Size, System.Drawing">
+ <value>307, 283</value>
+ </data>
+ <data name="trvSelection.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>trvSelection.Name" xml:space="preserve">
+ <value>trvSelection</value>
+ </data>
+ <data name=">>trvSelection.Type" xml:space="preserve">
+ </data>
+ <data name=">>trvSelection.Parent" xml:space="preserve">
+ <value>TAB_SELECTION</value>
+ </data>
+ <data name=">>trvSelection.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Right</value>
+ </data>
<data name=">>properties.Name" xml:space="preserve">
<value>properties</value>
</data>
@@ -602,6 +665,30 @@
<data name=">>groupBox3.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <data name="properties.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="properties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
+ </data>
+ <data name="properties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>264, 309</value>
+ </data>
+ <data name="properties.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>properties.Name" xml:space="preserve">
+ <value>properties</value>
+ </data>
+ <data name=">>properties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.PropertyGrid, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>properties.Parent" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>properties.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
More information about the mapguide-commits
