[mapguide-commits] r7542 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu May 30 01:30:27 PDT 2013
Author: christinebao
Date: 2013-05-30 01:30:27 -0700 (Thu, 30 May 2013)
New Revision: 7542
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
#2258: Serve WFS in alternate CS: SRSNAME not respected in getfeature, alternate SRS not available
- If there is no coordinate system pass in, get the primary SRS in resource header.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2013-05-30 07:13:22 UTC (rev 7541)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2013-05-30 08:30:27 UTC (rev 7542)
@@ -1827,8 +1827,39 @@
MgCoordinateSystemFactory fact;
- Ptr<MgCoordinateSystem> mapCs = (srs.empty()) ? NULL : fact.Create(srs);
+ std::wstring wkt = srs;
+ if (wkt.empty())
+ //If there is no coordinate system pass in, get the default one in resource header.
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(serviceMan->RequestService(MgServiceType::ResourceService));
+ assert(resourceService != NULL);
+ Ptr<MgByteReader> byteReaderHeader = resourceService->GetResourceHeader(fs);
+ Ptr<MgByteSink> byteSinkHeader = new MgByteSink(byteReaderHeader);
+ std::string resourceHeader;
+ byteSinkHeader->ToStringUtf8(resourceHeader);
+ //parse for default SRS of this WFS, the format is:
+ //<Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
+ // <Name>_PrimarySRS</Name>
+ // <Value>EPSG:4326</Value>
+ //</Property>
+ std::string begin("EPSG:");
+ std::size_t beginPos = resourceHeader.find(begin);
+ if (beginPos != std::string::npos)
+ std::size_t endPos = resourceHeader.find("</Value>", beginPos);
+ if (endPos != std::string::npos)
+ std::string primarySRS = resourceHeader.substr(beginPos+begin.length(), endPos-beginPos-begin.length());
+ int epsgCode = atoi(primarySRS.c_str());
+ wkt = fact.ConvertEpsgCodeToWkt(epsgCode);
+ Ptr<MgCoordinateSystem> mapCs = (wkt.empty()) ? NULL : fact.Create(wkt);
//get a transform from feature space to mapping space
TransformCache* item = TransformCache::GetLayerToMapTransform(transformCache, lfeatureName, fs, mapCs, &fact, this);
Ptr<MgCoordinateSystemTransform> trans = item? item->GetMgTransform() : NULL;
More information about the mapguide-commits
