[mapguide-commits] r7895 - trunk/MgDev/Common/Renderers
svn_mapguide at osgeo.org
Sun Nov 3 13:04:06 PST 2013
Author: waltweltonlair
Date: 2013-11-03 13:04:06 -0800 (Sun, 03 Nov 2013)
New Revision: 7895
trunk/MgDev/Common/Renderers/AGGRenderer.cpp
Fix #2285 (DOTS hatch pattern from DWF files not rendering using AGG Renderer)
Reviewed and applied path from from Faruk attached to ticket.
Modified: trunk/MgDev/Common/Renderers/AGGRenderer.cpp
--- trunk/MgDev/Common/Renderers/AGGRenderer.cpp 2013-11-03 20:46:34 UTC (rev 7894)
+++ trunk/MgDev/Common/Renderers/AGGRenderer.cpp 2013-11-03 21:04:06 UTC (rev 7895)
@@ -2012,8 +2012,8 @@
xform->transform(tx, ty, tx, ty);
// detect a close segment (in a Linebuffer this is caused by first and
- // last point of the contour being equal
- if (tx == sx && ty == sy)
+ // last point of the contour being equal and size of contour > 2 points)
+ if (tx == sx && ty == sy && ptlast > 1)
c->ps.close_polygon();
else if (ptlast == 1)
@@ -2030,11 +2030,21 @@
if (len2 < 100.0*LINE_SEGMENT_DOT_SIZE*LINE_SEGMENT_DOT_SIZE)
// found a dot - draw it as a 1-pixel long line
- double len = sqrt(len2);
- dx /= len;
- dy /= len;
- c->ps.move_to(tx-0.5*dx, ty-0.5*dy);
- c->ps.line_to(tx+0.5*dx, ty+0.5*dy);
+ if (len2 > 0.0)
+ double len = sqrt(len2);
+ dx /= len;
+ dy /= len;
+ c->ps.move_to(tx-0.5*dx, ty-0.5*dy);
+ c->ps.line_to(tx+0.5*dx, ty+0.5*dy);
+ else
+ // length of line can be 0 when DOTS_HATCH is rendered from DWF
+ // so use LINE_SEGMENT_DOT_SIZE to render that dots
+ c->ps.move_to(tx-LINE_SEGMENT_DOT_SIZE, ty-LINE_SEGMENT_DOT_SIZE);
+ c->ps.line_to(tx+LINE_SEGMENT_DOT_SIZE, ty+LINE_SEGMENT_DOT_SIZE);
else
More information about the mapguide-commits
