[mapguide-commits] r7904 - in trunk/MgDev/Doc/samples/ol2samples: . commercial data mixed
svn_mapguide at osgeo.org
Thu Nov 7 01:38:08 PST 2013
Author: jng
Date: 2013-11-07 01:38:08 -0800 (Thu, 07 Nov 2013)
New Revision: 7904
Added:
trunk/MgDev/Doc/samples/ol2samples/data/
trunk/MgDev/Doc/samples/ol2samples/data/SheboyganCommercial.MapDefinition.xml
trunk/MgDev/Doc/samples/ol2samples/data/SheboyganMixed.MapDefinition.xml
trunk/MgDev/Doc/samples/ol2samples/data/load.php
Removed:
trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml
trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml
trunk/MgDev/Doc/samples/ol2samples/commercial/index.html
trunk/MgDev/Doc/samples/ol2samples/mixed/index.html
#2343: Add a helper PHP script to load in the required resources for some of the OpenLayers integration samples to work.
Deleted: trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml
--- trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml 2013-11-07 05:38:17 UTC (rev 7903)
+++ trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml 2013-11-07 09:38:08 UTC (rev 7904)
@@ -1,116 +0,0 @@
-<?xml version="1.0"?>
-<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
- <Name>Sheboygan Map</Name>
- <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
- <Extents>
- <MinX>-9769953.6613122653</MinX>
- <MaxX>-9762220.7994439267</MaxX>
- <MinY>5417808.8801717851</MinY>
- <MaxY>5434161.2241863841</MaxY>
- </Extents>
- <BackgroundColor>ffcdbd9c</BackgroundColor>
- <MapLayer>
- <Name>Roads</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
- <Selectable>false</Selectable>
- <ShowInLegend>true</ShowInLegend>
- <LegendLabel>Roads</LegendLabel>
- <ExpandInLegend>true</ExpandInLegend>
- <Visible>true</Visible>
- <Group>Transportation</Group>
- </MapLayer>
- <MapLayer>
- <Name>Rail Lines</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</ResourceId>
- <LegendLabel>Rail Lines</LegendLabel>
- <Visible>false</Visible>
- </MapLayer>
- <MapLayer>
- <Name>Districts</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
- <LegendLabel>Districts</LegendLabel>
- <Group>Municipal</Group>
- </MapLayer>
- <MapLayer>
- <Name>Buildings</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
- <LegendLabel>Buildings</LegendLabel>
- </MapLayer>
- <MapLayer>
- <Name>Parcels</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
- <Selectable>true</Selectable>
- <LegendLabel>Parcels</LegendLabel>
- </MapLayer>
- <MapLayer>
- <Name>Islands</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
- <LegendLabel>Islands</LegendLabel>
- <Group>Base Map</Group>
- </MapLayer>
- <MapLayer>
- <Name>Hydrography</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
- <LegendLabel>Hydrography</LegendLabel>
- </MapLayer>
- <MapLayer>
- <Name>CityLimits</Name>
- <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
- <LegendLabel>CityLimits</LegendLabel>
- </MapLayer>
- <MapLayerGroup>
- <Name>Base Map</Name>
- <LegendLabel>Base Map</LegendLabel>
- <Group />
- </MapLayerGroup>
- <MapLayerGroup>
- <Name>Municipal</Name>
- <LegendLabel>Municipal</LegendLabel>
- <Group />
- </MapLayerGroup>
- <MapLayerGroup>
- <Name>Transportation</Name>
- <LegendLabel>Transportation</LegendLabel>
- <Group />
- </MapLayerGroup>
-</MapDefinition>
\ No newline at end of file
Modified: trunk/MgDev/Doc/samples/ol2samples/commercial/index.html
--- trunk/MgDev/Doc/samples/ol2samples/commercial/index.html 2013-11-07 05:38:17 UTC (rev 7903)
+++ trunk/MgDev/Doc/samples/ol2samples/commercial/index.html 2013-11-07 09:38:08 UTC (rev 7904)
@@ -218,6 +218,7 @@
<body>
<p>This example demonstrates MapGuide layer integration with Google/OSM. The map is created with CREATERUNTIMEMAP.</p>
<p>The Map Definition is in WGS84.PseudoMercator which allows for the MapGuide map to line up with any Google/OSM layer</p>
+ <p>Sample not loading? <a href="../data/load.php">Check that the required resources have been loaded</a></p>
<div id="error">
</div>
<div id="wrap">
Property changes on: trunk/MgDev/Doc/samples/ol2samples/data
___________________________________________________________________
Added: bugtraq:number
+ true
Copied: trunk/MgDev/Doc/samples/ol2samples/data/SheboyganCommercial.MapDefinition.xml (from rev 7896, trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml)
--- trunk/MgDev/Doc/samples/ol2samples/data/SheboyganCommercial.MapDefinition.xml (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/data/SheboyganCommercial.MapDefinition.xml 2013-11-07 09:38:08 UTC (rev 7904)
@@ -0,0 +1,116 @@
+<?xml version="1.0"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
+ <Name>Sheboygan Map</Name>
+ <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
+ <Extents>
+ <MinX>-9769953.6613122653</MinX>
+ <MaxX>-9762220.7994439267</MaxX>
+ <MinY>5417808.8801717851</MinY>
+ <MaxY>5434161.2241863841</MaxY>
+ </Extents>
+ <BackgroundColor>ffcdbd9c</BackgroundColor>
+ <MapLayer>
+ <Name>Roads</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+ <Selectable>false</Selectable>
+ <ShowInLegend>true</ShowInLegend>
+ <LegendLabel>Roads</LegendLabel>
+ <ExpandInLegend>true</ExpandInLegend>
+ <Visible>true</Visible>
+ <Group>Transportation</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Rail Lines</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</ResourceId>
+ <LegendLabel>Rail Lines</LegendLabel>
+ <Visible>false</Visible>
+ </MapLayer>
+ <MapLayer>
+ <Name>Districts</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+ <LegendLabel>Districts</LegendLabel>
+ <Group>Municipal</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Buildings</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+ <LegendLabel>Buildings</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>Islands</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+ <LegendLabel>Islands</LegendLabel>
+ <Group>Base Map</Group>
+ </MapLayer>
+ <MapLayer>
+ <Name>Hydrography</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+ <LegendLabel>Hydrography</LegendLabel>
+ </MapLayer>
+ <MapLayer>
+ <Name>CityLimits</Name>
+ <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+ <LegendLabel>CityLimits</LegendLabel>
+ </MapLayer>
+ <MapLayerGroup>
+ <Name>Base Map</Name>
+ <LegendLabel>Base Map</LegendLabel>
+ <Group />
+ </MapLayerGroup>
+ <MapLayerGroup>
+ <Name>Municipal</Name>
+ <LegendLabel>Municipal</LegendLabel>
+ <Group />
+ </MapLayerGroup>
+ <MapLayerGroup>
+ <Name>Transportation</Name>
+ <LegendLabel>Transportation</LegendLabel>
+ <Group />
+ </MapLayerGroup>
+</MapDefinition>
Copied: trunk/MgDev/Doc/samples/ol2samples/data/SheboyganMixed.MapDefinition.xml (from rev 7896, trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml)
--- trunk/MgDev/Doc/samples/ol2samples/data/SheboyganMixed.MapDefinition.xml (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/data/SheboyganMixed.MapDefinition.xml 2013-11-07 09:38:08 UTC (rev 7904)
@@ -0,0 +1,114 @@
+ <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+ <Extents>
+ <MinX>-87.764986990962839</MinX>
+ <MaxX>-87.695521510899724</MaxX>
+ <MinY>43.691398128787782</MinY>
+ <MaxY>43.797520000480347</MaxY>
+ </Extents>
+ <MapLayer>
+ <Group>Other</Group>
+ </MapLayer>
+ <MapLayer>
+ </MapLayer>
+ <MapLayer>
+ </MapLayer>
+ <MapLayerGroup>
+ <Name>Other</Name>
+ <LegendLabel>Other</LegendLabel>
+ <Group />
+ </MapLayerGroup>
+ <BaseMapDefinition>
+ <FiniteDisplayScale>1000</FiniteDisplayScale>
+ <FiniteDisplayScale>1930.69773</FiniteDisplayScale>
+ <FiniteDisplayScale>3727.59372</FiniteDisplayScale>
+ <FiniteDisplayScale>7196.85673</FiniteDisplayScale>
+ <FiniteDisplayScale>13894.95494</FiniteDisplayScale>
+ <FiniteDisplayScale>26826.95795</FiniteDisplayScale>
+ <FiniteDisplayScale>51794.74679</FiniteDisplayScale>
+ <FiniteDisplayScale>100000</FiniteDisplayScale>
+ <BaseMapLayerGroup>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ </BaseMapLayer>
+ </BaseMapDefinition>
+</MapDefinition>
Added: trunk/MgDev/Doc/samples/ol2samples/data/load.php
--- trunk/MgDev/Doc/samples/ol2samples/data/load.php (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/data/load.php 2013-11-07 09:38:08 UTC (rev 7904)
@@ -0,0 +1,62 @@
+<html>
+ <head>
+ <title>Load OpenLayers integration Sample Data</title>
+ <style type="text/css">
+ .error { color:red; }
+ </style>
+ </head>
+ <body>
+<?php
+include(dirname(__FILE__)."/../../mapadmin/constants.php");
+try
+MgInitializeWebTier(dirname(__FILE__)."/../../webconfig.ini");
+if (array_key_exists("USERNAME", $_POST) && array_key_exists("PASSWORD", $_POST)) {
+ $siteConn = new MgSiteConnection();
+ $userInfo = new MgUserInformation($_POST["USERNAME"], $_POST["PASSWORD"]);
+ $siteConn->Open($userInfo);
+ $resSvc = $siteConn->CreateService(MgServiceType::ResourceService);
+ //Commercial sample
+ $res1 = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition");
+ $bs1 = new MgByteSource(dirname(__FILE__)."/SheboyganCommercial.MapDefinition.xml");
+ $br1 = $bs1->GetReader();
+ $resSvc->SetResource($res1, $br1, null);
+ //Mixed sample
+ $res2 = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/SheboyganMixed.MapDefinition");
+ $bs2 = new MgByteSource(dirname(__FILE__)."/SheboyganMixed.MapDefinition.xml");
+ $br2 = $bs2->GetReader();
+ $resSvc->SetResource($res2, $br2, null);
+ <p>Sample resources required for OpenLayers integration samples loaded.</p>
+ <p><a href="../../samples.php">Return to samples</a></p>
+<? } else { ?>
+ <p>To load the sample resources required for OpenLayers integration samples, login as Administrator</p>
+ <p><strong>NOTE: Make sure you have already downloaded the <a href="http://download.osgeo.org/mapguide/releases/2.0.0/samples/Sheboygan.mgp">Sheboygan Dataset</a> and load this in via the <a href="../../mapadmin/login.php">MapGuide Site Administrator</a> first before loading these OpenLayers integration sample resources</strong></p>
+ <form action="load.php" method="post">
+ Username: <input type="text" name="USERNAME" id="USERNAME" />
+ <br/>
+ Password: <input type="password" name="PASSWORD" id="PASSWORD" />
+ <br/>
+ <input type="submit" value="Login" />
+ </form>
+} catch (MgException $e) {
+ <p>An error occured:</p>
+ <div class="error">
+ <?= $e->GetDetails() ?>
+ </div>
+ <p><a href="javascript:history.go(-1)">Go back</a></p>
+ </body>
+</html>
Deleted: trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml
--- trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml 2013-11-07 05:38:17 UTC (rev 7903)
+++ trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml 2013-11-07 09:38:08 UTC (rev 7904)
@@ -1,114 +0,0 @@
- <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
- <Extents>
- <MinX>-87.764986990962839</MinX>
- <MaxX>-87.695521510899724</MaxX>
- <MinY>43.691398128787782</MinY>
- <MaxY>43.797520000480347</MaxY>
- </Extents>
- <MapLayer>
- <Group>Other</Group>
- </MapLayer>
- <MapLayer>
- </MapLayer>
- <MapLayer>
- </MapLayer>
- <MapLayerGroup>
- <Name>Other</Name>
- <LegendLabel>Other</LegendLabel>
- <Group />
- </MapLayerGroup>
- <BaseMapDefinition>
- <FiniteDisplayScale>1000</FiniteDisplayScale>
- <FiniteDisplayScale>1930.69773</FiniteDisplayScale>
- <FiniteDisplayScale>3727.59372</FiniteDisplayScale>
- <FiniteDisplayScale>7196.85673</FiniteDisplayScale>
- <FiniteDisplayScale>13894.95494</FiniteDisplayScale>
- <FiniteDisplayScale>26826.95795</FiniteDisplayScale>
- <FiniteDisplayScale>51794.74679</FiniteDisplayScale>
- <FiniteDisplayScale>100000</FiniteDisplayScale>
- <BaseMapLayerGroup>
- <BaseMapLayer>
- </BaseMapLayer>
- <BaseMapLayer>
- </BaseMapLayer>
- </BaseMapLayerGroup>
- <BaseMapLayer>
- </BaseMapLayer>
- <BaseMapLayer>
- </BaseMapLayer>
- <BaseMapLayer>
- </BaseMapLayer>
- </BaseMapDefinition>
-</MapDefinition>
Modified: trunk/MgDev/Doc/samples/ol2samples/mixed/index.html
--- trunk/MgDev/Doc/samples/ol2samples/mixed/index.html 2013-11-07 05:38:17 UTC (rev 7903)
+++ trunk/MgDev/Doc/samples/ol2samples/mixed/index.html 2013-11-07 09:38:08 UTC (rev 7904)
@@ -220,6 +220,7 @@
</head>
<body>
<p>This example demonstrates loading a Map Definition with both tiled and untiled layers. The map is created with CREATERUNTIMEMAP</p>
<div id="error">
</div>
<div id="wrap">
More information about the mapguide-commits
