[mapguide-commits] r7927 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Sun Nov 24 08:18:16 PST 2013
Author: jng
Date: 2013-11-24 08:18:16 -0800 (Sun, 24 Nov 2013)
New Revision: 7927
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2013-11-24 16:10:38 UTC (rev 7926)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2013-11-24 16:18:16 UTC (rev 7927)
@@ -2,6 +2,15 @@
- Initial support for XML element auto-completion
- Initial API support for CREATERUNTIMEMAP and DESCRIBERUNTIMEMAP operations in MapGuide 2.6
- Resource ID "address bar" now has two buttons: One to open the resource using the designated editor and one to open using the Generic XML editor
+ - Create Package dialog now has a button to read all resource ids from a file when packaging by an explicit list of resource ids
+ - References tab in Resource Properties dialog now has quick access buttons to open upstream/downstream dependent resources in an editor
+ - Added open (Layer Definition) in editor shortcut for a selected layer in the Map Definition editor
+ - The resource of an active editor will now auto-focus on the Site Explorer
+ - Fix: "Show In Legend" checkbox in Layer Definition editor does nothing for CompositeTypeStyle elements
+ - Fix: Error XML validating v2.4.0 Layer Definition documents
+ - Fix: Bad restore center command icon when new WebLayout document is created
+ - Fix: Resource IDs in Load Procedures not being re-mapped when packaged with a custom restore path
+ - Fix: Map Definition Resource ID not being set during preview resource generation in Local Map preview mode
- Fix: Double identity properties not supported in MaestroAPI selection
- Fix: Missing context menu for granting/denying user/group access to a given resource in the Site Explorer
- Fix: Strange cursor behaviour in Generic XML editor
More information about the mapguide-commits
