[mapguide-commits] r7930 - in branches/2.5/MgDev/Server/src: Services/Mapping UnitTesting
svn_mapguide at osgeo.org
Tue Nov 26 00:44:00 PST 2013
Author: jng
Date: 2013-11-26 00:44:00 -0800 (Tue, 26 Nov 2013)
New Revision: 7930
branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.cpp
branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.h
branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.h
#2380: Merge r7929 to 2.5 branch
Modified: branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.cpp
--- branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.cpp 2013-11-26 06:36:14 UTC (rev 7929)
+++ branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.cpp 2013-11-26 08:44:00 UTC (rev 7930)
@@ -184,12 +184,54 @@
//for icon and label from the bottom up
y -= legendSpacing * convertUnits;
+ // Compile the necessary information needed to avoid repeated linear searches for this information
+ LayerGroupChildMap groupChildren;
+ VisibleLayerCountMap visibleLayers;
+ CompileInformation(map, visibleLayers, groupChildren);
// Add legend entries for layers that do not belong to a group
- ProcessLayersForLegend(map, scale, NULL, x, y, textDef, dr, legendSpec, legendOffsetY, convertUnits);
+ ProcessLayersForLegend(map, scale, NULL, x, y, textDef, dr, legendSpec, legendOffsetY, convertUnits, visibleLayers, groupChildren);
+void MgLegendPlotUtil::CompileInformation(MgMap* map, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgLayerGroupCollection> groups = map->GetLayerGroups();
-void MgLegendPlotUtil::ProcessLayersForLegend(MgMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgPlotSpecification* legendSpec, double legendOffsetY, double convertUnits)
+ for (INT32 i = 0; i < layers->GetCount(); i++)
+ Ptr<MgLayerBase> layer = layers->GetItem(i);
+ if (!layer->IsVisible()) //Not visible
+ continue;
+ Ptr<MgLayerGroup> parentGroup = layer->GetGroup();
+ if (NULL == parentGroup.p) //No parent
+ continue;
+ STRING parentGroupName = parentGroup->GetName();
+ VisibleLayerCountMap::iterator vit = visibleLayers.find(parentGroupName);
+ if (vit == visibleLayers.end())
+ visibleLayers[parentGroupName] = 0;
+ visibleLayers[parentGroupName]++;
+ for (INT32 i = 0; i < groups->GetCount(); i++)
+ Ptr<MgLayerGroup> group = groups->GetItem(i);
+ Ptr<MgLayerGroup> parentGroup = group->GetGroup();
+ if (NULL != parentGroup.p)
+ STRING groupName = group->GetName();
+ LayerGroupChildMap::iterator cit = groupChildren.find(parentGroupName);
+ if (cit == groupChildren.end())
+ groupChildren[parentGroupName] = LayerGroupList();
+ groupChildren[parentGroupName].push_back(groupName);
+void MgLegendPlotUtil::ProcessLayersForLegend(MgMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgPlotSpecification* legendSpec, double legendOffsetY, double convertUnits, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
double x;
double &y = startY;
@@ -464,7 +506,11 @@
Ptr<MgLayerGroup> groupParent = group->GetGroup();
if (groupParent.p == mggroup)
- ProcessLayersForLegend(map, mapScale, group, startX + initialMarginX, y, textDef, dr, legendSpec, legendOffsetY, convertUnits);
+ //If this group has no visible layers, skip it
+ if (!HasVisibleLayers(group->GetName(), visibleLayers, groupChildren))
+ continue;
+ ProcessLayersForLegend(map, mapScale, group, startX + initialMarginX, y, textDef, dr, legendSpec, legendOffsetY, convertUnits, visibleLayers, groupChildren);
if (y < bottomLimit)
break;
@@ -473,7 +519,28 @@
+bool MgLegendPlotUtil::HasVisibleLayers(CREFSTRING groupName, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren)
+ INT32 total = 0;
+ VisibleLayerCountMap::iterator vit = visibleLayers.find(groupName);
+ if (vit != visibleLayers.end())
+ if (vit->second > 0)
+ return true;
+ LayerGroupChildMap::iterator cit = groupChildren.find(groupName);
+ if (cit != groupChildren.end())
+ for (LayerGroupList::iterator lit = cit->second.begin(); lit != cit->second.end(); lit++)
+ if (HasVisibleLayers(*lit, visibleLayers, groupChildren))
+ return true;
+ return false;
// Compute the legend size and the offset position on the page
Modified: branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.h
--- branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.h 2013-11-26 06:36:14 UTC (rev 7929)
+++ branches/2.5/MgDev/Server/src/Services/Mapping/LegendPlotUtil.h 2013-11-26 08:44:00 UTC (rev 7930)
@@ -20,6 +20,10 @@
class EPlotRenderer;
+typedef std::vector<STRING> LayerGroupList;
+typedef std::map<STRING, LayerGroupList> LayerGroupChildMap;
+typedef std::map<STRING, int> VisibleLayerCountMap;
class MG_SERVER_MAPPING_API MgLegendPlotUtil
public:
@@ -42,12 +46,14 @@
//Eventually the scale bar and north arrow ones need to be cleaned up also in order
//to use them in the AJAX viewer
void AddLegendElement(double dMapScale, Renderer& dr, MgMap* map, MgPlotSpecification* plotSpec, double legendOffsetX, double legendOffsetY);
- void ProcessLayersForLegend(MgMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgPlotSpecification* plotSpec, double legendOffsetY, double convertUnits);
+ void ProcessLayersForLegend(MgMap* map, double mapScale, MgLayerGroup* mggroup, double startX, double& startY, RS_TextDef textDef, Renderer& dr, MgPlotSpecification* plotSpec, double legendOffsetY, double convertUnits, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
void BuildLegendContent(MgMap* map, double scale, MgPlotSpecification* legendSpec, double legendOffsetX, double legendOffsetY, Renderer& dr, double convertUnits);
void ExtentFromMapCenter(MgMap* map, double metersPerUnit, RS_Bounds& b);
+ void CompileInformation(MgMap* map, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
private:
+ static bool HasVisibleLayers(CREFSTRING groupName, VisibleLayerCountMap& visibleLayers, LayerGroupChildMap& groupChildren);
MgResourceService* m_svcResource;
RS_String m_legendFontName;
Modified: branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2013-11-26 06:36:14 UTC (rev 7929)
+++ branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2013-11-26 08:44:00 UTC (rev 7930)
@@ -796,6 +796,58 @@
+void TestRenderingService::TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ // make a runtime map
+ Ptr<MgMap> map = CreateTestMap();
+ map->SetViewScale(75000.0);
+ Ptr<MgColor> bgc = new MgColor(255, 255, 255, 255);
+ // Set up the following structure
+ // EmptyGroup1
+ // EmptyGroup2
+ // EmptyGroup3
+ // None of these should be visible when we render the legend
+ Ptr<MgLayerGroup> group1 = new MgLayerGroup(L"EmptyGroup1");
+ group1->SetLegendLabel(L"EmptyGroup1");
+ Ptr<MgLayerGroup> group2 = new MgLayerGroup(L"EmptyGroup2");
+ group2->SetLegendLabel(L"EmptyGroup2");
+ Ptr<MgLayerGroup> group3 = new MgLayerGroup(L"EmptyGroup3");
+ group3->SetLegendLabel(L"EmptyGroup3");
+ group1->SetDisplayInLegend(true);
+ group2->SetDisplayInLegend(true);
+ group3->SetDisplayInLegend(true);
+ groups->Add(group1);
+ groups->Add(group2);
+ groups->Add(group3);
+ group3->SetGroup(group2);
+ map->Save();
+ // Call the API
+ Ptr<MgByteReader> rdr3 = m_svcRendering->RenderMapLegend(map, 200, 400, bgc, imageFormat);
+ rdr3->ToFile(GetPath(L"../UnitTestFiles/RenderLegendEmptyGroups", imageFormat, extension));
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
void TestRenderingService::TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension)
try
Modified: branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.h
--- branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.h 2013-11-26 06:36:14 UTC (rev 7929)
+++ branches/2.5/MgDev/Server/src/UnitTesting/TestRenderingService.h 2013-11-26 08:44:00 UTC (rev 7930)
@@ -40,6 +40,7 @@
CPPUNIT_TEST(TestCase_RenderMapPNG);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG);
CPPUNIT_TEST(TestCase_RenderLegendPNG);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG);
CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG);
@@ -47,7 +48,7 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG);
- CPPUNIT_TEST(TestCase_SymbologyPointsPNG8);
+ CPPUNIT_TEST(TestCase_SymbologyPointsPNG8);
CPPUNIT_TEST(TestCase_SymbologyPointsParamPNG8);
CPPUNIT_TEST(TestCase_SymbologyLinesPNG8);
CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickPNG8);
@@ -62,6 +63,7 @@
CPPUNIT_TEST(TestCase_RenderMapPNG8);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkPNG8);
CPPUNIT_TEST(TestCase_RenderLegendPNG8);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsPNG8);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSPNG8);
CPPUNIT_TEST(TestCase_RenderLegendMultiCTSPNG8);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemePNG8);
@@ -69,7 +71,7 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG8);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG8);
- CPPUNIT_TEST(TestCase_SymbologyPointsGIF);
+ CPPUNIT_TEST(TestCase_SymbologyPointsGIF);
CPPUNIT_TEST(TestCase_SymbologyPointsParamGIF);
CPPUNIT_TEST(TestCase_SymbologyLinesGIF);
CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickGIF);
@@ -84,6 +86,7 @@
CPPUNIT_TEST(TestCase_RenderMapGIF);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkGIF);
CPPUNIT_TEST(TestCase_RenderLegendGIF);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsGIF);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSGIF);
CPPUNIT_TEST(TestCase_RenderLegendMultiCTSGIF);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeGIF);
@@ -91,7 +94,7 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSGIF);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSGIF);
- CPPUNIT_TEST(TestCase_SymbologyPointsJPG);
+ CPPUNIT_TEST(TestCase_SymbologyPointsJPG);
CPPUNIT_TEST(TestCase_SymbologyPointsParamJPG);
CPPUNIT_TEST(TestCase_SymbologyLinesJPG);
CPPUNIT_TEST(TestCase_SymbologyLinesCrossTickJPG);
@@ -106,6 +109,7 @@
CPPUNIT_TEST(TestCase_RenderMapJPG);
CPPUNIT_TEST(TestCase_RenderMapWithWatermarkJPG);
CPPUNIT_TEST(TestCase_RenderLegendJPG);
+ CPPUNIT_TEST(TestCase_RenderLegendEmptyGroupsJPG);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSJPG);
CPPUNIT_TEST(TestCase_RenderLegendMultiCTSJPG);
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSWithThemeJPG);
@@ -129,14 +133,15 @@
void TestStart();
void TestEnd();
- void TestCase_QueryFeatures();
+ void TestCase_QueryFeatures();
- //Parameterized versions that all format-specific tests call into
+ //Parameterized versions that all format-specific tests call into
void TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderDynamicOverlayTiledMap(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderMap(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderMapWithWatermark(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderLegend(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderLegendEmptyGroups(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderLegendMultiFTS(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderLegendMultiCTS(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_RenderLegendMultiFTSWithTheme(CREFSTRING imageFormat, CREFSTRING extension);
@@ -154,12 +159,13 @@
void TestCase_Annotation2(CREFSTRING imageFormat, CREFSTRING extension);
void TestCase_Annotation3(CREFSTRING imageFormat, CREFSTRING extension);
- //PNG output tests
- void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
+ //PNG output tests
+ void TestCase_RenderDynamicOverlayPNG() { TestCase_RenderDynamicOverlay(L"PNG", L"png"); }
void TestCase_RenderDynamicOverlayTiledMapPNG() { TestCase_RenderDynamicOverlayTiledMap(L"PNG", L"png"); }
void TestCase_RenderMapPNG() { TestCase_RenderMap(L"PNG", L"png"); }
void TestCase_RenderMapWithWatermarkPNG() { TestCase_RenderMapWithWatermark(L"PNG", L"png"); }
void TestCase_RenderLegendPNG() { TestCase_RenderLegend(L"PNG", L"png"); }
+ void TestCase_RenderLegendEmptyGroupsPNG() { TestCase_RenderLegendEmptyGroups(L"PNG", L"png"); }
void TestCase_SymbologyPointsPNG() { TestCase_SymbologyPoints(L"PNG", L"png"); }
void TestCase_SymbologyPointsParamPNG() { TestCase_SymbologyPointsParam(L"PNG", L"png"); }
void TestCase_SymbologyLinesPNG() { TestCase_SymbologyLines(L"PNG", L"png"); }
@@ -175,12 +181,13 @@
void TestCase_RenderLegendMultiFTSSingleCTSPNG() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG", L"png"); }
void TestCase_RenderLegendSingleFTSMultiCTSPNG() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG", L"png"); }
- //PNG8 output tests
- void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
+ //PNG8 output tests
+ void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
void TestCase_RenderDynamicOverlayTiledMapPNG8() { TestCase_RenderDynamicOverlayTiledMap(L"PNG8", L"png"); }
void TestCase_RenderMapPNG8() { TestCase_RenderMap(L"PNG8", L"png"); }
void TestCase_RenderMapWithWatermarkPNG8() { TestCase_RenderMapWithWatermark(L"PNG8", L"png"); }
void TestCase_RenderLegendPNG8() { TestCase_RenderLegend(L"PNG8", L"png"); }
+ void TestCase_RenderLegendEmptyGroupsPNG8() { TestCase_RenderLegendEmptyGroups(L"PNG8", L"png"); }
void TestCase_SymbologyPointsPNG8() { TestCase_SymbologyPoints(L"PNG8", L"png"); }
void TestCase_SymbologyPointsParamPNG8() { TestCase_SymbologyPointsParam(L"PNG8", L"png"); }
void TestCase_SymbologyLinesPNG8() { TestCase_SymbologyLines(L"PNG8", L"png"); }
@@ -196,12 +203,13 @@
void TestCase_RenderLegendMultiFTSSingleCTSPNG8() { TestCase_RenderLegendMultiFTSSingleCTS(L"PNG8", L"png"); }
void TestCase_RenderLegendSingleFTSMultiCTSPNG8() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG8", L"png"); }
- //GIF output tests
- void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
+ //GIF output tests
+ void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
void TestCase_RenderDynamicOverlayTiledMapGIF() { TestCase_RenderDynamicOverlayTiledMap(L"GIF", L"gif"); }
void TestCase_RenderMapGIF() { TestCase_RenderMap(L"GIF", L"gif"); }
void TestCase_RenderMapWithWatermarkGIF() { TestCase_RenderMapWithWatermark(L"GIF", L"gif"); }
void TestCase_RenderLegendGIF() { TestCase_RenderLegend(L"GIF", L"gif"); }
+ void TestCase_RenderLegendEmptyGroupsGIF() { TestCase_RenderLegendEmptyGroups(L"GIF", L"gif"); }
void TestCase_SymbologyPointsGIF() { TestCase_SymbologyPoints(L"GIF", L"gif"); }
void TestCase_SymbologyPointsParamGIF() { TestCase_SymbologyPointsParam(L"GIF", L"gif"); }
void TestCase_SymbologyLinesGIF() { TestCase_SymbologyLines(L"GIF", L"gif"); }
@@ -217,12 +225,13 @@
void TestCase_RenderLegendMultiFTSSingleCTSGIF() { TestCase_RenderLegendMultiFTSSingleCTS(L"GIF", L"gif"); }
void TestCase_RenderLegendSingleFTSMultiCTSGIF() { TestCase_RenderLegendSingleFTSMultiCTS(L"GIF", L"gif"); }
- //JPG output tests
- void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
+ //JPG output tests
+ void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
void TestCase_RenderDynamicOverlayTiledMapJPG() { TestCase_RenderDynamicOverlayTiledMap(L"JPG", L"jpg"); }
void TestCase_RenderMapJPG() { TestCase_RenderMap(L"JPG", L"jpg"); }
void TestCase_RenderMapWithWatermarkJPG() { TestCase_RenderMapWithWatermark(L"JPG", L"jpg"); }
void TestCase_RenderLegendJPG() { TestCase_RenderLegend(L"JPG", L"jpg"); }
+ void TestCase_RenderLegendEmptyGroupsJPG() { TestCase_RenderLegendEmptyGroups(L"JPG", L"jpg"); }
void TestCase_SymbologyPointsJPG() { TestCase_SymbologyPoints(L"JPG", L"jpg"); }
void TestCase_SymbologyPointsParamJPG() { TestCase_SymbologyPointsParam(L"JPG", L"jpg"); }
void TestCase_SymbologyLinesJPG() { TestCase_SymbologyLines(L"JPG", L"jpg"); }
@@ -245,7 +254,7 @@
MgMap* CreateTestTiledMap();
MgMap* CreateTestMapWithWatermark();
MgPolygon* CreateSelectionPolygon(MgMap* map, double width, double height);
- static STRING GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension);
+ static STRING GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension);
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
