[mapguide-commits] r7934 - in trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI: . Commands Feature Mapping
svn_mapguide at osgeo.org
Wed Nov 27 03:55:44 PST 2013
Author: jng
Date: 2013-11-27 03:55:44 -0800 (Wed, 27 Nov 2013)
New Revision: 7934
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/FeatureManipulationCommands.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/IReader.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
Maestro API documentation updates
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/FeatureManipulationCommands.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/FeatureManipulationCommands.cs 2013-11-27 10:50:31 UTC (rev 7933)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/FeatureManipulationCommands.cs 2013-11-27 11:55:44 UTC (rev 7934)
@@ -45,6 +45,60 @@
/// <summary>
/// Defines a command that creates a file-based data store on a given feature source
/// </summary>
+ /// <remarks>
+ /// This command is only supported on certain implementations of <see cref="T:OSGeo.MapGuide.MaestroAPI.IServerConnection"/>
+ /// You can find out if the connection supports this command through the <see cref="P:OSGeo.MapGuide.MaestroAPI.IServerConnection.Capabilities"/>
+ /// </remarks>
+ /// <example>
+ /// How to create a data store with a given schema
+ /// <code>
+ /// IServerConnection conn = ...;
+ /// FeatureSchema schema = new FeatureSchema("Default", "");
+ /// ClassDefinition cls = new ClassDefinition("MyClass", "");
+ /// cls.DefaultGeometryProperty = "GEOM";
+ /// //Add identity property KEY
+ /// cls.AddProperty(new DataPropertyDefinition("KEY", "")
+ /// DataType = DataPropertyType.Int32,
+ /// IsAutoGenerated = true,
+ /// IsReadOnly = true,
+ /// IsNullable = false
+ /// }, true);
+ /// //Add string property NAME
+ /// cls.AddProperty(new DataPropertyDefinition("NAME", "")
+ /// DataType = DataPropertyType.String,
+ /// Length = 255,
+ /// IsNullable = true,
+ /// IsReadOnly = false
+ /// //Add geometry property GEOM
+ /// cls.AddProperty(new GeometricPropertyDefinition("GEOM", "")
+ /// GeometricTypes = FeatureGeometricType.Point,
+ /// SpatialContextAssociation = "Default"
+ /// schema.AddClass(cls);
+ /// ICreateDataStore create = (ICreateDataStore)conn.CreateCommand((int)CommandType.CreateDataStore);
+ /// CoordinateSystemDefinitionBase coordSys = conn.CoordinateSystemCatalog.FindCoordSys("LL84");
+ /// create.FeatureSourceId = fsId;
+ /// create.CoordinateSystemWkt = coordSys.WKT;
+ /// create.Name = "Default";
+ /// create.ExtentType = OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextListSpatialContextExtentType.Dynamic;
+ /// create.FileName = "Test.sdf";
+ /// create.Provider = "OSGeo.SDF";
+ /// create.Schema = schema;
+ /// create.XYTolerance = 0.001;
+ /// create.ZTolerance = 0.001;
+ /// create.Execute();
+ /// </code>
+ /// </example>
public interface ICreateDataStore : ICommand, IFdoSpatialContext
/// <summary>
@@ -76,6 +130,27 @@
/// <summary>
/// Defines a command that inserts a feature into a Feature Source
/// </summary>
+ /// <remarks>
+ /// </remarks>
+ /// <example>
+ /// How to insert a feature that contains a string and geometry value
+ /// <code>
+ /// IInsertFeatures insertCmd = (IInsertFeatures)conn.CreateCommand((int)CommandType.InsertFeatures);
+ /// insertCmd.FeatureSourceId = "Library://My.FeatureSource";
+ /// insertCmd.ClassName = "MyFeatureClass";
+ /// MutableRecord insertRec = new MutableRecord();
+ /// FixedWKTReader wktReader = new FixedWKTReader();
+ /// insertRec.PutValue("Geometry", new GeometryValue(wktReader.Read("POINT (10 10)")));
+ /// insertRec.PutValue("Name", new StringValue("Foo"));
+ /// insertCmd.RecordToInsert = insertRec;
+ /// InsertResult res = insertCmd.Execute();
+ /// </code>
+ /// </example>
public interface IInsertFeatures : IFeatureCommand
/// <summary>
@@ -84,7 +159,7 @@
IMutableRecord RecordToInsert { get; set; }
/// <summary>
- /// Executes the command
+ /// Executes the command. Any error during execution will be caught and stored in the <see cref="P:OSGeo.MapGuide.MaestroAPI.Commands.InsertResult.Error"/> property
/// </summary>
/// <returns>The feature insert result</returns>
InsertResult Execute();
@@ -104,6 +179,10 @@
/// <summary>
/// Defines a command that inserts a series of features into a Feature Source
/// </summary>
+ /// <remarks>
+ /// </remarks>
public interface IBatchInsertFeatures : IFeatureCommand
/// <summary>
@@ -125,6 +204,25 @@
/// <summary>
/// Defines a command that updates one or more features in a Feature Source based on some filtering criteria
/// </summary>
+ /// <remarks>
+ /// </remarks>
+ /// <example>
+ /// How to update all features matching a given filter to the given value
+ /// <code>
+ /// IUpdateFeatures updateCmd = (IUpdateFeatures)conn.CreateCommand((int)CommandType.UpdateFeatures);
+ /// updateCmd.FeatureSourceId = "Library://My.FeatureSource";
+ /// updateCmd.ClassName = "MyFeatureClass";
+ /// updateCmd.Filter = "Name = 'Bar'";
+ /// updateCmd.ValuesToUpdate = new MutableRecord();
+ /// updateCmd.ValuesToUpdate.PutValue("Name", new StringValue("Foo"));
+ /// int updated = updateCmd.Execute();
+ /// </code>
+ /// </example>
public interface IUpdateFeatures : IFeatureCommand
/// <summary>
@@ -148,6 +246,23 @@
/// <summary>
/// Defines a command that deletes one or more features in a Feature Source based on some filtering criteria
/// </summary>
+ /// <remarks>
+ /// </remarks>
+ /// <example>
+ /// <code>
+ /// IDeleteFeatures deleteCmd = (IDeleteFeatures)conn.CreateCommand((int)CommandType.DeleteFeatures);
+ /// deleteCmd.FeatureSourceId = "Library://My.FeatureSource";
+ /// deleteCmd.ClassName = "MyFeatureClass";
+ /// deleteCmd.Filter = "Name = 'Bar'";
+ /// int deleted = deleteCmd.Execute();
+ /// </code>
+ /// </example>
public interface IDeleteFeatures : IFeatureCommand
/// <summary>
@@ -165,6 +280,10 @@
/// <summary>
/// Defines a command that applies the given Feature Schema to a Feature Source
/// </summary>
+ /// <remarks>
+ /// </remarks>
public interface IApplySchema : ICommand
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/IReader.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/IReader.cs 2013-11-27 10:50:31 UTC (rev 7933)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/IReader.cs 2013-11-27 11:55:44 UTC (rev 7934)
@@ -355,6 +355,9 @@
/// <summary>
/// Defines a records whose properties can be modified
/// </summary>
+ /// <remarks>
+ /// The default implementation of this interface is <see cref="T:OSGeo.MapGuide.MaestroAPI.Feature.MutableRecord"/>
+ /// </remarks>
public interface IMutableRecord : IRecord, IRecordInitialize
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2013-11-27 10:50:31 UTC (rev 7933)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2013-11-27 11:55:44 UTC (rev 7934)
@@ -105,12 +105,16 @@
/// <summary>
/// Creates a command of the specified type
/// </summary>
- /// <param name="commandType"></param>
+ /// <remarks>
+ /// Some commands may not be supported by the connection. You can find out if the connection supports a particular command through the <see cref="P:OSGeo.MapGuide.MaestroAPI.IServerConnection.Capabilities"/>
+ /// </remarks>
+ /// <param name="commandType">The type of command to create. See <see cref="T:OSGeo.MapGuide.MaestroAPI.Commands.CommandType"/> for allowed values</param>
/// <returns></returns>
ICommand CreateCommand(int commandType);
/// <summary>
- /// Gets the capabilities for this connection
+ /// Gets the capabilities for this connection. The capabilities describes
+ /// what commands and services are supported by this connection
/// </summary>
IConnectionCapabilities Capabilities { get; }
@@ -132,7 +136,10 @@
/// <summary>
/// Gets the service based on the given type
/// </summary>
- /// <param name="serviceType"></param>
+ /// <remarks>
+ /// </remarks>
+ /// <param name="serviceType">The type of service to create. See <see cref="T:OSGeo.MapGuide.MaestroAPI.Services.ServiceType"/> for allowed values</param>
IService GetService(int serviceType);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2013-11-27 10:50:31 UTC (rev 7933)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2013-11-27 11:55:44 UTC (rev 7934)
@@ -112,10 +112,10 @@
/// int read = 0;
/// do
- /// read = source.Read(buf, 0, buf.Length);
- /// target.Write(buf, 0, read);
- /// } while (read > 0);
+ /// read = source.Read(buf, 0, buf.Length);
+ /// target.Write(buf, 0, read);
+ /// } while (read > 0);
More information about the mapguide-commits
