[mapguide-commits] r7942 - trunk/Tools/Maestro/Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org
Fri Nov 29 07:20:24 PST 2013
Author: jng
Date: 2013-11-29 07:20:24 -0800 (Fri, 29 Nov 2013)
New Revision: 7942
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
#2385: Tie up loose ends in Map Definition editor as a result of introducing multi-selection support.
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2013-11-29 14:38:43 UTC (rev 7941)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2013-11-29 15:20:24 UTC (rev 7942)
@@ -23,6 +23,7 @@
using System.Drawing;
using System.Data;
using System.Text;
+using System.Linq;
using System.Windows.Forms;
using Maestro.Shared.UI;
using Aga.Controls.Tree;
@@ -191,6 +192,8 @@
private void OnDynamicGroupItemSelected(GroupItem group)
+ btnAddGroup.Enabled = true;
+ btnGRPAddLayer.Enabled = true;
btnRemoveGroup.Enabled = true;
btnMoveLayerOrGroupUp.Enabled = true;
btnMoveLayerOrGroupDown.Enabled = true;
@@ -484,6 +487,8 @@
private void OnDynamicLayerItemSelected(LayerItem layer)
+ btnAddGroup.Enabled = false;
+ btnGRPAddLayer.Enabled = false;
btnGRPRemoveLayer.Enabled = true;
btnMoveLayerOrGroupUp.Enabled = true; //TODO: Disable if layer is top of its group
btnMoveLayerOrGroupDown.Enabled = true; //TODO: Disable if layer is bottom of its group
@@ -495,22 +500,76 @@
propertiesPanel.Controls.Add(item);
+ static bool AllLayers(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
+ foreach(var node in nodes)
+ var layer = node.Tag as LayerItem;
+ if (layer == null)
+ return false;
+ return true;
+ static bool AllBaseLayers(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
+ foreach (var node in nodes)
+ var layer = node.Tag as BaseLayerItem;
+ return false;
+ return true;
+ static bool AllGroups(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
+ var group = node.Tag as GroupItem;
+ if (group == null)
+ return false;
+ return true;
+ static bool AllBaseGroups(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
+ var group = node.Tag as BaseLayerGroupItem;
+ return false;
+ return true;
private void OnMultipleItemsSelected(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
- //Disable all toolbar buttons
- btnGRPRemoveLayer.Enabled =
- btnMoveLayerOrGroupUp.Enabled =
+ bool bAllLayers = AllLayers(nodes);
+ bool bAllGroups = AllGroups(nodes);
+ bool bAllBaseLayers = AllBaseLayers(nodes);
+ bool bAllBaseGroups = AllBaseGroups(nodes);
+ btnRemoveGroup.Enabled = bAllGroups;
+ btnConvertLayerGroupToBaseGroup.Enabled = bAllGroups;
+ btnGRPRemoveLayer.Enabled = bAllLayers;
+ btnMoveLayerOrGroupUp.Enabled = false;
btnMoveLayerOrGroupDown.Enabled = false;
- btnDLMoveLayerBottom.Enabled =
- btnDLMoveLayerDown.Enabled =
- btnDLMoveLayerTop.Enabled =
- btnDLMoveLayerUp.Enabled =
+ btnDLMoveLayerBottom.Enabled = false;
+ btnDLMoveLayerDown.Enabled = false;
+ btnDLMoveLayerTop.Enabled = false;
+ btnDLMoveLayerUp.Enabled = false;
btnDLRemoveLayer.Enabled = false;
- btnAddBaseLayer.Enabled =
- btnRemoveBaseLayerGroup.Enabled =
- btnBaseLayerGroupToRegular.Enabled = false;
+ btnNewBaseLayerGroup.Enabled = false;
+ btnAddBaseLayer.Enabled = false;
+ btnRemoveBaseLayer.Enabled = bAllBaseLayers;
+ btnRemoveBaseLayerGroup.Enabled = bAllBaseGroups;
+ btnBaseLayerGroupToRegular.Enabled = bAllBaseGroups;
propertiesPanel.Controls.Clear();
@@ -550,13 +609,29 @@
private void btnRemoveGroup_Click(object sender, EventArgs e)
- var group = GetSelectedLayerGroupItem() as GroupItem;
- if (group != null)
+ var remove = new List<GroupItem>();
+ foreach (var item in GetSelectedLayerGroupItems())
- RemoveSelectedLayerGroupItem(group);
+ var group = item as GroupItem;
+ if (group != null)
+ remove.Add(group);
+ RemoveSelectedLayerGroupItems(remove);
+ private void RemoveSelectedLayerGroupItems(IEnumerable<GroupItem> groups)
+ foreach (var group in groups)
+ _map.RemoveLayerGroupAndChildLayers(group.Tag.Name);
+ propertiesPanel.Controls.Clear();
+ _grpLayerModel.Invalidate();
+ _doLayerModel.Invalidate();
private void RemoveSelectedLayerGroupItem(GroupItem group)
@@ -583,10 +658,13 @@
private void btnGRPRemoveLayer_Click(object sender, EventArgs e)
- var layer = GetSelectedLayerGroupItem() as LayerItem;
- if (layer != null)
- RemoveSelectedLayerGroupItem(layer);
+ var layer = item as LayerItem;
+ if (layer != null)
+ RemoveSelectedLayerGroupItem(layer);
@@ -599,39 +677,47 @@
private void btnConvertLayerGroupToBaseGroup_Click(object sender, EventArgs e)
+ List<string> messages = new List<string>();
- var layGroup = group.Tag;
- var layers = _map.GetLayersForGroup(layGroup.Name);
+ var layGroup = group.Tag;
+ var layers = _map.GetLayersForGroup(layGroup.Name);
- if (_map.BaseMap == null)
- _map.InitBaseMap();
+ if (_map.BaseMap == null)
+ _map.InitBaseMap();
- int counter = 1;
- string groupName = layGroup.Name;
- var blg = _map.BaseMap.GetGroup(groupName);
- while (blg != null)
- groupName = layGroup.Name + " (" + counter + ")";
- counter++;
+ int counter = 1;
+ string groupName = layGroup.Name;
+ var blg = _map.BaseMap.GetGroup(groupName);
+ while (blg != null)
+ groupName = layGroup.Name + " (" + counter + ")";
+ counter++;
- blg = _map.BaseMap.GetGroup(groupName);
- blg = _map.BaseMap.AddBaseLayerGroup(groupName);
- blg.LegendLabel = layGroup.LegendLabel;
+ blg = _map.BaseMap.GetGroup(groupName);
+ blg = _map.BaseMap.AddBaseLayerGroup(groupName);
+ blg.LegendLabel = layGroup.LegendLabel;
- foreach (var layer in layers)
- var bl = blg.AddLayer(layer.Name, layer.ResourceId);
- bl.LegendLabel = layer.LegendLabel;
- bl.Selectable = layer.Selectable;
- bl.ShowInLegend = layer.ShowInLegend;
- bl.ExpandInLegend = layer.ExpandInLegend;
+ foreach (var layer in layers)
+ var bl = blg.AddLayer(layer.Name, layer.ResourceId);
+ bl.LegendLabel = layer.LegendLabel;
+ bl.Selectable = layer.Selectable;
+ bl.ShowInLegend = layer.ShowInLegend;
+ bl.ExpandInLegend = layer.ExpandInLegend;
+ _map.RemoveLayerGroupAndChildLayers(layGroup.Name);
+ messages.Add(string.Format(Strings.LayerGroupConvertedToBaseLayerGroup, layGroup.Name, groupName));
- _map.RemoveLayerGroupAndChildLayers(layGroup.Name);
- MessageBox.Show(string.Format(Strings.LayerGroupConvertedToBaseLayerGroup, layGroup.Name, groupName));
+ if (messages.Count > 0)
+ MessageBox.Show(string.Join(Environment.NewLine, messages.ToArray()));
this.RefreshModels();
tabControl1.SelectedIndex = 2; //Switch to Base Layer Groups
@@ -639,38 +725,46 @@
private void btnBaseGroupToRegular_Click(object sender, EventArgs e)
- var group = GetSelectedTiledLayerItem() as BaseLayerGroupItem;
+ var messages = new List<string>();
+ foreach (var item in GetSelectedTiledLayerItems())
- int counter = 0;
- string groupName = group.Tag.Name;
- while (_map.GetGroupByName(groupName) != null)
+ var group = item as BaseLayerGroupItem;
- counter++;
- groupName = group.Tag.Name + "(" + counter + ")";
- _map.AddGroup(groupName);
- int layerCount = _map.GetLayerCount();
- foreach (var layer in group.Tag.BaseMapLayer)
- //We an avoid a duplicate name check because the Map Definition should already ensure uniqueness
- //among existing layers
- var dlayer = _map.AddLayer(groupName, layer.Name, layer.ResourceId);
- dlayer.ExpandInLegend = layer.ExpandInLegend;
- dlayer.LegendLabel = layer.LegendLabel;
- dlayer.Selectable = layer.Selectable;
- dlayer.ShowInLegend = layer.ShowInLegend;
+ int counter = 0;
+ string groupName = group.Tag.Name;
+ while (_map.GetGroupByName(groupName) != null)
+ counter++;
+ groupName = group.Tag.Name + "(" + counter + ")";
+ _map.AddGroup(groupName);
+ int layerCount = _map.GetLayerCount();
+ foreach (var layer in group.Tag.BaseMapLayer)
+ //We an avoid a duplicate name check because the Map Definition should already ensure uniqueness
+ //among existing layers
+ var dlayer = _map.AddLayer(groupName, layer.Name, layer.ResourceId);
+ dlayer.ExpandInLegend = layer.ExpandInLegend;
+ dlayer.LegendLabel = layer.LegendLabel;
+ dlayer.Selectable = layer.Selectable;
+ dlayer.ShowInLegend = layer.ShowInLegend;
- //HACK-ish, but we need to relocate this
- _map.RemoveLayer(dlayer);
+ //HACK-ish, but we need to relocate this
+ _map.RemoveLayer(dlayer);
- //Add to bottom
- _map.InsertLayer(layerCount, dlayer);
- layerCount++;
+ //Add to bottom
+ _map.InsertLayer(layerCount, dlayer);
+ layerCount++;
+ //Detach the base layer group
+ _map.RemoveBaseLayerGroup(group.Tag, true);
+ messages.Add(string.Format(Strings.BaseLayerGroupConvertedToLayerGroup, group.Tag.Name, groupName));
- //Detach the base layer group
- _map.RemoveBaseLayerGroup(group.Tag, true);
- MessageBox.Show(string.Format(Strings.BaseLayerGroupConvertedToLayerGroup, group.Tag.Name, groupName));
tabControl1.SelectedIndex = 0; //Switch to Layer Groups
@@ -935,11 +1029,15 @@
return null;
- private void btnNewBaseLayerGroup_Click(object sender, EventArgs e)
+ private IEnumerable<object> GetSelectedLayerGroupItems()
- var grp = _map.BaseMap.AddBaseLayerGroup(GenerateBaseGroupName(_map));
- _tiledLayerModel.Invalidate();
+ var result = new List<object>();
+ var nodes = trvLayersGroup.SelectedNodes;
+ if (nodes != null)
+ result.AddRange(nodes.Select(x => x.Tag));
+ return result;
private object GetSelectedTiledLayerItem()
@@ -950,15 +1048,48 @@
return null;
+ private IEnumerable<object> GetSelectedTiledLayerItems()
+ var nodes = trvBaseLayers.SelectedNodes;
+ return result;
+ private void btnNewBaseLayerGroup_Click(object sender, EventArgs e)
+ var grp = _map.BaseMap.AddBaseLayerGroup(GenerateBaseGroupName(_map));
+ _tiledLayerModel.Invalidate();
private void btnRemoveBaseLayerGroup_Click(object sender, EventArgs e)
+ var remove = new List<BaseLayerGroupItem>();
- RemoveSelectedTiledLayerItem(group);
+ RemoveSelectedTiledLayerItems(remove);
+ private void RemoveSelectedTiledLayerItems(IEnumerable<BaseLayerGroupItem> groups)
private void RemoveSelectedTiledLayerItem(BaseLayerGroupItem group)
@@ -1058,10 +1189,13 @@
private void btnRemoveBaseLayer_Click(object sender, EventArgs e)
- var layer = GetSelectedTiledLayerItem() as BaseLayerItem;
- RemoveSelectedTiledLayerItem(layer);
+ var layer = item as BaseLayerItem;
+ RemoveSelectedTiledLayerItem(layer);
More information about the mapguide-commits
