[mapguide-commits] r8012 - in trunk/Tools/Maestro: MaestroAPITests MaestroAPITests/UserTestData OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Apr 7 03:37:27 PDT 2014
Author: jng
Date: 2014-04-07 03:37:27 -0700 (Mon, 07 Apr 2014)
New Revision: 8012
Added:
   trunk/Tools/Maestro/MaestroAPITests/UserTestData/TestDuplicateLayerIds.xml
   trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
   trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
#2398: Fix RuntimeMap creation failure on duplicate Layer Definition IDs. Patch by johngalambos. Reviewed by me with unit test included.
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2014-04-07 10:21:55 UTC (rev 8011)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj	2014-04-07 10:37:27 UTC (rev 8012)
@@ -562,6 +562,9 @@
     <Content Include="UserTestData\1896.xml">
       <CopyToOutputDirectory>Always</CopyToOutputDirectory>
     </Content>
+    <Content Include="UserTestData\TestDuplicateLayerIds.xml">
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
     <Content Include="UserTestData\GeoRestConfig.xml">
     </Content>
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-04-07 10:21:55 UTC (rev 8011)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs	2014-04-07 10:37:27 UTC (rev 8012)
@@ -102,6 +102,7 @@
             resSvc.SetResourceXmlData("Library://UnitTests/Maps/Sheboygan.MapDefinition", File.OpenRead("TestData/MappingService/UT_Sheboygan.mdf"));
             resSvc.SetResourceXmlData("Library://UnitTests/Maps/SheboyganTiled.MapDefinition", File.OpenRead("UserTestData/TestTiledMap.xml"));
+            resSvc.SetResourceXmlData("Library://UnitTests/Maps/DuplicateLayerIds.MapDefinition", File.OpenRead("UserTestData/TestDuplicateLayerIds.xml"));
             resSvc.SetResourceXmlData("Library://UnitTests/Layers/HydrographicPolygons.LayerDefinition", File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.ldf"));
             resSvc.SetResourceXmlData("Library://UnitTests/Layers/Rail.LayerDefinition", File.OpenRead("TestData/MappingService/UT_Rail.ldf"));
@@ -1129,6 +1130,22 @@
             Assert.IsTrue(insertCalled);
+        public virtual void TestCaseDuplicateLayerIds()
+            try
+                IServerConnection conn = CreateTestConnection();
+                IMappingService mapSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+                string mapdefinition = "Library://UnitTests/Maps/DuplicateLayerIds.MapDefinition";
+                IMapDefinition mdef = (IMapDefinition)conn.ResourceService.GetResource(mapdefinition);
+                RuntimeMap rtm = mapSvc.CreateMap(mdef); // Create new runtime map
+            catch (Exception ex)
+                Assert.Fail(ex.ToString());
         public virtual void TestLargeMapCreatePerformance()
             TestMapCreate(50, 10);
@@ -1303,6 +1320,12 @@
         [Test]
+        public override void TestCaseDuplicateLayerIds()
+            base.TestCaseDuplicateLayerIds();
+        [Test]
         public void TestCreateRuntimeMapRequest()
             if (_conn.SiteVersion < new Version(2, 6))
@@ -1684,6 +1707,12 @@
             base.TestMapAddDwfLayer();
+        [Test]
     [TestFixture]
@@ -1783,6 +1812,12 @@
             base.TestMapManipulation3();
+        [Test]
         [Test]
         public override void TestLargeMapCreatePerformance()
Added: trunk/Tools/Maestro/MaestroAPITests/UserTestData/TestDuplicateLayerIds.xml
--- trunk/Tools/Maestro/MaestroAPITests/UserTestData/TestDuplicateLayerIds.xml	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/UserTestData/TestDuplicateLayerIds.xml	2014-04-07 10:37:27 UTC (rev 8012)
@@ -0,0 +1,60 @@
+<?xml version="1.0" encoding="utf-8"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
+    <Name>New Map</Name>
+    <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+    <Extents>
+        <MinX>-87.770746109180749</MinX>
+        <MaxX>-87.6957605384125</MaxX>
+        <MinY>43.686899685828813</MinY>
+        <MaxY>43.805498742206247</MaxY>
+    </Extents>
+    <BackgroundColor>ffffffff</BackgroundColor>
+    <BaseMapDefinition>
+        <FiniteDisplayScale>100</FiniteDisplayScale>
+        <FiniteDisplayScale>5427</FiniteDisplayScale>
+        <FiniteDisplayScale>10753</FiniteDisplayScale>
+        <FiniteDisplayScale>16080</FiniteDisplayScale>
+        <FiniteDisplayScale>21407</FiniteDisplayScale>
+        <FiniteDisplayScale>26733</FiniteDisplayScale>
+        <FiniteDisplayScale>32060</FiniteDisplayScale>
+        <FiniteDisplayScale>37387</FiniteDisplayScale>
+        <FiniteDisplayScale>42713</FiniteDisplayScale>
+        <FiniteDisplayScale>48040</FiniteDisplayScale>
+        <FiniteDisplayScale>53367</FiniteDisplayScale>
+        <FiniteDisplayScale>58693</FiniteDisplayScale>
+        <FiniteDisplayScale>64020</FiniteDisplayScale>
+        <FiniteDisplayScale>69347</FiniteDisplayScale>
+        <FiniteDisplayScale>80000</FiniteDisplayScale>
+        <BaseMapLayerGroup>
+            <Name>Base Layer Group</Name>
+            <Visible>true</Visible>
+            <ShowInLegend>true</ShowInLegend>
+            <ExpandInLegend>true</ExpandInLegend>
+            <LegendLabel>Base Layer Group</LegendLabel>
+            <BaseMapLayer>
+                <Name>Rail</Name>
+                <ResourceId>Library://UnitTests/Layers/Rail.LayerDefinition</ResourceId>
+                <Selectable>true</Selectable>
+                <LegendLabel>Rail</LegendLabel>
+            </BaseMapLayer>
+            <BaseMapLayer>
+                <Name>Parcels</Name>
+                <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+                <LegendLabel>Parcels</LegendLabel>
+            </BaseMapLayer>
+            <BaseMapLayer>
+                <Name>HydrographicPolygons</Name>
+                <LegendLabel>Parcels2</LegendLabel>
+            </BaseMapLayer>
+        </BaseMapLayerGroup>
+    </BaseMapDefinition>
+</MapDefinition>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2014-04-07 10:21:55 UTC (rev 8011)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2014-04-07 10:37:27 UTC (rev 8012)
@@ -19,19 +19,17 @@
 #endregion
 using System;
 using System.Collections.Generic;
-using System.Text;
+using System.Diagnostics;
+using System.Drawing;
+using System.Linq;
+using OSGeo.MapGuide.MaestroAPI.Commands;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.MaestroAPI.Serialization;
 using OSGeo.MapGuide.MaestroAPI.Services;
-using OSGeo.MapGuide.ObjectModels.Common;
-using OSGeo.MapGuide.ObjectModels.MapDefinition;
 using OSGeo.MapGuide.ObjectModels;
-using OSGeo.MapGuide.MaestroAPI.Serialization;
-using OSGeo.MapGuide.MaestroAPI.Resource;
-using System.ComponentModel;
+using OSGeo.MapGuide.ObjectModels.Common;
 using OSGeo.MapGuide.ObjectModels.LayerDefinition;
-using System.Diagnostics;
-using OSGeo.MapGuide.MaestroAPI.Commands;
-using OSGeo.MapGuide.MaestroAPI.Exceptions;
-using System.Drawing;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
 namespace OSGeo.MapGuide.MaestroAPI.Mapping
@@ -282,7 +280,7 @@
             if (_getRes != null)
                 Debug.WriteLine("[RuntimeMap.ctor]: Batching layer requests"); //NOXLATE
-                var res = _getRes.Execute(GetLayerIds(mdf));
+                var res = _getRes.Execute(GetLayerIds(mdf).Distinct());
                 //Pre-populate layer def cache so GetLayerDefinition() returns these
                 //instead of making a new request
                 foreach (var key in res.Keys)
More information about the mapguide-commits mailing list
