[mapguide-commits] r8015 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Commands/SiteExplorer Maestro.Editors Maestro.Editors/SymbolDefinition OSGeo.MapGuide.MaestroAPI/Resource/Conversion
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Apr 7 08:01:59 PDT 2014
Author: jng
Date: 2014-04-07 08:01:59 -0700 (Mon, 07 Apr 2014)
New Revision: 8015
Added:
   trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ExtractSymbolsCommand.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.cs
   trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.resx
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
   trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Strings.resx
   trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs
#2131: Add new context menu command to extract image symbols from a SymbolLibrary to individual Symbol Definition resources.
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ExtractSymbolsCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ExtractSymbolsCommand.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ExtractSymbolsCommand.cs	2014-04-07 15:01:59 UTC (rev 8015)
@@ -0,0 +1,91 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Editors.SymbolDefinition;
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Resource.Conversion;
+using System.Collections.Generic;
+using System.ComponentModel;
+namespace Maestro.Base.Commands.SiteExplorer
+    internal class ExtractSymbolsCommand : AbstractMenuCommand
+        public override void Run()
+            var wb = Workbench.Instance;
+            if (wb != null)
+                if (wb.ActiveSiteExplorer != null)
+                    var items = wb.ActiveSiteExplorer.SelectedItems;
+                    if (items.Length == 1)
+                        var it = items[0];
+                        if (it.ResourceType == ResourceTypes.SymbolLibrary.ToString())
+                            var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+                            var conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+                            var diag = new ExtractSymbolLibraryDialog(conn, it.ResourceId);
+                            if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                                string symbolLib = diag.SymbolLibrary;
+                                string targetFolder = diag.TargetFolder;
+                                IEnumerable<string> symbols = diag.SelectedSymbols;
+                                DoSymbolExtraction(conn, symbolLib, symbols, targetFolder);
+        private object SymbolExtractionWorker(BackgroundWorker worker, DoWorkEventArgs e, params object[] args)
+            int processed = 0;
+            IServerConnection conn  = (IServerConnection)args[0];
+            string symbolLib        = (string)args[1];
+            List<string> symbols    = (List<string>)args[2];
+            string targetFolder     = (string)args[3];
+            ImageSymbolConverter conv = new ImageSymbolConverter(conn, symbolLib);
+            conv.ExtractSymbols(targetFolder, symbols, (count, total) =>
+                processed = count;
+                int pc = (int)((double)count / (double)total);
+                worker.ReportProgress(pc);
+            return processed;
+        private void DoSymbolExtraction(IServerConnection conn, string symbolLib, IEnumerable<string> symbols, string targetFolder)
+            var list = new List<string>(symbols);
+            var diag = new ProgressDialog();
+            var worker = new ProgressDialog.DoBackgroundWork(SymbolExtractionWorker);
+            diag.RunOperationAsync(wb, worker, conn, symbolLib, list, targetFolder);
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2014-04-07 15:01:59 UTC (rev 8015)
@@ -611,6 +611,11 @@
             <MenuItem id="CompileDependencyList"
                       label="${res:SiteExplorer_SelectedItem_CompileDependencyList}"
                       class="Maestro.Base.Commands.SiteExplorer.CompileFullDependencyListCommand" />
+            <Condition action="Disable" name="ResourceType" types="SymbolLibrary">
+                <MenuItem id="ExtractImageSymbols"
+                          label="${res:SiteExplorer_SelectedItem_ExtractImageSymbols}"
+                          class="Maestro.Base.Commands.SiteExplorer.ExtractSymbolsCommand" />
+            </Condition>
             <MenuItem type="Separator" />
             <MenuItem id="Properties"
                       label="${res:SiteExplorer_SelectedItem_Properties}"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2014-04-07 15:01:59 UTC (rev 8015)
@@ -116,6 +116,7 @@
     <Compile Include="Commands\SaveResourceCommand.cs" />
     <Compile Include="Commands\SiteExplorer\CopyResourceIdCommand.cs" />
     <Compile Include="Commands\SiteExplorer\DuplicateResourceCommand.cs" />
+    <Compile Include="Commands\SiteExplorer\ExtractSymbolsCommand.cs" />
     <Compile Include="Commands\SiteExplorer\FindReplaceXmlContentCommand.cs" />
     <Compile Include="Commands\SiteExplorer\GetLayerSpatialContextCommand.cs" />
     <Compile Include="Commands\SiteExplorer\PurgeFeatureSourceCacheCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs	2014-04-07 15:01:59 UTC (rev 8015)
@@ -2042,6 +2042,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Extract symbols to Symbol Definitions.
+        /// </summary>
+        internal static string SiteExplorer_SelectedItem_ExtractImageSymbols {
+            get {
+                return ResourceManager.GetString("SiteExplorer_SelectedItem_ExtractImageSymbols", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Open.
         /// </summary>
         internal static string SiteExplorer_SelectedItem_Open {
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.resx
--- trunk/Tools/Maestro/Maestro.Base/Strings.resx	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.resx	2014-04-07 15:01:59 UTC (rev 8015)
@@ -992,4 +992,7 @@
   <data name="SiteExplorer_GetLayerSpatialContext" xml:space="preserve">
     <value>Get Layer's Spatial Context</value>
   </data>
+  <data name="SiteExplorer_SelectedItem_ExtractImageSymbols" xml:space="preserve">
+    <value>Extract symbols to Symbol Definitions</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2014-04-07 15:01:59 UTC (rev 8015)
@@ -1054,6 +1054,12 @@
     <Compile Include="SymbolDefinition\CompoundSymbolDefinitionEditorCtrl.Designer.cs">
       <DependentUpon>CompoundSymbolDefinitionEditorCtrl.cs</DependentUpon>
     </Compile>
+    <Compile Include="SymbolDefinition\ExtractSymbolLibraryDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="SymbolDefinition\ExtractSymbolLibraryDialog.Designer.cs">
+      <DependentUpon>ExtractSymbolLibraryDialog.cs</DependentUpon>
+    </Compile>
     <Compile Include="SymbolDefinition\GeneralSettingsCtrl.cs">
       <SubType>UserControl</SubType>
     </Compile>
@@ -1759,6 +1765,9 @@
     <EmbeddedResource Include="SymbolDefinition\CompoundSymbolDefinitionEditorCtrl.resx">
     </EmbeddedResource>
+    <EmbeddedResource Include="SymbolDefinition\ExtractSymbolLibraryDialog.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="SymbolDefinition\GeneralSettingsCtrl.resx">
       <DependentUpon>GeneralSettingsCtrl.cs</DependentUpon>
     </EmbeddedResource>
Added: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.Designer.cs	2014-04-07 15:01:59 UTC (rev 8015)
@@ -0,0 +1,147 @@
+namespace Maestro.Editors.SymbolDefinition
+    partial class ExtractSymbolLibraryDialog
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ExtractSymbolLibraryDialog));
+            this.btnSource = new System.Windows.Forms.Button();
+            this.grpAvailableSymbols = new System.Windows.Forms.GroupBox();
+            this.lstSymbols = new System.Windows.Forms.ListView();
+            this.txtSymbolLibrary = new System.Windows.Forms.TextBox();
+            this.label1 = new System.Windows.Forms.Label();
+            this.btnTarget = new System.Windows.Forms.Button();
+            this.txtTargetFolder = new System.Windows.Forms.TextBox();
+            this.label2 = new System.Windows.Forms.Label();
+            this.btnOK = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            this.grpAvailableSymbols.SuspendLayout();
+            this.SuspendLayout();
+            // btnSource
+            resources.ApplyResources(this.btnSource, "btnSource");
+            this.btnSource.Name = "btnSource";
+            this.btnSource.UseVisualStyleBackColor = true;
+            this.btnSource.Click += new System.EventHandler(this.btnSource_Click);
+            // grpAvailableSymbols
+            resources.ApplyResources(this.grpAvailableSymbols, "grpAvailableSymbols");
+            this.grpAvailableSymbols.Controls.Add(this.lstSymbols);
+            this.grpAvailableSymbols.Name = "grpAvailableSymbols";
+            this.grpAvailableSymbols.TabStop = false;
+            // lstSymbols
+            resources.ApplyResources(this.lstSymbols, "lstSymbols");
+            this.lstSymbols.Name = "lstSymbols";
+            this.lstSymbols.UseCompatibleStateImageBehavior = false;
+            this.lstSymbols.View = System.Windows.Forms.View.Tile;
+            this.lstSymbols.SelectedIndexChanged += new System.EventHandler(this.lstSymbols_SelectedIndexChanged);
+            // txtSymbolLibrary
+            resources.ApplyResources(this.txtSymbolLibrary, "txtSymbolLibrary");
+            this.txtSymbolLibrary.Name = "txtSymbolLibrary";
+            this.txtSymbolLibrary.ReadOnly = true;
+            // label1
+            resources.ApplyResources(this.label1, "label1");
+            this.label1.Name = "label1";
+            // btnTarget
+            resources.ApplyResources(this.btnTarget, "btnTarget");
+            this.btnTarget.Name = "btnTarget";
+            this.btnTarget.UseVisualStyleBackColor = true;
+            this.btnTarget.Click += new System.EventHandler(this.btnTarget_Click);
+            // txtTargetFolder
+            resources.ApplyResources(this.txtTargetFolder, "txtTargetFolder");
+            this.txtTargetFolder.Name = "txtTargetFolder";
+            this.txtTargetFolder.ReadOnly = true;
+            // label2
+            resources.ApplyResources(this.label2, "label2");
+            this.label2.Name = "label2";
+            // btnOK
+            resources.ApplyResources(this.btnOK, "btnOK");
+            this.btnOK.Name = "btnOK";
+            this.btnOK.UseVisualStyleBackColor = true;
+            this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+            // btnCancel
+            this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+            resources.ApplyResources(this.btnCancel, "btnCancel");
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // ExtractSymbolLibraryDialog
+            this.AcceptButton = this.btnOK;
+            resources.ApplyResources(this, "$this");
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.CancelButton = this.btnCancel;
+            this.ControlBox = false;
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnOK);
+            this.Controls.Add(this.btnTarget);
+            this.Controls.Add(this.txtTargetFolder);
+            this.Controls.Add(this.label2);
+            this.Controls.Add(this.btnSource);
+            this.Controls.Add(this.grpAvailableSymbols);
+            this.Controls.Add(this.txtSymbolLibrary);
+            this.Controls.Add(this.label1);
+            this.Name = "ExtractSymbolLibraryDialog";
+            this.grpAvailableSymbols.ResumeLayout(false);
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Button btnSource;
+        private System.Windows.Forms.GroupBox grpAvailableSymbols;
+        private System.Windows.Forms.ListView lstSymbols;
+        private System.Windows.Forms.TextBox txtSymbolLibrary;
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.Button btnTarget;
+        private System.Windows.Forms.TextBox txtTargetFolder;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.Button btnOK;
+        private System.Windows.Forms.Button btnCancel;
Added: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.cs	2014-04-07 15:01:59 UTC (rev 8015)
@@ -0,0 +1,177 @@
+#endregion
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using System;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+    public partial class ExtractSymbolLibraryDialog : Form
+        private ExtractSymbolLibraryDialog()
+            InitializeComponent();
+        private IServerConnection _conn;
+        public ExtractSymbolLibraryDialog(IServerConnection conn)
+            : this()
+            _conn = conn;
+        public ExtractSymbolLibraryDialog(IServerConnection conn, string symbolLibId)
+            : this(conn)
+            txtSymbolLibrary.Text = symbolLibId;
+            LoadSymbols(symbolLibId);
+            EvaluateCommands();
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+        private void btnOK_Click(object sender, EventArgs e)
+            this.DialogResult = System.Windows.Forms.DialogResult.OK;
+        private void btnSource_Click(object sender, EventArgs e)
+            using (var picker = new ResourcePicker(_conn.ResourceService, ResourceTypes.SymbolLibrary, ResourcePickerMode.OpenResource))
+                if (picker.ShowDialog() == DialogResult.OK)
+                    LastSelectedFolder.FolderId = picker.SelectedFolder;
+                    LoadSymbols(picker.ResourceID);
+                    txtSymbolLibrary.Text = picker.ResourceID;
+        private void LoadSymbols(string symResId)
+            var ds = ImageSymbolConverter.PrepareSymbolDrawingSource(_conn, symResId);
+            //Now we should be able to query it via Drawing Service APIs
+            var drawSvc = (IDrawingService)_conn.GetService((int)ServiceType.Drawing);
+            //Each section in the symbols.dwf represents a symbol
+            var sectionList = drawSvc.EnumerateDrawingSections(ds.ResourceID);
+            lstSymbols.Items.Clear();
+            int idx = 0;
+            var imgList = new ImageList();
+            imgList.ImageSize = new Size(32, 32);
+            var symbols = new List<ListViewItem>();
+            foreach (var sect in sectionList.Section)
+                var sectResources = drawSvc.EnumerateDrawingSectionResources(ds.ResourceID, sect.Name);
+                foreach (var res in sectResources.SectionResource)
+                    if (res.Role.ToUpper() == StringConstants.Thumbnail.ToUpper())
+                        using (var rs = drawSvc.GetSectionResource(ds.ResourceID, res.Href))
+                            Image img = Image.FromStream(rs);
+                            imgList.Images.Add(img);
+                            var item = new ListViewItem(sect.Title);
+                            item.ImageIndex = idx;
+                            symbols.Add(item);
+                            idx++;
+            lstSymbols.SmallImageList = imgList;
+            lstSymbols.LargeImageList = imgList;
+            foreach (var sym in symbols)
+                lstSymbols.Items.Add(sym);
+        private void btnTarget_Click(object sender, EventArgs e)
+            using (var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenFolder))
+                if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                    txtTargetFolder.Text = picker.SelectedFolder;
+        private void EvaluateCommands()
+            btnOK.Enabled = !string.IsNullOrEmpty(txtSymbolLibrary.Text) &&
+                            !string.IsNullOrEmpty(txtTargetFolder.Text) &&
+                            lstSymbols.SelectedItems.Count > 0 &&
+                            _conn.ResourceService.ResourceExists(txtSymbolLibrary.Text);
+        /// <summary>
+        /// Gets the selected symbol library
+        /// </summary>
+        public string SymbolLibrary { get { return txtSymbolLibrary.Text; } }
+        /// <summary>
+        /// Gets the selected target folder
+        /// </summary>
+        public string TargetFolder { get { return txtTargetFolder.Text; } }
+        /// <summary>
+        /// Gets the list of symbols to extract
+        /// </summary>
+        public IEnumerable<string> SelectedSymbols
+            get
+                foreach (ListViewItem item in lstSymbols.SelectedItems)
+                    yield return item.Text;
+        private void lstSymbols_SelectedIndexChanged(object sender, EventArgs e)
Added: trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/SymbolDefinition/ExtractSymbolLibraryDialog.resx	2014-04-07 15:01:59 UTC (rev 8015)
@@ -0,0 +1,408 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnSource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Right</value>
+  </data>
+  <data name="btnSource.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+    <value>NoControl</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="btnSource.Location" type="System.Drawing.Point, System.Drawing">
+    <value>583, 10</value>
+  </data>
+  <data name="btnSource.Size" type="System.Drawing.Size, System.Drawing">
+    <value>25, 23</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnSource.TabIndex" type="System.Int32, mscorlib">
+    <value>9</value>
+  </data>
+  <data name="btnSource.Text" xml:space="preserve">
+    <value>...</value>
+  </data>
+  <data name=">>btnSource.Name" xml:space="preserve">
+    <value>btnSource</value>
+  </data>
+  <data name=">>btnSource.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>btnSource.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name=">>btnSource.ZOrder" xml:space="preserve">
+    <value>5</value>
+  </data>
+  <data name="grpAvailableSymbols.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Left, Right</value>
+  </data>
+  <data name="lstSymbols.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Fill</value>
+  </data>
+  <data name="lstSymbols.Location" type="System.Drawing.Point, System.Drawing">
+    <value>3, 16</value>
+  </data>
+  <data name="lstSymbols.Size" type="System.Drawing.Size, System.Drawing">
+    <value>589, 169</value>
+  </data>
+  <data name="lstSymbols.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name=">>lstSymbols.Name" xml:space="preserve">
+    <value>lstSymbols</value>
+  </data>
+  <data name=">>lstSymbols.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>lstSymbols.Parent" xml:space="preserve">
+    <value>grpAvailableSymbols</value>
+  </data>
+  <data name=">>lstSymbols.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <data name="grpAvailableSymbols.Location" type="System.Drawing.Point, System.Drawing">
+    <value>13, 39</value>
+  </data>
+  <data name="grpAvailableSymbols.Size" type="System.Drawing.Size, System.Drawing">
+    <value>595, 188</value>
+  </data>
+  <data name="grpAvailableSymbols.TabIndex" type="System.Int32, mscorlib">
+    <value>8</value>
+  </data>
+  <data name="grpAvailableSymbols.Text" xml:space="preserve">
+    <value>Available Symbols</value>
+  </data>
+  <data name=">>grpAvailableSymbols.Name" xml:space="preserve">
+  </data>
+  <data name=">>grpAvailableSymbols.Type" xml:space="preserve">
+    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>grpAvailableSymbols.Parent" xml:space="preserve">
+  </data>
+  <data name=">>grpAvailableSymbols.ZOrder" xml:space="preserve">
+    <value>6</value>
+  </data>
+  <data name="txtSymbolLibrary.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  </data>
+  <data name="txtSymbolLibrary.Location" type="System.Drawing.Point, System.Drawing">
+    <value>128, 12</value>
+  </data>
+  <data name="txtSymbolLibrary.Size" type="System.Drawing.Size, System.Drawing">
+    <value>449, 20</value>
+  </data>
+  <data name="txtSymbolLibrary.TabIndex" type="System.Int32, mscorlib">
+    <value>7</value>
+  </data>
+  <data name=">>txtSymbolLibrary.Name" xml:space="preserve">
+    <value>txtSymbolLibrary</value>
+  </data>
+  <data name=">>txtSymbolLibrary.Type" xml:space="preserve">
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>txtSymbolLibrary.Parent" xml:space="preserve">
+  </data>
+  <data name=">>txtSymbolLibrary.ZOrder" xml:space="preserve">
+    <value>7</value>
+  </data>
+  <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
+  </data>
+  <data name="label1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  </data>
+  <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>13, 15</value>
+  </data>
+  <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>75, 13</value>
+  </data>
+  <data name="label1.TabIndex" type="System.Int32, mscorlib">
+    <value>6</value>
+  </data>
+  <data name="label1.Text" xml:space="preserve">
+    <value>Symbol Library</value>
+  </data>
+  <data name=">>label1.Name" xml:space="preserve">
+    <value>label1</value>
+  </data>
+  <data name=">>label1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>label1.Parent" xml:space="preserve">
+  </data>
+  <data name=">>label1.ZOrder" xml:space="preserve">
+    <value>8</value>
+  </data>
+  <data name="btnTarget.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  </data>
+  <data name="btnTarget.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  </data>
+  <data name="btnTarget.Location" type="System.Drawing.Point, System.Drawing">
+    <value>583, 231</value>
+  </data>
+  <data name="btnTarget.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnTarget.TabIndex" type="System.Int32, mscorlib">
+    <value>12</value>
+  </data>
+  <data name="btnTarget.Text" xml:space="preserve">
+  </data>
+  <data name=">>btnTarget.Name" xml:space="preserve">
+    <value>btnTarget</value>
+  </data>
+  <data name=">>btnTarget.Type" xml:space="preserve">
+  </data>
+  <data name=">>btnTarget.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnTarget.ZOrder" xml:space="preserve">
+    <value>2</value>
+  </data>
+  <data name="txtTargetFolder.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  </data>
+  <data name="txtTargetFolder.Location" type="System.Drawing.Point, System.Drawing">
+    <value>128, 233</value>
+  </data>
+  <data name="txtTargetFolder.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="txtTargetFolder.TabIndex" type="System.Int32, mscorlib">
+    <value>11</value>
+  </data>
+  <data name=">>txtTargetFolder.Name" xml:space="preserve">
+    <value>txtTargetFolder</value>
+  </data>
+  <data name=">>txtTargetFolder.Type" xml:space="preserve">
+  </data>
+  <data name=">>txtTargetFolder.Parent" xml:space="preserve">
+  </data>
+  <data name=">>txtTargetFolder.ZOrder" xml:space="preserve">
+    <value>3</value>
+  </data>
+  <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+  </data>
+  <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  </data>
+  <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+    <value>13, 236</value>
+  </data>
+  <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+    <value>94, 13</value>
+  </data>
+  <data name="label2.TabIndex" type="System.Int32, mscorlib">
+    <value>10</value>
+  </data>
+  <data name="label2.Text" xml:space="preserve">
+    <value>Extract Symbols to</value>
+  </data>
+  <data name=">>label2.Name" xml:space="preserve">
+    <value>label2</value>
+  </data>
+  <data name=">>label2.Type" xml:space="preserve">
+  </data>
+  <data name=">>label2.Parent" xml:space="preserve">
+  </data>
+  <data name=">>label2.ZOrder" xml:space="preserve">
+    <value>4</value>
+  </data>
+  <data name="btnOK.Location" type="System.Drawing.Point, System.Drawing">
+    <value>452, 267</value>
+  </data>
+  <data name="btnOK.Size" type="System.Drawing.Size, System.Drawing">
+    <value>75, 23</value>
+  </data>
+  <data name="btnOK.TabIndex" type="System.Int32, mscorlib">
+    <value>13</value>
+  </data>
+  <data name="btnOK.Text" xml:space="preserve">
+    <value>OK</value>
+  </data>
+  <data name=">>btnOK.Name" xml:space="preserve">
+    <value>btnOK</value>
+  </data>
+  <data name=">>btnOK.Type" xml:space="preserve">
+  </data>
+  <data name=">>btnOK.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnOK.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>533, 267</value>
+  </data>
+  <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+    <value>14</value>
+  </data>
+  <data name="btnCancel.Text" xml:space="preserve">
+    <value>Cancel</value>
+  </data>
+  <data name=">>btnCancel.Name" xml:space="preserve">
+    <value>btnCancel</value>
+  </data>
+  <data name=">>btnCancel.Type" xml:space="preserve">
+  </data>
+  <data name=">>btnCancel.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnCancel.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  </metadata>
+  <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+    <value>6, 13</value>
+  </data>
+  <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+    <value>620, 302</value>
+  </data>
+  <data name="$this.Text" xml:space="preserve">
+    <value>Extract Symbols</value>
+  </data>
+  <data name=">>$this.Name" xml:space="preserve">
+    <value>ExtractSymbolLibraryDialog</value>
+  </data>
+  <data name=">>$this.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs	2014-04-07 12:56:29 UTC (rev 8014)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/ImageSymbolConverter.cs	2014-04-07 15:01:59 UTC (rev 8015)
@@ -57,6 +57,46 @@
             _conn = conn;
+        public void ExtractSymbols(string targetFolder, IEnumerable<string> symbols, Action<int, int> progressCallback)
+            Check.NotEmpty(targetFolder, "targetFolder"); //NOXLATE
+            Check.Precondition(ResourceIdentifier.IsFolderResource(targetFolder), "ResourceIdentifier.IsFolderResource(targetFolder)"); //NOXLATE
+            if (symbols == null)
+                ExtractSymbols(targetFolder);
+            else
+                IDrawingService drawSvc = (IDrawingService)_conn.GetService((int)ServiceType.Drawing);
+                IDrawingSource ds = PrepareSymbolDrawingSource(_conn, _symbolLibId);
+                var symbolNames = new HashSet<string>(symbols);
+                    if (!symbolNames.Contains(sect.Title))
+                        continue;
+                            ExtractSymbol(targetFolder, drawSvc, ds, sect, res);
+                            processed++;
+                            if (progressCallback != null)
+                                progressCallback(processed, symbolNames.Count);
         /// <summary>
         /// Creates an image-based Symbol Definition in the specified folder for each image symbol in the Symbol Library.
@@ -82,52 +122,56 @@
-                        using (var rs = drawSvc.GetSectionResource(ds.ResourceID, res.Href))
-                            using (Image img = Image.FromStream(rs))
-                                string targetId = targetFolder + sect.Title + "." + ResourceTypes.SymbolDefinition.ToString();
-                                string dataName = sect.Title + "." + GetImageFormat(img.RawFormat);
+        private void ExtractSymbol(string targetFolder, IDrawingService drawSvc, IDrawingSource ds, ObjectModels.Common.DrawingSectionListSection sect, ObjectModels.Common.DrawingSectionResourceListSectionResource res)
+                using (Image img = Image.FromStream(rs))
+                    string targetId = targetFolder + sect.Title + "." + ResourceTypes.SymbolDefinition.ToString();
+                    string dataName = sect.Title + "." + GetImageFormat(img.RawFormat);
-                                var symDef = ObjectFactory.CreateSimpleSymbol(_conn, sect.Title, "Image symbol definition extracted from a Symbol Library by Maestro"); //NOXLATE
-                                var imgGraphics = symDef.CreateImageGraphics();
-                                symDef.AddGraphics(imgGraphics);
+                    var symDef = ObjectFactory.CreateSimpleSymbol(_conn, sect.Title, "Image symbol definition extracted from a Symbol Library by Maestro"); //NOXLATE
+                    var imgGraphics = symDef.CreateImageGraphics();
+                    symDef.AddGraphics(imgGraphics);
-                                imgGraphics.Item = symDef.CreateImageReference(string.Empty, Utility.FdoStringifiyLiteral(dataName)); //Empty resource id = self reference
+                    imgGraphics.Item = symDef.CreateImageReference(string.Empty, Utility.FdoStringifiyLiteral(dataName)); //Empty resource id = self reference
-                                imgGraphics.SizeScalable = "True"; //NOXLATE
-                                imgGraphics.ResizeControl = Utility.FdoStringifiyLiteral("ResizeNone"); //NOXLATE
-                                imgGraphics.Angle = "0.0"; //NOXLATE
-                                imgGraphics.PositionX = "0.0"; //NOXLATE
-                                imgGraphics.PositionY = "4.0"; //NOXLATE
+                    imgGraphics.SizeScalable = "True"; //NOXLATE
+                    imgGraphics.ResizeControl = Utility.FdoStringifiyLiteral("ResizeNone"); //NOXLATE
+                    imgGraphics.Angle = "0.0"; //NOXLATE
+                    imgGraphics.PositionX = "0.0"; //NOXLATE
+                    imgGraphics.PositionY = "4.0"; //NOXLATE
-                                imgGraphics.SizeX = PxToMillimeters(img.Width).ToString(CultureInfo.InvariantCulture);
-                                imgGraphics.SizeY = PxToMillimeters(img.Height).ToString(CultureInfo.InvariantCulture);
+                    imgGraphics.SizeX = PxToMillimeters(img.Width).ToString(CultureInfo.InvariantCulture);
+                    imgGraphics.SizeY = PxToMillimeters(img.Height).ToString(CultureInfo.InvariantCulture);
-                                symDef.PointUsage = symDef.CreatePointUsage();
-                                symDef.PointUsage.Angle = "%ROTATION_ANGLE%"; //NOXLATE
+                    symDef.PointUsage = symDef.CreatePointUsage();
+                    symDef.PointUsage.Angle = "%ROTATION_ANGLE%"; //NOXLATE
-                                var rotParam = symDef.CreateParameter();
-                                rotParam.DataType = "String"; //NOXLATE
-                                rotParam.Identifier = "ROTATION_ANGLE"; //NOXLATE
-                                rotParam.DisplayName = "Angle to rotate symbol"; //NOXLATE
-                                rotParam.DefaultValue = "0.0"; //NOXLATE
+                    var rotParam = symDef.CreateParameter();
+                    rotParam.DataType = "String"; //NOXLATE
+                    rotParam.Identifier = "ROTATION_ANGLE"; //NOXLATE
+                    rotParam.DisplayName = "Angle to rotate symbol"; //NOXLATE
+                    rotParam.DefaultValue = "0.0"; //NOXLATE
-                                symDef.ParameterDefinition.AddParameter(rotParam);
+                    symDef.ParameterDefinition.AddParameter(rotParam);
-                                _conn.ResourceService.SaveResourceAs(symDef, targetId);
-                                using (var ms = new MemoryStream())
-                                    img.Save(ms, ImageFormat.Png);
-                                    ms.Position = 0L; //Rewind
-                                    _conn.ResourceService.SetResourceData(targetId, dataName, ObjectModels.Common.ResourceDataType.File, ms);
+                    _conn.ResourceService.SaveResourceAs(symDef, targetId);
+                    using (var ms = new MemoryStream())
+                        img.Save(ms, ImageFormat.Png);
+                        ms.Position = 0L; //Rewind
+                        _conn.ResourceService.SetResourceData(targetId, dataName, ObjectModels.Common.ResourceDataType.File, ms);
-                                Trace.TraceInformation("Extracted symbol: " + targetId);
+                    Trace.TraceInformation("Extracted symbol: " + targetId);
More information about the mapguide-commits mailing list
