[mapguide-commits] r8026 - in trunk/MgDev: . Oem/LinuxApt Oem/httpd Oem/httpd/lib Oem/httpd/lib64 Oem/php Oem/php/Release_TS Oem/php/x64/Release_TS
svn_mapguide at osgeo.org
Wed Apr 9 18:23:58 PDT 2014
Author: jng
Date: 2014-04-09 18:23:58 -0700 (Wed, 09 Apr 2014)
New Revision: 8026
Added:
trunk/MgDev/Oem/LinuxApt/httpd-2.4.9.tar.bz2
trunk/MgDev/Oem/LinuxApt/php-5.5.11.tar.bz2
Removed:
trunk/MgDev/Oem/LinuxApt/httpd-2.4.6.tar.bz2
trunk/MgDev/Oem/LinuxApt/php-5.5.3.tar.bz2
trunk/MgDev/Oem/LinuxApt/build_apt.sh
trunk/MgDev/Oem/httpd/PROVENANCE.TXT
trunk/MgDev/Oem/httpd/lib/apr-1.lib
trunk/MgDev/Oem/httpd/lib/aprutil-1.lib
trunk/MgDev/Oem/httpd/lib/libapr-1.exp
trunk/MgDev/Oem/httpd/lib/libapr-1.lib
trunk/MgDev/Oem/httpd/lib/libapriconv-1.exp
trunk/MgDev/Oem/httpd/lib/libapriconv-1.lib
trunk/MgDev/Oem/httpd/lib/libaprutil-1.exp
trunk/MgDev/Oem/httpd/lib/libaprutil-1.lib
trunk/MgDev/Oem/httpd/lib/libhttpd.exp
trunk/MgDev/Oem/httpd/lib/libhttpd.lib
trunk/MgDev/Oem/httpd/lib/mod_dav.exp
trunk/MgDev/Oem/httpd/lib/mod_dav.lib
trunk/MgDev/Oem/httpd/lib/xml.lib
trunk/MgDev/Oem/httpd/lib64/apr-1.lib
trunk/MgDev/Oem/httpd/lib64/aprutil-1.lib
trunk/MgDev/Oem/httpd/lib64/libapr-1.exp
trunk/MgDev/Oem/httpd/lib64/libapr-1.lib
trunk/MgDev/Oem/httpd/lib64/libapriconv-1.exp
trunk/MgDev/Oem/httpd/lib64/libapriconv-1.lib
trunk/MgDev/Oem/httpd/lib64/libaprutil-1.exp
trunk/MgDev/Oem/httpd/lib64/libaprutil-1.lib
trunk/MgDev/Oem/httpd/lib64/libhttpd.exp
trunk/MgDev/Oem/httpd/lib64/libhttpd.lib
trunk/MgDev/Oem/httpd/lib64/mod_dav.exp
trunk/MgDev/Oem/httpd/lib64/mod_dav.lib
trunk/MgDev/Oem/httpd/lib64/xml.lib
trunk/MgDev/Oem/php/PROVENANCE.TXT
trunk/MgDev/Oem/php/Release_TS/php5ts.lib
trunk/MgDev/Oem/php/x64/Release_TS/php5ts.lib
trunk/MgDev/prepare_webtier_components.bat
trunk/MgDev/setenvironment.bat
trunk/MgDev/setenvironment64.bat
#2425: Update Apache to 2.4.9 and PHP to 5.5.11
Modified: trunk/MgDev/Oem/LinuxApt/build_apt.sh
--- trunk/MgDev/Oem/LinuxApt/build_apt.sh 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/Oem/LinuxApt/build_apt.sh 2014-04-10 01:23:58 UTC (rev 8026)
@@ -15,6 +15,8 @@
INSTALLDIR=/usr/local/mapguideopensource
+HTTPD_VER=2.4.9
+PHP_VER=5.5.11
PORT=8008
TOMCAT=0
TOMCAT_PORT=8009
@@ -140,16 +142,16 @@
# equivalent library in other Linux distributions
echo "Apache Httpd build started"
-tar -jxf httpd-2.4.6.tar.bz2
-if [ ! -d "httpd-2.4.6/srclib/apr" ]; then
+tar -jxf httpd-$HTTP_VER.tar.bz2
+if [ ! -d "httpd-$HTTP_VER/srclib/apr" ]; then
tar -jxf apr-1.4.8.tar.bz2
- mv apr-1.4.8 httpd-2.4.6/srclib/apr
+ mv apr-1.4.8 httpd-$HTTP_VER/srclib/apr
fi
-if [ ! -d "httpd-2.4.6/srclib/aprutil" ]; then
+if [ ! -d "httpd-$HTTP_VER/srclib/aprutil" ]; then
tar -jxf apr-util-1.5.2.tar.bz2
- mv apr-util-1.5.2 httpd-2.4.6/srclib/apr-util
+ mv apr-util-1.5.2 httpd-$HTTP_VER/srclib/apr-util
fi
-pushd httpd-2.4.6
+pushd httpd-$HTTP_VER
./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
--with-included-apr --with-port=$PORT
check_apache_build
@@ -181,7 +183,7 @@
# Notes: none
echo "Apache install started"
-pushd httpd-2.4.6
make install
check_apache_install
popd
@@ -225,8 +227,8 @@
# Notes: none
echo "Php build started"
-tar -jxf php-5.5.3.tar.bz2
-pushd php-5.5.3
+tar -jxf php-$PHP_VER.tar.bz2
+pushd php-$PHP_VER
./configure --prefix=$INSTALLWEB/php --with-apxs2=$INSTALLWEB/apache2/bin/apxs --with-openssl \
--with-curl --enable-xml --enable-wddx --enable-shared \
--enable-safe-mode --with-zlib --enable-zip --enable-mbstring=all --with-xsl=/usr/lib --with-gd --with-png --with-jpeg --with-freetype
@@ -241,7 +243,7 @@
# Notes: none
echo "Php install started"
-pushd php-5.5.3
+pushd php-$PHP_VER
make install
check_php_install
popd
Deleted: trunk/MgDev/Oem/LinuxApt/httpd-2.4.6.tar.bz2
(Binary files differ)
Added: trunk/MgDev/Oem/LinuxApt/httpd-2.4.9.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/httpd-2.4.9.tar.bz2
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/MgDev/Oem/LinuxApt/php-5.5.11.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/php-5.5.11.tar.bz2
Deleted: trunk/MgDev/Oem/LinuxApt/php-5.5.3.tar.bz2
Modified: trunk/MgDev/Oem/httpd/PROVENANCE.TXT
--- trunk/MgDev/Oem/httpd/PROVENANCE.TXT 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/Oem/httpd/PROVENANCE.TXT 2014-04-10 01:23:58 UTC (rev 8026)
@@ -1,7 +1,7 @@
lib
lib64
- Extracted from httpd-2.4.6 win32 and win64 binaries from http://www.apachelounge.com/download/
+ Extracted from httpd-2.4.9 win32 and win64 binaries from http://www.apachelounge.com/download/
include
Modified: trunk/MgDev/Oem/httpd/lib/apr-1.lib
Modified: trunk/MgDev/Oem/httpd/lib/aprutil-1.lib
Modified: trunk/MgDev/Oem/httpd/lib/libapr-1.exp
Modified: trunk/MgDev/Oem/httpd/lib/libapr-1.lib
Modified: trunk/MgDev/Oem/httpd/lib/libapriconv-1.exp
Modified: trunk/MgDev/Oem/httpd/lib/libapriconv-1.lib
Modified: trunk/MgDev/Oem/httpd/lib/libaprutil-1.exp
Modified: trunk/MgDev/Oem/httpd/lib/libaprutil-1.lib
Modified: trunk/MgDev/Oem/httpd/lib/libhttpd.exp
Modified: trunk/MgDev/Oem/httpd/lib/libhttpd.lib
Modified: trunk/MgDev/Oem/httpd/lib/mod_dav.exp
Modified: trunk/MgDev/Oem/httpd/lib/mod_dav.lib
Modified: trunk/MgDev/Oem/httpd/lib/xml.lib
Modified: trunk/MgDev/Oem/httpd/lib64/apr-1.lib
Modified: trunk/MgDev/Oem/httpd/lib64/aprutil-1.lib
Modified: trunk/MgDev/Oem/httpd/lib64/libapr-1.exp
Modified: trunk/MgDev/Oem/httpd/lib64/libapr-1.lib
Modified: trunk/MgDev/Oem/httpd/lib64/libapriconv-1.exp
Modified: trunk/MgDev/Oem/httpd/lib64/libapriconv-1.lib
Modified: trunk/MgDev/Oem/httpd/lib64/libaprutil-1.exp
Modified: trunk/MgDev/Oem/httpd/lib64/libaprutil-1.lib
Modified: trunk/MgDev/Oem/httpd/lib64/libhttpd.exp
Modified: trunk/MgDev/Oem/httpd/lib64/libhttpd.lib
Modified: trunk/MgDev/Oem/httpd/lib64/mod_dav.exp
Modified: trunk/MgDev/Oem/httpd/lib64/mod_dav.lib
Modified: trunk/MgDev/Oem/httpd/lib64/xml.lib
Modified: trunk/MgDev/Oem/php/PROVENANCE.TXT
--- trunk/MgDev/Oem/php/PROVENANCE.TXT 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/Oem/php/PROVENANCE.TXT 2014-04-10 01:23:58 UTC (rev 8026)
@@ -5,7 +5,7 @@
Release_TS
x64\Release_TS
- php5ts.lib extracted from official VC11 binary distribution of PHP 5.5.3 (http://windows.php.net/download/)
+ php5ts.lib extracted from official VC11 binary distribution of PHP 5.5.11 (http://windows.php.net/download/)
main\win95nt.h
Modified: trunk/MgDev/Oem/php/Release_TS/php5ts.lib
Modified: trunk/MgDev/Oem/php/x64/Release_TS/php5ts.lib
Modified: trunk/MgDev/prepare_webtier_components.bat
--- trunk/MgDev/prepare_webtier_components.bat 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/prepare_webtier_components.bat 2014-04-10 01:23:58 UTC (rev 8026)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.6
-SET PHP_VER=5.5.3
+SET HTTPD_VER=2.4.9
+SET PHP_VER=5.5.11
pushd Oem\LinuxApt
if exist httpd-%HTTPD_VER% (
echo httpd already unpacked. Nothing to do here.
Modified: trunk/MgDev/setenvironment.bat
--- trunk/MgDev/setenvironment.bat 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/setenvironment.bat 2014-04-10 01:23:58 UTC (rev 8026)
@@ -99,9 +99,9 @@
call prepare_webtier_components.bat
rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.3
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.11
SET PHP_LIB=%MG_OEM%\php\Release_TS
-SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.6
+SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.9
SET HTTPD_LIB=%MG_OEM%\httpd\lib
rem Sanity checks
if not exist "%PHP_SRC%" echo Environment variable PHP_SRC does not point to a valid directory (%PHP_SRC%). Please edit setenvironment64.bat to ensure PHP_SRC points to a valid directory
Modified: trunk/MgDev/setenvironment64.bat
--- trunk/MgDev/setenvironment64.bat 2014-04-09 15:44:36 UTC (rev 8025)
+++ trunk/MgDev/setenvironment64.bat 2014-04-10 01:23:58 UTC (rev 8026)
@@ -104,9 +104,9 @@
SET PHP_LIB=%MG_OEM%\php\x64\Release_TS
SET HTTPD_LIB=%MG_OEM%\httpd\lib64
rem Sanity checks
More information about the mapguide-commits
