[mapguide-commits] r8039 - trunk/MgDev/Web/src/viewerfiles
svn_mapguide at osgeo.org
Mon Apr 14 04:13:09 PDT 2014
Author: jng
Date: 2014-04-14 04:13:09 -0700 (Mon, 14 Apr 2014)
New Revision: 8039
trunk/MgDev/Web/src/viewerfiles/legendui.templ
#2416: Fix theme rules for a layer with multiple scale ranges stay shown in the legend if moving back to a scale range where that layer has no theme rules.
Modified: trunk/MgDev/Web/src/viewerfiles/legendui.templ
--- trunk/MgDev/Web/src/viewerfiles/legendui.templ 2014-04-14 01:00:57 UTC (rev 8038)
+++ trunk/MgDev/Web/src/viewerfiles/legendui.templ 2014-04-14 11:13:09 UTC (rev 8039)
@@ -1015,6 +1015,24 @@
// the layer's theme will be changed on demand
node.children[nodeCurScale].iconWasRequested = false;
+ var bCurrentScaleThemed = (node.children[nodeCurScale].children.length > 1);
+ var themeEl = document.getElementById('ChildrenOf_' + node.objectId);
+ if (bCurrentScaleThemed && themeEl) {
+ themeEl.style.display = "block";
+ for (var i = 0; i < node.children.length; i++) {
+ if (i == nodeCurScale) {
+ continue;
+ } else {
+ // Need to hide any previously set theme rule HTML for other scales
+ var bThemed = (node.children[i].children.length > 1);
+ if (bThemed && !bCurrentScaleThemed) {
+ if (themeEl)
+ themeEl.style.display = "none";
// the layer's legend image will be changed immediately
if(!HasCollapsedParent(node))
More information about the mapguide-commits
