[mapguide-commits] r8044 - trunk/Installer/Libraries/MapGuide Server/Lang
svn_mapguide at osgeo.org
Mon Apr 14 17:57:35 PDT 2014
Author: jng
Date: 2014-04-14 17:57:35 -0700 (Mon, 14 Apr 2014)
New Revision: 8044
trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_en-US.wxl
trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_es-ES.wxl
#2428: Add missing string
Modified: trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_en-US.wxl
--- trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_en-US.wxl 2014-04-14 14:38:52 UTC (rev 8043)
+++ trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_en-US.wxl 2014-04-15 00:57:35 UTC (rev 8044)
@@ -18,6 +18,7 @@
<String Id="ServerRepositoriesTileCacheFeature_Description">You may choose a location for the Tile Cache repository.</String>
<String Id="ServerTempFeature">Temp Directory</String>
<String Id="ServerTempFeature_Description">You may choose a location where MapGuide will store temporary files.</String>
+ <String Id="Common_MgServerIp">MapGuide Server IP</String>
<!-- FDO -->
<String Id="FdoDescription">FDO (Feature Data Objects) allows abstract access to many different data sources.</String>
<String Id="ArcSdeProvider">ArcSDE Provider</String>
Modified: trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_es-ES.wxl
--- trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_es-ES.wxl 2014-04-14 14:38:52 UTC (rev 8043)
+++ trunk/Installer/Libraries/MapGuide Server/Lang/MapGuideServer_es-ES.wxl 2014-04-15 00:57:35 UTC (rev 8044)
@@ -18,6 +18,7 @@
<String Id="ServerTempFeature">Archivos temporales</String>
<String Id="ServerTempFeature_Description">Usted puede elegir un lugar donde MapGuide almacenará los archivos temporales</String>
+ <String Id="Common_MgServerIp">MapGuide Servidor IP</String>
<!-- FDO -->
<String Id="FdoDescription">FDO (objetos de datos de características) permite el acceso al resumen diferentes fuentes de datos.</String>
<String Id="ArcSdeProvider">ArcSDE Proveedor</String>
More information about the mapguide-commits
