[mapguide-commits] r8050 - in trunk/Tools/Maestro: Maestro.Editors Maestro.Editors/FeatureSource/Providers/Wms OSGeo.MapGuide.MaestroAPI/SchemaOverrides
svn_mapguide at osgeo.org
Wed Apr 16 07:33:46 PDT 2014
Author: jng
Date: 2014-04-16 07:33:46 -0700 (Wed, 16 Apr 2014)
New Revision: 8050
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsProviderCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs
Move some WMS configuration document convenience methods into the main Maestro API
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.cs 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.cs 2014-04-16 14:33:46 UTC (rev 8050)
@@ -259,52 +259,8 @@
try
_config = (WmsConfigurationDocument)_service.FeatureService.GetSchemaMapping("OSGeo.WMS", _fs.ConnectionString); //NOXLATE
- //BOGUS: This was not as sufficient as I originally thought, nevertheless this contains
- //information that would not exist if we constructed the document the old fashioned way.
- string defaultScName = string.Empty;
- if (_config.SpatialContexts.Length > 0)
- defaultScName = _config.SpatialContexts[0].Name;
- else
- var list = _fs.GetSpatialInfo(false);
- if (list.SpatialContext.Count > 0)
- defaultScName = list.SpatialContext[0].Name;
- else //Really? What kind of WMS service are you????
- var sc = new FdoSpatialContextListSpatialContext()
- Name = "EPSG:4326", //NOXLATE
- Description = "Maestro-generated spatial context", //NOXLATE
- CoordinateSystemName = "EPSG:4326", //NOXLATE
- CoordinateSystemWkt = "GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]", //NOXLATE
- Extent = new FdoSpatialContextListSpatialContextExtent()
- LowerLeftCoordinate = new FdoSpatialContextListSpatialContextExtentLowerLeftCoordinate()
- X = "-180.0", //NOXLATE
- Y = "-90.0" //NOXLATE
- UpperRightCoordinate = new FdoSpatialContextListSpatialContextExtentUpperRightCoordinate()
- X = "180.0", //NOXLATE
- Y = "90.0" //NOXLATE
- ExtentType = FdoSpatialContextListSpatialContextExtentType.Static,
- IsActive = true,
- XYTolerance = 0.0001,
- ZTolerance = 0.0001,
- _config.AddSpatialContext(sc);
- defaultScName = sc.Name;
- EnsureRasterProperties(defaultScName);
+ string defaultScName = _config.GetDefaultSpatialContext(_fs);
+ _config.EnsureRasterProperties(defaultScName);
_config.EnsureConsistency();
catch
@@ -313,58 +269,6 @@
- private void EnsureRasterProperties(string defaultScName)
- foreach (var schema in _config.Schemas)
- foreach (var cls in schema.Classes)
- //Add identity property if none found
- if (cls.IdentityProperties.Count == 0)
- cls.AddProperty(new DataPropertyDefinition("Id", string.Empty) //NOXLATE
- DataType = DataPropertyType.String,
- Length = 256,
- IsNullable = false
- }, true);
- //Add raster property if there's only one property (the identity property we either just added or found)
- if (cls.Properties.Count == 1)
- cls.AddProperty(new RasterPropertyDefinition("Image", string.Empty) //NOXLATE
- DefaultImageXSize = 1024,
- DefaultImageYSize = 1024,
- SpatialContextAssociation = defaultScName
- else
- bool bFoundRaster = false;
- //Try to find this raster property
- foreach (var prop in cls.Properties)
- if (prop.Type == OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinitionType.Raster)
- bFoundRaster = true;
- break;
- if (!bFoundRaster)
private void grdSpatialContexts_CellContentClick(object sender, DataGridViewCellEventArgs e)
if (e.ColumnIndex == 1)
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsAdvancedConfigurationDialog.resx 2014-04-16 14:33:46 UTC (rev 8050)
@@ -175,10 +175,10 @@
<value>Top, Bottom, Left, Right</value>
</data>
<data name="grpRaster.Location" type="System.Drawing.Point, System.Drawing">
- <value>294, 224</value>
+ <value>294, 256</value>
</data>
<data name="grpRaster.Size" type="System.Drawing.Size, System.Drawing">
- <value>357, 262</value>
+ <value>357, 279</value>
</data>
<data name="grpRaster.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
@@ -202,7 +202,7 @@
<value>Bottom, Right</value>
</data>
<data name="btnSave.Location" type="System.Drawing.Point, System.Drawing">
- <value>495, 492</value>
+ <value>495, 541</value>
</data>
<data name="btnSave.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -229,7 +229,7 @@
</data>
<data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
- <value>576, 492</value>
+ <value>576, 541</value>
</data>
<data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
@@ -252,60 +252,9 @@
<data name=">>btnCancel.ZOrder" xml:space="preserve">
<value>5</value>
</data>
- <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
<data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left</value>
</data>
- <data name=">>lstFeatureClasses.Name" xml:space="preserve">
- <value>lstFeatureClasses</value>
- </data>
- <data name=">>lstFeatureClasses.Type" xml:space="preserve">
- <value>System.Windows.Forms.ListBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>lstFeatureClasses.Parent" xml:space="preserve">
- <value>groupBox2</value>
- </data>
- <data name=">>lstFeatureClasses.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>toolStrip1.Name" xml:space="preserve">
- <value>toolStrip1</value>
- </data>
- <data name=">>toolStrip1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>toolStrip1.Parent" xml:space="preserve">
- </data>
- <data name=">>toolStrip1.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 134</value>
- </data>
- <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
- <value>276, 352</value>
- </data>
- <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
- <value>5</value>
- </data>
- <data name="groupBox2.Text" xml:space="preserve">
- <value>Feature Classes</value>
- </data>
- <data name=">>groupBox2.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox2.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>groupBox2.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>groupBox2.ZOrder" xml:space="preserve">
- <value>4</value>
- </data>
<data name="lstFeatureClasses.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -313,7 +262,7 @@
<value>3, 16</value>
</data>
<data name="lstFeatureClasses.Size" type="System.Drawing.Size, System.Drawing">
- <value>270, 333</value>
+ <value>270, 350</value>
</data>
<data name="lstFeatureClasses.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -333,6 +282,27 @@
</metadata>
+ <data name="btnAdd.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnAdd.Size" type="System.Drawing.Size, System.Drawing">
+ <value>49, 22</value>
+ </data>
+ <data name="btnAdd.Text" xml:space="preserve">
+ <value>Add</value>
+ </data>
+ <data name="btnRemove.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnRemove.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnRemove.Size" type="System.Drawing.Size, System.Drawing">
+ <value>70, 22</value>
+ </data>
+ <data name="btnRemove.Text" xml:space="preserve">
+ <value>Remove</value>
+ </data>
<data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -360,32 +330,35 @@
<value>1</value>
</data>
- <data name="btnAdd.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
- <value>Magenta</value>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 166</value>
</data>
- <data name="btnAdd.Size" type="System.Drawing.Size, System.Drawing">
- <value>49, 22</value>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>276, 369</value>
</data>
- <data name="btnAdd.Text" xml:space="preserve">
- <value>Add</value>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
</data>
- <data name="btnRemove.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Feature Classes</value>
</data>
- <data name="btnRemove.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ <value>groupBox2</value>
</data>
- <data name="btnRemove.Size" type="System.Drawing.Size, System.Drawing">
- <value>70, 22</value>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name="btnRemove.Text" xml:space="preserve">
- <value>Remove</value>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ <value>$this</value>
</data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
<data name="btnReset.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Left</value>
</data>
<data name="btnReset.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 492</value>
+ <value>12, 541</value>
</data>
<data name="btnReset.Size" type="System.Drawing.Size, System.Drawing">
<value>107, 23</value>
@@ -411,48 +384,18 @@
<data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
- <data name=">>grdSpatialContexts.Name" xml:space="preserve">
- <value>grdSpatialContexts</value>
- </data>
- <data name=">>grdSpatialContexts.Type" xml:space="preserve">
- <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>grdSpatialContexts.Parent" xml:space="preserve">
- <value>groupBox1</value>
- </data>
- <data name=">>grdSpatialContexts.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 39</value>
- </data>
- <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
- <value>639, 89</value>
- </data>
- <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
- <value>7</value>
- </data>
- <data name="groupBox1.Text" xml:space="preserve">
- <value>Spatial Contexts (click cell to edit coordinate system)</value>
- </data>
- <data name=">>groupBox1.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox1.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox1.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox1.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
<metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
+ <data name="COL_NAME.HeaderText" xml:space="preserve">
+ <value>Name</value>
+ </data>
<metadata name="COL_CS.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
+ <data name="COL_CS.HeaderText" xml:space="preserve">
+ <value>Coordinate System</value>
+ </data>
<data name="grdSpatialContexts.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -460,7 +403,7 @@
</data>
<data name="grdSpatialContexts.Size" type="System.Drawing.Size, System.Drawing">
- <value>633, 70</value>
+ <value>633, 102</value>
</data>
<data name="grdSpatialContexts.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -477,108 +420,33 @@
<value>0</value>
</data>
- <metadata name="COL_NAME.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
- <value>True</value>
- </metadata>
- <data name="COL_NAME.HeaderText" xml:space="preserve">
- <value>Name</value>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 39</value>
</data>
- <metadata name="COL_CS.UserAddedColumn" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
- </metadata>
- <data name="COL_CS.HeaderText" xml:space="preserve">
- <value>Coordinate System</value>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>639, 121</value>
</data>
- <data name="grpLogicalClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Left, Right</value>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
</data>
- <data name=">>lnkSwap.Name" xml:space="preserve">
- <value>lnkSwap</value>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Spatial Contexts (click cell to edit coordinate system)</value>
</data>
- <data name=">>lnkSwap.Type" xml:space="preserve">
- <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ <value>groupBox1</value>
</data>
- <data name=">>lnkSwap.Parent" xml:space="preserve">
- <value>grpLogicalClass</value>
- </data>
- <data name=">>lnkSwap.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>txtClassDescription.Name" xml:space="preserve">
- <value>txtClassDescription</value>
- </data>
- <data name=">>txtClassDescription.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>txtClassDescription.Parent" xml:space="preserve">
- </data>
- <data name=">>txtClassDescription.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>label3.Name" xml:space="preserve">
- <value>label3</value>
- </data>
- <data name=">>label3.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>label3.Parent" xml:space="preserve">
- </data>
- <data name=">>label3.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name=">>txtClassName.Name" xml:space="preserve">
- <value>txtClassName</value>
- </data>
- <data name=">>txtClassName.Type" xml:space="preserve">
- </data>
- <data name=">>txtClassName.Parent" xml:space="preserve">
- </data>
- <data name=">>txtClassName.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name=">>label2.Name" xml:space="preserve">
- <value>label2</value>
- </data>
- <data name=">>label2.Type" xml:space="preserve">
- </data>
- <data name=">>label2.Parent" xml:space="preserve">
- </data>
- <data name=">>label2.ZOrder" xml:space="preserve">
- <value>4</value>
- </data>
- <data name="grpLogicalClass.Enabled" type="System.Boolean, mscorlib">
- </data>
- <data name="grpLogicalClass.Location" type="System.Drawing.Point, System.Drawing">
- <value>294, 134</value>
- </data>
- <data name="grpLogicalClass.Size" type="System.Drawing.Size, System.Drawing">
- <value>354, 84</value>
- </data>
- <data name="grpLogicalClass.TabIndex" type="System.Int32, mscorlib">
- <value>8</value>
- </data>
- <data name="grpLogicalClass.Text" xml:space="preserve">
- <value>Logical Class</value>
- </data>
- <data name=">>grpLogicalClass.Name" xml:space="preserve">
- </data>
- <data name=">>grpLogicalClass.Type" xml:space="preserve">
+ <data name=">>groupBox1.Type" xml:space="preserve">
</data>
- <data name=">>grpLogicalClass.Parent" xml:space="preserve">
+ <data name=">>groupBox1.Parent" xml:space="preserve">
</data>
- <data name=">>grpLogicalClass.ZOrder" xml:space="preserve">
- <value>1</value>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>2</value>
</data>
+ <data name="grpLogicalClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
<data name="lnkSwap.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -711,11 +579,38 @@
<value>4</value>
</data>
+ <data name="grpLogicalClass.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="grpLogicalClass.Location" type="System.Drawing.Point, System.Drawing">
+ <value>297, 166</value>
+ </data>
+ <data name="grpLogicalClass.Size" type="System.Drawing.Size, System.Drawing">
+ <value>354, 84</value>
+ </data>
+ <data name="grpLogicalClass.TabIndex" type="System.Int32, mscorlib">
+ <value>8</value>
+ </data>
+ <data name="grpLogicalClass.Text" xml:space="preserve">
+ <value>Logical Class</value>
+ </data>
+ <data name=">>grpLogicalClass.Name" xml:space="preserve">
+ <value>grpLogicalClass</value>
+ </data>
+ <data name=">>grpLogicalClass.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpLogicalClass.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpLogicalClass.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="btnSwapAll.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
<data name="btnSwapAll.Location" type="System.Drawing.Point, System.Drawing">
- <value>125, 492</value>
+ <value>125, 541</value>
</data>
<data name="btnSwapAll.Size" type="System.Drawing.Size, System.Drawing">
<value>160, 23</value>
@@ -742,7 +637,7 @@
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>663, 527</value>
+ <value>663, 576</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>CenterParent</value>
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsProviderCtrl.cs 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Wms/WmsProviderCtrl.cs 2014-04-16 14:33:46 UTC (rev 8050)
@@ -29,6 +29,7 @@
using OSGeo.MapGuide.MaestroAPI.Resource;
using OSGeo.MapGuide.ObjectModels.FeatureSource;
using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI.SchemaOverrides;
namespace Maestro.Editors.FeatureSource.Providers.Wms
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-04-16 14:33:46 UTC (rev 8050)
@@ -97,6 +97,15 @@
/// <summary>
+ /// Looks up a localized string similar to Building configuration document for WMS Feature Source.
+ /// </summary>
+ internal static string AutoConfiguringFeatureSource {
+ get {
+ return ResourceManager.GetString("AutoConfiguringFeatureSource", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Base Layer Group.
/// </summary>
internal static string BaseLayerGroup {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-04-16 14:33:46 UTC (rev 8050)
@@ -1578,4 +1578,7 @@
<data name="ThemingNotAVectorLayer" xml:space="preserve">
<value>The layer being themed is not a vector layer</value>
</data>
+ <data name="AutoConfiguringFeatureSource" xml:space="preserve">
+ <value>Building configuration document for WMS Feature Source</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs 2014-04-16 13:58:39 UTC (rev 8049)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs 2014-04-16 14:33:46 UTC (rev 8050)
@@ -18,6 +18,8 @@
#endregion
using OSGeo.MapGuide.MaestroAPI.Schema;
+using OSGeo.MapGuide.ObjectModels.Common;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
using System;
using System.Collections.Generic;
using System.Text;
@@ -151,7 +153,7 @@
//Since we're here. Fix up the raster logical property if there's a mismatch
- if (prop.Type == PropertyDefinitionType.Raster)
+ if (prop.Type == OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinitionType.Raster)
if (prop.Name != mapping.RasterPropertyName)
mapping.RasterPropertyName = prop.Name;
@@ -174,5 +176,117 @@
schema.RemoveClass(cls);
+ /// <summary>
+ /// Gets the default spatial context from this configuration document. If none is found, the first spatial
+ /// context from the given Feature Source is used
+ /// </summary>
+ /// <param name="fs"></param>
+ /// <returns></returns>
+ public string GetDefaultSpatialContext(IFeatureSource fs)
+ //BOGUS: This was not as sufficient as I originally thought, nevertheless this contains
+ //information that would not exist if we constructed the document the old fashioned way.
+ string defaultScName = string.Empty;
+ if (this.SpatialContexts.Length > 0)
+ defaultScName = this.SpatialContexts[0].Name;
+ else
+ var list = fs.GetSpatialInfo(false);
+ if (list.SpatialContext.Count > 0)
+ defaultScName = list.SpatialContext[0].Name;
+ else //Really? What kind of WMS service are you????
+ var sc = new FdoSpatialContextListSpatialContext()
+ Name = "EPSG:4326", //NOXLATE
+ Description = "Maestro-generated spatial context", //NOXLATE
+ CoordinateSystemName = "EPSG:4326", //NOXLATE
+ CoordinateSystemWkt = "GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]", //NOXLATE
+ Extent = new FdoSpatialContextListSpatialContextExtent()
+ LowerLeftCoordinate = new FdoSpatialContextListSpatialContextExtentLowerLeftCoordinate()
+ X = "-180.0", //NOXLATE
+ Y = "-90.0" //NOXLATE
+ UpperRightCoordinate = new FdoSpatialContextListSpatialContextExtentUpperRightCoordinate()
+ X = "180.0", //NOXLATE
+ Y = "90.0" //NOXLATE
+ ExtentType = FdoSpatialContextListSpatialContextExtentType.Static,
+ IsActive = true,
+ XYTolerance = 0.0001,
+ ZTolerance = 0.0001,
+ this.AddSpatialContext(sc);
+ defaultScName = sc.Name;
+ return defaultScName;
+ /// <summary>
+ /// Ensures that classes in this document have an identity property and a raster property. Any classes which
+ /// have neither, will have properties created for them
+ /// </summary>
+ /// <param name="defaultScName">The name of the default spatial context</param>
+ public void EnsureRasterProperties(string defaultScName)
+ foreach (var schema in this.Schemas)
+ foreach (var cls in schema.Classes)
+ //Add identity property if none found
+ if (cls.IdentityProperties.Count == 0)
+ cls.AddProperty(new DataPropertyDefinition("Id", string.Empty) //NOXLATE
+ DataType = DataPropertyType.String,
+ Length = 256,
+ IsNullable = false
+ }, true);
+ //Add raster property if there's only one property (the identity property we either just added or found)
+ if (cls.Properties.Count == 1)
+ cls.AddProperty(new RasterPropertyDefinition("Image", string.Empty) //NOXLATE
+ DefaultImageXSize = 1024,
+ DefaultImageYSize = 1024,
+ SpatialContextAssociation = defaultScName
+ else
+ bool bFoundRaster = false;
+ //Try to find this raster property
+ foreach (var prop in cls.Properties)
+ bFoundRaster = true;
+ break;
+ if (!bFoundRaster)
More information about the mapguide-commits
