[mapguide-commits] r8063 - in trunk/MgDev/Oem/agg-2.4: . src
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Apr 18 10:46:10 PDT 2014
Author: jng
Date: 2014-04-18 10:46:09 -0700 (Fri, 18 Apr 2014)
New Revision: 8063
Removed:
   trunk/MgDev/Oem/agg-2.4/gpc/
   trunk/MgDev/Oem/agg-2.4/src/Makefile
#2295: GPC has incompatible licensing terms and is not used by MapGuide. So remove GPC from agg to avoid any accidental linkage
Modified: trunk/MgDev/Oem/agg-2.4/src/Makefile
--- trunk/MgDev/Oem/agg-2.4/src/Makefile	2014-04-18 07:22:42 UTC (rev 8062)
+++ trunk/MgDev/Oem/agg-2.4/src/Makefile	2014-04-18 17:46:09 UTC (rev 8063)
@@ -38,12 +38,8 @@
 ctrl/agg_polygon_ctrl.cpp \
 ctrl/agg_bezier_ctrl.cpp
-SRC_C=\
-../gpc/gpc.c
+OBJ=$(SRC_CXX:.cpp=.o)
-OBJ=$(SRC_CXX:.cpp=.o) $(SRC_C:.c=.o)
 all:	$(OBJ)
 	$(LIB) libagg.a $(OBJ)
More information about the mapguide-commits mailing list
