[mapguide-commits] r8076 - in trunk/Tools/Maestro: . Maestro Maestro/packages MgCooker MpuCalc MpuCalc/Properties
svn_mapguide at osgeo.org
Sat Apr 26 13:27:28 PDT 2014
Author: jng
Date: 2014-04-26 13:27:28 -0700 (Sat, 26 Apr 2014)
New Revision: 8076
Added:
trunk/Tools/Maestro/MpuCalc/
trunk/Tools/Maestro/MpuCalc/App.config
trunk/Tools/Maestro/MpuCalc/MpuCalc.csproj
trunk/Tools/Maestro/MpuCalc/Program.cs
trunk/Tools/Maestro/MpuCalc/Properties/
trunk/Tools/Maestro/MpuCalc/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MpuCalc/packages.config
trunk/Tools/Maestro/Maestro/Maestro_All.sln
trunk/Tools/Maestro/Maestro/packages/repositories.config
trunk/Tools/Maestro/MgCooker/MgCooker.csproj
trunk/Tools/Maestro/MgCooker/SetupRun.cs
trunk/Tools/Maestro/MgCooker/SetupRun.designer.cs
trunk/Tools/Maestro/MgCooker/SetupRun.resx
trunk/Tools/Maestro/MgCooker/Strings.Designer.cs
trunk/Tools/Maestro/MgCooker/Strings.resx
#2359: Add ability to auto-calculate meters-per-unit required for the official method in MgCooker to work properly. We use the following methods depending on support:
* The output of the new MpuCalc executable
* The new CREATERUNTIMEMAP operation in 2.6
Modified: trunk/Tools/Maestro/Maestro/Maestro_All.sln
--- trunk/Tools/Maestro/Maestro/Maestro_All.sln 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/Maestro/Maestro_All.sln 2014-04-26 20:27:28 UTC (rev 8076)
@@ -158,6 +158,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.WebLayout-2.6.0", "..\ExtendedModels\WebLayout-2.6.0\OSGeo.MapGuide.ObjectModels.WebLayout-2.6.0.csproj", "{829D2A4E-7DBC-48AD-9CF9-12ACFBF943A6}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MpuCalc", "..\MpuCalc\MpuCalc.csproj", "{43B01C27-E0D2-439B-83ED-8C814ED1526A}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -352,6 +354,10 @@
{829D2A4E-7DBC-48AD-9CF9-12ACFBF943A6}.Debug|Any CPU.Build.0 = Debug|Any CPU
{829D2A4E-7DBC-48AD-9CF9-12ACFBF943A6}.Release|Any CPU.ActiveCfg = Release|Any CPU
{829D2A4E-7DBC-48AD-9CF9-12ACFBF943A6}.Release|Any CPU.Build.0 = Release|Any CPU
+ {43B01C27-E0D2-439B-83ED-8C814ED1526A}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {43B01C27-E0D2-439B-83ED-8C814ED1526A}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {43B01C27-E0D2-439B-83ED-8C814ED1526A}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {43B01C27-E0D2-439B-83ED-8C814ED1526A}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Modified: trunk/Tools/Maestro/Maestro/packages/repositories.config
--- trunk/Tools/Maestro/Maestro/packages/repositories.config 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/Maestro/packages/repositories.config 2014-04-26 20:27:28 UTC (rev 8076)
@@ -9,6 +9,7 @@
<repository path="..\..\Maestro.Shared.UI\packages.config" />
<repository path="..\..\MaestroAPITestRunner\packages.config" />
<repository path="..\..\MaestroAPITests\packages.config" />
+ <repository path="..\..\MpuCalc\packages.config" />
<repository path="..\..\OSGeo.MapGuide.MaestroAPI.Local\packages.config" />
<repository path="..\..\OSGeo.MapGuide.MaestroAPI\packages.config" />
<repository path="..\packages.config" />
Modified: trunk/Tools/Maestro/MgCooker/MgCooker.csproj
--- trunk/Tools/Maestro/MgCooker/MgCooker.csproj 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/MgCooker.csproj 2014-04-26 20:27:28 UTC (rev 8076)
@@ -142,6 +142,10 @@
<Project>{07588440-5f9f-4c30-aa06-9cf30ba6dde6}</Project>
<Name>Maestro.Login</Name>
</ProjectReference>
+ <ProjectReference Include="..\Maestro.Shared.UI\Maestro.Shared.UI.csproj">
+ <Project>{cfd19053-2172-41d3-8460-0fd2123a1e88}</Project>
+ <Name>Maestro.Shared.UI</Name>
+ </ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.ExtendedObjectModels\OSGeo.MapGuide.ExtendedObjectModels.csproj">
<Project>{b3a2b816-9f41-4857-a111-09d2df2550d6}</Project>
<Name>OSGeo.MapGuide.ExtendedObjectModels</Name>
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2014-04-26 20:27:28 UTC (rev 8076)
@@ -22,6 +22,7 @@
using System.ComponentModel;
using System.Data;
using System.Drawing;
+using System.Linq;
using System.Text;
using System.Windows.Forms;
using OSGeo.MapGuide.MaestroAPI;
@@ -31,6 +32,12 @@
using System.Collections.Specialized;
using OSGeo.MapGuide.MaestroAPI.Tile;
using OSGeo.MapGuide.ObjectModels;
+using System.IO;
+using System.Reflection;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI.Commands;
+using System.Diagnostics;
+using Maestro.Shared.UI;
namespace MgCooker
@@ -331,10 +338,11 @@
private List<Config> ReadTree()
List<Config> lst = new List<Config>();
- foreach(TreeNode mn in MapTree.Nodes)
+ foreach (TreeNode mn in MapTree.Nodes)
if (mn.Checked)
- foreach(TreeNode gn in mn.Nodes)
+ foreach (TreeNode gn in mn.Nodes)
if (gn.Checked)
List<int> ix = new List<int>();
@@ -346,6 +354,7 @@
lst.Add(new Config(mn.Text, gn.Text, ix.ToArray(), (m_coordinateOverrides.ContainsKey(mn.Text) ? m_coordinateOverrides[mn.Text] : null)));
return lst;
@@ -536,16 +545,6 @@
- private void label8_Click(object sender, EventArgs e)
- private void numericUpDown5_ValueChanged(object sender, EventArgs e)
private void LimitTileset_CheckedChanged(object sender, EventArgs e)
TilesetLimitPanel.Enabled = LimitTileset.Checked;
@@ -553,7 +552,7 @@
private void UseOfficialMethod_CheckedChanged(object sender, EventArgs e)
- OfficialMethodPanel.Enabled = UseOfficialMethod.Checked;
+ OfficialMethodPanel.Enabled = lnkCalcMpu.Enabled = UseOfficialMethod.Checked;
MapTree_AfterSelect(null, null);
@@ -638,5 +637,89 @@
if (double.TryParse(txtUpperY.Text, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.CurrentUICulture, out d))
m_coordinateOverrides[root.Text].MaxY = d;
+ private void lnkCalcMpu_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ var configs = ReadTree();
+ var mapDefs = configs.Select(x => x.MapDefinition).Distinct().ToArray();
+ if (mapDefs.Length == 0)
+ MessageBox.Show(Strings.NoMapSelected);
+ else if (mapDefs.Length == 1)
+ TryCalcMpu(mapDefs[0]);
+ else
+ MessageBox.Show(Strings.CannotCalculateMpuForMultipleMaps);
+ private void TryCalcMpu(string mapDef)
+ BusyWaitDialog.Run(Strings.CalculatingMpu, () => {
+ var currentPath = Path.GetDirectoryName(new Uri(Assembly.GetExecutingAssembly().CodeBase).LocalPath);
+ var mpuCalc = Path.Combine(currentPath, "AddIns/Local/MpuCalc.exe");
+ if (!File.Exists(mpuCalc))
+ int[] cmdTypes = m_connection.Capabilities.SupportedCommands;
+ if (Array.IndexOf(cmdTypes, (int)OSGeo.MapGuide.MaestroAPI.Commands.CommandType.CreateRuntimeMap) < 0)
+ return Strings.NoMethodToCalculateMpu;
+ else
+ ICreateRuntimeMap create = (ICreateRuntimeMap)m_connection.CreateCommand((int)OSGeo.MapGuide.MaestroAPI.Commands.CommandType.CreateRuntimeMap);
+ create.MapDefinition = mapDef;
+ create.RequestedFeatures = (int)RuntimeMapRequestedFeatures.None;
+ var info = create.Execute();
+ return Convert.ToDecimal(info.CoordinateSystem.MetersPerUnit);
+ else
+ IMapDefinition mdf = (IMapDefinition)m_connection.ResourceService.GetResource(mapDef);
+ var proc = new Process
+ StartInfo = new ProcessStartInfo
+ FileName = mpuCalc,
+ Arguments = mdf.CoordinateSystem,
+ UseShellExecute = false,
+ RedirectStandardOutput = true,
+ CreateNoWindow = true
+ proc.Start();
+ StringBuilder sb = new StringBuilder();
+ while (!proc.StandardOutput.EndOfStream)
+ string line = proc.StandardOutput.ReadLine();
+ // do something with line
+ sb.AppendLine(line);
+ string output = sb.ToString();
+ double mpu;
+ if (double.TryParse(output, out mpu))
+ return Convert.ToDecimal(mpu);
+ else
+ return string.Format(Strings.FailedToCalculateMpu, output);
+ }, (res, ex) => {
+ if (ex != null)
+ ErrorDialog.Show(ex);
+ else
+ if (res is decimal)
+ MetersPerUnit.Value = (decimal)res;
+ else
+ MessageBox.Show(res.ToString());
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.designer.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.designer.cs 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.designer.cs 2014-04-26 20:27:28 UTC (rev 8076)
@@ -74,6 +74,7 @@
this.MaxColLimit = new System.Windows.Forms.NumericUpDown();
this.label7 = new System.Windows.Forms.Label();
this.toolTip1 = new System.Windows.Forms.ToolTip(this.components);
+ this.lnkCalcMpu = new System.Windows.Forms.LinkLabel();
this.panel1.SuspendLayout();
this.panel2.SuspendLayout();
this.BoundsOverride.SuspendLayout();
@@ -331,6 +332,7 @@
// groupBox2
resources.ApplyResources(this.groupBox2, "groupBox2");
+ this.groupBox2.Controls.Add(this.lnkCalcMpu);
this.groupBox2.Controls.Add(this.OfficialMethodPanel);
this.groupBox2.Controls.Add(this.LimitTileset);
this.groupBox2.Controls.Add(this.UseOfficialMethod);
@@ -366,13 +368,11 @@
0,
0,
0});
- this.MetersPerUnit.ValueChanged += new System.EventHandler(this.numericUpDown5_ValueChanged);
// label8
resources.ApplyResources(this.label8, "label8");
this.label8.Name = "label8";
- this.label8.Click += new System.EventHandler(this.label8_Click);
// LimitTileset
@@ -421,6 +421,13 @@
resources.ApplyResources(this.label7, "label7");
this.label7.Name = "label7";
+ // lnkCalcMpu
+ resources.ApplyResources(this.lnkCalcMpu, "lnkCalcMpu");
+ this.lnkCalcMpu.Name = "lnkCalcMpu";
+ this.lnkCalcMpu.TabStop = true;
+ this.lnkCalcMpu.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkCalcMpu_LinkClicked);
// SetupRun
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -497,5 +504,6 @@
private System.Windows.Forms.Label ModfiedOverrideWarning;
private System.Windows.Forms.CheckBox chkUseDifferentConnection;
private System.Windows.Forms.TextBox Username;
+ private System.Windows.Forms.LinkLabel lnkCalcMpu;
\ No newline at end of file
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.resx
--- trunk/Tools/Maestro/MgCooker/SetupRun.resx 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.resx 2014-04-26 20:27:28 UTC (rev 8076)
@@ -117,18 +117,78 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name=">>button3.Name" xml:space="preserve">
+ <value>button3</value>
+ </data>
+ <data name=">>button3.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>button3.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>button3.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>button2.Name" xml:space="preserve">
+ <value>button2</value>
+ </data>
+ <data name=">>button2.Type" xml:space="preserve">
+ </data>
+ <data name=">>button2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>button2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>button1.Name" xml:space="preserve">
+ <value>button1</value>
+ </data>
+ <data name=">>button1.Type" xml:space="preserve">
+ </data>
+ <data name=">>button1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>button1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Bottom</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 537</value>
+ </data>
+ <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>565, 41</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="panel1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>panel1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>panel1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<data name="button3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="button3.Location" type="System.Drawing.Point, System.Drawing">
<value>227, 9</value>
</data>
<data name="button3.Size" type="System.Drawing.Size, System.Drawing">
<value>112, 23</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="button3.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
</data>
@@ -201,30 +261,6 @@
<value>2</value>
</data>
- <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- <value>Bottom</value>
- </data>
- <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 537</value>
- </data>
- <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
- <value>565, 41</value>
- </data>
- <data name="panel1.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name=">>panel1.Name" xml:space="preserve">
- <value>panel1</value>
- </data>
- <data name=">>panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>panel1.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>panel1.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
<data name="MapTree.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -239,54 +275,54 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAB6
- DAAAAk1TRnQBSQFMAgEBBAEAAWQBAAFkAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ DAAAAk1TRnQBSQFMAgEBBAEAAWwBAAFsAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
AwABIAMAAQEBAAEgBgABIP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AKgADHAEoAyQBNgMk
ATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDGwEmHAADFgEeAVsCWAHGAx0BKgMC
- AQOgAAP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wMbASYcAAGE
- Am0B9wH0AeYB4QH/AcEBuAG3Af0BigGCAYEB+QFNAkwBkQMRAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/
+ AQOgAAP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wMbASYcAAGD
+ Am0B9wH0AeYB4QH/Ab4BtwG2Af0BiQGBAYAB+QFNAkwBkQMRAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/
AfIB4gHdAf8B8QHgAdkB/wHwAd0B1gH/Ae8B2wHTAf8B7gHZAdEB/wHuAdgB0AH/Ae4B2AHQAf8B7gHY
AdAB/wP9Af8DGwEmGAABLAIrAUMB9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/
- AaIBkwGPAfoBZgJaAfABNgI1AVgDCwEPDAADHQEqAx0BKiAAAwUBBwMdASoDHQEqTAAD/QH/AfcB7QHp
- Af8B9gHqAeYB/wH0AecB4wH/Ad0BtQGwAf8BvQFoAWMB/wG+AWwBZwH/AeMBwgG8Af8B7wHaAdIB/wHu
- AdgB0AH/Ae4B2AHQAf8D/QH/AxsBJhgAAYgCeAH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
- Af8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGYAYABfQH6AVkCVwHCCwAB/ygAAzABTAMA
- Af9MAAP9Af8B+AHwAe0B/wHtAdcB0gH/AbkBiQFmAf8BVgGTASYB/wHqAbEBLgH/AegBrgElAf8B6wHB
- AVkB/wGxAVABSwH/Ae4B2QHSAf8B7gHZAdIB/wP9Af8DGwEmFAADQAFwAfUB6QHlAf8B9QHoAeMB/wH0
+ AaABkAGMAfoBZQJaAfABNgI1AVgDCwEPDAADHQEqAx0BKiAAAwUBBwMdASoDHQEqTAAD/QH/AfcB7QHp
+ Af8B9gHqAeYB/wH0AecB4wH/Ad0BtQGwAf8BvQFnAWIB/wG+AWsBZgH/AeMBwgG8Af8B7wHaAdIB/wHu
+ AdgB0AH/Ae4B2AHQAf8D/QH/AxsBJhgAAYUCdwH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
+ Af8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGVAX4BfAH6AVkCVwHCCwAB/ygAAzABTAMA
+ Af9MAAP9Af8B+AHwAe0B/wHtAdcB0gH/AbkBiQFlAf8BVQGTASUB/wHqAbEBLQH/AegBrgEkAf8B6wHB
+ AVgB/wGxAU8BSgH/Ae4B2QHSAf8B7gHZAdIB/wP9Af8DGwEmFAADQAFwAfUB6QHlAf8B9QHoAeMB/wH0
AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHdAdcB/wHvAdwB1QH/Ae8B2gHT
Af8DOAFcCwAB/wgAAUYCRQF/AwAEAQECA0UBfQQAAygBPAMlATcEAAMvAUoDAAH/DAADEQEXA1gB0QMA
- Af8DKAE8EAADOAFcAwAB/xgAA/0B/wH2AeoB5gH/AegBvwGcAf8B+wHLAVkB/wEzAa0BQAH/AUsBnQEh
- Af8B/gHEATkB/wH+Ab4BJAH/AfYBtgEaAf8BlwFpAUYB/wHwAd0B1gH/A/0B/wMbASYUAAGSAn4B+AH1
+ Af8DKAE8EAADOAFcAwAB/xgAA/0B/wH2AeoB5gH/AegBvwGcAf8B+wHLAVgB/wEyAa0BPwH/AUoBnQEg
+ Af8B/gHEATgB/wH+Ab4BIwH/AfYBtgEZAf8BlwFoAUUB/wHwAd0B1gH/A/0B/wMbASYUAAGQAn0B+AH1
AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wHxAd8B2QH/AfAB3QHX
- Af8B7wHcAdUB/wFzAmIB9gMEAQYLAAH/CwAB/wNFAX0DSAGFAwAB/wcAAf8DAAH/BAADLwFKAwAB/xAA
- A0IBdAMAAf8UAAMNAREDWgHVGAAD/QH/AbkBVgFBAf8B+gHOAWUB/wGkAbYBTQH/ATMBrQFBAf8BMgGt
- AUAB/wHJAb8BTwH/Af4BxAE4Af8B/gHAASkB/wExAaUBOAH/AbwBaAFlAf8D/QH/AxsBJhAAA1ABngH2
+ Af8B7wHcAdUB/wFxAmIB9gMEAQYLAAH/CwAB/wNFAX0DSAGFAwAB/wcAAf8DAAH/BAADLwFKAwAB/xAA
+ A0IBdAMAAf8UAAMNAREDWgHVGAAD/QH/AbkBVQFAAf8B+gHOAWQB/wGkAbYBTAH/ATIBrQFAAf8BMQGt
+ AT8B/wHJAb8BTgH/Af4BxAE3Af8B/gHAASgB/wEwAaUBNwH/AbwBZwFkAf8D/QH/AxsBJhAAA1ABngH2
AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZ
- Af8B8AHdAdcB/wG3Aa0BqQH8AygBPA8AAf8oAAMvAUoDAAH/EAADQgF0AwAB/zQAA/0B/wHqAcMBoQH/
- Af0B1gGEAf8BmwG2AVMB/wExAZ8BJgH/AfEB2AGRAf8B/QHRAWkB/wGcAbABOgH/ATMBrQFBAf8BMwGt
- AUEB/wGYAWQBQwH/A/0B/wMbASYQAAGPAYYBhQH3AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/AfQB5gHh
- Af8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHfAdkB/wHwAd0B1wH/AWYCWQHrAwEBAg8AAf8oAAMv
- AUoDAAH/EAADQgF0AwAB/xQAAwIBAwNRAaEYAAP9Af8B+gHiAbkB/wE0AZoBHQH/AtQBmwH/Af0B4wG1
- Af8B/QHdAZ0B/wH9AdQBcgH/AeQByAFXAf8BMgGsAT8B/wFJAZwBHgH/AZ4BigFUAf8D/QH/AxsBJgwA
+ Af8B8AHdAdcB/wG1AasBpgH8AygBPA8AAf8oAAMvAUoDAAH/EAADQgF0AwAB/zQAA/0B/wHqAcMBoQH/
+ Af0B1gGEAf8BmwG2AVIB/wEwAZ8BJQH/AfEB2AGRAf8B/QHRAWgB/wGcAbABOQH/ATIBrQFAAf8BMgGt
+ AUAB/wGYAWMBQgH/A/0B/wMbASYQAAGNAYUBhAH3AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/AfQB5gHh
+ Af8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHfAdkB/wHwAd0B1wH/AWQCWQHrAwEBAg8AAf8oAAMv
+ AUoDAAH/EAADQgF0AwAB/xQAAwIBAwNRAaEYAAP9Af8B+gHiAbkB/wEzAZoBHAH/AtQBmwH/Af0B4wG1
+ Af8B/QHdAZ0B/wH9AdQBcQH/AeQByAFWAf8BMQGsAT4B/wFIAZwBHQH/AZ4BigFTAf8D/QH/AxsBJgwA
AVwCWQHJAfcB7QHpAf8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
- Af8B8gHhAdsB/wHxAd8B2QH/AaQBlgGSAfoDGwEmEwAB/ygAAy8BSgMAAf8QAANCAXQDAAH/FAADPgFr
- AwAB/xgAA/0B/wFmAZABLgH/ATMBrQFBAf8BMwGtAUEB/wGvAcEBbQH/Af0B2wGVAf8B/QHTAW0B/wH+
- AcoBSwH/ATsBmgEdAf8BMQGXARgB/wGcAWYBRAH/A/0B/wMbASYIAAMEAQUBpgGcAZsB+gH3Ae0B6QH/
+ Af8B8gHhAdsB/wHxAd8B2QH/AaIBkwGPAfoDGwEmEwAB/ygAAy8BSgMAAf8QAANCAXQDAAH/FAADPgFr
+ AwAB/xgAA/0B/wFlAZABLQH/ATIBrQFAAf8BMgGtAUAB/wGvAcEBbAH/Af0B2wGVAf8B/QHTAWwB/wH+
+ AcoBSgH/AToBmgEcAf8BMAGXARcB/wGcAWUBQwH/A/0B/wMbASYIAAMEAQUBpAGaAZkB+gH3Ae0B6QH/
AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHf
- AdkB/wFdAlkB0hcAAf8oAAMvAUoDAAH/EAADQgF2AwAB/zQAA/0B/wG+AWgBSAH/ATMBrQFBAf8BMgGj
- AS8B/wEyAa0BQAH/AcABwgFgAf8B/gHOAVsB/wH+AcYBPQH/AVIBlAEPAf8BwgG6AT8B/wHFAYEBcQH/
+ AdkB/wFdAlkB0hcAAf8oAAMvAUoDAAH/EAADQgF2AwAB/zQAA/0B/wG+AWcBRwH/ATIBrQFAAf8BMQGj
+ AS4B/wExAa0BPwH/AcABwgFfAf8B/gHOAVoB/wH+AcYBPAH/AVEBlAEOAf8BwgG6AT4B/wHFAYEBcAH/
A/0B/wMbASYIAAFkAlwB5wH4Ae4B6wH/AfcB7QHpAf8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHm
- AeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wGVAYQBgQH4AxMBGhcAAf8oAAMvAUoDAAH/DAADCAEL
- A1oB3gMAAf80AAP9Af8B9wHtAekB/wFuAZABMgH/AacBtQFHAf8BMwGTAREB/wGqAbcBSQH/AUYBngEi
- Af8B8gHCAToB/wH+Ab0BHwH/AcUBcQFdAf8B+QHxAe4B/wP9Af8DGwEmBAADEgEZAacCngH6AfgB7gHr
+ AeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wGTAYEBfgH4AxMBGhcAAf8oAAMvAUoDAAH/DAADCAEL
+ A1oB3gMAAf80AAP9Af8B9wHtAekB/wFtAZABMQH/AacBtQFGAf8BMgGTARAB/wGqAbcBSAH/AUUBngEh
+ Af8B8gHCATkB/wH+Ab0BHgH/AcUBcAFcAf8B+QHxAe4B/wP9Af8DGwEmBAADEgEZAaUCnAH6AfgB7gHr
Af8B9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHy
AeEB2wH/A1QBrxgAA1cB3wFJAkgBhyAAAwsBDwNVAbcDVwHfTAAD/QH/AfkB8QHuAf8B8gHhAdsB/wGt
- AYYBTgH/Ae4B2AGLAf8BRwGeASIB/wEyAa0BQAH/ATgBlAEUAf8BuwFbAUcB/wH4AfAB7QH/AfkB8QHu
- Af8D/QH/AxsBJggAAwEBAgFSAlEBpwGOAocB+QH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/
- AfMB5AHfAf8B8gHjAd0B/wGSAX0BewH4Aw4BE5gAA/0B/wH5AfEB7gH/AfkB8QHuAf8B+QHxAe4B/wHs
+ AYYBTQH/Ae4B2AGLAf8BRgGeASEB/wExAa0BPwH/ATcBlAETAf8BuwFaAUYB/wH4AfAB7QH/AfkB8QHu
+ Af8D/QH/AxsBJggAAwEBAgFSAlEBpwGNAoYB+QH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/
+ AfMB5AHfAf8B8gHjAd0B/wGQAXwBegH4Aw4BE5gAA/0B/wH5AfEB7gH/AfkB8QHuAf8B+QHxAe4B/wHs
AdIByQH/AdIBlQGCAf8B1AGaAYkB/wHyAeEB3AH/AfkB8QHuAf8B+QHxAe4B/wH5AfEB7gH/A/0B/wMb
- ASYUAAMdASkBYQJaAeQBlgGLAYoB+QH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wFJAkgBiJwAA/0B/wH6
+ ASYUAAMdASkBYQJaAeQBkgGKAYkB+QH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wFJAkgBiJwAA/0B/wH6
AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0
- Af8B+gH2AfQB/wH6AfYB9AH/A/0B/wMbASYgAAM+AWsBigJ4AfoBiAJ3AfgDBwEKnAABpQKgAf8BpAGg
+ Af8B+gH2AfQB/wH6AfYB9AH/A/0B/wMbASYgAAM+AWsBhwJ3AfoBhQJ2AfgDBwEKnAABpQKgAf8BpAGg
AZ8B/wGkAp8B/wGjAp4B/wGiAp0B/wGhApwB/wGgApsB/wGfApoB/wGdApkB/wGcAZgBlwH/AZsClgH/
AZkClQH/yAABQgFNAT4HAAE+AwABKAMAAUADAAEgAwABAQEAAQEGAAEBFgAD/4EAAcABAQH8AT8E/wHA
AQEB/AEPBP8BwAEBAfgBAQHPAfEC/wHAAQEB+AEAAd8B+QL/AcABAQHwAQAB2AFJAcMBzwHAAQEB8AEA
@@ -328,6 +364,597 @@
<data name="BoundsOverride.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
+ <data name=">>ModfiedOverrideWarning.Name" xml:space="preserve">
+ <value>ModfiedOverrideWarning</value>
+ </data>
+ <data name=">>ModfiedOverrideWarning.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ModfiedOverrideWarning.Parent" xml:space="preserve">
+ <value>BoundsOverride</value>
+ </data>
+ <data name=">>ModfiedOverrideWarning.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>ResetBounds.Name" xml:space="preserve">
+ <value>ResetBounds</value>
+ </data>
+ <data name=">>ResetBounds.Type" xml:space="preserve">
+ </data>
+ <data name=">>ResetBounds.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ResetBounds.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>txtUpperY.Name" xml:space="preserve">
+ <value>txtUpperY</value>
+ </data>
+ <data name=">>txtUpperY.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtUpperY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtUpperY.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>label4.Name" xml:space="preserve">
+ <value>label4</value>
+ </data>
+ <data name=">>label4.Type" xml:space="preserve">
+ </data>
+ <data name=">>label4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label4.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>txtUpperX.Name" xml:space="preserve">
+ <value>txtUpperX</value>
+ </data>
+ <data name=">>txtUpperX.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtUpperX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtUpperX.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name=">>label5.Name" xml:space="preserve">
+ <value>label5</value>
+ </data>
+ <data name=">>label5.Type" xml:space="preserve">
+ </data>
+ <data name=">>label5.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label5.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name=">>txtLowerY.Name" xml:space="preserve">
+ <value>txtLowerY</value>
+ </data>
+ <data name=">>txtLowerY.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtLowerY.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtLowerY.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name=">>label10.Name" xml:space="preserve">
+ <value>label10</value>
+ </data>
+ <data name=">>label10.Type" xml:space="preserve">
+ </data>
+ <data name=">>label10.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label10.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name=">>txtLowerX.Name" xml:space="preserve">
+ <value>txtLowerX</value>
+ </data>
+ <data name=">>txtLowerX.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtLowerX.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtLowerX.ZOrder" xml:space="preserve">
+ <value>8</value>
+ </data>
+ <data name=">>label11.Name" xml:space="preserve">
+ <value>label11</value>
+ </data>
+ <data name=">>label11.Type" xml:space="preserve">
+ </data>
+ <data name=">>label11.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label11.ZOrder" xml:space="preserve">
+ <value>9</value>
+ </data>
+ <data name="BoundsOverride.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="BoundsOverride.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 424</value>
+ </data>
+ <data name="BoundsOverride.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 120</value>
+ </data>
+ <data name="BoundsOverride.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name="BoundsOverride.Text" xml:space="preserve">
+ <value>Override bounds</value>
+ </data>
+ <data name=">>BoundsOverride.Name" xml:space="preserve">
+ </data>
+ <data name=">>BoundsOverride.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>BoundsOverride.Parent" xml:space="preserve">
+ <value>panel2</value>
+ </data>
+ <data name=">>BoundsOverride.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="grpDifferentConnection.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name=">>chkUseDifferentConnection.Name" xml:space="preserve">
+ <value>chkUseDifferentConnection</value>
+ </data>
+ <data name=">>chkUseDifferentConnection.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkUseDifferentConnection.Parent" xml:space="preserve">
+ <value>grpDifferentConnection</value>
+ </data>
+ <data name=">>chkUseDifferentConnection.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>UseNativeAPI.Name" xml:space="preserve">
+ <value>UseNativeAPI</value>
+ </data>
+ <data name=">>UseNativeAPI.Type" xml:space="preserve">
+ </data>
+ <data name=">>UseNativeAPI.Parent" xml:space="preserve">
+ </data>
+ <data name=">>UseNativeAPI.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>Password.Name" xml:space="preserve">
+ <value>Password</value>
+ </data>
+ <data name=">>Password.Type" xml:space="preserve">
+ </data>
+ <data name=">>Password.Parent" xml:space="preserve">
+ </data>
+ <data name=">>Password.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>Username.Name" xml:space="preserve">
+ <value>Username</value>
+ </data>
+ <data name=">>Username.Type" xml:space="preserve">
+ </data>
+ <data name=">>Username.Parent" xml:space="preserve">
+ </data>
+ <data name=">>Username.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>MapAgent.Name" xml:space="preserve">
+ <value>MapAgent</value>
+ </data>
+ <data name=">>MapAgent.Type" xml:space="preserve">
+ </data>
+ <data name=">>MapAgent.Parent" xml:space="preserve">
+ </data>
+ <data name=">>MapAgent.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>6</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>7</value>
+ </data>
+ <data name="grpDifferentConnection.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 8</value>
+ </data>
+ <data name="grpDifferentConnection.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 128</value>
+ </data>
+ <data name="grpDifferentConnection.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name=">>grpDifferentConnection.Name" xml:space="preserve">
+ </data>
+ <data name=">>grpDifferentConnection.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpDifferentConnection.Parent" xml:space="preserve">
+ </data>
+ <data name=">>grpDifferentConnection.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name=">>RandomTileOrder.Name" xml:space="preserve">
+ <value>RandomTileOrder</value>
+ </data>
+ <data name=">>RandomTileOrder.Type" xml:space="preserve">
+ </data>
+ <data name=">>RandomTileOrder.Parent" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>RandomTileOrder.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>ThreadCount.Name" xml:space="preserve">
+ <value>ThreadCount</value>
+ </data>
+ <data name=">>ThreadCount.Type" xml:space="preserve">
+ <value>System.Windows.Forms.NumericUpDown, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>ThreadCount.Parent" xml:space="preserve">
+ </data>
+ <data name=">>ThreadCount.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>label9.Name" xml:space="preserve">
+ <value>label9</value>
+ </data>
+ <data name=">>label9.Type" xml:space="preserve">
+ </data>
+ <data name=">>label9.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label9.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 328</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 80</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Threading</value>
+ </data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="lnkCalcMpu.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="lnkCalcMpu.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="lnkCalcMpu.Location" type="System.Drawing.Point, System.Drawing">
+ <value>141, 105</value>
+ </data>
+ <data name="lnkCalcMpu.Size" type="System.Drawing.Size, System.Drawing">
+ <value>51, 13</value>
+ </data>
+ <data name="lnkCalcMpu.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name="lnkCalcMpu.Text" xml:space="preserve">
+ <value>Calculate</value>
+ </data>
+ <data name=">>lnkCalcMpu.Name" xml:space="preserve">
+ <value>lnkCalcMpu</value>
+ </data>
+ <data name=">>lnkCalcMpu.Type" xml:space="preserve">
+ <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lnkCalcMpu.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>lnkCalcMpu.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>MetersPerUnit.Name" xml:space="preserve">
+ <value>MetersPerUnit</value>
+ </data>
+ <data name=">>MetersPerUnit.Type" xml:space="preserve">
+ </data>
+ <data name=">>MetersPerUnit.Parent" xml:space="preserve">
+ <value>OfficialMethodPanel</value>
+ </data>
+ <data name=">>MetersPerUnit.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>label8.Name" xml:space="preserve">
+ <value>label8</value>
+ </data>
+ <data name=">>label8.Type" xml:space="preserve">
+ </data>
+ <data name=">>label8.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label8.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="OfficialMethodPanel.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="OfficialMethodPanel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 128</value>
+ </data>
+ <data name="OfficialMethodPanel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>216, 24</value>
+ </data>
+ <data name="OfficialMethodPanel.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name=">>OfficialMethodPanel.Name" xml:space="preserve">
+ </data>
+ <data name=">>OfficialMethodPanel.Type" xml:space="preserve">
+ </data>
+ <data name=">>OfficialMethodPanel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>OfficialMethodPanel.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="LimitTileset.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="LimitTileset.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 24</value>
+ </data>
+ <data name="LimitTileset.Size" type="System.Drawing.Size, System.Drawing">
+ <value>118, 17</value>
+ </data>
+ <data name="LimitTileset.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name="LimitTileset.Text" xml:space="preserve">
+ <value>Limit number of tiles</value>
+ </data>
+ <data name="LimitTileset.ToolTip" xml:space="preserve">
+ <value>Set a limit on the number of tiles generated, note that this may prevent all tiles from being created</value>
+ </data>
+ <data name=">>LimitTileset.Name" xml:space="preserve">
+ <value>LimitTileset</value>
+ </data>
+ <data name=">>LimitTileset.Type" xml:space="preserve">
+ </data>
+ <data name=">>LimitTileset.Parent" xml:space="preserve">
+ </data>
+ <data name=">>LimitTileset.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="UseOfficialMethod.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="UseOfficialMethod.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 104</value>
+ </data>
+ <data name="UseOfficialMethod.Size" type="System.Drawing.Size, System.Drawing">
+ <value>116, 17</value>
+ </data>
+ <data name="UseOfficialMethod.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name="UseOfficialMethod.Text" xml:space="preserve">
+ <value>Use official method</value>
+ </data>
+ <data name="UseOfficialMethod.ToolTip" xml:space="preserve">
+ <value>The official method is the most accurate, but requires that the meters per map unit is entered</value>
+ </data>
+ <data name=">>UseOfficialMethod.Name" xml:space="preserve">
+ <value>UseOfficialMethod</value>
+ </data>
+ <data name=">>UseOfficialMethod.Type" xml:space="preserve">
+ </data>
+ <data name=">>UseOfficialMethod.Parent" xml:space="preserve">
+ </data>
+ <data name=">>UseOfficialMethod.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name=">>MaxRowLimit.Name" xml:space="preserve">
+ <value>MaxRowLimit</value>
+ </data>
+ <data name=">>MaxRowLimit.Type" xml:space="preserve">
+ </data>
+ <data name=">>MaxRowLimit.Parent" xml:space="preserve">
+ <value>TilesetLimitPanel</value>
+ </data>
+ <data name=">>MaxRowLimit.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name=">>label6.Name" xml:space="preserve">
+ <value>label6</value>
+ </data>
+ <data name=">>label6.Type" xml:space="preserve">
+ </data>
+ <data name=">>label6.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label6.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name=">>MaxColLimit.Name" xml:space="preserve">
+ <value>MaxColLimit</value>
+ </data>
+ <data name=">>MaxColLimit.Type" xml:space="preserve">
+ </data>
+ <data name=">>MaxColLimit.Parent" xml:space="preserve">
+ </data>
+ <data name=">>MaxColLimit.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name=">>label7.Name" xml:space="preserve">
+ <value>label7</value>
+ </data>
+ <data name=">>label7.Type" xml:space="preserve">
+ </data>
+ <data name=">>label7.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label7.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="TilesetLimitPanel.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="TilesetLimitPanel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 48</value>
+ </data>
+ <data name="TilesetLimitPanel.Size" type="System.Drawing.Size, System.Drawing">
+ <value>216, 48</value>
+ </data>
+ <data name="TilesetLimitPanel.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name=">>TilesetLimitPanel.Name" xml:space="preserve">
+ </data>
+ <data name=">>TilesetLimitPanel.Type" xml:space="preserve">
+ </data>
+ <data name=">>TilesetLimitPanel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>TilesetLimitPanel.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 144</value>
+ </data>
+ <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>248, 168</value>
+ </data>
+ <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="groupBox2.Text" xml:space="preserve">
+ <value>Tilesettings</value>
+ </data>
+ <data name=">>groupBox2.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox2.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="panel2.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Right</value>
+ </data>
+ <data name="panel2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>293, 0</value>
+ </data>
+ <data name="panel2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>272, 537</value>
+ </data>
+ <data name="panel2.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>panel2.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel2.Type" xml:space="preserve">
+ </data>
+ <data name=">>panel2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>panel2.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="ModfiedOverrideWarning.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -562,36 +1189,6 @@
<value>9</value>
</data>
- <data name="BoundsOverride.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
- </data>
- <data name="BoundsOverride.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 424</value>
- </data>
- <data name="BoundsOverride.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 120</value>
- </data>
- <data name="BoundsOverride.TabIndex" type="System.Int32, mscorlib">
- <value>12</value>
- </data>
- <data name="BoundsOverride.Text" xml:space="preserve">
- <value>Override bounds</value>
- </data>
- <data name=">>BoundsOverride.Name" xml:space="preserve">
- <value>BoundsOverride</value>
- </data>
- <data name=">>BoundsOverride.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>BoundsOverride.Parent" xml:space="preserve">
- <value>panel2</value>
- </data>
- <data name=">>BoundsOverride.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name="grpDifferentConnection.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Left, Right</value>
- </data>
<data name="chkUseDifferentConnection.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -619,6 +1216,9 @@
<value>0</value>
</data>
+ <metadata name="toolTip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>250, 17</value>
+ </metadata>
<data name="UseNativeAPI.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -634,9 +1234,6 @@
<data name="UseNativeAPI.Text" xml:space="preserve">
<value>Connect using native API</value>
</data>
- <metadata name="toolTip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>250, 17</value>
- </metadata>
<data name="UseNativeAPI.ToolTip" xml:space="preserve">
<value>Using the Native API is potentially faster, but requires binary files, open ports and a webconfig.ini file</value>
</data>
@@ -805,30 +1402,6 @@
<value>7</value>
</data>
- <data name="grpDifferentConnection.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 8</value>
- </data>
- <data name="grpDifferentConnection.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 128</value>
- </data>
- <data name="grpDifferentConnection.TabIndex" type="System.Int32, mscorlib">
- <value>5</value>
- </data>
- <data name=">>grpDifferentConnection.Name" xml:space="preserve">
- <value>grpDifferentConnection</value>
- </data>
- <data name=">>grpDifferentConnection.Type" xml:space="preserve">
- </data>
- <data name=">>grpDifferentConnection.Parent" xml:space="preserve">
- </data>
- <data name=">>grpDifferentConnection.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- </data>
<data name="RandomTileOrder.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -910,33 +1483,6 @@
<value>2</value>
</data>
- <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 328</value>
- </data>
- <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 80</value>
- </data>
- <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
- <value>7</value>
- </data>
- <data name="groupBox3.Text" xml:space="preserve">
- <value>Threading</value>
- </data>
- <data name=">>groupBox3.Name" xml:space="preserve">
- <value>groupBox3</value>
- </data>
- <data name=">>groupBox3.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox3.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox3.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- </data>
<data name="MetersPerUnit.Location" type="System.Drawing.Point, System.Drawing">
<value>104, 0</value>
</data>
@@ -988,90 +1534,6 @@
<value>1</value>
</data>
- <data name="OfficialMethodPanel.Enabled" type="System.Boolean, mscorlib">
- </data>
- <data name="OfficialMethodPanel.Location" type="System.Drawing.Point, System.Drawing">
- <value>24, 128</value>
- </data>
- <data name="OfficialMethodPanel.Size" type="System.Drawing.Size, System.Drawing">
- <value>216, 24</value>
- </data>
- <data name="OfficialMethodPanel.TabIndex" type="System.Int32, mscorlib">
- <value>13</value>
- </data>
- <data name=">>OfficialMethodPanel.Name" xml:space="preserve">
- <value>OfficialMethodPanel</value>
- </data>
- <data name=">>OfficialMethodPanel.Type" xml:space="preserve">
- </data>
- <data name=">>OfficialMethodPanel.Parent" xml:space="preserve">
- <value>groupBox2</value>
- </data>
- <data name=">>OfficialMethodPanel.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name="LimitTileset.AutoSize" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="LimitTileset.Location" type="System.Drawing.Point, System.Drawing">
- <value>24, 24</value>
- </data>
- <data name="LimitTileset.Size" type="System.Drawing.Size, System.Drawing">
- <value>118, 17</value>
- </data>
- <data name="LimitTileset.TabIndex" type="System.Int32, mscorlib">
- <value>11</value>
- </data>
- <data name="LimitTileset.Text" xml:space="preserve">
- <value>Limit number of tiles</value>
- </data>
- <data name="LimitTileset.ToolTip" xml:space="preserve">
- <value>Set a limit on the number of tiles generated, note that this may prevent all tiles from being created</value>
- </data>
- <data name=">>LimitTileset.Name" xml:space="preserve">
- <value>LimitTileset</value>
- </data>
- <data name=">>LimitTileset.Type" xml:space="preserve">
- <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>LimitTileset.Parent" xml:space="preserve">
- </data>
- <data name=">>LimitTileset.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="UseOfficialMethod.AutoSize" type="System.Boolean, mscorlib">
- </data>
- <data name="UseOfficialMethod.Location" type="System.Drawing.Point, System.Drawing">
- <value>24, 104</value>
- </data>
- <data name="UseOfficialMethod.Size" type="System.Drawing.Size, System.Drawing">
- <value>116, 17</value>
- </data>
- <data name="UseOfficialMethod.TabIndex" type="System.Int32, mscorlib">
- <value>10</value>
- </data>
- <data name="UseOfficialMethod.Text" xml:space="preserve">
- <value>Use official method</value>
- </data>
- <data name="UseOfficialMethod.ToolTip" xml:space="preserve">
- <value>The official method is the most accurate, but requires that the meters per map unit is entered</value>
- </data>
- <data name=">>UseOfficialMethod.Name" xml:space="preserve">
- <value>UseOfficialMethod</value>
- </data>
- <data name=">>UseOfficialMethod.Type" xml:space="preserve">
- </data>
- <data name=">>UseOfficialMethod.Parent" xml:space="preserve">
- </data>
- <data name=">>UseOfficialMethod.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
<data name="MaxRowLimit.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -1174,78 +1636,9 @@
<value>3</value>
</data>
- <data name="TilesetLimitPanel.Enabled" type="System.Boolean, mscorlib">
- </data>
- <data name="TilesetLimitPanel.Location" type="System.Drawing.Point, System.Drawing">
- <value>24, 48</value>
- </data>
- <data name="TilesetLimitPanel.Size" type="System.Drawing.Size, System.Drawing">
- <value>216, 48</value>
- </data>
- <data name="TilesetLimitPanel.TabIndex" type="System.Int32, mscorlib">
- <value>12</value>
- </data>
- <data name=">>TilesetLimitPanel.Name" xml:space="preserve">
- <value>TilesetLimitPanel</value>
- </data>
- <data name=">>TilesetLimitPanel.Type" xml:space="preserve">
- </data>
- <data name=">>TilesetLimitPanel.Parent" xml:space="preserve">
- </data>
- <data name=">>TilesetLimitPanel.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 144</value>
- </data>
- <data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
- <value>248, 168</value>
- </data>
- <data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
- <value>6</value>
- </data>
- <data name="groupBox2.Text" xml:space="preserve">
- <value>Tilesettings</value>
- </data>
- <data name=">>groupBox2.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox2.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox2.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox2.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name="panel2.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
- <value>Right</value>
- </data>
- <data name="panel2.Location" type="System.Drawing.Point, System.Drawing">
- <value>293, 0</value>
- </data>
- <data name="panel2.Size" type="System.Drawing.Size, System.Drawing">
- <value>272, 537</value>
- </data>
- <data name="panel2.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name=">>panel2.Name" xml:space="preserve">
- </data>
- <data name=">>panel2.Type" xml:space="preserve">
- </data>
- <data name=">>panel2.Parent" xml:space="preserve">
- </data>
- <data name=">>panel2.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
+ </metadata>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
Modified: trunk/Tools/Maestro/MgCooker/Strings.Designer.cs
--- trunk/Tools/Maestro/MgCooker/Strings.Designer.cs 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/Strings.Designer.cs 2014-04-26 20:27:28 UTC (rev 8076)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.18047
+// Runtime Version:4.0.30319.18444
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -71,6 +71,24 @@
/// <summary>
+ /// Looks up a localized string similar to Calculating meters-per-unit.
+ /// </summary>
+ internal static string CalculatingMpu {
+ get {
+ return ResourceManager.GetString("CalculatingMpu", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Cannot calculate meters-per-unit when multiple maps are selected.
+ /// </summary>
+ internal static string CannotCalculateMpuForMultipleMaps {
+ get {
+ return ResourceManager.GetString("CannotCalculateMpuForMultipleMaps", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Unable to connect: {0}.
/// </summary>
internal static string ConnectionError {
@@ -233,6 +251,15 @@
/// <summary>
+ /// Looks up a localized string similar to Failed to calculate MPU. Output was: {0}.
+ /// </summary>
+ internal static string FailedToCalculateMpu {
+ get {
+ return ResourceManager.GetString("FailedToCalculateMpu", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to All files ({0}).
/// </summary>
internal static string FileTypeAllFiles {
@@ -279,6 +306,24 @@
/// <summary>
+ /// Looks up a localized string similar to No Map Definition selected.
+ /// </summary>
+ internal static string NoMapSelected {
+ get {
+ return ResourceManager.GetString("NoMapSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not determine any method to calculate meters per unit.
+ /// </summary>
+ internal static string NoMethodToCalculateMpu {
+ get {
+ return ResourceManager.GetString("NoMethodToCalculateMpu", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to MgCooker is now paused, click OK to resume rendering.
/// </summary>
internal static string PauseMessage {
Modified: trunk/Tools/Maestro/MgCooker/Strings.resx
--- trunk/Tools/Maestro/MgCooker/Strings.resx 2014-04-26 18:58:29 UTC (rev 8075)
+++ trunk/Tools/Maestro/MgCooker/Strings.resx 2014-04-26 20:27:28 UTC (rev 8076)
@@ -122,6 +122,12 @@
Please be patient.</value>
<comment>A message that is displayed when the user clicks quit more than once</comment>
</data>
+ <data name="CalculatingMpu" xml:space="preserve">
+ <value>Calculating meters-per-unit</value>
+ </data>
+ <data name="CannotCalculateMpuForMultipleMaps" xml:space="preserve">
+ <value>Cannot calculate meters-per-unit when multiple maps are selected</value>
+ </data>
<data name="ConnectionError" xml:space="preserve">
<value>Unable to connect: {0}</value>
<comment>An error message that is displayed, when the initial connection fails</comment>
@@ -194,6 +200,9 @@
<value>Tile {0:###,###,###,###} of {1:###,###,###,###} {2}</value>
<comment>Label that displays the current tile and the total number of tiles and number of failed tiles, eg: tile 1 of 100 (5 failed tiles)</comment>
</data>
+ <data name="FailedToCalculateMpu" xml:space="preserve">
+ <value>Failed to calculate MPU. Output was: {0}</value>
+ </data>
<data name="FileTypeAllFiles" xml:space="preserve">
<value>All files ({0})</value>
<comment>The name displayed for the *.* filetype when the user is prompted to save a file</comment>
@@ -215,6 +224,12 @@
Either copy in the file, or do not use the Native connection method</value>
<comment>A message displayed when the webconfig.ini file is missing</comment>
</data>
+ <data name="NoMapSelected" xml:space="preserve">
+ <value>No Map Definition selected</value>
+ </data>
+ <data name="NoMethodToCalculateMpu" xml:space="preserve">
+ <value>Could not determine any method to calculate meters per unit</value>
+ </data>
<data name="PauseMessage" xml:space="preserve">
<value>MgCooker is now paused, click OK to resume rendering</value>
<comment>A text message displayed when MgCooker is paused</comment>
Property changes on: trunk/Tools/Maestro/MpuCalc
___________________________________________________________________
Added: svn:ignore
+ bin
obj
*.user
Added: trunk/Tools/Maestro/MpuCalc/App.config
--- trunk/Tools/Maestro/MpuCalc/App.config (rev 0)
+++ trunk/Tools/Maestro/MpuCalc/App.config 2014-04-26 20:27:28 UTC (rev 8076)
@@ -0,0 +1,6 @@
+<?xml version="1.0"?>
+<configuration>
+ <startup>
+ <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0,Profile=Client"/>
+ </startup>
+</configuration>
Added: trunk/Tools/Maestro/MpuCalc/MpuCalc.csproj
--- trunk/Tools/Maestro/MpuCalc/MpuCalc.csproj (rev 0)
+++ trunk/Tools/Maestro/MpuCalc/MpuCalc.csproj 2014-04-26 20:27:28 UTC (rev 8076)
@@ -0,0 +1,85 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProjectGuid>{43B01C27-E0D2-439B-83ED-8C814ED1526A}</ProjectGuid>
+ <OutputType>Exe</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>MpuCalc</RootNamespace>
+ <AssemblyName>MpuCalc</AssemblyName>
+ <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ <SolutionDir Condition="$(SolutionDir) == '' Or $(SolutionDir) == '*Undefined*'">..\Maestro\</SolutionDir>
+ <RestorePackages>true</RestorePackages>
+ <TargetFrameworkProfile>Client</TargetFrameworkProfile>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <PlatformTarget>x86</PlatformTarget>
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>..\out\Debug\AddIns\Local\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>..\out\Release\AddIns\Local\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="OSGeo.MapGuide.Foundation, Version=2.5.2.7949, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Maestro\packages\mapguide-api-base-x86.2.5.2.7949\lib\net40\OSGeo.MapGuide.Foundation.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Geometry, Version=2.5.2.7949, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <HintPath>..\Maestro\packages\mapguide-api-base-x86.2.5.2.7949\lib\net40\OSGeo.MapGuide.Geometry.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.PlatformBase, Version=2.5.2.7949, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <HintPath>..\Maestro\packages\mapguide-api-base-x86.2.5.2.7949\lib\net40\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+ </Reference>
+ <Reference Include="System" />
+ <Reference Include="System.Core" />
+ <Reference Include="System.Xml.Linq" />
+ <Reference Include="System.Data.DataSetExtensions" />
+ <Reference Include="Microsoft.CSharp" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="Program.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="App.config" />
+ <None Include="packages.config" />
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <Import Project="$(SolutionDir)\.nuget\NuGet.targets" Condition="Exists('$(SolutionDir)\.nuget\NuGet.targets')" />
+ <Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild">
+ <PropertyGroup>
+ <ErrorText>This project references NuGet package(s) that are missing on this computer. Enable NuGet Package Restore to download them. For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText>
+ </PropertyGroup>
+ <Error Condition="!Exists('$(SolutionDir)\.nuget\NuGet.targets')" Text="$([System.String]::Format('$(ErrorText)', '$(SolutionDir)\.nuget\NuGet.targets'))" />
+ </Target>
+ <PropertyGroup>
+ <PostBuildEvent>
+xcopy /s /y "$(SolutionDir)packages\mapguide-api-base-x86.2.5.2.7949\mapguide-api-base\*.*" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
Added: trunk/Tools/Maestro/MpuCalc/Program.cs
--- trunk/Tools/Maestro/MpuCalc/Program.cs (rev 0)
+++ trunk/Tools/Maestro/MpuCalc/Program.cs 2014-04-26 20:27:28 UTC (rev 8076)
@@ -0,0 +1,77 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using OSGeo.MapGuide;
+using System;
+using System.Collections.Generic;
+using System.IO;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+namespace MpuCalc
+ class Program
+ static void Main(string[] args)
+ if (args.Length == 1)
+ if (string.IsNullOrEmpty(Environment.GetEnvironmentVariable("MENTOR_DICTIONARY_PATH")))
+ var currentDir = Path.GetDirectoryName(new Uri(Assembly.GetExecutingAssembly().CodeBase).LocalPath);
+ var dictionaryDir = Path.Combine(currentDir, "Dictionaries");
+ if (Directory.Exists(dictionaryDir))
+ Environment.SetEnvironmentVariable("MENTOR_DICTIONARY_PATH", dictionaryDir, EnvironmentVariableTarget.Process);
+ else
+ Console.WriteLine("Error: Could not find CS-Map dictionary path");
+ MgCoordinateSystemFactory csFact = null;
+ MgCoordinateSystem cs = null;
+ try
+ csFact = new MgCoordinateSystemFactory();
+ cs = csFact.Create(args[0]);
+ double mpu = cs.ConvertCoordinateSystemUnitsToMeters(1.0);
+ Console.WriteLine(mpu);
+ cs.Dispose();
+ csFact.Dispose();
+ catch (MgException ex)
+ Console.WriteLine(ex.Message);
+ ex.Dispose();
+ finally
+ if (cs != null)
+ cs.Dispose();
+ if (csFact != null)
+ csFact.Dispose();
+ else
+ Console.WriteLine("Error: Insufficient arguments. Usage: MpuCalc.exe [Coord sys WKT]");
Property changes on: trunk/Tools/Maestro/MpuCalc/Properties
Added: bugtraq:number
+ true
Added: trunk/Tools/Maestro/MpuCalc/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MpuCalc/Properties/AssemblyInfo.cs (rev 0)
+++ trunk/Tools/Maestro/MpuCalc/Properties/AssemblyInfo.cs 2014-04-26 20:27:28 UTC (rev 8076)
@@ -0,0 +1,36 @@
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("MpuCalc")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("MpuCalc")]
+[assembly: AssemblyCopyright("Copyright © 2014")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("0becf425-6ac4-454e-a961-906568941d7d")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/Tools/Maestro/MpuCalc/packages.config
--- trunk/Tools/Maestro/MpuCalc/packages.config (rev 0)
+++ trunk/Tools/Maestro/MpuCalc/packages.config 2014-04-26 20:27:28 UTC (rev 8076)
@@ -0,0 +1,4 @@
+<packages>
+ <package id="mapguide-api-base-x86" version="2.5.2.7949" targetFramework="net45" />
+</packages>
More information about the mapguide-commits
