[mapguide-commits] r8080 - trunk/MgDev/Common/PlatformBase/Services
svn_mapguide at osgeo.org
Sun Apr 27 09:50:50 PDT 2014
Author: jng
Date: 2014-04-27 09:50:50 -0700 (Sun, 27 Apr 2014)
New Revision: 8080
trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
#2431: Promote MgResourceType::WatermarkDefinition to PUBLISHED_API, ensuring it is exposed in the wrappers for .net/PHP/Java
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h
--- trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2014-04-27 16:25:23 UTC (rev 8079)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceDefs.h 2014-04-27 16:50:50 UTC (rev 8080)
@@ -264,6 +264,17 @@
static const STRING ApplicationDefinition; ///\if INTERNAL value("ApplicationDefinition") \endif
+ /// \brief
+ /// This resource is a watermark definition.
+ /// \remarks
+ /// It represents the watermark rendered in a map.
+ /// \see \ref WatermarkDefinition_schema "WatermarkDefinition schema"
+ static const STRING WatermarkDefinition; ///\if INTERNAL value("WatermarkDefinition") \endif
INTERNAL_API:
@@ -282,18 +293,7 @@
static const STRING PrintLayoutElementDefinition; ///\if INTERNAL value("PrintLayoutElementDefinition") \endif
- /// \brief
- /// This resource is a watermark definition.
- /// \remarks
- /// It represents the watermark rendered in a map.
- /// \see \ref WatermarkDefinition_schema "WatermarkDefinition schema"
- static const STRING WatermarkDefinition; ///\if INTERNAL value("WatermarkDefinition") \endif
INTERNAL_API:
static const STRING User; /// User definition
static const STRING Group; /// Group definition
More information about the mapguide-commits
