[mapguide-commits] r8084 - in trunk/Tools/Vagrant: centos/x64 centos/x86 scripts sources sources/patches sources/patches/fdo sources/patches/fdo/Thirdparty sources/patches/fdo/Thirdparty/boost sources/patches/fdo/Thirdparty/boost/boost sources/patches/mapguide sources/patches/mapguide/Oem sources/patches/mapguide/Oem/CsMap sources/patches/mapguide/Oem/CsMap/Include sources/patches/mapguide/Oem/CsMap/Source support ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Tue Apr 29 04:14:57 PDT 2014
Author: jng
Date: 2014-04-29 04:14:57 -0700 (Tue, 29 Apr 2014)
New Revision: 8084
Added:
trunk/Tools/Vagrant/sources/atomic.h
trunk/Tools/Vagrant/sources/patches/
trunk/Tools/Vagrant/sources/patches/fdo/
trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/
trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/
trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost/
trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost/cstdint.hpp
trunk/Tools/Vagrant/sources/patches/mapguide/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include/cs_Geocon.h
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/CSdata.c
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/Library.mak
trunk/Tools/Vagrant/sources/patches/patchinfo.txt
trunk/Tools/Vagrant/centos/x64/Vagrantfile
trunk/Tools/Vagrant/centos/x86/Vagrantfile
trunk/Tools/Vagrant/scripts/build_fdo.sh
trunk/Tools/Vagrant/support/apt_list.txt
trunk/Tools/Vagrant/support/vagrant_base_box_prep.sh
trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
Vagrant configuration updates:
- Set up FDO to build against system MySQL/PostgreSQL libs on Ubuntu
- Check in atomic.h required for Ubuntu 14.04 as the liboss4-salsa-dev package (which contains this header) no longer exists
- Check in pending FDO/CS-Map patches needed for compilation, but have not landed upstream.
Modified: trunk/Tools/Vagrant/centos/x64/Vagrantfile
--- trunk/Tools/Vagrant/centos/x64/Vagrantfile 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/centos/x64/Vagrantfile 2014-04-29 11:14:57 UTC (rev 8084)
@@ -139,6 +139,7 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
+MG_UNIT_TEST=0
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo
FDO_SRC=$FDO_SRC_ROOT/trunk
@@ -170,6 +171,7 @@
sed -i 's/FDO_PLATFORM=32/FDO_PLATFORM=64/g' build_fdo.sh
sed -i 's/FDO_CPU=x86/FDO_CPU=x64/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=i386/FDO_BUILD_CPU=amd64/g' build_fdo.sh
+sed -i 's/LIB_DIRNAME=lib/LIB_DIRNAME=lib64/g' build_fdo.sh
if [ $HAVE_FDO_LIBS -eq 0 ];
then
echo [provision]: Extracting FDO thirdparty libs
@@ -195,6 +197,16 @@
BUILD_COMPONENT="svn update MapGuide"
svn update $MG_SRC
check_build
+if [ -d /mapguide_sources/patches/fdo ];
+then
+ echo [provision]: Applying FDO source patches
+ cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+fi
+if [ -d /mapguide_sources/patches/mapguide ];
+then
+ echo [provision]: Applying MapGuide source patches
+ cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
+fi
cd ~/scripts
BUILD_COMPONENT="FDO"
sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
@@ -202,9 +214,12 @@
BUILD_COMPONENT="MapGuide"
sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
check_build
-echo [provision]: Unit test MapGuide
-cd $SCRIPT_ROOT/mgdev
-sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+if [ $MG_UNIT_TEST -eq 1 ];
+then
+ echo [provision]: Unit test MapGuide
+ cd $SCRIPT_ROOT/mgdev
+ sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+fi
cd $SCRIPT_ROOT
sudo mkdir -p /vagrant/build
sudo mv -f ~/*.log /vagrant/build
Modified: trunk/Tools/Vagrant/centos/x86/Vagrantfile
--- trunk/Tools/Vagrant/centos/x86/Vagrantfile 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/centos/x86/Vagrantfile 2014-04-29 11:14:57 UTC (rev 8084)
@@ -171,6 +171,7 @@
sed -i 's/FDO_PLATFORM=64/FDO_PLATFORM=32/g' build_fdo.sh
sed -i 's/FDO_CPU=x64/FDO_CPU=x86/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=amd64/FDO_BUILD_CPU=i386/g' build_fdo.sh
+sed -i 's/LIB_DIRNAME=lib64/LIB_DIRNAME=lib/g' build_fdo.sh
then
@@ -196,6 +197,16 @@
svn update $MG_SRC
check_build
+then
+fi
+then
+fi
cd ~/scripts
Modified: trunk/Tools/Vagrant/scripts/build_fdo.sh
--- trunk/Tools/Vagrant/scripts/build_fdo.sh 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/scripts/build_fdo.sh 2014-04-29 11:14:57 UTC (rev 8084)
@@ -18,6 +18,7 @@
FDO_CPU=x86
FDO_PLATFORM=32
FDO_BUILD_CPU=i386
+LIB_DIRNAME=lib
# FDO install directory
FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
@@ -97,12 +98,76 @@
FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
FDO_FILELIST=${FDO_BUILD_AREA}/install/filelist
+shim_thirdparty_lib_paths()
+ echo "[info]: Shimming include/lib paths"
+ # Note:
+ # FDO assumes you're going to be linking against an SDK whose directory structure
+ # is different from how system dev libraries are installed on Ubuntu, so we leverage the
+ # power of symlinks to set up the expected directory structure that points to the system
+ # headers and libraries, and modify setenvironment.sh to point to this shimmed directory
+ # structure
+ # This structure assumes you've apt-get installed the following:
+ # libmysqlclient-dev libpq-dev
+ mkdir -p ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU
+ # PostgreSQL include path
+ if [ ! -d ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include ];
+ then
+ ln -s /usr/include/postgresql ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include
+ echo "[info]: Symlinked PostgreSQL include path"
+ else
+ echo "[info]: PostgreSQL include path already symlinked"
+ fi
+ # PostgreSQL lib path
+ if [ ! -d ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME ];
+ then
+ ln -s /usr/lib ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME
+ echo "[info]: Symlinked PostgreSQL lib path"
+ else
+ echo "[info]: PostgreSQL lib path already symlinked"
+ fi
+ mkdir -p ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU
+ # MySQL include path
+ if [ ! -d ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include ];
+ then
+ ln -s /usr/include/mysql ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include
+ echo "[info]: Symlinked MySQL include path"
+ else
+ echo "[info]: MySQL include path already symlinked"
+ fi
+ # MySQL lib path
+ if [ ! -d ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME ];
+ then
+ if [ ${FDO_PLATFORM} -eq 32 ];
+ then
+ ln -s /usr/lib/i386-linux-gnu ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ echo "[info]: Symlinked MySQL lib path (x86)"
+ else
+ ln -s /usr/lib/x86_64-linux-gnu ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ echo "[info]: Symlinked MySQL lib path (x64)"
+ fi
+ else
+ echo "[info]: MySQL lib path already symlinked"
+ fi
modify_sdk_paths()
- echo "[info]: Updating setenvironment.sh"
- # Note: Change your paths here if they're different
- sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
- sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ if [ ${UBUNTU} -eq 1 ];
+ then
+ echo "[info]: Updating setenvironment.sh"
+ sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/pgsql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ else
+ # Note: Change your paths here if they're different
+ sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ fi
echo "export FDOORACLE=/home/vagrant/fdo_rdbms_thirdparty/oracle/${FDO_CPU}/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
@@ -125,6 +190,11 @@
start_time=`date +%s`
REVISION=`svn info ${FDO_SRC} | perl revnum.pl`
+if [ ${UBUNTU} -eq 1 ];
+then
+ shim_thirdparty_lib_paths
+fi
if [ -d ${FDO_INST} ];
then
echo "[info]: Deleting directory ${FDO_INST} before build"
Added: trunk/Tools/Vagrant/sources/atomic.h
--- trunk/Tools/Vagrant/sources/atomic.h (rev 0)
+++ trunk/Tools/Vagrant/sources/atomic.h 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,127 @@
+#ifndef _ATOMIC_H
+#define _ATOMIC_H
+ * Atomic type.
+typedef struct {
+ volatile int counter;
+} atomic_t;
+#define ATOMIC_INIT(i) { (i) }
+ * Read atomic variable
+ * @param v pointer of type atomic_t
+ * Atomically reads the value of @v.
+#define atomic_read(v) ((v)->counter)
+ * Set atomic variable
+ * @param i required value
+#define atomic_set(v,i) (((v)->counter) = (i))
+ * Add to the atomic variable
+ * @param i integer value to add
+static inline void atomic_add( int i, atomic_t *v )
+ (void)__sync_add_and_fetch(&v->counter, i);
+ * Subtract the atomic variable
+ * @param i integer value to subtract
+ * Atomically subtracts @i from @v.
+static inline void atomic_sub( int i, atomic_t *v )
+ (void)__sync_sub_and_fetch(&v->counter, i);
+ * Subtract value from variable and test result
+ * Atomically subtracts @i from @v and returns
+ * true if the result is zero, or false for all
+ * other cases.
+static inline int atomic_sub_and_test( int i, atomic_t *v )
+ return !(__sync_sub_and_fetch(&v->counter, i));
+ * Increment atomic variable
+ * Atomically increments @v by 1.
+static inline void atomic_inc( atomic_t *v )
+ (void)__sync_fetch_and_add(&v->counter, 1);
+ * @brief decrement atomic variable
+ * @param v: pointer of type atomic_t
+ * Atomically decrements @v by 1. Note that the guaranteed
+ * useful range of an atomic_t is only 24 bits.
+static inline void atomic_dec( atomic_t *v )
+ (void)__sync_fetch_and_sub(&v->counter, 1);
+ * @brief Decrement and test
+ * Atomically decrements @v by 1 and
+ * returns true if the result is 0, or false for all other
+ * cases.
+static inline int atomic_dec_and_test( atomic_t *v )
+ return !(__sync_sub_and_fetch(&v->counter, 1));
+ * @brief Increment and test
+ * and returns true if the result is zero, or false for all
+ * other cases.
+static inline int atomic_inc_and_test( atomic_t *v )
+ return !(__sync_add_and_fetch(&v->counter, 1));
+ * @brief add and test if negative
+ * Atomically adds @i to @v and returns true
+ * if the result is negative, or false when
+ * result is greater than or equal to zero.
+static inline int atomic_add_negative( int i, atomic_t *v )
+ return (__sync_add_and_fetch(&v->counter, i) < 0);
+#endif
Property changes on: trunk/Tools/Vagrant/sources/patches
___________________________________________________________________
Added: bugtraq:number
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/fdo
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost
+ true
Added: trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost/cstdint.hpp
--- trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost/cstdint.hpp (rev 0)
+++ trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/boost/cstdint.hpp 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,511 @@
+// boost cstdint.hpp header file ------------------------------------------//
+// (C) Copyright Beman Dawes 1999.
+// (C) Copyright Jens Mauer 2001
+// (C) Copyright John Maddock 2001
+// Distributed under the Boost
+// Software License, Version 1.0. (See accompanying file
+// LICENSE_1_0.txt or copy at http://www.boost.org/LICENSE_1_0.txt)
+// See http://www.boost.org/libs/integer for documentation.
+// Revision History
+// 31 Oct 01 use BOOST_HAS_LONG_LONG to check for "long long" (Jens M.)
+// 16 Apr 01 check LONGLONG_MAX when looking for "long long" (Jens Maurer)
+// 23 Jan 01 prefer "long" over "int" for int32_t and intmax_t (Jens Maurer)
+// 12 Nov 00 Merged <boost/stdint.h> (Jens Maurer)
+// 23 Sep 00 Added INTXX_C macro support (John Maddock).
+// 22 Sep 00 Better 64-bit support (John Maddock)
+// 29 Jun 00 Reimplement to avoid including stdint.h within namespace boost
+// 8 Aug 99 Initial version (Beman Dawes)
+#ifndef BOOST_CSTDINT_HPP
+#define BOOST_CSTDINT_HPP
+// Since we always define the INT#_C macros as per C++0x,
+// define __STDC_CONSTANT_MACROS so that <stdint.h> does the right
+// thing if possible, and so that the user knows that the macros
+// are actually defined as per C99.
+#ifndef __STDC_CONSTANT_MACROS
+# define __STDC_CONSTANT_MACROS
+#endif
+#include <boost/config.hpp>
+// Note that GLIBC is a bit inconsistent about whether int64_t is defined or not
+// depending upon what headers happen to have been included first...
+// so we disable use of stdint.h when GLIBC does not define __GLIBC_HAVE_LONG_LONG.
+// See https://svn.boost.org/trac/boost/ticket/3548 and http://sources.redhat.com/bugzilla/show_bug.cgi?id=10990
+#if defined(BOOST_HAS_STDINT_H) \
+ && (!defined(__GLIBC__) \
+ || defined(__GLIBC_HAVE_LONG_LONG) \
+ || (defined(__GLIBC__) && ((__GLIBC__ > 2) || ((__GLIBC__ == 2) && (__GLIBC_MINOR__ >= 17)))))
+// The following #include is an implementation artifact; not part of interface.
+# ifdef __hpux
+// HP-UX has a vaguely nice <stdint.h> in a non-standard location
+# include <inttypes.h>
+# ifdef __STDC_32_MODE__
+ // this is triggered with GCC, because it defines __cplusplus < 199707L
+# define BOOST_NO_INT64_T
+# endif
+# elif defined(__FreeBSD__) || defined(__IBMCPP__) || defined(_AIX)
+# else
+# include <stdint.h>
+// There is a bug in Cygwin two _C macros
+# if defined(__STDC_CONSTANT_MACROS) && defined(__CYGWIN__)
+# undef INTMAX_C
+# undef UINTMAX_C
+# define INTMAX_C(c) c##LL
+# define UINTMAX_C(c) c##ULL
+# endif
+# endif
+#ifdef __QNX__
+// QNX (Dinkumware stdlib) defines these as non-standard names.
+// Reflect to the standard names.
+typedef ::intleast8_t int_least8_t;
+typedef ::intfast8_t int_fast8_t;
+typedef ::uintleast8_t uint_least8_t;
+typedef ::uintfast8_t uint_fast8_t;
+typedef ::intleast16_t int_least16_t;
+typedef ::intfast16_t int_fast16_t;
+typedef ::uintleast16_t uint_least16_t;
+typedef ::uintfast16_t uint_fast16_t;
+typedef ::intleast32_t int_least32_t;
+typedef ::intfast32_t int_fast32_t;
+typedef ::uintleast32_t uint_least32_t;
+typedef ::uintfast32_t uint_fast32_t;
+# ifndef BOOST_NO_INT64_T
+typedef ::intleast64_t int_least64_t;
+typedef ::intfast64_t int_fast64_t;
+typedef ::uintleast64_t uint_least64_t;
+typedef ::uintfast64_t uint_fast64_t;
+# endif
+#endif
+namespace boost
+ using ::int8_t;
+ using ::int_least8_t;
+ using ::int_fast8_t;
+ using ::uint8_t;
+ using ::uint_least8_t;
+ using ::uint_fast8_t;
+ using ::int16_t;
+ using ::int_least16_t;
+ using ::int_fast16_t;
+ using ::uint16_t;
+ using ::uint_least16_t;
+ using ::uint_fast16_t;
+ using ::int32_t;
+ using ::int_least32_t;
+ using ::int_fast32_t;
+ using ::uint32_t;
+ using ::uint_least32_t;
+ using ::uint_fast32_t;
+ using ::int64_t;
+ using ::int_least64_t;
+ using ::int_fast64_t;
+ using ::uint64_t;
+ using ::uint_least64_t;
+ using ::uint_fast64_t;
+# endif
+ using ::intmax_t;
+ using ::uintmax_t;
+} // namespace boost
+#elif defined(__FreeBSD__) && (__FreeBSD__ <= 4) || defined(__osf__) || defined(__VMS)
+// FreeBSD and Tru64 have an <inttypes.h> that contains much of what we need.
+namespace boost {
+ using ::int8_t;
+ typedef int8_t int_least8_t;
+ typedef int8_t int_fast8_t;
+ using ::uint8_t;
+ typedef uint8_t uint_least8_t;
+ typedef uint8_t uint_fast8_t;
+ using ::int16_t;
+ typedef int16_t int_least16_t;
+ typedef int16_t int_fast16_t;
+ using ::uint16_t;
+ typedef uint16_t uint_least16_t;
+ typedef uint16_t uint_fast16_t;
+ using ::int32_t;
+ typedef int32_t int_least32_t;
+ typedef int32_t int_fast32_t;
+ using ::uint32_t;
+ typedef uint32_t uint_least32_t;
+ typedef uint32_t uint_fast32_t;
+ using ::int64_t;
+ typedef int64_t int_least64_t;
+ typedef int64_t int_fast64_t;
+ using ::uint64_t;
+ typedef uint64_t uint_least64_t;
+ typedef uint64_t uint_fast64_t;
+ typedef int64_t intmax_t;
+ typedef uint64_t uintmax_t;
+# else
+ typedef int32_t intmax_t;
+ typedef uint32_t uintmax_t;
+# endif
+#else // BOOST_HAS_STDINT_H
+# include <boost/limits.hpp> // implementation artifact; not part of interface
+# include <limits.h> // needed for limits macros
+namespace boost
+// These are fairly safe guesses for some 16-bit, and most 32-bit and 64-bit
+// platforms. For other systems, they will have to be hand tailored.
+// Because the fast types are assumed to be the same as the undecorated types,
+// it may be possible to hand tailor a more efficient implementation. Such
+// an optimization may be illusionary; on the Intel x86-family 386 on, for
+// example, byte arithmetic and load/stores are as fast as "int" sized ones.
+// 8-bit types ------------------------------------------------------------//
+# if UCHAR_MAX == 0xff
+ typedef signed char int8_t;
+ typedef signed char int_least8_t;
+ typedef signed char int_fast8_t;
+ typedef unsigned char uint8_t;
+ typedef unsigned char uint_least8_t;
+ typedef unsigned char uint_fast8_t;
+# else
+# error defaults not correct; you must hand modify boost/cstdint.hpp
+# endif
+// 16-bit types -----------------------------------------------------------//
+# if USHRT_MAX == 0xffff
+# if defined(__crayx1)
+ // The Cray X1 has a 16-bit short, however it is not recommend
+ // for use in performance critical code.
+ typedef short int16_t;
+ typedef short int_least16_t;
+ typedef int int_fast16_t;
+ typedef unsigned short uint16_t;
+ typedef unsigned short uint_least16_t;
+ typedef unsigned int uint_fast16_t;
+# else
+ typedef short int_fast16_t;
+ typedef unsigned short uint_fast16_t;
+# endif
+# elif (USHRT_MAX == 0xffffffff) && defined(__MTA__)
+ // On MTA / XMT short is 32 bits unless the -short16 compiler flag is specified
+ // MTA / XMT does support the following non-standard integer types
+ typedef __short16 int16_t;
+ typedef __short16 int_least16_t;
+ typedef __short16 int_fast16_t;
+ typedef unsigned __short16 uint16_t;
+ typedef unsigned __short16 uint_least16_t;
+ typedef unsigned __short16 uint_fast16_t;
+# elif (USHRT_MAX == 0xffffffff) && defined(CRAY)
+ // no 16-bit types on Cray:
+# else
+# endif
+// 32-bit types -----------------------------------------------------------//
+# if UINT_MAX == 0xffffffff
+ typedef int int32_t;
+ typedef int int_least32_t;
+ typedef int int_fast32_t;
+ typedef unsigned int uint32_t;
+ typedef unsigned int uint_least32_t;
+ typedef unsigned int uint_fast32_t;
+ typedef short int32_t;
+ typedef short int_least32_t;
+ typedef short int_fast32_t;
+ typedef unsigned short uint32_t;
+ typedef unsigned short uint_least32_t;
+ typedef unsigned short uint_fast32_t;
+# elif ULONG_MAX == 0xffffffff
+ typedef long int32_t;
+ typedef long int_least32_t;
+ typedef long int_fast32_t;
+ typedef unsigned long uint32_t;
+ typedef unsigned long uint_least32_t;
+ typedef unsigned long uint_fast32_t;
+# elif (UINT_MAX == 0xffffffffffffffff) && defined(__MTA__)
+ // Integers are 64 bits on the MTA / XMT
+ typedef __int32 int32_t;
+ typedef __int32 int_least32_t;
+ typedef __int32 int_fast32_t;
+ typedef unsigned __int32 uint32_t;
+ typedef unsigned __int32 uint_least32_t;
+ typedef unsigned __int32 uint_fast32_t;
+# else
+# endif
+// 64-bit types + intmax_t and uintmax_t ----------------------------------//
+# if defined(BOOST_HAS_LONG_LONG) && \
+ !defined(BOOST_MSVC) && !defined(__BORLANDC__) && \
+ (!defined(__GLIBCPP__) || defined(_GLIBCPP_USE_LONG_LONG)) && \
+ (defined(ULLONG_MAX) || defined(ULONG_LONG_MAX) || defined(ULONGLONG_MAX))
+# if defined(__hpux)
+ // HP-UX's value of ULONG_LONG_MAX is unusable in preprocessor expressions
+# elif (defined(ULLONG_MAX) && ULLONG_MAX == 18446744073709551615ULL) || (defined(ULONG_LONG_MAX) && ULONG_LONG_MAX == 18446744073709551615ULL) || (defined(ULONGLONG_MAX) && ULONGLONG_MAX == 18446744073709551615ULL)
+ // 2**64 - 1
+# else
+# endif
+ typedef ::boost::long_long_type intmax_t;
+ typedef ::boost::ulong_long_type uintmax_t;
+ typedef ::boost::long_long_type int64_t;
+ typedef ::boost::long_long_type int_least64_t;
+ typedef ::boost::long_long_type int_fast64_t;
+ typedef ::boost::ulong_long_type uint64_t;
+ typedef ::boost::ulong_long_type uint_least64_t;
+ typedef ::boost::ulong_long_type uint_fast64_t;
+# elif ULONG_MAX != 0xffffffff
+# if ULONG_MAX == 18446744073709551615 // 2**64 - 1
+ typedef long intmax_t;
+ typedef unsigned long uintmax_t;
+ typedef long int64_t;
+ typedef long int_least64_t;
+ typedef long int_fast64_t;
+ typedef unsigned long uint64_t;
+ typedef unsigned long uint_least64_t;
+ typedef unsigned long uint_fast64_t;
+# else
+# endif
+# elif defined(__GNUC__) && defined(BOOST_HAS_LONG_LONG)
+ __extension__ typedef long long intmax_t;
+ __extension__ typedef unsigned long long uintmax_t;
+ __extension__ typedef long long int64_t;
+ __extension__ typedef long long int_least64_t;
+ __extension__ typedef long long int_fast64_t;
+ __extension__ typedef unsigned long long uint64_t;
+ __extension__ typedef unsigned long long uint_least64_t;
+ __extension__ typedef unsigned long long uint_fast64_t;
+# elif defined(BOOST_HAS_MS_INT64)
+ // we have Borland/Intel/Microsoft __int64:
+ typedef __int64 intmax_t;
+ typedef unsigned __int64 uintmax_t;
+ typedef __int64 int64_t;
+ typedef __int64 int_least64_t;
+ typedef __int64 int_fast64_t;
+ typedef unsigned __int64 uint64_t;
+ typedef unsigned __int64 uint_least64_t;
+ typedef unsigned __int64 uint_fast64_t;
+# else // assume no 64-bit integers
+# endif
+#endif // BOOST_HAS_STDINT_H
+#endif // BOOST_CSTDINT_HPP
+Macro definition section:
+Added 23rd September 2000 (John Maddock).
+Modified 11th September 2001 to be excluded when
+BOOST_HAS_STDINT_H is defined (John Maddock).
+Modified 11th Dec 2009 to always define the
+INT#_C macros if they're not already defined (John Maddock).
+#if !defined(BOOST__STDC_CONSTANT_MACROS_DEFINED) && \
+ (!defined(INT8_C) || !defined(INT16_C) || !defined(INT32_C) || !defined(INT64_C))
+// For the following code we get several warnings along the lines of:
+// boost/cstdint.hpp:428:35: error: use of C99 long long integer constant
+// So we declare this a system header to suppress these warnings.
+#if defined(__GNUC__) && (__GNUC__ >= 4)
+#pragma GCC system_header
+#endif
+#include <limits.h>
+# define BOOST__STDC_CONSTANT_MACROS_DEFINED
+# if defined(BOOST_HAS_MS_INT64)
+// Borland/Intel/Microsoft compilers have width specific suffixes:
+#ifndef INT8_C
+# define INT8_C(value) value##i8
+#endif
+#ifndef INT16_C
+# define INT16_C(value) value##i16
+#endif
+#ifndef INT32_C
+# define INT32_C(value) value##i32
+#endif
+#ifndef INT64_C
+# define INT64_C(value) value##i64
+#endif
+# ifdef __BORLANDC__
+ // Borland bug: appending ui8 makes the type a signed char
+# define UINT8_C(value) static_cast<unsigned char>(value##u)
+# else
+# define UINT8_C(value) value##ui8
+# endif
+#ifndef UINT16_C
+# define UINT16_C(value) value##ui16
+#endif
+#ifndef UINT32_C
+# define UINT32_C(value) value##ui32
+#endif
+#ifndef UINT64_C
+# define UINT64_C(value) value##ui64
+#endif
+#ifndef INTMAX_C
+# define INTMAX_C(value) value##i64
+# define UINTMAX_C(value) value##ui64
+#endif
+# else
+// do it the old fashioned way:
+# if (UCHAR_MAX == 0xff) && !defined(INT8_C)
+# define INT8_C(value) static_cast<boost::int8_t>(value)
+# define UINT8_C(value) static_cast<boost::uint8_t>(value##u)
+# endif
+# if (USHRT_MAX == 0xffff) && !defined(INT16_C)
+# define INT16_C(value) static_cast<boost::int16_t>(value)
+# define UINT16_C(value) static_cast<boost::uint16_t>(value##u)
+# endif
+#ifndef INT32_C
+# if (UINT_MAX == 0xffffffff)
+# define INT32_C(value) value##L
+# define UINT32_C(value) value##uL
+# endif
+#endif
+#ifndef INT64_C
+ (defined(ULLONG_MAX) || defined(ULONG_LONG_MAX) || defined(ULONGLONG_MAX) || defined(_LLONG_MAX))
+# define INT64_C(value) value##LL
+# define UINT64_C(value) value##uLL
+# elif (defined(ULLONG_MAX) && ULLONG_MAX == 18446744073709551615ULL) || \
+ (defined(ULONG_LONG_MAX) && ULONG_LONG_MAX == 18446744073709551615ULL) || \
+ (defined(ULONGLONG_MAX) && ULONGLONG_MAX == 18446744073709551615ULL) || \
+ (defined(_LLONG_MAX) && _LLONG_MAX == 18446744073709551615ULL)
+# else
+# endif
+# if ULONG_MAX == 18446744073709551615U // 2**64 - 1
+# else
+# endif
+# elif defined(BOOST_HAS_LONG_LONG)
+ // Usual macros not defined, work things out for ourselves:
+# if(~0uLL == 18446744073709551615ULL)
+# else
+# endif
+# else
+# endif
+# ifdef BOOST_NO_INT64_T
+# define INTMAX_C(value) INT32_C(value)
+# define UINTMAX_C(value) UINT32_C(value)
+# else
+# define INTMAX_C(value) INT64_C(value)
+# define UINTMAX_C(value) UINT64_C(value)
+# endif
+#endif
+# endif // Borland/Microsoft specific width suffixes
+#endif // INT#_C macros.
Property changes on: trunk/Tools/Vagrant/sources/patches/mapguide
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/mapguide/Oem
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap
+ true
Property changes on: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include
+ true
Added: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include/cs_Geocon.h
--- trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include/cs_Geocon.h (rev 0)
+++ trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Include/cs_Geocon.h 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,458 @@
+ * Copyright (c) 2008, Autodesk, Inc.
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * * Neither the name of the Autodesk, Inc. nor the names of its
+ * contributors may be used to endorse or promote products derived
+ * from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY Autodesk, Inc. ``AS IS'' AND ANY
+ * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Autodesk, Inc. OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+ * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
+ * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+** US GEOCON (2012) Data Files (e.g. dela?.b, delo?.b & dev.b files) **
+** (also geoid99.bin & g2012a??.bin files) **
+** This is the CS-MAP rendition of the US National Geodetic Survey's grid **
+** system for converting from NAD83/HARN to NAD83/2011. Thus, to get from, **
+** say, NAD27, to NAD83/2011 one needs to: **
+** 1> use NADCON to convert from NAD27 to NAD83, then **
+** 2> Use HARN to convert from NAD83 to HARN, then **
+** 3> Use GEOCON with the appropriate grid files to convert from **
+** HARN to NAD83/2011 **
+** As of this writing, we are assuming NAD83/2012 is just another **
+** name for NAD83/2011. We are not at all sure exactly how to distinguish **
+** between a 2007 and a 2011 grid data file. Hopefully, we'll be able to **
+** figure this all out when we have some code running which will enable to **
+** examine the results using different grid data files. **
+** We have used a 5 character naming system since the origin of CS-MAP **
+** in 1987 (when function names were limited to 8 characters (seven in **
+** some compiler/linker products). Thus, we have chosen to use the **
+** following names as appropriate in the Geodetic Transformation naming **
+** convention: "geocn", "cs_Geocn_". **
+** Note that the grid file formats and calculation algorithms are the same **
+** as that used in the NGS's Geoid 1999 grid effort. Thus, we have most **
+** all of the code necessary to implement this new grid file based **
+** transformation. Question as I write this comment: Do we isolate the **
+** Geoid99 code and rename it so that it takes on the more generic **
+** function which has mow made itself evident? Think so, especially since **
+** data files in this same format are used for the vertical portion of the **
+** base geodetic transformation, and also for using the quality of **
+** conversion data files associated with this geodetic transformation. **
+** Another reason for isolating/renaming/refactoring is that our new **
+** Geodetic Transformation paradigm requires several new functions which **
+** do not exist in the original Geoid 1999 implementation. **
+** So, the end result of these deliberations is that much of what you **
+** find in this header file and its corresponding implementation file(s) **
+** is a cut/paste/replace of the code previously existing in cs_map.h and **
+** CS_geoid99.c with struct and function names such as csGeoid99GridFile_ **
+** and CSnewGeoid99GridFile. The new names will adhere to the naming **
+** system used in the rewrite of Geodetic Transformations initiated by **
+** RFC 2. **
+** The actual, "official", NGS code for doing this transformation **
+** is written in (drum roll please) FORTRAN. For integrity purposes, the **
+** actual FORTRAN code is included as a huge comment at the tail end of **
+** implementation file associated with this header file. **
+** The data files for this geodetic conversion, as it applies to
+** NAD832007 and(?) NAD83/2011 come in groups of 6. Our implementation **
+** relies pretty heavily on this nameing convention in order to get the **
+** data files properly paired with each other. Since the coverage and **
+** grid cell size are the same in each of a paired set, a comparison of **
+** these values is done at construction time to insure that the files are **
+** being properly paired with each other. **
+** dela.b --> conterminous 48 states, latitude shift **
+** delo.b --> conterminous 48 states, longitude shift **
+** dev.b --> conterminous 48 states, vertical shift **
+** dsla.b --> conterminous 48 states, latitude shift quality estimate **
+** dslo.b --> conterminous 48 states, longitude shift quailty estimate **
+** dsv.b --> conterminous 48 states, vertical shift quality estimate **
+** delaa.b --> Alaska, latitude shift **
+** deloa.b --> Alaska, longitude shift **
+** deva.b --> Alaska, vertical shift **
+** dslaa.b --> Alaska, latitude shift quality estimate **
+** dsloa.b --> Alaska, longitude shift quailty estimate **
+** dsva.b --> Alaska, vertical shift quality estimate **
+** delap.b --> Puerto Rico/Virgin Is, latitude shift **
+** delop.b --> Puerto Rico/Virgin Is, longitude shift **
+** devp.b --> Puerto Rico/Virgin Is, vertical shift **
+** dslap.b --> Puerto Rico/Virgin Is, latitude shift quality estimate **
+** dslop.b --> Puerto Rico/Virgin Is, longitude shift quailty estimate **
+** dsvp.b --> Puerto Rico/Virgin Is, vertical shift quality estimate **
+** Presumably, in the future there may be an 'h' series for Hawaii, but **
+** no such data files have been found for Hawaii. **
+** Finally, there are files with names such as infoh.txt, infoha.txt, and **
+** infohp.txt. These files contain the locations of holes in the **
+** related grid files. Currently, we do not use them at all, although **
+** you might see some "future use provisions" for such. **
+/* United States 2012 Grid File Object (GEOCON)
+These file types are used for several different purposes. While
+not crucial, we like to identify each of the grid structures as to
+the purpose of the file it represents.
+Applications in which this file format is used:
+ 1> NAD83/HARN to NAD83/2012 geodetic cconversions,
+ both horizontal and vertical (ext = .b)
+ 2> Geoid 2012 Height calculation (ext = .bin)
+ 3> Geoid 2009 Height calculation (ext = .bin)
+ 4> Geoid 2003 Height calculation (ext = .bin)
+ 5> Geoid 1999 Height calculation (ext = .bin)
+Note sure at the current time if we'll be able to distinguish a 2007
+grid file from a 2007 grid file. Thus, this distinction may disappear.
+/* The following very arbitrary value is returned by functions
+ which typically return a grid shift value extracted from a
+ GEOCON grid file when an error is detected. This condition
+ is quite unimaginable, so a huge number which will not
+ go unnoticed in reaults has been chosen. */
+#define csGEOCON_SHIFT_ERROR -9.9E+12;
+enum csGeocnFileType { geocnTypeNoneYet = 0,
+ geocnTypeLatShift,
+ geocnTypeLngShift,
+ geocnTypeHgtShift,
+ geocnTypeGeoidHgt,
+ geocnTypeUnknown = 999
+enum csGeocnEdgeEffects { geocnEdgeNone = 0,
+ geocnEdgeSouthwest,
+ geocnEdgeSouth,
+ geocnEdgeSoutheast,
+ geocnEdgeEast,
+ geocnEdgeNortheast,
+ geocnEdgeNorth,
+ geocnEdgeNorthwest,
+ geocnEdgeWest,
+ geocnEdgeUnknown
+/* Geocon Grid Cell Object --> Used to hold the definition of a grid cell.
+ A Geocon frid cell is similar in function to the grid cell (with an
+ unqualified name) which is used in the NADCON and NTv2 datum shift
+ calculations. However, a Geocon grid cell carries nine data values
+ in a array of nine doubles. The interpolation is therefore, a bit more
+ mathematically rigourous that the standard bi-linear interpolation used
+ in the NADCON and NTv2 environments.
+ The grid cell is identified by the grid indices (zero based in our case)
+ of the central data element. The data extraction algorithm always extracts
+ a cell such that the point being converted is closer to the central
+ point than any of the others. Thus, when determining if we can use
+ a specific grid cell, we will use the integral indicies rather than
+ a range of coverage type calculation.
+ The array of doubles is used as follows:
+ IDX [0] [1] [2]
+ NORTH
+ [2] W nw n ne E
+ [1] E w ctr e A
+ [0] S sw s se S
+ T T
+ SOUTH
+ Note that the first record in the data files is the southernmost record,
+ amd that the values in each record start at the western edge and run to
+ the eastern edge (i.e. left to right, west to east).
+struct csGeocnGridCell_
+ short isValid; /* TRUE if this cell accurately represents data
+ data extracted from the associated grid data
+ file; otherwise FALSE. */
+ short cellAge; /* A cell is aged (i.e. the age element incremented
+ by one) for each conversion which takes place.
+ A cell's age is set to zero whenever the cell is
+ actually used to performa a conversion. This
+ is intended to support a possible future
+ performance enhancement of a grid cell cahce.
+ This is not currently implemented.*/
+ enum csGeocnEdgeEffects edge;
+ /* The appropriate edge effect calculation in
+ force for this grid cell. */
+ long32_t lngIdx; /* longitude grid file index value associated
+ with cellData [0][0] element of the grid
+ cell. */
+ long32_t latIdx; /* latitude grid file index value associated
+ cell. */
+ double swLng; /* Longitude, in degrees, of the southwest
+ point of the southwest value of the 3x3 grid
+ cell matrix. */
+ double swLat; /* Latitude, in degrees, of the southwest
+ cell matrix. */
+ double deltaLng; /* dimensions of cell, in degrees; for
+ Geocon files this is often 0.0166666666666667,
+ a rather ugly number for us to deal with. */
+ double deltaLat; /* dimensions of cell, in degrees; for
+ double cellData [3][3]; /* For performance purposes, cells carry data
+ values pre-converted to doubles. */
+ char sourceId [32]; /* File name of the source of the grid cell data. */
+/* The following represents the data contained in the header of
+ a GEOCON grid data file. Note, to avoid compiler packing
+ issues, we do not read this structure directly from disk;
+ each element is read individually and stored in a structure
+ of this form simply for covenience.
+ Note that the latitude and longitude values in this structure
+ are assumed to be NAD83/HARN based. Further, we assume that
+ for geoid height calculations, the datum to which the geographic
+ coordinates are based are considered immaterial, but probably
+ the datum of the indicated geoid.
+ Note, that the grid carried in one of these files, given the
+ information extracted from the header, is essentially as follows:
+ float cs_GeocnGridFileData [latCount][lngCount];
+ where element [0][0] is the grid shift value for a point
+ precisely at latitude = latMin and longitude = lngMin.
+ Horizontal datum shift values are floats, in arc-seconds * 100,000.00 (~ 0.3 mm)
+ Verical datum shift values are floats in centimeters.
+ Geoid height data elements are in meters.
+struct cs_GeoconFileHdr_
+ double latMin; /* Southernmost latitude covered in the file,
+ in degrees. */
+ double lngMin; /* Westernmost longitude covered in the file,
+ 0 thru 360, positive east from Greenwich. */
+ double latDelta; /* Latitudinal grid cell size, in degrees. */
+ double lngDelta; /* Longitudinal grid cell size, in degrees. */
+ long32_t latCount; /* Latitudinal size of the grid, i.e. number of
+ rows datum shift records in the grid file. */
+ long32_t lngCount; /* Longitudinal size of the grid, i.e. the number
+ of datum shift values in each record of the
+ grid file. */
+ long32_t iKind; /* Generally, a value of +1 means no swapping
+ required, i.e. the file is in byte order of
+ the host platform already. Any other value
+ probably means swapping is required on
+ the current host machine. */
+ long32_t headerSize; /* Actual size of the header in the file
+ from which it was extracted; not necessarily
+ the sizeof this structure for several reasons.*/
+#define cs_BSWP_GeocnHdr "ddddlll"
+** cs_GeoconFile_ --> A Single GEOCON file Object **
+** While two such files are required to perform a datum shift (e.g. HARN **
+** to NAD83/2007), a single file is used for other purposes such as geoid **
+** height calculations. Thus, is it convenient to have an object which can **
+** be used independently to access a single file of this type. **
+** While not really used in any way, we do our best to classify the file **
+** type and purpose to aid in debugging. The need for byte swappping is **
+** determined by a static data constant which indicates the byte order of **
+** the processor we are running on, and examination of the data in the **
+** file header. I.e. the first two elements in the header are 8 byte **
+** doubles which are a valid latitude and a valid ongitude values. Clearly **
+** we swap if necessary to get values which meet this criteria. **
+** Files are now heavily buffered. In fact, in some cases the entire file **
+** resides in memory after the first access. In such cases, the file **
+** stream will be closed. Note, the typical GEOCON Grid Data file is more **
+** than 25 megabytes. Since two are required for a horizontal datum shift, **
+** buffering the entire file(s) would normally consume 50 megabytes of **
+** memory. We won't do that unless it is really necessary for performance **
+** purposes. **
+** Please note that the grid cell size on GEOCON files is often set to **
+** rather painful values. I.e. the most popular of the several files uses **
+** a geoid cell size of 0.0166666667 degrees (one minute of arc). This is **
+** is a rather unfriendly value to work with in a digital computer and **
+** produces all sorts of strange bugs when working on the edge of a grid **
+** cell or the entire grid itself. Watch out for these problems. Make **
+** sure that, when using these types of values, you get extended precision **
+** rather than just what appears in the files. To accomplish this, you are **
+** likely to find that min/max type calculations are done using integers **
+** carrying seconds of arc to insure maximum precison is obtained. **
+/* The following is what a US GEOCON Grid file, looks like in memory,
+ regardless of its function.
+struct cs_GeoconFile_
+ enum csGeocnFileType type; /* Type of file. */
+ double latMin; /* Latitude of the the southwest corner
+ of the grid in decimal degrees. */
+ double lngMin; /* Longitude of the the southwest corner
+ This value rangs from 0.0 to +360.0. */
+ double latMax; /* Latitude of the northeast corner
+ double lngMax; /* Longitude of the the northeast corner
+ double deltaLng; /* size of a grid cell in degrees */
+ double deltaLat; /* size of a grid cell in degrees */
+ double density; /* smaller of the two deltas, just
+ in case they ever are different. */
+ long32_t elementCount; /* elements per record */
+ long32_t recordCount; /* number of records in the file */
+ long32_t elementSize; /* size of the internal elements,
+ i.e. sizeof (float). */
+ long32_t headerSize; /* size of the file header, in
+ bytes. */
+ long32_t recordSize; /* size in bytes of a record for
+ I/O and buffer management
+ purposes. This includes the 32 bit
+ record size word that FORTRAN likes
+ to put on the fron and end of records
+ in an unformatted (i.e. binary) data
+ file. */
+ long32_t fileSize; /* size of complete file on disk,
+ stream will be closed if
+ bufferSize == fileSize */
+ long32_t bufferSize; /* size of buffer allocated */
+ long32_t bufferBeginPosition; /* file position of 1st byte in buffer,
+ -1 says nothing in buffer */
+ long32_t bufferEndPosition; /* file position of last byte in buffer,
+ -2 says nothing in buffer */
+ csFILE* strm; /* file is not opened until required,
+ may be closed if entire contents
+ have been buffered. */
+ void *dataBuffer; /* not allocated until required, i.e.
+ file is actually opened. */
+ short swapBytes; /* True (+1) indicates that byte swapping
+ is necessary in the current
+ environment. */
+ char filePath [MAXPATH]; /* Full path name to the file. */
+ char fileName [32]; /* Last 31 characters of the actual
+ file name (sans ext); used to generate
+ point data ID's. */
+ struct csGeocnGridCell_ gridCell;
+ /* Last used grid cell. */
+/* The following structure combines three GEOCON Grid file structures into a
+ single object capable of doing a 2D/3D datum shift, i.e. a horizontal datum
+ shift or a horizontal and vertical datum shift.
+ Since this is a grid file interpolation method based on just another grid
+ file format, the function protocols are designed to fit within the design
+ of the existing grid file.
+struct cs_Geocn_
+ short verticalAvailable; /* Redundant? Equivalent to hgtShift != NULL */
+ double minLng; /* 0.0 <= minLng < 360.0 */
+ double minLat; /* -90.0 < minLat <= 90.0 */
+ double maxLng; /* minLng < maxLng <= 360.0 */
+ double maxLat; /* -90.0 < minLat <= 90.0 */
+ double density; /* smaller of the two cell dimensions in degrees,
+ usually 0.0166666667 for these types of files. */
+ /* The two dimensional inverse reqires iteration. Thus, the following
+ values are used to deal with the remote possibility that the interation
+ doesn't converge.
+ * If, after maxIterations, the delta value remains >= errorValue,
+ the transformation is reported as a fatal error.
+ * If, after maxIterations, the delta value is less than errorValue
+ but >= convergeValue, the transformation is treated as a failure
+ to converge.
+ * The iteration loop is considered successful and complete when the
+ delta value is lkess than cnvrgValue.
+ * The loop never iterates more than maxIterations.
+ double errorValue;
+ double cnvrgValue;
+ short maxIterations;
+ struct cs_GeoconFile_* lngShift;
+ struct cs_GeoconFile_* latShift;
+ struct cs_GeoconFile_* hgtShift; /* Could be null if vertical option
+ is not activated. */
+struct cs_GeoconFile_* CSnewGeoconFile (Const char* filePath,long32_t bufferSize,
+ ulong32_t flags,
+ double density,
+ enum csGeocnFileType fileType);
+int CSpathsGeoconFile (char *pathBufferLng,char *pathBufferLat,char *pathBufferHgt,
+ Const char *pathBuffer);
+int CSheaderGeoconFile (struct cs_GeoconFileHdr_ *thisPtr,csFILE *fstr);
+int CSchkHdrGeoconFile (struct cs_GeoconFileHdr_ *thisPtr);
+void CSinitGeoconFile (struct cs_GeoconFile_ *thisPtr);
+void CSreleaseGeoconFile (struct cs_GeoconFile_* thisPtr);
+void CSdeleteGeoconFile (struct cs_GeoconFile_* thisPtr);
+double CStestGeoconFile (struct cs_GeoconFile_* thisPtr,Const double *sourceLL);
+int CScalcGeoconFile (struct cs_GeoconFile_* thisPtr,double* result,Const double* sourceLL);
+int CSextractGeoconGridFile (struct csGeocnGridCell_ *gridCellPtr,struct cs_GeoconFile_* thisPtr,
+ long32_t eleNbr,
+ long32_t recNbr);
+int CSreadGeoconGridFile (struct cs_GeoconFile_* thisPtr,long32_t recNbr);
+double CSvalueGeoconGridFile (struct cs_GeoconFile_* thisPtr,long32_t eleNbr,
+ long32_t recNbr);
+int CSedgeGeocnGridCell (struct csGeocnGridCell_ *cellPtr,struct cs_GeoconFile_* filePtr,
+ long32_t eleNbr,
+ long32_t recNbr,
+ enum csGeocnEdgeEffects edge);
+void CSinitGeocnGridCell (struct csGeocnGridCell_* thisPtr);
+double CScalcGeocnGridCell (struct csGeocnGridCell_* thisPtr,Const double *sourceLL);
+const char *CSsourceGeocnGridCell (struct csGeocnGridCell_* thisPtr);
+double EXP_LVL9 CSgeocnQterp (struct csGeocnGridCell_* thisPtr,double sourceDelta [2]);
+double EXP_LVL9 CSgeocnQterpOne (double delta,double rowData [3]);
Property changes on: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source
+ true
Added: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/CSdata.c
--- trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/CSdata.c (rev 0)
+++ trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/CSdata.c 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,657 @@
+#include "cs_map.h"
+#include "cs_Legacy.h"
+ The following defines and declarations are used to
+ access the various data files required by CS_MAP.
+ NOTE: cs_DirP MUST point to the terminating null
+ character of the string contained in the cs_Dir
+ array. cs_Dir MUST end with a directory separation
+ character. If you modify the initialization of
+ cs_Dir, YOU MUST ALSO MODIFY THE INITIALIZATION OF
+ cs_DirP.
+#if _RUN_TIME < _rt_UNIXPCC
+char cs_DirK [MAXPATH] = "C:\\ProgramData\\GeodeticData";
+csThread char cs_Dir [MAXPATH] = "";
+csThread char *cs_DirP = NULL;
+csThread char cs_UserDir [MAXPATH] = "";
+char cs_DirsepC = '\\';
+char cs_ExtsepC = '.';
+char cs_OptchrC = '/';
+char cs_EnvchrC = '%';
+char cs_EnvStartC = '%';
+char cs_EnvEndC = '%';
+wchar_t cs_DirsepWC = L'\\';
+wchar_t cs_ExtsepWC = L'.';
+wchar_t cs_OptchrWC = L'/';
+wchar_t cs_EnvchrWC = L'%';
+wchar_t cs_EnvStartWC = L'%';
+wchar_t cs_EnvEndWC = L'%';
+csThread char cs_NameMapperName [MAXPATH] = "NameMapper.csv";
+#else
+char cs_DirK [MAXPATH] = "/usr/etc/GeodeticData/";
+char cs_Dir [MAXPATH] = "";
+char *cs_DirP = NULL;
+char cs_UserDir [MAXPATH] = "";
+char cs_DirsepC = '/';
+char cs_OptchrC = '-';
+char cs_EnvchrC = '$';
+char cs_EnvStartC = '{';
+char cs_EnvEndC = '}';
+wchar_t cs_DirsepWC = L'/';
+wchar_t cs_OptchrWC = L'-';
+wchar_t cs_EnvchrWC = L'$';
+wchar_t cs_EnvStartWC = L'{';
+wchar_t cs_EnvEndWC = L'}';
+wchar_t cs_NameMapperName [MAXPATH] = L"NameMapper.csv";
+#endif
+ The following are used in CS_atof and CS_ftoa for the
+ conversion of numbers to/from ASCII. Modify as appropriate
+ for the current locale.
+char cs_DecpntC = '.';
+char cs_DigsepC = ',';
+char cs_RatioC = ':';
+char cs_LngDir [6] = "EeWw";
+char cs_LatDir [6] = "NnSs";
+ The following array contains the set of characters which
+ are considered valid for coordinate system, datum, and
+ ellipsoid key names. The test occurs in the CS_nampp function.
+ Note, as of Release 8, we allow a space character. The
+ name preprocessor, CS_nampp, will flag a double space as
+ an error, however. Also, as of release 8, we no longer
+ convert key names to upper case. However, all comparisions
+ remain case Insensitive.
+ As of Release 9, all alpha numeric characters are tested by
+ hard code in the CS_nampp module. This string now only
+ contains the special characters (i.e. non-alphanumeric)
+ which are allowed. Note that cs_Unique need not be included
+ in this string. Include a space in this string if you want to
+ support spaces in key names. CS_nampp will enforce a
+ restriction which does not allow two consectuive spaces.
+ If the underscore is included in this list, it will be
+ considered acceptable as the first alphanumeric in a key name.
+Const char cs_Nmchset [32] = " _-$:.;~/";
+ As of release 5.0, the names of the Coordinate System, Datums,
+ and Elipsoid dictionaries are maintained here. Should your
+ application desire to use names other than the standard names,
+ you may change them here and recompile or use the CS_csnam,
+ CS_dtnam, or CS_elnam functions at runtime.
+ Of course, you could just copy to these global variables, but
+ the function interface provides a bit more insulation from
+ future changes in the system.
+csThread char cs_Csname [cs_FNM_MAXLEN] = cs_CS_NAME;
+csThread char cs_Dtname [cs_FNM_MAXLEN] = cs_DAT_NAME;
+csThread char cs_Elname [cs_FNM_MAXLEN] = cs_ELL_NAME;
+csThread char cs_Ctname [cs_FNM_MAXLEN] = cs_CT_NAME;
+csThread char cs_Gxname [cs_FNM_MAXLEN] = cs_GX_NAME;
+csThread char cs_Gpname [cs_FNM_MAXLEN] = cs_GP_NAME;
+csThread char cs_Envvar [cs_FNM_MAXLEN] = cs_ENV_VAR;
+csThread char cs_NmMapNm [cs_FNM_MAXLEN] = cs_NMP_NAME;
+csThread char cs_NadName [cs_FNM_MAXLEN] = cs_NAD_NAME;
+csThread char cs_HarnName [cs_FNM_MAXLEN] = cs_HARN_NAME;
+csThread char cs_GeoidName [cs_FNM_MAXLEN] = cs_GEOID_NAME;
+csThread char cs_VertconName [cs_FNM_MAXLEN] = cs_VERTCON_NAME;
+csThread char cs_Agd66Name [cs_FNM_MAXLEN] = cs_AGD66_NAME;
+csThread char cs_Agd84Name [cs_FNM_MAXLEN] = cs_AGD84_NAME;
+csThread char cs_Nzgd49Name [cs_FNM_MAXLEN] = cs_NZGD49_NAME;
+csThread char cs_Ats77Name [cs_FNM_MAXLEN] = cs_ATS77_NAME;
+csThread char cs_CsrsName [cs_FNM_MAXLEN] = cs_CSRS_NAME;
+csThread char cs_Csrs27Name [cs_FNM_MAXLEN] = cs_CSRS27_NAME;
+csThread char cs_Jgd2kName [cs_FNM_MAXLEN] = cs_JGD2K_NAME;
+csThread char cs_Ed50Name [cs_FNM_MAXLEN] = cs_ED50_NAME;
+csThread char cs_Rgf93Name [cs_FNM_MAXLEN] = cs_RGF93_NAME;
+csThread char cs_DhdnName [cs_FNM_MAXLEN] = cs_DHDN_NAME;
+csThread char cs_Ch1903Name [cs_FNM_MAXLEN] = cs_CH1903_NAME;
+csThread char cs_N27A77Name [cs_FNM_MAXLEN] = cs_N27A77_NAME;
+ The following array supports the enumerator for GDC file
+ names. This is used in the GDC file editor. Adding a new
+ file to this array will, essentially, add it to the
+ GDC File Editor.
+ This array is also used for the functions which enable
+ applications to change the default names. While
+ applications can modify the global variables directly,
+ this is no longer recommended. When connvenient,
+ change your application to use the new name change
+ functions.
+ Note, that gdcFileNone marks the end of the table.
+struct cs_GdcCatalogTable_ cs_GdcCatalogTable [] =
+ { gdcFileNad27ToNad83, cs_NadName , gdcTypeHorizontal, 0UL, ".las.los.gsb.dac", "NADCON files (*.l?s)|*.l?s|Canadian Ntv2 (*.gsb)|*.gsb|Canadian Ntv1 (*.dac)|*.dac||"},
+ { gdcFileNad83ToHarn, cs_HarnName , gdcTypeHorizontal, 0UL, ".las.los" ,"NADCON files (*.l?s)|*.l?s||" },
+ { gdcFileAgd66ToGda94, cs_Agd66Name , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileAgd84ToGda94, cs_Agd84Name , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ {gdcFileNzgd49ToNzgd2K, cs_Nzgd49Name , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileAts77ToCsrs, cs_Ats77Name , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileNad83ToCsrs, cs_CsrsName , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileTokyoToJgd2k, cs_Jgd2kName , gdcTypeHorizontal, 0UL, ".gsb" ,"Japanese Grid format (*.par)|*.par||" },
+ { gdcFileNad27ToCsrs, cs_Csrs27Name , gdcTypeHorizontal, 0UL, ".gsb.gdc" ,"Canadian Ntv2 format (*.gsb)|*.gsb|Ats77 Geodetic Data Catalog (*.gdc)|*.gdc||"},
+ { gdcFileEd50ToEtrf89, cs_Ed50Name , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileDhdnToEtrf89, cs_DhdnName , gdcTypeHorizontal, 0UL, ".gsb" ,"Canadian Ntv2 format (*.gsb)|*.gsb||" },
+ { gdcFileNad27ToAts77, cs_N27A77Name , gdcTypeHorizontal, 0UL, ".gsb" ,"ATS77 Transform files (*.DAT)|*.DAT" },
+ { gdcFileGeoidHeight, cs_GeoidName , gdcTypeSeparation, 0UL, ".geo.bin.byn.txt.grd","Geoid96 (*.geo)|*.geo|Geoid99 (*.bin)|*.bin|Canadian (*.byn)|*.byn|UK OSGM91 (*.txt)|*.txt|EGM96 (*.grd)|*.grd||"},
+ { gdcFileVertcon, cs_VertconName, gdcTypeVertical, 0UL, ".94" ,"Vertcon files (*.94)|*.94||" },
+ { gdcFileRgf93ToNtf, cs_Rgf93Name , gdcTypeThreeDimensional, 0UL, ".txt.gsb" ,"French IGN Datum Shift Files (*.txt)|*.txt|Canadian Ntv2 (*.gsb)|*.gsb|All Files (*.*)|*.*||"},
+ { gdcFileNone, 0 , gdcTypeNone, 0UL, "" ,"" }
+ The following arrays are used to process default values
+ for datums, ellipsoids, and units. The value assigned,
+ the null string, says that the specific feature is
+ inactive.
+csThread char csDtDflt [32] = ""; /* The current default datum. */
+csThread char csElDflt [32] = ""; /* The current default ellipsoid. */
+csThread char csLuDflt [32] = ""; /* The current default linear unit. */
+csThread char csAuDflt [32] = ""; /* The current default angular unit. */
+ The following are used to control the dictionary protection
+ scheme. cs_Unique is a character which must appear in a
+ user defined dictionary key name, one which the system
+ distributer will never use. Disable this feature by setting
+ cs_Unique to '\0'.
+ cs_Protect controls the protection of distribution coordinate
+ systems and user defined systems. Set cs_Protect to -1 to
+ disable all protection. Set cs_Protect to 0 to enable
+ distribution protection, but disable user coordinate system
+ protection. If cs_Protect is positive and non-zero, it is
+ taken to mean that user coordinate systems are protected
+ after remaining unaltered for that number of days.
+char cs_Unique = ':';
+short cs_Protect = 0;
+int cs_Safe = 1;
+ The following are used to communicate certain information
+ between modules without overloading the calling sequence
+ of the functions involved.
+#if _MEM_MODEL == _mm_VIRTUAL || _MEM_MODEL == _mm_FLAT
+csThread int cs_Sortbs = 128 * 1024;
+#else
+csThread int cs_Sortbs = 24 * 1024;
+#endif
+csThread int cs_Error = 0;
+csThread int cs_Errno = 0;
+csThread int csErrlng = 0;
+csThread int csErrlat = 0;
+csThread unsigned short cs_ErrSup = 0;
+#if _RUN_TIME <= _rt_UNIXPCC
+csThread ulong32_t cs_Doserr = 0;
+#endif
+/* The following should be left assigned to zero. When this variable is
+ non-zero, it is assumed to point to a a valid stream, and diagnostic
+ information is written to the stream.
+csFILE* csDiagnostic = 0;
+ The following points are used in the High Performance
+ Interface. We define them here, so that CS_init can
+ initialize them, without forcing the code of the
+ High Performance Interface.
+csThread struct csCscach_ *csCscachP = NULL;
+csThread int csCscachI = cs_CSCACH_MAX;
+csThread struct csDtcach_ *csDtcachP = NULL;
+csThread int csDtcachI = cs_DTCACH_MAX;
+csThread char *cs_CsKeyNames = NULL;
+csThread char *cs_DtKeyNames = NULL;
+csThread char *cs_ElKeyNames = NULL;
+csThread char *cs_CsLlEnum = NULL;
+csThread struct cs_Csgrplst_ *cs_CsGrpList = NULL;
+/* Used for high level MGRS access. */
+csThread struct cs_Mgrs_ *cs_MgrsPtr = NULL;
+/* Used for geocentric coordinate calculations. */
+csThread double csGeoCtrErad = 0.0;
+csThread double csGeoCtrEsq = 0.0;
+/* Note: several functions assume that csErrnam is dimensioned
+ at MAXPATH (i.e. a minimum value). */
+csThread char csErrnam [MAXPATH] = "???";
+csThread char csErrmsg [cs_ERRMSG_SIZE] = "???";
+/* The following carries a pointer to the category list. */
+struct cs_Ctdef_* cs_CtDefHead = NULL;
+ Hook function pointers. Set to NULL to deativate.
+ The following group of hook functions are called prior to actual
+ fetching of the related definition from the dictionaries/tables.
+ They have been implemented to support dynamically created (temporary)
+ definitions.
+int (*CS_usrCsDefPtr)(struct cs_Csdef_ *csDef,Const char *keyName) = NULL;
+int (*CS_usrDtDefPtr)(struct cs_Dtdef_ *dtDef,Const char *keyName) = NULL;
+int (*CS_usrElDefPtr)(struct cs_Eldef_ *elDef,Const char *keyName) = NULL;
+double (*CS_usrUnitPtr)(short type,Const char *unitName) = NULL;
+ The following hook functions are called after the definition has been read,
+ but before any default processing.
+int (*cs_CsHook)(struct cs_Csdef_ *csdef,unsigned short prj_code,ulong32_t prj_flags) = NULL;
+int (*cs_DtHook)(struct cs_Dtdef_ *dtdef) = NULL;
+ The following constants are used throughout CS_MAP.
+ They are declared here, once, to reduce data space
+ requirements of the package. Variables, rather
+ than literals, are used to reduce code space and
+ improve performance.
+Const double cs_Pi = PI; /* 3.14159..... */
+Const double cs_Mpi = -PI; /* -3.14159..... */
+Const double cs_Two_pi = (2.0 * PI); /* 6.28218..... */
+Const double cs_Three_pi = (3.0 * PI); /* 9.424777.... */
+Const double cs_3Pi_o_2 = (3.0 * PI / 2.0); /* 3 pi over 2 */
+Const double cs_Pi_o_2 = PI_OVR_2; /* PI / 2.0 */
+Const double cs_Mpi_o_2 = -PI_OVR_2; /* -PI / 2.0 */
+Const double cs_Pi_o_3 = (PI / 3.0); /* PI / 3.0 */
+Const double cs_Pi_o_4 = PI_OVR_4; /* PI / 4.0 */
+Const double cs_Mpi_o_4 = -PI_OVR_4; /* PI / 4.0 */
+Const double cs_Radian = RADIAN; /* 57.29577..... */
+Const double cs_Degree = ONE_DEGREE; /* 1.0 / RADIAN */
+Const double cs_Mone = -1.0; /* -1.0 */
+Const double cs_Zero = 0.0;
+Const double cs_Fifth = (1.0 / 5.0);
+Const double cs_Fourth = (1.0 / 4.0);
+Const double cs_Third = (1.0 / 3.0);
+Const double cs_Half = 0.5;
+Const double cs_Mhalf = -0.5;
+Const double cs_One = 1.0;
+Const double cs_Two = 2.0;
+Const double cs_Three = 3.0;
+Const double cs_Four = 4.0;
+Const double cs_Mfour = -4.0;
+Const double cs_Five = 5.0;
+Const double cs_Six = 6.0;
+Const double cs_Seven = 7.0;
+Const double cs_Eight = 8.0;
+Const double cs_Nine = 9.0;
+Const double cs_Ten = 10.0;
+Const double cs_K15 = 15.0;
+Const double cs_K30 = 30.0;
+Const double cs_K45 = 45.0;
+Const double cs_Km45 = -45.0;
+Const double cs_K60 = 60.0;
+Const double cs_K75 = 75.0;
+Const double cs_K540 = 540.0;
+Const double cs_K360 = 360.0;
+Const double cs_K270 = 270.0;
+Const double cs_K180 = 180.0;
+Const double cs_K90 = 90.0;
+Const double cs_K89 = 89.0;
+Const double cs_Km360 = -360.0;
+Const double cs_Km270 = -270.0;
+Const double cs_Km180 = -180.0;
+Const double cs_Km90 = -90.0;
+Const double cs_Km89 = -89.0;
+Const double cs_SclInf = 9999.99; /* The value we return for
+ a scale factor when the
+ result actually approaches
+ infinity. */
+ /* The value of INFINITY has been carefully selected to
+ be very large, but not so large as it cannot be used.
+ Thus, for tan (PI/2), we often use this value and then
+ proceed to square it, multiply by it, divide by it,
+ etc. Thus, don't make this value too small, but don't
+ make it too big either. Its possible that this value
+ will be used in cases where floats are used, so we
+ like to keep it around 1.0E+32. */
+Const double cs_Zero1 = 0.0;
+#if (_RUN_TIME == _rt_HPUX) || (_RUN_TIME == _rt_AIX)
+ /* It appears that HP UNIX has it's own idea about INFINITY. I guess I should
+ have used the name cs_INFINITY. */
+ Const double cs_Huge = 1.0E+32; /* Value often returned when
+ the real result would be
+ infinite. */
+ Const double cs_Mhuge = -1.0E+32; /* Negative infinity. */
+#else
+ Const double cs_Huge = INFINITY; /* Value often returned when
+ infinite. */
+ Const double cs_Mhuge = -INFINITY; /* Negative infinity. */
+#endif
+ /* The following constants are used to check the validity of
+ a definitions following acquisition from disk.
+ Change them here or at run time. Note, we allow a
+ radius as small as 1.0 to handle the test cases. Also,
+ some folks use this stuff to map planets and the moon. So,
+ the following numbers are pretty liberal. You may want
+ to be more conservative. */
+double cs_ERadMax = 7.0E+06;
+double cs_PRadMax = 7.0E+06;
+double cs_ERadMin = 6.0E+06;
+double cs_PRadMin = 6.0E+06;
+double cs_EccentMax = 0.2;
+double cs_DelMax = 50000.0;
+double cs_RotMax = 50000.0;
+double cs_SclMax = 2000.0;
+double cs_SclRedMin = 0.5;
+double cs_SclRedMax = 1.5;
+double cs_ElevElMin = -25000.0;
+double cs_ElevElMax = 50000.0;
+ /* The following value is used to test angles for being equal
+ to a specific value, usually 0.0 or 90 degrees. The value
+ is in radians an corresponds to .001 seconds of arc. This
+ equates to about 30 centimeters on the earth. See Synder,
+ page 71. He suggests 1.E-07. I feel that 4.85E-08 is
+ close enough to his value, works fine, and is a bit easier
+ to document.
+ This value was established here in release 6.05. The replacement
+ of the several different literal constants currently used will
+ take place over the next few releases. */
+Const double cs_AnglTest = 4.85E-08;
+Const double cs_AnglTest1 = (1.0 - 4.85E-08);
+ /* cs_ParmTest is similar to cs_AnglTest, but it:
+ 1) is in units of degrees;
+ 2) is used when checking user entered parameters;
+ 3) is a bit larger, representing .1 seconds of arc, about
+ 3 meters on the surface of the earth (at the equator).
+ This is the value used to, for example, see if the two
+ standard parallels of a conic are the same.
+Const double cs_ParmTest = 2.78E-05;
+ The following values are used to test for proximity to
+ the north and south poles, and 90 degrees east and west
+ of the central merdian for many projections. Essentially,
+ these values represent +- 90 degrees of latitude, less the
+ cs_AnglTest value, in radians. These constants are designed
+ to be consistent with cs_AnglTest, but make checking more
+ efficient.
+Const double cs_NPTest = ( PI_OVR_2 - 4.85E-08); /* North Pole TEST value. */
+Const double cs_SPTest = (-PI_OVR_2 + 4.85E-08); /* South Pole TEST value. */
+Const double cs_EETest = ( PI_OVR_2 - 4.85E-08); /* East Extent TEST value. */
+Const double cs_WETest = (-PI_OVR_2 + 4.85E-08); /* West Extent TEST value. */
+ The following are used where appropriate to filter out noise
+ in the low order bits of double precision latitude and
+ longitude numbers.
+Const double cs_Micron = 1.0E-06;
+Const double cs_LlNoise = 1.0E-12;
+ The following values, all in degrees, are used to test
+ coordinate system definition parameters.
+Const double cs_MinLng = -180.00;
+Const double cs_MaxLng = 180.00;
+Const double cs_MinLat = -90.00;
+Const double cs_MaxLat = 90.00;
+Const double cs_MinLngFz = -179.9997222; /* 1 second greater than -180. */
+Const double cs_MaxLngFz = 179.9997222; /* 1 second less than 180. */
+Const double cs_MinLatFz = -89.9997222; /* 1 second less than 90. */
+Const double cs_MaxLatFz = 89.9997222; /* 1 second greater than -90. */
+Const double cs_Deg2Sec = 3600.0; /* Converts degrees to
+ arc seconds. */
+Const double cs_Sec2Deg = (1.0 / 3600.0); /* Converts arc seconds to
+ degrees. */
+Const double cs_Min2Deg = (1.0 / 60.0); /* Converts arc minutes to
+ degrees. */
+Const double cs_HlfSecDeg = (0.5 / 3600.0); /* One half second of arc
+ in degrees. */
+Const double cs_Sec2Rad = (1.0 / 3600.0 / RADIAN);/* Converts arc seconds to
+ radians. */
+Const double cs_Sin1Sec = 0.00000484813681107636782;
+ /* Sine of one second of arc,
+ also can be used as one
+ arc second in radians. */
+Const double cs_NPSecs = (90.0 * 3600.0); /* Latitude of the north
+ pole in arc seconds. */
+Const double cs_Wgs84_aa = 6378137.000; /* WGS-84 major radius. */
+Const double cs_Wgs84_ff = 1.0 / 298.257223563; /* WGS-84 flattening */
+Const double cs_Wgs84_esq = 0.00669437999013; /* WGS-84 eccentricity
+ squared */
+Const double cs_Wgs84_1esq = 0.99330562000987; /* WGS-84 1.0 - e_sq */
+/* Formatting variables used by the CScs2src, CScs2xml, and similar
+ functions. */
+long32_t csLatFrmt = 16L;
+long32_t csLngFrmt = 16L;
+long32_t csAnglFrmt = 16L;
+long32_t csXyFrmt = 5L;
+long32_t csZzFrmt = 5L;
+long32_t csRedFrmt = 0L;
+long32_t csSclFrmt = 0L;
+long32_t csCoefFrmt = 11L;
+/* The following definition is used in fallback cases only. That is, where
+ extraordinary calculations are being performed. In all "normal"
+ situations, the definition fetched from the dictionary(s) is/are used. */
+struct cs_Datum_ cs_Wgs84Def =
+ "WGS84", /* datum key name */
+ "WGS84", /* ellipsoid key name */
+ 6378137.000, /* equatorial radius */
+ 6356752.3142, /* polar radius */
+ 1.0 / 298.257223563, /* flattening */
+ 0.0818191908426, /* eccentricity */
+ 0.0, /* Delta X */
+ 0.0, /* Delta Y */
+ 0.0, /* Delta Z */
+ 0.0, /* Rot X */
+ 0.0, /* Rot Y */
+ 0.0, /* Rot Z */
+ 0.0, /* Scale */
+ cs_DTCTYP_WGS84, /* to84_via */
+ "World Geodetic System of 1984",
+#if !defined(__SUNPRO_C)
+ struct cs_Datum_ *cs_Wgs84Ptr = &cs_Wgs84Def;
+#endif
+ The following are global constants used to define the
+ operation of the non-standard cartesian system
+ feature of CS_MAP.
+ cs_QuadMin & cs_QuadMax are used in the CS_cschk function
+ to determine validity of the user supplied value.
+ cs_QuadMap is used in the projection setup functions
+ to convert the user supplied value to the bit map
+ value expected by CS_quadF and cs_quadI.
+ Note, the projection setup functions use
+ trmer->quad = cs_QuadMap [csprm->csdef.quad - cs_QuadMin];
+ to convert from user specified code to internal code.
+Const short cs_QuadMax = 4;
+Const short cs_QuadMin = -4;
+Const short cs_QuadMap [] =
+ cs_QUAD_SWAP | cs_QUAD_INVY, /* -4 */
+ cs_QUAD_SWAP | cs_QUAD_INVX | cs_QUAD_INVY, /* -3 */
+ cs_QUAD_SWAP | cs_QUAD_INVX, /* -2 */
+ cs_QUAD_SWAP, /* -1 */
+ 0, /* 0 */
+ 0, /* 1 */
+ cs_QUAD_INVX, /* 2 */
+ cs_QUAD_INVX | cs_QUAD_INVY, /* 3 */
+ cs_QUAD_INVY /* 4 */
+ A quad map for use with south oriented coordinate systems.
+Const short cs_QuadMapSO [] =
+ cs_QUAD_SWAP | cs_QUAD_INVX, /* -4 */
+ cs_QUAD_SWAP, /* -3 */
+ cs_QUAD_SWAP | cs_QUAD_INVY, /* -2 */
+ cs_QUAD_SWAP | cs_QUAD_INVX | cs_QUAD_INVY, /* -1 */
+ cs_QUAD_INVX | cs_QUAD_INVY, /* 0 */
+ cs_QUAD_INVX | cs_QUAD_INVY, /* 1 */
+ cs_QUAD_INVY, /* 2 */
+ 0, /* 3 */
+ cs_QUAD_INVX /* 4 */
+ The following table defines the list of currently supported
+ Coordinate System groups. It is suggested that application
+ developers resist the temptation to add new groups. If there
+ are too many groups, with too few members, the whole group
+ concept loses its effectiveness. Applications developers
+ may, need however, to translate the table to a different
+ language.
+Const struct cs_Grptbl_ cs_CsGrptbl [] =
+ { "SPCS27","State Planes, NAD27 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPCS83","State Planes, NAD83 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "SPCS83F","State Planes, NAD83 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPCS83I","State Planes, NAD83 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPCSHP","State Planes, HARN (HPGN) Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "SPCSHPF","State Planes, HARN (HPGN) Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPCSHPI","State Planes, HARN (HPGN) Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS07","State Planes, NSRS 2007 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS07F","State Planes, NSRS 2007 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS07I","State Planes, NSRS 2007 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS11","State Planes, NSRS 2011 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS11F","State Planes, NSRS 2011 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "SPNSRS11I","State Planes, NSRS 2011 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "LL","Latitude/Longitude" ,cs_GRPTBL_ACTIVE},
+ { "UTM27","UTM Zones, NAD27 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTM27F","UTM Zones, NAD27 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTM27I","UTM Zones, NAD27 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTM83","UTM Zones, NAD83 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTM83F","UTM Zones, NAD83 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTM83I","UTM Zones, NAD83 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMHP","UTM Zones, HARN (HPGN) Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTMHPF","UTM Zones, HARN (HPGN) Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMHPI","UTM Zones, HARN (HPGN) Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS07","UTM Zones, NSRS 2007 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS07F","UTM Zones, NSRS 2007 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS07I","UTM Zones, NSRS 2007 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS11","UTM Zones, NSRS 2011 Based, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS11F","UTM Zones, NSRS 2011 Based, US Foot" ,cs_GRPTBL_ACTIVE},
+ { "UTMNSRS11I","UTM Zones, NSRS 2011 Based, Intn'l Foot" ,cs_GRPTBL_ACTIVE},
+ { "OTHR-US","Other US Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "CANADA","Canadian Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "OTHR-NA","Other North American Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "UTMN","UTM Zones, Northern Hemisphere, Meters" ,cs_GRPTBL_ACTIVE},
+ { "UTMS","UTM Zones, Southern Hemisphere, Meters" ,cs_GRPTBL_ACTIVE},
+ { "WORLD","World/Continent Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "EUROPE","European Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "AUSNZ","Australia/New Zealand Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "SAMER","South American Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "CAMER","Central American Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "AFRICA","African Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "ASIA","Asian Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "RUSSIA","Russian Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "PACIFIC","Other Pacific Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "ATLANTIC","Other Atlantic Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "POLAR","Polar Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "EPSGPRJ","Projected defs from EPSG, area undetermined" ,cs_GRPTBL_ACTIVE},
+ { "EPSGLL","Geographic defs from EPSG, area undetermined ",cs_GRPTBL_ACTIVE},
+ { "TEST","Test Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "USER","User Defined Coordinate Systems" ,cs_GRPTBL_ACTIVE},
+ { "WKTSUPPT","Well Known Text Support" ,cs_GRPTBL_ACTIVE},
+ { "CARIB","Caribean/Gulf of Mexico and Vicinity" ,cs_GRPTBL_ACTIVE},
+ { "MIDEAST","Mideast/Holy Land" ,cs_GRPTBL_ACTIVE},
+ { "INDIAN","Indian Ocean" ,cs_GRPTBL_ACTIVE},
+ { "NERTH","Non geospatial (non-Earth) transformations" ,cs_GRPTBL_ACTIVE},
+ { "NONE","No group specified in definition" ,cs_GRPTBL_ACTIVE},
+ { "LEGACY","Obsolete/Incorrect; for legacy use only" ,cs_GRPTBL_ACTIVE},
+ { "","" ,cs_GRPTBL_END}
Added: trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/Library.mak
--- trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/Library.mak (rev 0)
+++ trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/Source/Library.mak 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,320 @@
+C_FLG = -c -DGCC_3 -D__CPP__ -Wall -O3 -I../Include
+CPP_FLG = -c -DGCC_3 -D__CPP__ -Wall -O3 -I../Include
+.cpp.o:
+ $(CXX) $(CPP_FLG) $<
+.c.o:
+ $(CC) $(C_FLG) $<
+CSMAP_LIB_SRC = \
+ csIoUtil.cpp \
+ CS_alber.c \
+ CS_angle.c \
+ CS_ansi.c \
+ CS_ats77New.c \
+ CS_azmea.c \
+ CS_azmed.c \
+ CS_badekas.c \
+ CS_bonne.c \
+ CS_bpcnc.c \
+ CS_bursa.c \
+ CS_bynFile.c \
+ CS_category.c \
+ cs_ctio.c \
+ CS_csini.c \
+ CS_csio.c \
+ CS_csprm.c \
+ CS_csWktLoc.c \
+ CS_datum.c \
+ CS_defaults.c \
+ CS_defCmp.c \
+ CS_defCmpEx.c \
+ CS_dtcalc.c \
+ CS_dtio.c \
+ CS_dtmBridge.c \
+ CS_edcnc.c \
+ CS_edcyl.c \
+ CS_egm96.c \
+ CS_ekrt4.c \
+ CS_ekrt6.c \
+ CS_elCalc.c \
+ CS_elio.c \
+ CS_erpt.c \
+ CS_error.c \
+ CS_fips.c \
+ CS_frame.c \
+ CS_frnch.c \
+ CS_gauss.c \
+ CS_general.c \
+ CS_geocn.c \
+ CS_geoct.c \
+ CS_geoid96.c \
+ CS_geoid99.c \
+ CS_GeoidHeight.c \
+ CS_gissupprt.c \
+ CS_gnomc.c \
+ CS_gpio.c \
+ CS_gridi.c \
+ CS_groups.c \
+ CS_guiApi.c \
+ CS_gxIndex.c \
+ CS_gxio.c \
+ CS_gxprm.c \
+ CS_hlApi.c \
+ CS_hmlsn.c \
+ CS_hpApi.c \
+ CS_japanNew.c \
+ CS_krovk.c \
+ CS_lmbrt.c \
+ CS_lmtan.c \
+ CS_mfc.cpp \
+ CS_mgrs.c \
+ CS_millr.c \
+ CS_modpc.c \
+ CS_molod.c \
+ CS_molwd.c \
+ CS_mrcat.c \
+ CS_mstro.c \
+ CS_mulrg.c \
+ CS_nacyl.c \
+ CS_nadcn.c \
+ CS_nerth.c \
+ CS_ntv1.c \
+ CS_ntv2.c \
+ CS_nullx.c \
+ CS_nzlnd.c \
+ CS_oblqm.c \
+ CS_optional.c \
+ CS_ortho.c \
+ CS_osgm91.c \
+ CS_ost02.c \
+ CS_ost97.c \
+ CS_ostn02.c \
+ CS_ostn97.c \
+ CS_ostro.c \
+ CS_parm3.c \
+ CS_parm4.c \
+ CS_parm6.c \
+ CS_parm7.c \
+ CS_plycn.c \
+ CS_pstro.c \
+ CS_rlsUpdt.c \
+ CS_robin.c \
+ CS_sinus.c \
+ CS_sstro.c \
+ CS_supprt.c \
+ CS_swiss.c \
+ CS_sys34.c \
+ CS_system.c \
+ CS_tacyl.c \
+ CS_trmer.c \
+ CS_trmrs.c \
+ CS_units.c \
+ CS_unity.c \
+ CS_vdgrn.c \
+ CS_VertconUS.c \
+ CS_vrtcon.c \
+ cs_wellknowntext.cpp \
+ CS_wgs72.c \
+ CS_winkelTripel.c \
+ CS_zones.c \
+ csBrowser.cpp \
+ CScs2Wkt.cpp \
+ cscscomp.c \
+ csCsvFileSupport.cpp \
+ CSdata.c \
+ csDataDir.cpp \
+ CSdataDT.c \
+ CSdataPJ.c \
+ CSdataU.c \
+ CSdatumCatalog.c \
+ CSdictDiff.c \
+ CSdt2Wkt.cpp \
+ CSdtcomp.c \
+ csDualBrowse.cpp \
+ csEdit.cpp \
+ CSel2Wkt.cpp \
+ CSelcomp.c \
+ csEpsgStuff.cpp \
+ csEpsgSupport.cpp \
+ CSgeodeticSupport.c \
+ CSgpcomp.c \
+ CSgxcomp.c \
+ csKeyNm.cpp \
+ CSmrcomp.c \
+ csNameMapper.cpp \
+ csNameMapperSupport.cpp \
+ csTest.cpp \
+ CSwinHlp.cpp \
+ CSwktFlavors.c \
+ dtEdit.cpp \
+ dtSelect.cpp \
+ elEdit.cpp \
+ elSelect.cpp \
+ gdcEdit.cpp \
+ mgTest.cpp \
+ rcWellKnownText.cpp \
+ rcWktKonstants.cpp
+CSMAP_LIB_OBJ = \
+ csIoUtil.o \
+ CS_alber.o \
+ CS_angle.o \
+ CS_ansi.o \
+ CS_ats77New.o \
+ CS_azmea.o \
+ CS_azmed.o \
+ CS_badekas.o \
+ CS_bonne.o \
+ CS_bpcnc.o \
+ CS_bursa.o \
+ CS_bynFile.o \
+ CS_category.o \
+ cs_ctio.o \
+ CS_csini.o \
+ CS_csio.o \
+ CS_csprm.o \
+ CS_csWktLoc.o \
+ CS_datum.o \
+ CS_defaults.o \
+ CS_defCmp.o \
+ CS_defCmpEx.o \
+ CS_dtcalc.o \
+ CS_dtio.o \
+ CS_dtmBridge.o \
+ CS_edcnc.o \
+ CS_edcyl.o \
+ CS_egm96.o \
+ CS_ekrt4.o \
+ CS_ekrt6.o \
+ CS_elCalc.o \
+ CS_elio.o \
+ CS_erpt.o \
+ CS_error.o \
+ CS_fips.o \
+ CS_frame.o \
+ CS_frnch.o \
+ CS_gauss.o \
+ CS_general.o \
+ CS_geocn.o \
+ CS_geoct.o \
+ CS_geoid96.o \
+ CS_geoid99.o \
+ CS_GeoidHeight.o \
+ CS_gissupprt.o \
+ CS_gnomc.o \
+ CS_gpio.o \
+ CS_gridi.o \
+ CS_groups.o \
+ CS_guiApi.o \
+ CS_gxIndex.o \
+ CS_gxio.o \
+ CS_gxprm.o \
+ CS_hlApi.o \
+ CS_hmlsn.o \
+ CS_hpApi.o \
+ CS_japanNew.o \
+ CS_krovk.o \
+ CS_lmbrt.o \
+ CS_lmtan.o \
+ CS_mfc.o \
+ CS_mgrs.o \
+ CS_millr.o \
+ CS_modpc.o \
+ CS_molod.o \
+ CS_molwd.o \
+ CS_mrcat.o \
+ CS_mstro.o \
+ CS_mulrg.o \
+ CS_nacyl.o \
+ CS_nadcn.o \
+ CS_nerth.o \
+ CS_ntv1.o \
+ CS_ntv2.o \
+ CS_nullx.o \
+ CS_nzlnd.o \
+ CS_oblqm.o \
+ CS_optional.o \
+ CS_ortho.o \
+ CS_osgm91.o \
+ CS_ost02.o \
+ CS_ost97.o \
+ CS_ostn02.o \
+ CS_ostn97.o \
+ CS_ostro.o \
+ CS_parm3.o \
+ CS_parm4.o \
+ CS_parm6.o \
+ CS_parm7.o \
+ CS_plycn.o \
+ CS_pstro.o \
+ CS_rlsUpdt.o \
+ CS_robin.o \
+ CS_sinus.o \
+ CS_sstro.o \
+ CS_supprt.o \
+ CS_swiss.o \
+ CS_sys34.o \
+ CS_system.o \
+ CS_tacyl.o \
+ CS_trmer.o \
+ CS_trmrs.o \
+ CS_units.o \
+ CS_unity.o \
+ CS_vdgrn.o \
+ CS_VertconUS.o \
+ CS_vrtcon.o \
+ cs_wellknowntext.o \
+ CS_wgs72.o \
+ CS_winkelTripel.o \
+ CS_zones.o \
+ csBrowser.o \
+ CScs2Wkt.o \
+ cscscomp.o \
+ csCsvFileSupport.o \
+ CSdata.o \
+ csDataDir.o \
+ CSdataDT.o \
+ CSdataPJ.o \
+ CSdataU.o \
+ CSdatumCatalog.o \
+ CSdictDiff.o \
+ CSdt2Wkt.o \
+ CSdtcomp.o \
+ csDualBrowse.o \
+ csEdit.o \
+ CSel2Wkt.o \
+ CSelcomp.o \
+ csEpsgStuff.o \
+ csEpsgSupport.o \
+ CSgeodeticSupport.o \
+ CSgpcomp.o \
+ CSgxcomp.o \
+ csKeyNm.o \
+ CSmrcomp.o \
+ csNameMapper.o \
+ csNameMapperSupport.o \
+ csTest.o \
+ CSwinHlp.o \
+ CSwktFlavors.o \
+ dtEdit.o \
+ dtSelect.o \
+ elEdit.o \
+ elSelect.o \
+ gdcEdit.o \
+ mgTest.o \
+ rcWellKnownText.o \
+ rcWktKonstants.o
+CsMap.a : $(CSMAP_LIB_OBJ)
+ ar rv CsMap.a $?
+clean:
+ rm -f $(CSMAP_LIB_OBJ)
+ rm -f CsMap.a
+rebuild: clean CsMap.a
Added: trunk/Tools/Vagrant/sources/patches/patchinfo.txt
--- trunk/Tools/Vagrant/sources/patches/patchinfo.txt (rev 0)
+++ trunk/Tools/Vagrant/sources/patches/patchinfo.txt 2014-04-29 11:14:57 UTC (rev 8084)
@@ -0,0 +1,2 @@
+http://trac.osgeo.org/csmap/ticket/172
+http://trac.osgeo.org/fdo/ticket/888
\ No newline at end of file
Modified: trunk/Tools/Vagrant/support/apt_list.txt
--- trunk/Tools/Vagrant/support/apt_list.txt 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/support/apt_list.txt 2014-04-29 11:14:57 UTC (rev 8084)
@@ -1,3 +1,13 @@
+Ubuntu 12.04
build-essential bison automake libtool libpng-dev libjpeg62-dev libxslt-dev libfreetype6-dev libpcre3-dev openjdk-7-jdk subversion lintian ant scons dos2unix liboss4-salsa-dev libldap-dev libssl-dev libcurl4-openssl-dev libexpat-dev libmysqlclient-dev unixODBC-dev python-dev libpq-dev libcppunit-dev
libboost-thread1.46-dev (for non-internal boost for cmake)
-libboost-date-time-dev
+libboost-date-time-dev
+Ubuntu 14.04
+Need atomic.h copied to /usr/include/asm/atomic.h
+build-essential bison automake libtool libpng-dev libjpeg62-dev libxslt-dev libfreetype6-dev libpcre3-dev openjdk-7-jdk subversion lintian ant scons dos2unix libldap-dev libssl-dev libcurl4-openssl-dev libexpat-dev libmysqlclient-dev unixODBC-dev python-dev libpq-dev libcppunit-dev
Modified: trunk/Tools/Vagrant/support/vagrant_base_box_prep.sh
--- trunk/Tools/Vagrant/support/vagrant_base_box_prep.sh 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/support/vagrant_base_box_prep.sh 2014-04-29 11:14:57 UTC (rev 8084)
@@ -1,4 +1,13 @@
#!/usr/bin/env bash
+# vagrant_base_box_prep.sh
+# Prepares an Ubuntu VM for packaging by vagrant.
+# Targeted for Ubuntu 14.04. Assumes the default user is "vagrant".
+# Make sure the Virtualbox Guest Additions ISO is mounted on the VM before
+# running this script
apt-get -y update
apt-get -y install build-essential zlib1g-dev libssl-dev libreadline6-dev libyaml-dev
cd /tmp
@@ -16,9 +25,7 @@
wget http://github.com/mitchellh/vagrant/raw/master/keys/vagrant.pub
mv vagrant.pub authorized_keys
apt-get install linux-headers-$(uname -r) build-essential
-mkdir /media/cdrom
-mount /dev/cdrom /media/cdrom
-sh /media/cdrom/VBoxLinuxAdditions.run
apt-get clean
groupadd admin
usermod -G admin vagrant
Modified: trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2014-04-29 11:14:57 UTC (rev 8084)
@@ -10,7 +10,7 @@
# please see the online documentation at vagrantup.com.
# Every Vagrant virtual environment requires a box to build off of.
- config.vm.box = "vagrant-mapguide-ubuntu-precise64"
+ config.vm.box = "vagrant-trusty64"
# The url from where the 'config.vm.box' box will be fetched if it
# doesn't already exist on the user's system.
@@ -132,6 +132,7 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
+MG_UNIT_TEST=0
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo
FDO_SRC=$FDO_SRC_ROOT/trunk
@@ -150,8 +151,16 @@
then
HAVE_MAPGUIDE=1
fi
-echo [provision]: Checking all tools and libs are in place
-sudo apt-get -y install build-essential bison automake libtool libpng-dev libjpeg62-dev libxslt-dev libfreetype6-dev libpcre3-dev openjdk-7-jdk subversion lintian ant scons dos2unix liboss4-salsa-dev libldap-dev libssl-dev libcurl4-openssl-dev libexpat-dev libmysqlclient-dev unixODBC-dev python-dev libpq-dev libcppunit-dev
+if [ -f /usr/include/asm/atomic.h ];
+then
+ echo [provision]: atomic.h exists. Doing nothing
+else
+ echo [provision]: Copy atomic.h
+ sudo mkdir -p /usr/include/asm
+ sudo cp /mapguide_sources/atomic.h /usr/include/asm
+fi
+echo [provision]: Checking libraries
+sudo apt-get install -y libpq-dev libmysqlclient-dev
echo [provision]: Copying shell scripts
mkdir -p $SCRIPT_ROOT
cp -f /vagrant/*.sh $SCRIPT_ROOT
@@ -163,6 +172,7 @@
sed -i 's/FDO_PLATFORM=32/FDO_PLATFORM=64/g' build_fdo.sh
sed -i 's/FDO_CPU=x86/FDO_CPU=x64/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=i386/FDO_BUILD_CPU=amd64/g' build_fdo.sh
+sed -i 's/LIB_DIRNAME=lib/LIB_DIRNAME=lib64/g' build_fdo.sh
if [ $HAVE_FDO_LIBS -eq 0 ];
then
echo [provision]: Extracting FDO thirdparty libs
@@ -182,12 +192,28 @@
fi
echo [provision]: svn update FDO
BUILD_COMPONENT="svn update FDO"
+# Only for this VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
+svn upgrade $FDO_SRC
svn update $FDO_SRC
check_build
echo [provision]: svn update MapGuide
BUILD_COMPONENT="svn update MapGuide"
+svn upgrade $MG_SRC
svn update $MG_SRC
check_build
+if [ -d /mapguide_sources/patches/fdo ];
+then
+ echo [provision]: Applying FDO source patches
+ cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+fi
+if [ -d /mapguide_sources/patches/mapguide ];
+then
+ echo [provision]: Applying MapGuide source patches
+ cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
+fi
+echo [provision]: Making sure swig is executable
+chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
cd ~/scripts
BUILD_COMPONENT="FDO"
sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
@@ -199,27 +225,35 @@
BUILD_COMPONENT="MapGuide deb packages"
sudo ./dpkgmapguide.sh amd64 $MG_REV
check_build
-echo [provision]: Unit test MapGuide
-cd $SCRIPT_ROOT/mgdev
-sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+if [ $MG_UNIT_TEST -eq 1 ];
+then
+ echo [provision]: Unit test MapGuide
+ cd $SCRIPT_ROOT/mgdev
+ sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+fi
cd $SCRIPT_ROOT
sudo mkdir -p /vagrant/build
sudo mv -f ~/*.log /vagrant/build
sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
sudo cp bin/*.deb /vagrant/build
-if [ ! -d /mapguide_sources/updated ]; then
- sudo mkdir -p /mapguide_sources/updated
- cd ~/mapguide/trunk
- echo [provision]: Updating mapguide source tarball
- tar -zcf mapguide-checkout.tar.gz MgDev
- sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
- cd ~/fdo
- echo [provision]: Updating fdo source tarball
- tar -zcf fdo-checkout.tar.gz trunk
- sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
-else
- echo [provision]: Updated tarballs already exist. Doing nothing
-fi
+# Do not update the working copy tarballs. Ubuntu 14.04 uses svn 1.8 which will break
+# the working copy if copied over to a CentOS VM (which is still on 1.6)
+# If anyone is doing to do the working copy update, it will be the CentOS VM
+#if [ ! -d /mapguide_sources/updated ]; then
+# sudo mkdir -p /mapguide_sources/updated
+# cd ~/mapguide/trunk
+# echo [provision]: Updating mapguide source tarball
+# tar -zcf mapguide-checkout.tar.gz MgDev
+# sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
+# cd ~/fdo
+# echo [provision]: Updating fdo source tarball
+# tar -zcf fdo-checkout.tar.gz trunk
+# sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
+#else
+# echo [provision]: Updated tarballs already exist. Doing nothing
+#fi
echo [provision]: Build complete
SCRIPT
Modified: trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2014-04-28 14:14:08 UTC (rev 8083)
+++ trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2014-04-29 11:14:57 UTC (rev 8084)
@@ -10,7 +10,7 @@
- config.vm.box = "vagrant-mapguide-ubuntu-precise32"
+ config.vm.box = "vagrant-trusty32"
@@ -151,8 +151,16 @@
then
HAVE_MAPGUIDE=1
fi
+then
+else
+fi
@@ -164,6 +172,7 @@
sed -i 's/FDO_PLATFORM=64/FDO_PLATFORM=32/g' build_fdo.sh
sed -i 's/FDO_CPU=x64/FDO_CPU=x86/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=amd64/FDO_BUILD_CPU=i386/g' build_fdo.sh
+sed -i 's/LIB_DIRNAME=lib64/LIB_DIRNAME=lib/g' build_fdo.sh
then
@@ -183,12 +192,28 @@
fi
svn update $FDO_SRC
check_build
svn update $MG_SRC
check_build
+then
+fi
+then
+fi
cd ~/scripts
@@ -211,19 +236,24 @@
- cd ~/fdo
-else
-fi
+# cd ~/fdo
+#else
+#fi
SCRIPT
More information about the mapguide-commits
