[mapguide-commits] r8096 - trunk/Installer
svn_mapguide at osgeo.org
Wed Apr 30 19:08:45 PDT 2014
Author: jng
Date: 2014-04-30 19:08:45 -0700 (Wed, 30 Apr 2014)
New Revision: 8096
trunk/Installer/build.bat
Undo testing modifications on installer build script
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2014-05-01 02:08:28 UTC (rev 8095)
+++ trunk/Installer/build.bat 2014-05-01 02:08:45 UTC (rev 8096)
@@ -320,14 +320,11 @@
if "%errorlevel%"=="1" goto error
pushd "%INSTALLER_DEV_BOOTSTRAP%"
echo [bootstrap]: Copying vcredist
-copy /Y vcredist_2008_%PLATFORM_CLR%.exe "%INSTALLER_OUTPUT%\vcredist_2008_%PLATFORM_CLR%.exe"
-copy /Y vcredist_2010_%PLATFORM_CLR%.exe "%INSTALLER_OUTPUT%\vcredist_2010_%PLATFORM_CLR%.exe"
copy /Y vcredist_2012_%PLATFORM_CLR%.exe "%INSTALLER_OUTPUT%\vcredist_2012_%PLATFORM_CLR%.exe"
popd
-rem if "%MAX_COMPRESSION%"=="YES" goto build_max_compress
-rem goto build_min_compress
-goto quit
+if "%MAX_COMPRESSION%"=="YES" goto build_max_compress
+goto build_min_compress
:build_min_compress
More information about the mapguide-commits
