[mapguide-commits] r8333 - trunk/MgDev/Common/MapGuideCommon/Controller
svn_mapguide at osgeo.org
Sun Aug 17 22:21:35 PDT 2014
Author: hubu
Date: 2014-08-17 22:21:35 -0700 (Sun, 17 Aug 2014)
New Revision: 8333
trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
#2479: Select features doesn't work if map has no CS.
The reason is that it will call MgCoordinateSystemFactory::Create(CREFSTRING wkt) in method MgHtmlController::QueryMapFeatures(). If the map doesn't have CS assigned, a null argument exception will be thrown. Now we add a check for map->GetMapSRS() to solve the issue.
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-08-15 08:25:11 UTC (rev 8332)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/HtmlController.cpp 2014-08-18 05:21:35 UTC (rev 8333)
@@ -434,7 +434,9 @@
Ptr<MgReadOnlyLayerCollection> selLayers = selectionSet->GetLayers();
if (NULL != selLayers.p)
- Ptr<MgCoordinateSystem> mapCs = csFactory.Create(map->GetMapSRS());
+ Ptr<MgCoordinateSystem> mapCs;
+ if (map->GetMapSRS() != L"")
+ mapCs = csFactory.Create(map->GetMapSRS());
// Our structure is as follows
// [0...n] <SelectedLayer> - A layer containing selected features
@@ -450,7 +452,9 @@
Ptr<MgLayerBase> selLayer = selLayers->GetItem(i);
STRING layerName = selLayer->GetName();
- Ptr<MgCoordinateSystemTransform> transform = GetLayerToMapTransform(selLayer, mapCs, &csFactory, featureService);
+ Ptr<MgCoordinateSystemTransform> transform;
+ if (mapCs)
+ transform = GetLayerToMapTransform(selLayer, mapCs, &csFactory, featureService);
xmlOut.append(L"<SelectedLayer id=\"");
xmlOut.append(selLayer->GetObjectId());
More information about the mapguide-commits
