[mapguide-commits] r8337 - trunk/MgDev
svn_mapguide at osgeo.org
Mon Aug 18 06:22:43 PDT 2014
Author: jng
Date: 2014-08-18 06:22:43 -0700 (Mon, 18 Aug 2014)
New Revision: 8337
trunk/MgDev/
trunk/MgDev/build_oem.sh
Merged revision(s) 8335 from branches/2.6/MgDev:
Fix the cause of non-functional iconv APIs in MapGuide on CentOS. It was r8106 that introduced 2 aclocal/libtoolize/automake/autoconf quartets to build_oem.sh, one or both of these has rendered the use of any iconv APIs within MapGuide non-functional as a result. Non functional iconv APIs caused:
* "Could not load a transcoding service" error in xerces that we worked around by building xerces with a different transcoder. We can probably revert this change.
* "Memory allocation failed" errors from the SHP provider. SHP provider uses iconv APIs to do char <-> wchar_t conversion.
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318
/sandbox/jng/convenience_apis:8263
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335
Modified: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh 2014-08-18 08:11:15 UTC (rev 8336)
+++ trunk/MgDev/build_oem.sh 2014-08-18 13:22:43 UTC (rev 8337)
@@ -232,10 +232,6 @@
build_geos()
pushd geos-2.2.0
- aclocal
- libtoolize --copy --force
- automake --add-missing --copy
- autoconf
if [ $BUILD_CPU -eq 64 ]; then
sh ./configure --with-pic --prefix="${INSTALLDIR}"
else
@@ -524,10 +520,6 @@
build_gd()
pushd gd/gd
- aclocal
- autoconf
sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
else
More information about the mapguide-commits
