[mapguide-commits] r8340 - in branches/2.6/MgDev/Common: Renderers Stylization
svn_mapguide at osgeo.org
Wed Aug 20 07:03:31 PDT 2014
Author: jng
Date: 2014-08-20 07:03:31 -0700 (Wed, 20 Aug 2014)
New Revision: 8340
branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp
branches/2.6/MgDev/Common/Renderers/GDRenderer.cpp
branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp
#2481: The previous fix for #852 is incomplete. When SE_Renderer::SetRenderMode() is called without an RGBA value, it is supposed do default to blue with a pre-determined transparency but because that default color has an alpha component of 0, the fill is now fully transparent. The fix is to default to blue with an alpha of 255, that will result in the old behaviour.
Modified: branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp
--- branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp 2014-08-20 10:40:16 UTC (rev 8339)
+++ branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp 2014-08-20 14:03:31 UTC (rev 8340)
@@ -1408,7 +1408,7 @@
void AGGRenderer::SetRenderSelectionMode(bool mode)
- SetRenderSelectionMode(mode, 0x0000FF00);
+ SetRenderSelectionMode(mode, 0x0000FFFF);
Modified: branches/2.6/MgDev/Common/Renderers/GDRenderer.cpp
--- branches/2.6/MgDev/Common/Renderers/GDRenderer.cpp 2014-08-20 10:40:16 UTC (rev 8339)
+++ branches/2.6/MgDev/Common/Renderers/GDRenderer.cpp 2014-08-20 14:03:31 UTC (rev 8340)
@@ -1529,7 +1529,7 @@
void GDRenderer::SetRenderSelectionMode(bool mode)
Modified: branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp
--- branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp 2014-08-20 10:40:16 UTC (rev 8339)
+++ branches/2.6/MgDev/Common/Stylization/SE_Renderer.cpp 2014-08-20 14:03:31 UTC (rev 8340)
@@ -150,7 +150,7 @@
void SE_Renderer::SetRenderSelectionMode(bool mode)
More information about the mapguide-commits
