[mapguide-commits] r8460 - in trunk/MgDev/UnitTest/TestData: DrawingService MappingService PrintLayout ResourceService Symbology TileService Wfs Wms
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Dec 25 04:14:34 PST 2014
Author: jng
Date: 2014-12-25 04:14:34 -0800 (Thu, 25 Dec 2014)
New Revision: 8460
   trunk/MgDev/UnitTest/TestData/DrawingService/InvalidDrawingSource.xml
   trunk/MgDev/UnitTest/TestData/DrawingService/MapGuideDrawingSource.xml
   trunk/MgDev/UnitTest/TestData/DrawingService/SpaceShipDrawingSource.xml
   trunk/MgDev/UnitTest/TestData/MappingService/UT_HydrographicPolygons.fs
   trunk/MgDev/UnitTest/TestData/MappingService/UT_Rail.fs
   trunk/MgDev/UnitTest/TestData/PrintLayout/MapViewportSample1.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/Content2.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/LibraryRepositoryContent.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryContent.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryHeader.xml
   trunk/MgDev/UnitTest/TestData/ResourceService/SampleResourceHeader.xml
   trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyLines.fs
   trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyPoints.fs
   trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyRoads.fs
   trunk/MgDev/UnitTest/TestData/TileService/UT_Parcels.fs
   trunk/MgDev/UnitTest/TestData/TileService/UT_RoadCenterLines.fs
   trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistricts.fs
   trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Content.xml
   trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Header.xml
   trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Content.xml
   trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Header.xml
   trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Content.xml
   trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Header.xml
   trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Content.xml
   trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Header.xml
That previous CodeMain cleanup run also hit some externally referenced files which we didn't want to do. This submission undoes the changes to these files.
Modified: trunk/MgDev/UnitTest/TestData/DrawingService/InvalidDrawingSource.xml
--- trunk/MgDev/UnitTest/TestData/DrawingService/InvalidDrawingSource.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/DrawingService/InvalidDrawingSource.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -2,4 +2,4 @@
 <DrawingSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="DrawingSource-1.0.0.xsd">
   <SourceName>%MG_DATA_FILE_PATH%CorruptedDwf.dwf</SourceName>
   <CoordinateSpace>LL84</CoordinateSpace>
-</DrawingSource>
\ No newline at end of file
+</DrawingSource>
Modified: trunk/MgDev/UnitTest/TestData/DrawingService/MapGuideDrawingSource.xml
--- trunk/MgDev/UnitTest/TestData/DrawingService/MapGuideDrawingSource.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/DrawingService/MapGuideDrawingSource.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -2,4 +2,4 @@
   <SourceName>%MG_DATA_FILE_PATH%test.dwf</SourceName>
-</DrawingSource>
+</DrawingSource>
Modified: trunk/MgDev/UnitTest/TestData/DrawingService/SpaceShipDrawingSource.xml
--- trunk/MgDev/UnitTest/TestData/DrawingService/SpaceShipDrawingSource.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/DrawingService/SpaceShipDrawingSource.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -2,4 +2,4 @@
   <SourceName>%MG_DATA_FILE_PATH%SpaceShip.dwf</SourceName>
-</DrawingSource>
+</DrawingSource>
Modified: trunk/MgDev/UnitTest/TestData/MappingService/UT_HydrographicPolygons.fs
--- trunk/MgDev/UnitTest/TestData/MappingService/UT_HydrographicPolygons.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/MappingService/UT_HydrographicPolygons.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,12 +1,12 @@
-<?xml version="1.0" encoding="utf-8"?>
+<?xml version="1.0" encoding="utf-8"?>
 <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
-  <Provider>OSGeo.SDF.3.2</Provider>
+  <Provider>OSGeo.SDF.3.2</Provider>
   <Parameter>
-    <Name>File</Name>
-    <Value>%MG_DATA_FILE_PATH%UT_HydrographicPolygons.sdf</Value>
+    <Name>File</Name>
+    <Value>%MG_DATA_FILE_PATH%UT_HydrographicPolygons.sdf</Value>
   </Parameter>
   <Parameter>
-    <Name>ReadOnly</Name>
-    <Value>TRUE</Value>
+    <Name>ReadOnly</Name>
+    <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/MappingService/UT_Rail.fs
--- trunk/MgDev/UnitTest/TestData/MappingService/UT_Rail.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/MappingService/UT_Rail.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,12 +1,12 @@
   <Parameter>
-    <Name>File</Name>
-    <Value>%MG_DATA_FILE_PATH%UT_Rail.sdf</Value>
+    <Name>File</Name>
+    <Value>%MG_DATA_FILE_PATH%UT_Rail.sdf</Value>
   </Parameter>
   <Parameter>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/PrintLayout/MapViewportSample1.xml
--- trunk/MgDev/UnitTest/TestData/PrintLayout/MapViewportSample1.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/PrintLayout/MapViewportSample1.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -5,7 +5,7 @@
 		<ResourceId>String</ResourceId>
 		<Stylization>
-			<ExtendedData1 />
+			<ExtendedData1/>
 		</Stylization>
 		<Data>
@@ -17,12 +17,12 @@
 					<TargetProperty>String</TargetProperty>
 					<SourceProperty>String</SourceProperty>
 					<SourceUnits>String</SourceUnits>
-					<ExtendedData1 />
+					<ExtendedData1/>
 				</PropertyMapping>
 			</PropertyMappings>
-			<ExtendedData1 />
+			<ExtendedData1/>
 		</Data>
-		<ExtendedData1 />
+		<ExtendedData1/>
 		<MapName>String</MapName>
 		<HiddenLayerNames>
 			<Name>String</Name>
@@ -43,7 +43,7 @@
 				<Z>0.0</Z>
 			</ViewDirection>
 			<ModelUnits>String</ModelUnits>
-			<ExtendedData1 />
+			<ExtendedData1/>
 		</MapView>
 	</MapViewportDefinition>
-</PrintLayoutElementDefinition>
+</PrintLayoutElementDefinition>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/Content2.xml
--- trunk/MgDev/UnitTest/TestData/ResourceService/Content2.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/Content2.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -25,4 +25,4 @@
 		<Errors>0</Errors>
 		<Failures>1</Failures>
 	</Statistics>
-</TestRun>
+</TestRun>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/LibraryRepositoryContent.xml
--- trunk/MgDev/UnitTest/TestData/ResourceService/LibraryRepositoryContent.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/LibraryRepositoryContent.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,4 +1,4 @@
 <RepositoryContent xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="RepositoryContent-1.0.0.xsd">
   <Description>Library repository</Description>
-</RepositoryContent>
+</RepositoryContent>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryContent.xml
--- trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryContent.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryContent.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,4 +1,4 @@
   <Description>Test repository</Description>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryHeader.xml
--- trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryHeader.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/SampleRepositoryHeader.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
       </Group>
     </Groups>
   </Security>
-</ResourceFolderHeader>
+</ResourceFolderHeader>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/SampleResourceHeader.xml
--- trunk/MgDev/UnitTest/TestData/ResourceService/SampleResourceHeader.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/SampleResourceHeader.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -3,4 +3,4 @@
   <Security>
     <Inherited>true</Inherited>
   </Security>
-</ResourceDocumentHeader>
+</ResourceDocumentHeader>
Modified: trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyLines.fs
--- trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyLines.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyLines.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyPoints.fs
--- trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyPoints.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyPoints.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyRoads.fs
--- trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyRoads.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Symbology/UT_SymbologyRoads.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/TileService/UT_Parcels.fs
--- trunk/MgDev/UnitTest/TestData/TileService/UT_Parcels.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_Parcels.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/TileService/UT_RoadCenterLines.fs
--- trunk/MgDev/UnitTest/TestData/TileService/UT_RoadCenterLines.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_RoadCenterLines.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistricts.fs
--- trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistricts.fs	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/TileService/UT_VotingDistricts.fs	2014-12-25 12:14:34 UTC (rev 8460)
@@ -9,4 +9,4 @@
     <Value>TRUE</Value>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Content.xml
--- trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Content.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Content.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,12 +1,12 @@
-<?xml version="1.0" encoding="UTF-8"?>
+<?xml version="1.0" encoding="UTF-8"?>
   <Parameter>
-    <Name>File</Name>
-    <Value>%MG_DATA_FILE_PATH%Sheboygan_CityLimits.sdf</Value>
+    <Name>File</Name>
+    <Value>%MG_DATA_FILE_PATH%Sheboygan_CityLimits.sdf</Value>
   </Parameter>
   <Parameter>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Header.xml
--- trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Header.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Header.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -6,4 +6,4 @@
   <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
   </Security>
Modified: trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Content.xml
--- trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Content.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Content.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -43,4 +43,4 @@
       </AreaTypeStyle>
     </VectorScaleRange>
   </VectorLayerDefinition>
-</LayerDefinition>
+</LayerDefinition>
Modified: trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Header.xml
--- trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Header.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wfs/Sheboygan_CityLimits_Layer_Header.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -34,4 +34,4 @@
       </Property>
     </Simple>
   </Metadata>
Modified: trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Content.xml
--- trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Content.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Content.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -1,12 +1,12 @@
   <Parameter>
-    <Name>File</Name>
+    <Name>File</Name>
   </Parameter>
   <Parameter>
   </Parameter>
-</FeatureSource>
+</FeatureSource>
Modified: trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Header.xml
--- trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Header.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Header.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -6,4 +6,4 @@
   </Security>
Modified: trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Content.xml
--- trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Content.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Content.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -43,4 +43,4 @@
       </AreaTypeStyle>
     </VectorScaleRange>
-</LayerDefinition>
+</LayerDefinition>
Modified: trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Header.xml
--- trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Header.xml	2014-12-25 08:20:40 UTC (rev 8459)
+++ trunk/MgDev/UnitTest/TestData/Wms/Sheboygan_CityLimits_Layer_Header.xml	2014-12-25 12:14:34 UTC (rev 8460)
@@ -34,4 +34,4 @@
       </Property>
     </Simple>
   </Metadata>
More information about the mapguide-commits mailing list
