[mapguide-commits] r7974 - trunk/Installer/scripts
svn_mapguide at osgeo.org
Sat Feb 8 20:37:32 PST 2014
Author: jng
Date: 2014-02-08 20:37:32 -0800 (Sat, 08 Feb 2014)
New Revision: 7974
trunk/Installer/scripts/build_fdo.sh
Update trunk linux build script from 2.5
Modified: trunk/Installer/scripts/build_fdo.sh
--- trunk/Installer/scripts/build_fdo.sh 2014-02-08 17:42:45 UTC (rev 7973)
+++ trunk/Installer/scripts/build_fdo.sh 2014-02-09 04:37:32 UTC (rev 7974)
@@ -11,20 +11,23 @@
# FDO version. Make sure this matches your FDO build source
FDO_VER_MAJOR=3
-FDO_VER_MINOR=8
-FDO_VER_REV=1
+FDO_VER_MINOR=9
+FDO_VER_REV=0
+UBUNTU=1
+FDO_BUILD_CPU=i386
# FDO install directory
FDO_VER_FULL=${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}
FDO_INST=/usr/local/fdo-${FDO_VER_FULL}
check_build()
- error=$?
- if [ $error -ne 0 ]; then
- echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
- exit $error
- fi
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
+ exit $error
+ fi
check_fdo_lib()
@@ -37,22 +40,67 @@
fi
+save_current_file_list()
+ echo "[info]: Saving current FDO dir file list"
+ pushd $FDO_INST
+ # For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
+ find . -name .svn -exec rm -rf {} \;
+ find . -type f -print > ${FDO_FILELIST}/temp.lst
+ find . -type l -print >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
+ popd
+update_fdocore_file_list()
+ echo "[info]: Updating FDO core file list for deb packaging"
+ pushd $FDO_INST
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
+ popd
+update_provider_file_list()
+ PROVIDER=$1
+ echo "[info]: Updating $PROVIDER file list for deb packaging"
+ pushd $FDO_INST
+ #mkdir -p $BUILDLIST
+ cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
+ cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
+ popd
BUILDROOT=`pwd`
LOCALSVN=1
PRESERVE_BUILD_ROOT=1
CMAKE=0
-FDO_SRC=/home/mgbuild/fdo/trunk
-#FDO_SRC=http://svn.osgeo.org/fdo/trunk
+FDO_SRC=/home/mgbuild/fdo/branches/3.8
+#FDO_SRC=http://svn.osgeo.org/fdo/branches/3.8
FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
+FDO_FILELIST=${FDO_BUILD_AREA}/install/filelist
modify_sdk_paths()
echo "[info]: Updating setenvironment.sh"
# Note: Change your paths here if they're different
- sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/usr/g' ${FDO_BUILD_AREA}/setenvironment.sh
- sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/usr/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/mgbuild\/fdo_rdbms_thirdparty\/mysql\/x86/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/mgbuild\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
echo "export FDOORACLE=/home/mgbuild/fdo_rdbms_thirdparty/oracle/x86/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
@@ -67,12 +115,21 @@
echo " FDO Build Area: ${FDO_BUILD_AREA}"
echo " FDO Install dir: ${FDO_INST}"
echo " CMake build: ${CMAKE}"
+echo " Is Ubuntu?: ${UBUNTU}"
echo " Export from local SVN checkout: ${LOCALSVN}"
echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
echo "***********************************************************"
start_time=`date +%s`
REVISION=`svn info ${FDO_SRC} | perl revnum.pl`
+if [ -d ${FDO_INST} ];
+then
+ echo "[info]: Deleting directory ${FDO_INST} before build"
+ rm -rf ${FDO_INST}
+else
+ echo "[info]: ${FDO_INST} doesn't exist. Continuing build"
+fi
if [ ${CMAKE} -eq 1 ];
then
echo "[error]: CMake build of FDO not supported yet"
@@ -95,7 +152,7 @@
echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
modify_sdk_paths
- fi
+ fi
fi
else
echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
@@ -131,12 +188,21 @@
exit 1;
else
#NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
- for comp in fdocore fdo utilities shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+ for comp in fdocore fdo utilities
do
FDO_BUILD_COMPONENT="$comp (automake)"
./build_linux.sh --w $comp --p ${FDO_INST}
+ update_fdocore_file_list
check_build
done
+ for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+ do
+ save_current_file_list
+ FDO_BUILD_COMPONENT="$comp (automake)"
+ ./build_linux.sh --w $comp --p ${FDO_INST}
+ update_provider_file_list $comp
+ check_build
+ done
fi
check_fdo_lib libFDO
check_fdo_lib libExpressionEngine
@@ -180,8 +246,15 @@
cd $BUILDROOT
FDO_BUILD_COMPONENT="Make tarball"
# Create a binary tar ball for FDO
-tar -zcf fdosdk-centos5-${FDO_VER_FULL}_${REVISION}.tar.gz ${FDO_INST}
+tar -zcf fdosdk-centos6-${FDO_VER_FULL}_${REVISION}.tar.gz ${FDO_INST}
check_build
+if [ ${UBUNTU} -eq 1 ];
+then
+cd ${FDO_BUILD_AREA}/install
+dos2unix *
+./dpkgall.sh ${FDO_BUILD_CPU} ${REVISION}
+fi
echo "[info]: FDO build complete!"
echo Main build execution time: `expr $end_time - $start_time` s
More information about the mapguide-commits
